cocktail
When will MikroTik hAP ac2 be released?
Sat Mar 10, 2018 11:48 am
Where will I be able to buy it?
zapata
Re: When will MikroTik hAP ac2 be released?
Tue Mar 13, 2018 12:20 am
I've ordered one from eurodk.com. At the moment they have 108 pcs in stock. It should arrive here on Friday.
juliokato
Tue Mar 13, 2018 2:16 am
In Brazil, maybe @2019. :?
Waiting Wave 2 support, otherwise there worth buying the hw.
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
cocktail
Tue Mar 13, 2018 2:30 am
My country uses 220V Type C power plugs. My country's Type C power plugs are far thicker(4.8mm) than Euro plug(4.0mm).
I'm going to need a power plug adaptor with any of the plugs available for hAP ac2.
Does hAP ac2 with US plug, UK plug, or Euro plug support 220V?
mistry7
Tue Mar 13, 2018 7:05 am
We have 230V in Europe so 220v is no problem
cocktail
Tue Mar 13, 2018 7:23 am
Does hAP ac2 support 220V regardless of power plug type? Or, do I have to buy hAP ac2 with euro plug to use it at home?
grusu
Tue Mar 13, 2018 10:32 am
Power Supply works between 100 - 240V~
https://img.routerboard.com/mimg/part11391161548m.jpg
vadimbn
Tue Mar 13, 2018 10:47 am
Anyway, you can use almost any power supply with this router. All mikrotik routers have a DC voltage regulator on the motherboard and can work with a wide range of supply voltage (12-30 V).
Veni. Vidi. Feci.
RBSXTLTE3-7, CRS326-24G-2S+RM, RB850Gx2, RBMRTG, RB1100AHx4, RB750Gr3, RBD52G-5HacD2HnD-TC, Woobm-USB
cocktail
Tue Mar 13, 2018 2:12 pm
Thanks. I'll buy hAP ac2 with any plug type for which adapters for my country's power plug exist.
By the way, what is the thickness of the euro plug that comes with hAP ac2?
4.8mm? 4.0mm? I need one that is 4.8mm thick.
normis
Tue Mar 13, 2018 2:44 pm
do you mean the prong of the adapter that was posted above?
all external PSUs come with 4mm prongs.
Only IEC connectors for the rackmount units have 4.8mm prongs.
cocktail
Tue Mar 13, 2018 3:13 pm
I meant the thickness of prongs in https://img.routerboard.com/mimg/part11391161548m.jpg that go directly into electrical outlets.
I'm looking for 4.0mm to 4.8mm converters. If I can't, I might need to buy a US/UK plug to 4.8mm Type C converter.
normis
Tue Mar 13, 2018 3:20 pm
Where are you located? The 4mm prongs fit in any type of EU compatible sockets. I could imagine that thicker ones wouldn't fit, but thinner ones should fit for sure. Also, you should ask the local distributor. They either provide the required PSU, or will suggest how to use the existing ones.
cocktail
Tue Mar 13, 2018 3:34 pm
I live in south korea. Here, people complain a lot about Euro plug prongs that are 4.0mm thick.
They reported that 4.0mm prongs tend to slip out of 4.8mm outlets and generate sparks in 4.8mm outlets.
They were worried about the possibility of fire due to electrical sparks generated by 0.8mm gap.
Fire is scary.
US plug to KR plug converters are common, but I'm still finding 4.0mm to 4.8mm adapters. I might end up buying US plug version.
normis
Tue Mar 13, 2018 3:38 pm
I suggest contacting the local distributor for advice.
jarda
Tue Mar 13, 2018 3:40 pm
You can use localy available power supply instead of the packed one. You can also request your local dealer to solve the problem if the plug type doesn't correspond to your local regulations.
cocktail
Tue Mar 13, 2018 3:45 pm
I'm not sure if there is a local distributor in korea. I searched local shopping websites for mikrotik products. All search results are imported goods.
In my perspective, there are a few solutions.
1. Buy the US plug version and a US plug to KR plug adapter.
2. Keep finding 4.0mm to 4.8mm adapter
3. Ask MikroTik to release 4.8mm Type C plug version of hAP ac2.
normis
Tue Mar 13, 2018 3:46 pm
Try this:
True Networks Ltd.
Bundang, Korea, Republic of
Tel:(+82)10-4605-8041
cocktail
Tue Mar 13, 2018 3:48 pm
I haven't thought of buying a locally available power supply, but that could work.
However, I think buying hAP ac2 with US plug and a US to KR plug adapter would be cheaper.
cocktail
Tue Mar 13, 2018 3:50 pm
Try this:
True Networks Ltd.
Thanks I'll contact True Networks.
grusu
Tue Mar 13, 2018 3:55 pm
Be careful because hAP ac²-US (USA) is factory locked for 2412-2462MHz, 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
https://mikrotik.com/product/hap_ac2
cocktail
Tue Mar 13, 2018 4:03 pm
I sent an email to True Networks Ltd. I'll get a reply tomorrow.
Are UK and EU versions hAP ac² (International)? This is more complex than I thought.
Update 1. I just found a universal adapter available in my country that can convert anything including 4.0mm Type C plug to 4.8mm Type C plug. The total cost of this product including delivery cost is ~5.63USD. Although it's expensive for just an adapter, I think I can buy EU plug version. If you think this won't work, tell me.
Update 2. I just ordered hAP ac2 with Euro plug from eurodk.com and a universal power plug converter for domestic use from a local vendor. The vendor says the universal power plug converter supports euro plug. I think it'll be fine.
Update 3. My local distributor, True Networks Ltd, told me to buy an EU to KR convertor or a PSU.
Users browsing this forum: No registered users and 4 guests
