zuf
schedule user logins
Tue Jan 02, 2007 9:47 pm
hi i use mt 2.9.27 level6 i want to login some users in this time only from 9:pm to 9:am plz :?:sorry i use hotspot to login all users and 1ethernet
savagedavid
Trainer
Trainer
Tue Jan 02, 2007 10:03 pm
What system are you using to log them in?
csickles
Tue Jan 02, 2007 10:17 pm
If the users are on their own interface, IE a particular office, you could easaly write a script that would cycle the port on and off based on the time of day. (see scripting forum) Particular IPs /subnets can handeled in a similar way, by turning on and off NATs.
Craig
Things that make you go "Hmmmmmmmm"...
Craig
nazadnan2003
Wed Jan 03, 2007 10:34 pm
What if I have a Hotspot on Ethernet Interface and 3 AP's connected to it through switch and each AP connected to Sector Panel covering 120 degrees.
Maybe someone well advice me to use 3 wireless Interfaces instead of Ethernet Interface, my answer is no, it is not suitable to my situation because I should configure a Hotspot server for each wireless interface, while It is very important to my users to be able to connect to any sector in any time.
savagedavid
Trainer
Trainer
Wed Jan 03, 2007 11:06 pm
You can have 3 hotspots all sharing the same user secrets database. Alternatively you can bridge the wireless interfaces to the ether. Just make sure you running the latest MT version.
savagedavid
Trainer
Trainer
Wed Jan 03, 2007 11:11 pm
nazadnan2003
schedule user logins on Hotspot
Wed Jan 03, 2007 11:57 pm
You mean that I can identify my users (username and password) and leave the Server parameter set to (all) to insure that the user can login from any Hotspot server. this will solve first half of the problem and the other half is when a user is connected to a Hotspot and somehow he disconnect and reconnect to other Hotspot, he will receive new IP and then new login page for the new Hotspot, when he use his Username and Password, he well get "No more sessions are allowed for user $(username)" if we assume that the shared user is set to (1), then he should wait :roll: the Idle timeout
On the other hand we go far away from the main topic:
hi i use mt 2.9.27 i want to login some users in this time only from 9:pm to 9:am plz Question
savagedavid
Trainer
Trainer
Thu Jan 04, 2007 1:00 am
That is true. The bridging solution will allow seamless roaming across wireless interfaces
Users browsing this forum: billjellis, Hear10d, MSN [Bot] and 147 guests
