MUM Europe 2020
RyperX
DHCP Server use different DNS on specified IPs
Sun Mar 25, 2018 11:37 pm
Hello guys,
i need your help. I have a DHCP running in my network and set to use the mikrotik router as DNS Server.
On the same network are also 3 Devices that should use a different DNS Server.
Is it possible after reserving an IP Adress to set an different DNS Server only for the specified adress?
As i understand the DNS Setting can only set in the DHCP Server - Networks Setting, in which i set the full /24 network (in which are the 3 hosts)
Or do you have an simplier idea todo this? (I could set it by static but would prefer over dhcp)
Thanks and best regards
BartoszP
Re: DHCP Server use different DNS on specified IPs
Sun Mar 25, 2018 11:57 pm
Do redirect DNS queries for particular IPs with dst-nat rules
Real admins use real keyboards.
RyperX
Mon Mar 26, 2018 12:18 am
Was my first idea but it is not working because the DNS Server is on the same subnet as the clients.
BartoszP
Mon Mar 26, 2018 12:25 am
You need to implement Harpin procedure.
make dst-nat rule to redirect queries to new DNS server and src-nat to make packets look like coming from router.
nickshore
Re: DHCP Server use different DNS on specified IPs  [SOLVED]
Mon Mar 26, 2018 12:28 am
You can add /32s into the DHCP network settings so that you can override settings for individual IPs
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
RyperX
Mon Mar 26, 2018 12:34 am
Mmh i exactly understand how hairpin-nat is helping, maybe i dont understand it correct^^
My network:
address-pool=dhcp-local authoritative=after-2sec-delay disabled=no interface=bridge1 lease-time=1d name=dhcp-local
address=192.168.1.0/24 dns-server=192.168.1.2,192.168.1.3 gateway=192.168.1.1 netmask=24
Clients 192.168.1.121-139 should recieve the DNS Server from another network 192.168.2.1 for example.
The problem why the dst-nat rule is not working for the moment is because the dns request doesnt get through the router the DNS Servers 192.168.1.2 and 192.168.1.3 will contacted directly.
Or did you mean something else?
Edit:
@nickshore
I will try thanks
Is this correct?
address=192.168.1.121/32 dns-server=192.168.2.1 gateway=192.168.1.1 netmask=24 ntp-server=192.168.1.1
Edit2:
Thanks it is working :)
Datanav
Sat Jul 27, 2019 4:20 pm
My network:
Edi
@nickshore
I will try thanks
Is this correct?
Edit2:
How were able to implement this? can you lay down the steps for me?
Users browsing this forum: No registered users and 43 guests
