alltech
RB2011UiAS-RM loading kernel from nand
Fri Feb 09, 2018 3:04 am
I've search forum and not finding any helpful suggestions. The device boots to "loading kernel from nand"
I've tried to use netinstall
1. i see the device using ethernet conenction
2. when i press "install" the device changes from ready to nothing
3. 10 seconds later it goes back tor ready
any suggestions?
allstarcomps
Re: RB2011UiAS-RM loading kernel from nand
Mon Feb 12, 2018 12:56 am
You will need to preform a netinstall and reload the config from a backup or start fresh. I just did this last week with a router that was in a hot closet with no ventilation.
alltech
Mon Feb 12, 2018 1:01 am
I tried a netinstall with a fresh firmware. Like I wrote previously, I see the evice and it shows ready. When I click install, ready goes away. After 5-10 seconds it comes back, but nothing changes.
LucZWFM
Mon Feb 12, 2018 11:15 am
Try connecting the router via a switch.
It looks like that the NIC switches off, a switch will keep it up.
Volunteer Techie @ZuidWest FM / ZuidWest TV, Stichting Repeater Bergen op Zoom & WRLP CB Repeater
alltech
Tue Feb 20, 2018 2:22 am
Switch didn't help. Device became undetectable.
Users browsing this forum: romihg, ste and 38 guests
