jo2jo
Forum Veteran
Forum Veteran
Please add basic portScan tool ( port scanner scan )
Sun Mar 18, 2018 5:57 pm
Hi, I’ve been using routerOS since v 2.x (and LOVE IT), and have hundreds of mt s deployed, a feature I’m constantly in need of is even a bare-bones/basic built in port scanner:
/tool portscan (or /tool portScanner)
It doesn’t have to be powerful or advanced like nmap, nor fast, just a tool that can help admins identify/recall private IPs or other internal network uses ( ie, which ip is running the Web server on this office network? Or which ip is running the SQL Server on this network?) - this could be very helpful versus having to keep a Linux VM attached to a VPN, strictly for port scanning my internal networks when I can’t remember the private IP of a customers VNC server , and when I need to remote-in support their PC) - or which private subnet, DHCP-server provided ip (192.168..) is running XYZ service, so I can quickly set up this Dst-nat rule for them)
I’m not sure how tools like a built-in SMB server (or built in tftp/ftp server) made it into routerOS before a useful, network-centric tool like portscan ( but I’m happy to have both/all three).
Please strongly consider adding a basic (even if only TCP only, 1 port per second limit, if needed) port scan tool to ROS 7 ROS 6.X.
:beep :beep :beep
honzam
Re: Please add basic portScan tool
Sun Mar 18, 2018 7:42 pm
+ 1
LAN, FTTx, Wireless. ISP operator
MayestroPW
Mon Mar 19, 2018 3:56 am
+ 1
emikrotik
Mon Mar 26, 2018 3:59 am
+ 1
Steveocee
Wed Mar 28, 2018 12:47 pm
+1 to this as well.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
soulflyhigh
Wed Mar 28, 2018 1:13 pm
Yes, please.
+1
MTCRE, MTCTCE, MTCSE
jspool
Wed Mar 28, 2018 7:19 pm
+1 Please
boxpik
Wed Mar 28, 2018 10:36 pm
+1 for such a useful tool
poizzon
Sun Apr 01, 2018 5:22 pm
Will TheDude not save the situation?
poi
jo2jo
Forum Veteran
Forum Veteran
Mon Apr 02, 2018 1:24 am
Not sure how theDude is relevant to this ( or thedude is just as relevant/irrelevant as manually running nmap outside ros ) , we are looking for a port scan utility to be added to routerOS, this way it is accessible directly from/on our various routerboards/rOSdevices directly.
Tks
:beep :beep :beep
vipe
Tue May 01, 2018 6:51 pm
+1 xpon
Cal5582
Tue May 01, 2018 7:44 pm
+1 on this
thobias
Wed May 02, 2018 10:05 am
Yes, this would be great to be able to identify what is a printer or a web server in a network.
Combined with a MAC-address vendor list (in winbox) to show the manufacturer of all devices.
jo2jo
Forum Veteran
Forum Veteran
Re: Please add basic portScan tool ( port scanner scan )
Fri Jul 06, 2018 5:01 pm
while i know it is wrong to " bump" your own thread, but on a weekly basis ( weekly is a bare minimum, sometimes daily basis) i need a portscan tool on ros. Its ridiculous having to look up mac-address OIDs and/or use /sys telnet port=x as a rough port scan tool to ID devices.
Often when i come into a new , existing network to begin managing (or clean up / improve) there will be a managed switch somewhere on the network (but the prior admin either has not ID'd / noted it or it has grabbed a dhcp IP like the 100s of other random client devices , wo a readable dhcp client id. Ofcourse a ros built-in portscan tool would help in this scenario tremendously ( even slowed/restricted ps tool). But incase it helps others, here is a rough work around i use. ( you will need to change the mac addresses to which ever vendor's device you are trying to locate, i usually grab the OIDs from a website like "Wireshark · OUI Lookup Tool" (google search) and type into that site the vendor (netgear / ruckus in this case). then use linux cli tools, or an app like notepad +++ (w regex find/replace) to modify this command to paste in the list of macs.
(also note, you may need to search /ip arp if you are not using ros bridges, or this may not work at all depending upon your network layout):
(ex. to find IP of a netgear managed switch)
/int bridge host print where mac-address~"00:09:5B" || mac-address~"00:0F:B5" || mac-address~"00:14:6C" || mac-address~"00:18:4D" || mac-address~"00:1B:2F" || mac-address~"00:1E:2A" || mac-address~"00:1F:33" || mac-address~"00:22:3F" || mac-address~"00:24:B2" || mac-address~"00:26:F2" || mac-address~"00:8E:F2" || mac-address~"04:A1:51" || mac-address~"08:02:8E" || mac-address~"08:BD:43" || mac-address~"10:0D:7F" || mac-address~"10:DA:43" || mac-address~"20:0C:C8" || mac-address~"20:4E:7F" || mac-address~"20:E5:2A" || mac-address~"28:C6:8E" || mac-address~"2C:30:33" || mac-address~"2C:B0:5D" || mac-address~"30:46:9A" || mac-address~"40:5D:82" || mac-address~"44:94:FC" || mac-address~"4C:60:DE" || mac-address~"50:4A:6E" || mac-address~"50:6A:03" || mac-address~"6C:B0:CE" || mac-address~"74:44:01" || mac-address~"78:D2:94" || mac-address~"80:37:73" || mac-address~"84:1B:5E" || mac-address~"8C:3B:AD" || mac-address~"9C:3D:CF" || mac-address~"9C:D3:6D" || mac-address~"A0:04:60" || mac-address~"A0:21:B7" || mac-address~"A0:40:A0" || mac-address~"A0:63:91" || mac-address~"A4:2B:8C" || mac-address~"B0:39:56" || mac-address~"B0:7F:B9" || mac-address~"B0:B9:8A" || mac-address~"C0:3F:0E" || mac-address~"C0:FF:D4" || mac-address~"C4:04:15" || mac-address~"C4:3D:C7" || mac-address~"CC:40:D0" || mac-address~"DC:EF:09" || mac-address~"E0:46:9A" || mac-address~"E0:91:F5" || mac-address~"E4:F4:C6" || mac-address~"E8:FC:AF" || mac-address~"F8:73:94"
(find IPs of ruckus APs - i use /ip arp here just to show 2nd command option, /int bridge host print where , may work better depending upon your network layout ) :
/ip arp print where mac-address~"00:13:92" || mac-address~"00:1D:2E" || mac-address~"00:1F:41" || mac-address~"00:22:7F" || mac-address~"00:24:82" || mac-address~"00:25:C4" || mac-address~"04:4F:AA" || mac-address~"0C:F4:D5" || mac-address~"1C:B9:C4" || mac-address~"24:79:2A" || mac-address~"24:C9:A1" || mac-address~"2C:5D:93" || mac-address~"2C:C5:D3" || mac-address~"2C:E6:CC" || mac-address~"30:87:D9" || mac-address~"34:8F:27" || mac-address~"34:FA:9F" || mac-address~"38:FF:36" || mac-address~"44:1E:98" || mac-address~"50:A7:33" || mac-address~"54:3D:37" || mac-address~"58:93:96" || mac-address~"58:B6:33" || mac-address~"60:D0:2C" || mac-address~"68:92:34" || mac-address~"6C:AA:B3" || mac-address~"74:3E:2B" || mac-address~"74:91:1A" || mac-address~"84:18:3A" || mac-address~"8C:0C:90" || mac-address~"90:3A:72" || mac-address~"94:F6:65" || mac-address~"AC:67:06" || mac-address~"C0:8A:DE" || mac-address~"C0:C5:20" || mac-address~"C4:01:7C" || mac-address~"C4:10:8A" || mac-address~"D4:68:4D" || mac-address~"D4:C1:9E" || mac-address~"D8:38:FC" || mac-address~"E0:10:7F" || mac-address~"E8:1D:A8" || mac-address~"EC:58:EA" || mac-address~"EC:8C:A2" || mac-address~"F0:3E:90" || mac-address~"F0:B0:52" || mac-address~"F8:E7:1E"
(also it may help to run an /tool ip-scan of your entire subnet, before running these commands, if device you are trying to find has not pushed any traffic for awhile, and thus is not in the arp/hosts tables)
:beep :beep :beep
DotTest37
Thu Sep 06, 2018 3:52 am
+1 from me
dagelf
Thu Nov 01, 2018 10:19 pm
Until then, here you go: (This conforms to your "it doesn't have to be advanced" request :-)
:for p from=1 to=65535 do={put $p;/sys telnet 192.168.1.1 port=$p}
vecernik87
Long time Member
Long time Member
Thu Nov 01, 2018 10:39 pm
@dagelf
Originally I thought you just came with miracle, but it does not really work. Firstly, it would take huge amount of time as it does not work in parallel and you have to interrupt each connection which gets established, secondly, it actually crashed my winbox and produced autosupout.rif ... Not really sure what happened in there and i was unable to replicate it.
mitzone
Mon Nov 26, 2018 12:47 pm
+1 .
kc7aad
Tue Feb 12, 2019 5:03 pm
+1 +1 +1 +1 +1 +1!!
vitich
Sun Feb 17, 2019 9:09 pm
+1 pls!
Kamaz
Mon Feb 18, 2019 9:36 am
+++1
jo2jo
Forum Veteran
Forum Veteran
Sat Mar 02, 2019 3:35 am
@dagelf
(note; quote above is refering to a reply above, where a cleaver user suggests a script with a loop across all ports using /telnet port=i )
I could see this causing problems, as telnet in winbox def. was not made to work like this. (however we often use telnet on the cli as a rough, poor mans tool for a single port, port scan).
i would say the script/loop using telnet across all ports should not be used, as i have often seen some issues with telnet in winbox. (ie i often see a RB will show 100% cpu usage, only to find that profile shows either mgmt or telnet as the 100% reason. The cause/fix is that a disconnected telnet window was left open in winbox, once you close that telnet window, the cpu immediately goes back down). (i have seen this on RBs of all types and cpu power). not a big deal, but possibly the source of your RB crash/supout when running that 1 to 65555 telnet loop.
+1 - please add port scan to ros / winbox! thanks!
:beep :beep :beep
vili11
Thu Mar 28, 2019 7:42 pm
+1000
excession
Tue Apr 16, 2019 5:02 pm
yep + another 1
jo2jo
Forum Veteran
Forum Veteran
Fri May 10, 2019 1:13 am
+1 (for own post), 2x times this week different customers needed us to find a cctv DVR on their system (which is behind our mikrotik). would have been so quick via port scan x/24 for port 80 via a ROS ps tool . but instead had to setup a MT + a VPN setup on both sides and a laptop with nmap (about 20-30min, each time).
MT- we REALLY need even a single port at a time, port scanner. pls! (i say single port at a time, as there was a menton of abuse of a portscan tool, while i disagree with this concern, even a single port at a time would address that concern, and still be very useful)
thanks!
:beep :beep :beep
EvgeniyV
Sun May 19, 2019 10:52 pm
+1 it would be very useful
vecernik87
Long time Member
Long time Member
Mon May 20, 2019 6:36 am
... 2x times this week different customers needed us to find a cctv DVR on their system (which is behind our mikrotik). would have been so quick via port scan x/24 for port 80 via a ROS ps tool . but instead had to setup a MT + a VPN setup on both sides and a laptop with nmap (about 20-30min, each time). ...
You could just make scan in TheDude and have results in no time. If you do this more than once per year, it is definitely worth it.
jo2jo
Forum Veteran
Forum Veteran
Tue May 21, 2019 7:32 am
That is interesting idea, but when we often need to do this, its on random customers/routers , so using dude as a "port scan" tool, would take a fair amount of setup (and a router reboot/downtime - ie install dude pkg + configure it) just to do a portscan, one time.
tks
:beep :beep :beep
gotsprings
Forum Veteran
Forum Veteran
Thu Jul 11, 2019 1:46 pm
Bump.
This sounds like what I am trying to do.
I want to know if a device service is still running. Like checking a printer if 9100 is responding.
In my case I have a device that responds to pings.
Webserver works.
But a service on 51510 stops responding as confirmed by Digital Loggers autoping against a TCP Port or Domotz Eyes.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
ziegenberg
Thu Jul 11, 2019 10:01 pm
Hi!
Webserver works.
If you know the port, use
/system telnet host port
ziegenberg
Thu Jul 11, 2019 10:10 pm
Hi!
while i know it is wrong to " bump" your own thread, but on a weekly basis (weekly is a bare minimum, sometimes daily basis) i need a portscan tool on ROs. It's ridiculous having to look up mac-address OIDs and/or use /sys telnet port=x as a rough port scan tool to ID devices.
... </snip>
For mac vendor look-up have a look at the scripts of eworm. He has a function called GetMacVendor in his global-functions file. I guess, you need to go through the setup of his scripts for it to work, but the are really great anyway: https://gitlab.com/eworm-de/routeros-scripts
Maybe you can come up with some new scripts for your port and network scanning. Use his repository of scripts as a source of inspiration.
JAza
Sun Jul 21, 2019 9:32 pm
+100
Basic need for networks we don't have a VPN into but need to troubleshoot/scan if a particular service is up or identify services running on the network.
It doesn't have to be nmap. Just some basic port open/closed/filtered logic in a loop.
PLEASE.
zeek01
Sun Nov 10, 2019 4:50 pm
+1
It would be a useful tool for remote network testing
RackKing
Thu Dec 05, 2019 7:33 pm
+1
agree - my +1
kapi2454
Fri Jan 10, 2020 9:10 pm
+1 please
r00t
Fri Jan 10, 2020 9:26 pm
This should have been implemented long time ago, before adding stuff like Kid Control...
amouses
Sat Jan 11, 2020 12:43 am
+1 please. I can't believe this is not there! Oh the shame of it all
sudmal
Sat Feb 01, 2020 3:06 pm
+99999
inteq
Sat Feb 01, 2020 6:07 pm
(2+0)/2
jo2jo
Forum Veteran
Forum Veteran
Mon Feb 17, 2020 7:17 pm
wow, i still have constant needs for even the most basic portscan tools nearly on a daily basis of managing 300+ mikrotiks.
( i constantly need to scan a private /24 or /23 for one or two ports to find IP of a service)
PLS mt! pls! add this tool. even a very muted version of nmap or a portscan tool (muted so that abuse can not be done if that is yall concern/hold up).
thanks!!
:beep :beep :beep
vortex
Mon Feb 17, 2020 7:26 pm
I don't know how to identify the hosts in my network.
anv
Fri Mar 06, 2020 10:07 am
+1 (please)
pe1chl
Sat Mar 07, 2020 11:25 am
There already is "/tool ip-scan" which scans using ping, arp, snmp and netbios and does IP lookup in DNS.
Maybe you can specify what other features you would want it to have?
(like other services it should scan for, or to have a list of ports)
d3m0
Fri Apr 10, 2020 2:11 pm
+1 plz
k6ccc
Long time Member
Long time Member
Sat Apr 11, 2020 1:51 am
There have been a bunch of various posts, but the original poster was asking for a port scanner. /tool ip-scan gives a list of IPs in use, but not the ports that each will respond to - I just tried it it to make sure.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
pe1chl
Sat Apr 11, 2020 9:54 am
People are asking for a tool to identify hosts on their network and to troubleshoot a VPN, and /tool ip-scan can be used for that.
Of course there is always one more thing that one can request, but I think the debugging tools available on MikroTik already are way better than industry standard.
As I mentioned several times before, I think MikroTik should create some way to run user binaries in a very restricted setting (non-privileged user, chrooted to a user-created directory, etc) so niche requests like this can be catered for by independent developers and the programmers at MikroTik would not have to be bothered by all those whining +1 posters in several topics.
vortex
Sat Apr 11, 2020 4:44 pm
How does ip-scan identify devices if it does not do a portscan?
pe1chl
Sat Apr 11, 2020 4:49 pm
It DOES do a portscan. But it is a bit limited, it tries SNMP and SMBv1 ports only (after it has received a PING reply).
It also does a reverse-lookup in DNS.
Users browsing this forum: Bing [Bot], eworm, Google [Bot], Google Feedfetcher, Hammy, hardtecsti, mdkberry, sutrus and 145 guests
