m4t7e0
btest - Where Is
Thu Mar 15, 2018 7:24 pm
Hi dear,
i will try the btest application on windows, from the official site there is no exe.
Anyone know about the end of this software?
victorsoares
Re: btest - Where Is
Thu Mar 15, 2018 7:41 pm
I've downloaded btest a week ago from Mikotik's website, yesterday I tried to download the exe again in a client and didn't find it. Softpedia still has it available. I hope that this isn't the end of the application.
MTCNA MTCRE
JB172
Thu Mar 15, 2018 8:24 pm
It's not in the site but you still can found it here: http://www.mikrotik.com/download/btest.exe
m4t7e0
Thu Mar 15, 2018 8:32 pm
Thanks for the package, anyone know why mikrotik hide it?
vecernik87
Forum Veteran
Forum Veteran
Fri Apr 20, 2018 3:08 am
I guess it is not developed anymore and there are compatibility issues:
I just tried it and it would not connect to my hAP ac^2 running ROS 6.41.3 / 6.42. Right after "running" it says "disconnected". I can do btest from other ROS devices without issue and I am sure that auth is correct because with different password it says "auth. failed" .
(btw: the "help" button leads to ROS 2.8 website.. thats just prehistoric stuff. No wonder it does not work anymore)
mikruser
Wed Jul 25, 2018 5:34 pm
Any official info about Bandwidth Test for Windows?
do not ask me why it is necessary.
Steveocee
Wed Jul 25, 2018 5:45 pm
MikroTik would rather you no longer use it as it is so inefficient. They recommend to use traffic generator instead.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
mersudin
Wed Oct 03, 2018 12:51 am
Disable , untick "Authenticate" on Btest Server Settings, and it will work, after you enable it , it stops working.
Users browsing this forum: Bing [Bot] and 152 guests
