olivernz
NetInstall or bricked RB2011UAS-2HnD-IN
Thu Mar 01, 2018 5:24 am
Hi
So I haven't used my Mikrotik in a while. Since then the network changed and I can't just hook it up because it would have clashed. So I thought the thing to do was to reset it to factory and re-install.
So I did and now when it boots it won't allow me to connect to any Ethernet ports and shows no WiFi. The little screen comes up and works. I have also tried NetInstall and pulled the newest RouterOS on it. That worked fine but it still has the same behaviour.
What's going on??? Is it bricked? Am I missing something here? I don't have a serial cable for it (I have a FTDI tho) so can't see the console.
Hope someone can help!
Cheers Oliver
haik01
Re: NetInstall or bricked RB2011UAS-2HnD-IN
Thu Mar 01, 2018 9:26 pm
After a Netinstall the router is completely blank. So no DHCP, no IP etc....
Try to connect by MAC address in Winbox.
olivernz
Fri Mar 02, 2018 2:31 am
Thanks!! That was exactly the tip I needed and that wasn't clear from the instructions. All back and working now.
Fafode
Mon Mar 05, 2018 4:35 pm
salut je peux avoir la configuration complète de l'antenne mikrotik
Users browsing this forum: No registered users and 12 guests
