MUM Europe 2020
estebandipietro
Powerbox Pro Grounding
Thu Mar 22, 2018 2:32 pm
Hello, sorry for my English. Could someone please tell me what would be the correct way to ground the connected equipment in a Powerbox Pro using the outgoing POE function?
The housing has a connector apparently for that purpose, but it is not attached to anything, just threads in the plastic. Regards and thanks from now.
Liliya
Re: Powerbox Pro Grounding
Mon May 07, 2018 5:13 pm
Have you found the answer? We are also interested.
PaulsMT
Tue May 08, 2018 5:39 pm
Actually, the screw is directly connected to the board PCB, with a small metal plate between the plastic case, so it is recommended to ground your PowerBOX Pro using this screw.
blue
Fri Jul 06, 2018 11:04 am
PowerBoxPro metal grounding screw is only connected to SPF and DC negative! It is not connected to metal grounding of LAN ports! Design error?
blue
Fri Jul 06, 2018 11:10 am
Here are the pictures
npero
Tue Jul 10, 2018 11:05 am
Some question. Do we need to ground cable separately or have some type of varistor or similar between utp ports and ground and not need to ground cable ?
boardman
Wed Aug 01, 2018 9:43 pm
Anybody? Same question here....
Users browsing this forum: No registered users and 30 guests
