fbslim
Routers' "hard drive" chip. Is it possible to read information from it?
Sun Feb 18, 2018 1:14 pm
Hello!
Subj.
Is there any protect from reading data from chip with Routers OS or not?
I mean, if somebody steal my router, can he(she) read info from cheap other way?
fbslim
Re: Routers' "hard drive" chip. Is it possible to read information from it?
Mon Feb 26, 2018 2:00 pm
Cool answer )))
soulflyhigh
Mon Feb 26, 2018 2:24 pm
Well, unless the chip is encrypted then it is theoretically possible to read it with appropriate electronic and software tools.
The question is, would you consider yourself a "target" for someone with such advanced equipment and knowledge?
If you really need high level of security then you should really know that use of the same user/password on multiple devices/services is a very bad practice.
Regards,
M.
MTCRE, MTCTCE, MTCSE
normis
Mon Feb 26, 2018 2:26 pm
Physical security is also important. And you can always enclose your device in epoxy, forbidding such type of access :)
sebastia
Mon Feb 26, 2018 9:37 pm
Someone, cough Kackele cough, going to get kicked again...
CZFan
Mon Feb 26, 2018 10:55 pm
I once forgot a password for an old RB532. I simple booted openwrt from PXE and read what I had to. Also changed the password again, but that's not important, just bragging :-)
I am sure you won the Google user of the month award for that one, congratulations, well done!
MTCNA, MTCTCE, MTCRE & MTCINE
Users browsing this forum: Bing [Bot], Google [Bot] and 107 guests
