abhijeetsamant
Static routing help needed
Sun Mar 25, 2018 8:24 pm
Hi I am a newbie in networking and having mikrotik as core router, what is the best way to route data on below secnario
Vlan 6 has ip address 172.29.29.1/30
Vlan 7 has ip address 172.30.30.1/30
Need to be able to ping 172.30.30.2 from 172.29.29.2, any suggestion would be helpful
Regards
Abhi
Sob
Re: Static routing help needed
Sun Mar 25, 2018 8:58 pm
Check your firewall. By default, if you didn't have any, it would work (assuming 172.29.29.2/30 is connected to vlan 6 and 172.30.30.2/30 is connected to vlan 7). It's what router does, it routes anything it can. If it doesn't work, it's probably some firewall rule blocking it, or configuration mistake somewhere else.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
Vooray
Sun Mar 25, 2018 9:18 pm
set corresponding gateways and masks on your 172.30.30.2 and 172.29.29.2 hosts.
sri2007
Tue May 01, 2018 4:24 pm
And you may need to check the Layer2 Switch in the middle too, i'd check if the plans are properly tagged and the port configuration is correct (between trunks & access)
MikroTik Support and Consultancy - Español / English +593 93 924 1262
https://www.safenet.ec/consultoria.html/ support@safenet.ec
scampbell
Trainer
Trainer
Sun May 13, 2018 5:59 am
There should be no further action on the Mikrotik needed (assuming no restrictive firewall rules). It should show two routes with flags DAC for both 172.30.30.0/30 and 172.29.29.0/30
When routing traffic your source device need a route to your destination and your destination device needs a route back to the source.
So your host on 172.29.29.2 must have a route added for 172.30.30.0/30 with gateway=172.29.29.1 - and likewise the 172.30.30.2 host must have a route to 172.29.29.0/30 with gateway=172.30.30.1
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, MTCEWE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
Users browsing this forum: No registered users and 11 guests
