reseni
not getting all routes
Mon Mar 05, 2018 9:39 am
hello
please give some recommendations
i setup a bgp connection on my new 1009 ccr
upstream isp give me a full view table
i'm trying to ping some ip's and its give me - no route to host
in route list i dont see this network at all, only 1-3 ip's from it
like 46.38.xx.54
what could be an issue ?
mrz
Re: not getting all routes
Mon Mar 05, 2018 11:39 am
Contact your ISP why they are advertising /32 prefix instead of /24. As far as I know /24 is the minimum that should appear in global tables.
reseni
Mon Mar 05, 2018 1:02 pm
so base on screens, my configuration is correct ?
its from upstream ?
Vooray
Mon Mar 05, 2018 1:44 pm
Try
 /ip route print where "address_you_ping_here" in dst-address
on your bgp router.
May be your ISP, for some reasons, dont have prefixes you are looking for.
All prefix lengths are legit on Full View, but most ISPs drop longer then 24.
reseni
Mon Mar 05, 2018 4:07 pm
Try
on your bgp router.
no entries for this address at all ((
Vooray
Mon Mar 05, 2018 4:30 pm
So, this is a question for your ISP provider.
46.38.56.0/21 is perfectly visible on internet.
https://stat.ripe.net/46.38.56.0%2F21#tabId=at-a-glance
reseni
Mon Mar 05, 2018 4:44 pm
sorry, long reply from command line
[admin@Core0] > ip route print where "46.38.56.76" in dst-address
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 combo1 1
1 S 0.0.0.0/0 combo1 1
Users browsing this forum: No registered users and 21 guests
