MUM Europe 2020
yehia
DNS
Thu Apr 05, 2018 12:45 pm
Hi all...
What is the purpose of set DNS for access point when i give it static ip address ?
is it necessary to set dns for access points or not and what is for ?
Steveocee
Re: DNS
Thu Apr 05, 2018 12:56 pm
Necessary? Probably not. It will still work without.
If you choose to give the AP a route to the internet then DNS will of course help. System>Packages can't update as it needs to resolve a host name to do work as an example.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
erlinden
Re: DNS
Thu Apr 05, 2018 2:24 pm
What is the use of setting a fixed IP address to an accesspoint? I prefer to have all my IP related stuff done by a DHCP server, reservations for any device necessary.
And to answer you question: DNS is for name resolving. So in any case of name resolving you need a DNS server.
Steveocee
Re: DNS
Thu Apr 05, 2018 2:49 pm
This approach is fine until your router bites the dust and you don't have a backup config saved with the reservations in it.
yehia
Re: DNS
Fri Apr 06, 2018 4:45 pm
thnx 4 replaying guys
yhfung
Re: DNS
Mon Apr 09, 2018 6:27 am
Both methods can work. Depending on the policy or preference, some company prefer fixed IP to dynamic IP. I believe that the control for fixed is much easier. However it requires more settings. If we use the DHCP client method, the connected device can receive not only IP but also dns server and gateway.
YH
Users browsing this forum: No registered users and 46 guests
