MUM Europe 2020
Equis
Forum Veteran
Forum Veteran
Best way to upgrade bios
Fri Jan 05, 2007 3:08 am
Hello
What is the best way to upgrade the bios in a routerboard?
I can see where to download the bios but not how to upgrade it.
The manual says you can download some remote ethernet loader thing but I can't find that.
GotNet
Fri Jan 05, 2007 3:40 am
http://www.mikrotik.com/testdocs/ros/2. ... rboard.php
Do a /system routerboard upgrade. You might need to manually reboot. The upgrade command should reboot for you (per docs) but doesn't for me.
I think the eth utility is just for 200 series.
Equis
Forum Veteran
Forum Veteran
Fri Jan 05, 2007 3:48 am
Thanks, sorry about that, I didnt think to look in that part of the manual
Thanks again
GotNet
Fri Jan 05, 2007 4:44 am
Docs are tricky - between the Wiki, routerboard.com and mikrotik.com. :) Little pieces here and there...
Users browsing this forum: CZFan and 30 guests
