Mitar
Mikrotik for 900/100 Mbit WAN
Thu Mar 29, 2018 10:55 am
Soon I will have internet speed up and I am looking for new router,
currently I have RB951G-2HnD but obviously it wont work fine with that much traffic.
So the WAN will be 900/100 Mbit using PPPoE and I want that divided thru mikrotik for few PCs and other devices via LAN and Wifi is not very important but 200-300 Mbit real speed thru Wifi would have been nice tho, just some basic firewall rules (maybe 20-30) without qos.
I was looking at different Routerboards and seems theres no all in one for home solution,
so I was thinking maybe use 2 Mikrotiks, one RB750Gr3 as main router and my current RB951G-2HnD as switch + wifi ?
Or combination of RB750Gr3 + RB962UiGS-5HacT2HnT ?
Or a combination of RB3011UiAS-RM ( wish there was smaller non rack version of this one ) + some AP
And just now I have found out a RBD52G-5HacD2HnD-TC which according to test results just seems too perfect to be real for its tiny price, I mean the 4 core cpu + gbit switch + 2,4 GHz + 5 GHz + small case and its cheaper than RB951G-2HnD ?? No for real wheres the catch ?
mistry7
Re: Mikrotik for 900/100 Mbit WAN
Thu Mar 29, 2018 11:08 am
look here if you are searching an Home Model:
https://mikrotik.com/product/hap_ac2#fndtn-testresults
But Wireless on ARM platform no working fast:
viewtopic.php?f=7&t=131975
But this will hopefully fixed with newer ROS versions.
If you are searching something for Business i would go with 3011 + WAP ac
mistry7
Mitar
Thu Mar 29, 2018 11:30 am
Well the real question is will hAP AC 2 be able to handle 900/100 Mbit via PPPoE + NAT + around 30 firewall rules via LAN ?
mistry7
Thu Mar 29, 2018 10:04 pm
HzMeister
Fri Mar 30, 2018 4:55 am
That's a relatively simple setup that an rb750gr3 could handle, so a hap ac2 will be more than enough. Since mikrotik makes really powerful hardware, it's easy to think that anything on the lower end won't be good enough. The high end gear is meant for a lot of clients and/or complex setups that utilize more advanced routing features, so unless you know you need it, there's no point in overspending.
Mitar
Fri Mar 30, 2018 8:41 pm
So I have bought hAP ac2 and its amazing, on same settings as my RB951G cpu usage is only 2-3% when fully using 100 Mbit PPPoE, while on RB951G cpu usage was ~20% ( with fastpath, without it was double that ).
squeeze
Fri Mar 30, 2018 10:01 pm
Did you get 900/100 Mbit WAN connection speed with the hAP ac2, PPPoE and same IP firewall rules? If so, how did you test it?
Mitar
Sat Mar 31, 2018 2:12 am
Nope I dont have 900/100 yet I only tested at 100/50
Users browsing this forum: Ahrefs [Bot], anav, bschapendonk, Network5, Philippe57, qatar2022, satepson and 104 guests
