MUM Europe 2020
Azendale
RouterOS no longer responds to ff02::1?
Mon Feb 12, 2018 11:49 pm
I have used link-local addresses to connect to routerboards without having to use a serial console while configuring them.
(This is helpful for things that can't be done with a console, such as routing filters with multiple types of routes to match. Everything, even exports, say you can do protocol=connect,static, but you will get an error if you try that on the console.)
I would discover the link local address by pinging like this:
ping ff02::1 -I <nameofinterface>
And then look at the address that responds that is NOT my computer. Then I could connect with something like [fe80::2eec:3adf:e95f:a44%interfacename]
This worked great, but in recent versions, I get no ICMP replies when pinging the multicast address ff02::1. Is this a bug? A "feature"? Something I can fix with configuration? (but that kind of defeats how I use this).
acruhl
Re: RouterOS no longer responds to ff02::1?
Tue Feb 13, 2018 6:03 am
I just tested this between my Mac laptop and my RB750Gr3 running 6.41.1. I had no problem connecting to the link local address on the MikroTik.
I also see the link local address from the MikroTik when I ping ff02::1%en0
I have lots of stuff in the same L2 domain and lots of stuff is responding
Something seems wrong with yours maybe.
Stuff.
Users browsing this forum: Google [Bot], MSN [Bot] and 85 guests
