sindy
Multiple Road Warrior L2TP/IPsec clients behind NAT - solved
Thu Apr 05, 2018 11:54 pm
WARNING! Risk of brain overheat. Prepare some coolware before reading.
The well-known problem
L2TP/IPsec clients reaching the server via NAT do work but only one at a time per each public address. A new client connection from behind the same public address ruins the pre-existing client session.
The root cause
To understand what is wrong, one must stop looking at L2TP/IPsec as at a magic blackbox and closely inspect its strictly layered structure. L2TP/IPsec is literally L2TP transported using IPsec, both protocol-wise and (at least in case of RouterOS) application-wise: when you tick the "use IPsec" check-box in L2TP settings, RouterOS automatically creates an IPSec peer and, at client side, an appropriate policy necessary to transport the L2TP connection. The same IPsec setup can be done manually instead of ticking the check-box in the L2TP configuration, and the resulting processing of the packets is exactly the same in both cases.
According to the standard, L2TP is transported using UDP and both the server and the client use port 1701 to both send and receive. So all standards adherent client implementations use port 1701 also locally.
The L2TP/IPsec standard requires that ESP transport mode is used. ESP transport mode is designed for efficient encapsulation of encrypted traffic directly between two machines, so it does not carry any information about source and destination IP address in the encapsulated payload as it would be redundant. It is assumed that these addresses are the same for the original transported packet and the ESP transport packet. If one of the addresses eventually changes on the way from the sender to the recipient, the decrypted and de-encapsulated packet inherits this changed address. The information about ports is part of the transported payload; ESP itself has no notion of ports at all.
The fact that ESP uses no ports means that it cannot be handled by a NAT; to work this around, the NAT-T extension to IPsec has introduced encapsulation of ESP into UDP. However, this only allows the UDP-encapsulated ESP to be forwarded through the NAT properly. In the process of de-encapsulation of the ESP payload from the UDP transport, the information about source port of the UDP (which has been changed by the NAT to distinguish one flow from another) is lost. The source address of the ESP packet is inherited from the UDP packet in which the ESP has come encapsulated.
When, in the next step, the UDP packet carrying the L2TP is decrypted and de-encapsulated from the ESP, its source address is inherited from the ESP, so it is again the public IP of the NAT, and the source port is the one from which the client has sent the UDP before encapsulating it into the ESP. So if both clients behind the same NAT send from the same port (1701), the L2TP server sees both as coming from the same socket address, consisting of the public address of the NAT and the same port provided by each client. Thus not only that the flows are indistinguishable from each other when received but there is also no way to address the response packets selectively to one of them - the IPsec policy matches only on address and port, not on anything in the payload.
Some client implementations are aware of this and use random ports. RouterOS server implementation is not strict in this and accepts connections from such clients, so this is a solution of the problem for these implementations but not for other ones, like the one of Microsoft Windows. And it is also not a solution for the Android embedded client which uses a random port for L2TP but doesn't restrict its IPsec policy to this port.
The solution at server side RouterOS
As there is no out-of-the-box way to link the source port of the "inner" UDP (the one which carries the L2TP) to the source port of the "outer" UDP packet (the one which carries the ESP), we need to convey the information distinguishing the two client's flows from one another across two encapsulating layers using some other means. Without coding, the only way is to change the transport packets' source IP addresses to unique ones depending on their source ports. So what we need is to use source-NAT on received packets. Problem solved - from the point of view of the L2TP server and IPsec policy matching, there is no ambiquity or conflict as each flow is coming from a unique IP address.
Implementation Details
The above sounds easy but the first cooldown comes when you realize that src-nat does not work for received packets as it is deemed useless for any sane application scenario. We could use two routers in a chain to do that but that would mean extra hardware costs and also some inconvenience. So the first task is to make RouterOS src-nat a received packet and then continue handling it as a received one. The solution is to take any two local addresses and establish an IP-IP tunnel between them, so that we could run the same packet through the whole firewall machinery twice on a single machine. We receive the packet from a physical interface, route it "out" using one of the IP-IP tunnel's ends as the output interface, and we "receive" it the second time from the other end of that tunnel.
Another task is the assignment of a unique source address depending on port. While we could theoretically map the port number 1:1 into the lower two bytes of the IP address, the issue here is that very often flows from two clients behind different NAT boxes come from the same port (like 1024), so that method would not be 100% safe. So this is not the way even if we neglect some other associated complications. The solution is to use a stack of addresses and give each new connection its own address regardless the actual source address and port.
The address assignment policy of src-nat action of RouterOS firewall is not helpful here, as it does not prefer diversity, so if two connections come from different ports on the same IP address, the src-nat rule is likely to assign them the same address no matter how large pool it has got as
to-address
. A
per-connection-classifier
can use a hash of source address and port but even with an annoying amount of rules the uniqueness of address assignment would not be guaranteed. The solution is to use a single address in the src-nat rule and increment it each time it gets assigned to a new connection. As using the available means it is impossible to do this fast enough, there is a big chance that two connections get src-nat'ed to the same source address, so we need to resolve that systematically. To do so, the firewall filter in the second pass checks a
src-address-list
for the first packet of each new connection; if the source address is already there, the firewall drops the packet, thus preventing the connection from establishing, otherwise it adds the source to the address list with a 1 minute lifetime and accepts the packet. So the first connection with a particular source address always succeeds and all the following ones always fail. Once per a couple of seconds, a cleaner script checks whether the source address currently configured in the src-nat rule is used by a properly established connection; if it is, the script updates the rule with an unused address and cleans any connection attempts waiting for a response because their establishing packets have been dropped by the second pass through the firewall, which makes the firewall treat a retransmission of the same packet as a brand new one and thus use the src-nat rule on it. The client retransmits the IPsec connection establishing packet for tens of seconds before it gives up, therefore many clients would have to attempt to connect during the same time window of several seconds so that the most unlucky ones would fail. This can happen e.g. after a network outage if the clients are autonomous devices which keep on trying, so effectively for some of them the network outage will seem to last longer than for others.
It is also worth noting that we need to prevent the incoming UDP transport packets from being delivered to the IPsec stack already in the first pass; to do that, we must dst-nat them to an address which is not a local one to the router using a dst-nat rule which matches in the first pass, and dst-nat them back to the original address using a dst-nat rule which matches in the second pass. Routes must be added to send the internal traffic through the tunnel.
What makes all this even possible is that it is enough to give this special treatment to packets coming to UDP port 4500. The NAT-T mechanism of IPsec does not require that the UDP-encapsulated communication coming to port 4500 would come from the same IP address from which the initial IKE communication was coming to port 500. There would be no way to pair connections to port 500 with connections to port 4500 coming from the same client.
The limitations
The pool of IP addresses used for src-nat must be significantly larger than the maximum expected number of clients connected simultaneously, because if an established connection breaks, the connection tracker remembers it for minutes so its src-nat address cannot be reused during that time. So if some of the clients have unstable connections and reconnect quite frequently, they would exhaust the pool. If your network is so large and complex that you cannot find a free pool of thousands of addresses, the way out is to mark the response IPsec packets from the server and policy-route them back to the tunnel, while the traffic to actual owners of these addresses is routed normally.
The risks
Each modification of the src-nat rule causes a configuration save. This means an extra wear for the flash chip. I have no idea what this may cause in real life deployment on Routerboards. To reduce the impact and also to save some resources, I recommend to exclude packets with source port 4500 from the special treatment. The background is such that NATs usually only change the source port if the original one is already used for another connection to the same remote socket. So in many cases the connection from our first client behind each NAT comes from port 4500 and thus does not cause a modification of the src-nat rule, and in many of these cases the client will be the only one behind that NAT.
The configuration
# Create a bridge without any member ports so that we'd have something to attach the additional local IP address to.
# Actually the address could be added to an existing interface, but a member-less bridge never fails.
add name=aux-lo protocol-mode=none
# Add another local address - just to have this part independent from the rest of the configuration.
add address=127.0.1.1 interface=aux-lo network=127.0.1.1
# Add a firewall rule permitting local traffic - currently, default firewall rules drop traffic from in-interface-list=!LAN which
# includes local traffic
add chain=input src-address=127.0.0.0/8 dst-address=127.0.0.0/8 action=accept place-before=right after the "accept established,related" rule
# Create the two ends of the local tunnel
/interface ipip
add local-address=127.0.0.1 mtu=1500 name=ipip-inner remote-address=127.0.1.1
add local-address=127.0.1.1 mtu=1500 name=ipip-outer remote-address=127.0.0.1
# Add routes for the addresses used for the solution
add distance=1 dst-address=10.0.0.0/20 gateway=ipip-inner
add distance=1 dst-address=10.0.15.254/32 gateway=ipip-outer
# Add the chain of firewall rules preventing newer connections from killing an older one before the cleaner script changes the src-nat address
add chain=udp-4500-in src-address-list=src-addresses-in-use action=drop
add chain=udp-4500-in action=add-src-to-address-list address-list=src-addresses-in-use address-list-timeout=1m
add chain=udp-4500-in action=accept
# Add the firewall rule sending new packets to UDP 4500 coming from the tunnel to the chain above
add action=jump chain=input connection-state=new dst-port=4500 in-interface=ipip-inner jump-target=udp-4500-in protocol=udp place-before=right after the "accept established,related" rule
# The usual IPsec- and L2TP-related firewall rules must be there as well, usually they already exist
add action=accept chain=input connection-state=new dst-port=500,4500 protocol=udp
add action=accept chain=input connection-state=new dst-port=1701 ipsec-policy=in,ipsec protocol=udp
# Add the firewall rule permitting forwarding of dst-nated packets in the first pass
add action=accept chain=forward connection-state=new dst-address=10.0.15.254
# Add the NAT rules
# Restore our public IP address on packets after they've passed through the tunnel
add action=dst-nat chain=dstnat dst-address=10.0.15.254 in-interface=ipip-inner to-addresses=1.2.3.4
# src-nat the packets before sending them to the tunnel
add action=src-nat chain=srcnat out-interface=ipip-outer protocol=udp to-addresses=10.0.0.1
# Redirect packets to port 4500 to the auxiliary destination address to give them the special treatment;
# for testing that it works with only two client devices, remove the "src-port=!4500"
add action=dst-nat chain=dstnat dst-port=4500 src-port=!4500 dst-address=1.2.3.4 protocol=udp to-addresses=10.0.15.254
# Add the cleaner script
/system script
add name=l2tp-helper owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
":local cntr 0; \\\
    \n:local auxip [/ip firewall nat get [find chain=\"srcnat\" && out-interface=\"ipip-outer\"] to-addresses]; \\\
    \n:while ([/ip firewall connection print count-only where src-address~\"^\$auxip\" && dst-address~\":4500\" && seen-reply]=1) \
    do={\
    \n  :set auxip (\$auxip+1); \\\
    \n  :if (\$auxip>10.0.15.253) do={:set auxip 10.0.0.1};:set cntr (\$cntr+1)\
    \n}\
    \n:if (\$cntr>0) do={\
    \n  /ip firewall nat set [find chain=\"srcnat\" && out-interface=\"ipip-outer\"] to-addresses=\"\$auxip\"; \\\
    \n  /ip firewall connection remove [find dst-address~\":4500\" && !seen-reply]\
    \n}\
    \n"
# Schedule the cleaner script to run every 3 seconds right from the restart
/system scheduler
add interval=3s name=l2tp-scheduler on-event=l2tp-helper policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-time=startup
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
pcunite
Re: Multiple L2TP/IPsec clients behind NAT - solved
Fri Apr 06, 2018 3:30 am
Wow ... I've had issues with this on Peplink devices.
I think MikroTik should someone bake your solution into the firmware somehow.
drakerex
Re: Multiple Road Warrior L2TP/IPsec clients behind NAT - solved
Sat May 05, 2018 2:28 am
@sindy - In the following is the 10.0.0.0/20 for inner considered what you're using as your LAN? ie, the same as 192.168.2.0/24 (as example).
Also - Is the 10.0.15.254/32 the same as a WAN IP or is this an internal binding for the loop creation on the bridge only? Or is that considered the end client's IP range given the /32? If so on the latter, if we're using a DHCP pool for our external vpns, how would we bind that part dynamically?
sindy
Wed May 16, 2018 4:12 pm
Sorry for late answer, I haven't received a notification e-mail.
Yes, 10.0.15.254 is just the last individual address from 10.0.0.0/20. The whole range you choose instead of the 10.0.0.0/20 in the example must not collide with any private range you use, including the pools you use to assign addresses to the L2TP clients. There is no relationship between the pool from which you assign addresses to L2TP clients and this range (except that they must not collide). These addresses are not assigned to any interface anywhere.
voll
Mon Sep 03, 2018 5:39 pm
Hi Sindy!
I've been trying to implement your solution for a couple of days now, but with minimal progress unfortunately and am hoping for some help at this point...
On first glance, your tutorial screams complex (took me a good couple of hours to disseminate everything lol).
My setup involves a CHR v 6.42.7 acting as the L2TP/IPsec server and two windows 10 clients dialling from behind the same public IP. As expected, the last dialled client will "keep alive", while the first will hang around for anything between 1-15mins before disconnecting. Pinging the router while both are connected renders an alternate response (5-10s worth of responses for one client, then it times out and the other one begins to receive them - to be expected I guess).
My Jump rule (and consequently the udp-4500-in chain) is not being hit at all, no matter where I position it in the firewall and am beginning to suspect an IP config problem somewhere. Also, I have no local ranges conflicting with your proposed config values.
Would it be too much to ask for a server-side config sample for reference?
Much appreciated!
sindy
Mon Sep 03, 2018 8:24 pm
Both the lab device on which I've developed the configuration and the sole machine on which I'm currently running it in production have much more complex firewall rules and many unrelated settings. Therefore, both would have to be edited before posting, so there is a risk of losing some important bit during this process. On the other hand, the configuration already posted in the OP has been cut to bare bone of what is necessary for it to run.
So I propose you the reverse, export your config following the instruction in my automatic signature (and take special care about the "systematical" part while obfuscating) and I'll have a look. This will also allow me to identify the missing or misleading part of the description above.
voll
Tue Sep 04, 2018 10:58 am
Thanks for your swift reply & totally understand.
Here is my export:
# sep/03/2018 15:31:25 by RouterOS 6.42.7
set [ find default-name=ether1 ] name=mgmt-106
set [ find default-name=ether1 ] name=technative-LAN-2002
set [ find default-name=ether1 ] name=wan-704
/interface ipip
add name=VPN-pool ranges=10.200.31.20-10.200.31.120
add name=DHCP-pool ranges=10.200.30.121-10.200.30.200
add address-pool=DHCP-pool disabled=no interface=technative-LAN-2002 name=\
    dhcp-technative
/ppp profile
add dns-server=10.200.30.254 local-address=10.200.31.254 name=l2tp-in \
    remote-address=VPN-pool
/interface l2tp-server server
set authentication=mschap2 default-profile=l2tp-in enabled=yes ipsec-secret=\
    [Secret] use-ipsec=yes
add address=10.200.30.254/24 interface=technative-LAN-2002 network=\
    10.200.30.0
add address=[public_IP]/27 interface=wan-704 network=[public_network]
/ip dhcp-client
add add-default-route=no disabled=no interface=mgmt-106
add address=10.200.30.0/24 dns-server=10.200.30.254 gateway=10.200.30.254
set allow-remote-requests=yes
/ip firewall address-list
add address=10.222.203.0/24 list=bliss-mgmt
add address=10.220.220.0/24 list=bliss-mgmt
add address=10.200.30.0/24 list=internal-LAN
add address=10.200.31.0/24 list=internal-LAN
add action=accept chain=input comment="Accept mgmt-in" src-address-list=\
    bliss-mgmt
add action=accept chain=input disabled=yes src-address-list=internal-LAN
add action=accept chain=input comment="Allows Ping" protocol=icmp
add action=drop chain=udp-4500-in comment=\
    "Prevent new VPN-conn to kill old one" src-address-list=\
add action=add-src-to-address-list address-list=src-addresses-in-use \
    address-list-timeout=1m chain=udp-4500-in
add action=accept chain=udp-4500-in
add action=accept chain=input comment="Allow E&R In" connection-state=\
    established,related
add action=jump chain=input connection-state=new dst-port=4500 in-interface=\
add action=accept chain=input comment="Allow local loop" dst-address=\
    127.0.0.0/8 log-prefix=local127 src-address=127.0.0.0/8
add action=accept chain=input comment="Allow VPN protocols" connection-state=\
    new dst-port=500 protocol=udp
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=input connection-state=new dst-port=1701 \
add action=accept chain=input connection-state=new dst-port=4500 protocol=udp
add action=accept chain=input in-interface=technative-LAN-2002
add action=drop chain=input comment="Drop all other" in-interface=wan-704 \
    log-prefix="drop pool"
    "Allow forwarding of dst-nated packets in the first pass" \
add action=accept chain=forward comment="Allow E&R Fw" connection-state=\
    established,related
add action=accept chain=forward comment="Allow Internal FW" dst-address-list=\
    internal-LAN src-address-list=internal-LAN
add action=drop chain=forward comment="Drop all other" connection-state=\
    invalid
add action=dst-nat chain=dstnat comment="Restore our public IP address on pack\
    ets after they've passed through the tunnel" dst-address=10.0.15.254 \
add action=src-nat chain=srcnat comment=\
    "src-nat the packets before sending them to the tunnel" out-interface=\
add action=dst-nat chain=dstnat comment="Redirect packets to port 4500 to the \
    auxiliary destination address to give them the special treatment" \
    dst-address=1.2.3.4 dst-port=4500 protocol=udp src-port=!4500 \
add action=masquerade chain=srcnat comment="Masq everything else" \
    dst-address=!10.0.0.0/8 out-interface=wan-704
/ip ipsec peer
add address=0.0.0.0/0 dh-group=modp1024 enc-algorithm=aes-256,aes-128,3des \
    exchange-mode=main-l2tp generate-policy=port-override secret=[Secret]
add distance=2 gateway=[next_hop]
add distance=1 dst-address=10.220.220.0/24 gateway=10.223.203.254
/ppp aaa
set use-radius=yes
/ppp secret
add name=[test_acc1] password=[pass] profile=l2tp-in service=l2tp
add name=[test_acc2] password=[pass] profile=l2tp-in service=l2tp
/radius
add address=10.200.30.251 secret=[radius_secret] service=ppp src-address=\
    10.200.30.254
/system clock
set time-zone-name=Europe/London
/system identity
set name=Technative-vr2
/system logging
add disabled=yes prefix=VPNLog topics=ipsec
/system scheduler
add interval=3s name=l2tp-scheduler on-event=l2tp-helper policy=\
    start-time=startup
/system script
add name=l2tp-helper owner=dionita policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
    \":local cntr 0; \\\\\\\r\
    \n    \\n:local auxip [/ip firewall nat get [find chain=\\\"srcnat\\\" && \
    out-interface=\\\"ipip-outer\\\"] to-addresses]; \\\\\\\r\
    \n    \\n:while ([/ip firewall connection print count-only where src-addre\
    ss~\\\"^\\\$auxip\\\" && dst-address~\\\":4500\\\" && seen-reply]=1) \\\r\
    \n    do={\\\r\
    \n    \\n  :set auxip (\\\$auxip+1); \\\\\\\r\
    \n    \\n  :if (\\\$auxip>10.0.15.253) do={:set auxip 10.0.0.1};:set cntr \
    (\\\$cntr+1)\\\r\
    \n    \\n}\\\r\
    \n    \\n:if (\\\$cntr>0) do={\\\r\
    \n    \\n  /ip firewall nat set [find chain=\\\"srcnat\\\" && out-interfac\
    e=\\\"ipip-outer\\\"] to-addresses=\\\"\\\$auxip\\\"; \\\\\\\r\
    \n    \\n  /ip firewall connection remove [find dst-address~\\\":4500\\\" \
    && !seen-reply]\\\r\
    \n    \\n}\\\r\
    \n    \\n\""
As you can see, besides a radius instance and some mgmt rules, the setup is pretty much bare. The CHR is VLAN agnostic so the IDs are set per interface outside the VM. Must be something small that I'm missing :)
Really appreciate taking the time to examine this!
sindy
Tue Sep 04, 2018 12:01 pm
Could it be as simple as that you haven't realized that you have to replace 1.2.3.4 in my chain=dstnat rules by your actual public IP address?
Other than that, you have configured an IPsec peer with exchange-mode=main-l2tp manually, and you have also configured use-ipsec=yes and secret on /interface l2tp-server server. It works but you end up with two peers running and only one of them actually used.
voll
Tue Sep 04, 2018 1:18 pm
Yes, those did slip through. Thanks for pointing that out!
I've changed the L2TP Server settings to "Use IPsec=no" and left only one IPsec Peer on. Also, did the public IP swap in the NAT dst rules.
Now I'm getting some hits on rules which defo counts as progress... The drop rule meant to prevent killing the old connection as well as the 127 loop are never hit thou :(. Secondary connections do drop randomly within minutes and any effort to communicate simultaneously from test1 / test2 (while established) fails. Sometimes, the disconnection occurs immediately after attempting to actively send packets through a connection (pinging for example).
Noticed that, upon dialling, the generated IPsec policies differ:
1st established connection generates a policy with src-addr=router_public_Ip and dst-addr=10.0.0.1
2nd established connection generates a policy with src-addr=router_public_Ip and dst-addr=remote_public_ip
Would that be normal?
mrz
Tue Sep 04, 2018 3:04 pm
Does this overcomplicated thing really necessary, where you can switch to ike2 and forget about NAT problems?
voll
Tue Sep 04, 2018 3:45 pm
I'm new to IKE1/2 really.. So, let me get this straight: Implementing a cert-based VPN would assign uniqueness to two or more clients dialling behind same NAT device?
pe1chl
Tue Sep 04, 2018 3:59 pm
IKE2 does require a PKI infrastructure, doesn't it? That is overcomplicated just as well... it introduces the new
problem of certificate generation, installation, backup and renewal. Using a PSK is so much simpler.
mrz
Tue Sep 04, 2018 4:00 pm
Not really, can be done with EAP authentication.
And if clients are only ROS devices or IOS you can use PSK as well.
sindy
Tue Sep 04, 2018 4:33 pm
...and User Manager isn't sufficient for this (unless I've missed something during past half a year) so you need an external RADIUS server.
pe1chl
Tue Sep 04, 2018 4:50 pm
I decided to experiment a little with this.
It appears to be possible to have a IKE2 IPsec peer alongside a main peer at the server side (where I do not use the auto-generated peer config), good.
However, at the client side I would like to use auto-generated peer but it is not possible to specify IKE2 anywhere.
WIth manually configured peer it is working. However, my L2TP client has a DNS name that resolves to 2 different IP addresses (2 different ISP at the main office)
so auto-generated peer is more convenient as it generates the correct peer for the actual remote IP in use for the connection.
sindy
Tue Sep 04, 2018 5:13 pm
I'm a bit lost - what has an auto-generated peer to do with IKE2 mode? If you use an IKE2-controlled SA to transport L2TP, you fall to the same rabbit hole like with IKE1-controlled SA regarding NAT and transport mode; if you use plain IKE2 mode, which is what @mrz suggests, I cannot see how the client-side peer could be a dynamic one.
pe1chl
Tue Sep 04, 2018 5:17 pm
I did not know that, I understood I only needed to change main exchange mode into IKE2 exchange mode at both ends.
However, that is not possible with auto-generated peer (setting IPsec checkmark and entering PSK).
How do you configure an L2TP client with "plain IKE2 mode"?
mrz
Tue Sep 04, 2018 5:23 pm
You don't there is no need for L2TP when ike2 is used.
sindy
Tue Sep 04, 2018 5:24 pm
@voll, sorry, I need to concentrate on analysing your behaviour which is currently impossible due to other factors so we'll come back to it later :-)
@pe1chl, as you've anticipated you cannot, you need to configure the peer manually. The auto-generated peer always uses main-l2tp, and the auto-generated peers for ipip, gre, eoip... tunnels always use main. If you want anything special (non-default exchange modes, non-default proposals used to auto-generate policies), you have to configure the peer manually.
pe1chl
Tue Sep 04, 2018 6:02 pm
Then what kind of tunnel do you use? I don't want to use plain IPsec because I want to route traffic between several subnets, not only a single endpoint address.
pe1chl
Tue Sep 04, 2018 6:04 pm
But unfortunately you cannot use manual peer config with multiple peer addresses (which works OK with auto-generated policies)
sindy
Tue Sep 04, 2018 6:15 pm
Don't mix auto-generated (dynamic) policies with auto-generated (dynamic) peers. With mode-config, the policy is dynamically generated at both peers ("client" and "server"), always using the locally visible (public) IP address of the remote peer as sa-dst-address.
But yes, plain IKE2 uses policies to choose packets to be tunnelled, which you are famous for not being a fan of :-)
voll
Tue Sep 04, 2018 7:02 pm
No worries Sindy
I've temporarily set in place a softether.org server instance which seems to work flawlessly with multiple clients dialling side-by-side behind same wan ip.
Would be nice to have a pure mikrotik solution to it, but I can also appreciate Mikrotik not focusing on L2TP/IPsec that much as it becomes deprecated in favour of IKE.
Will pursue this thread with same interest as your solution does look intriguing in its own right :)
sindy
Wed Sep 05, 2018 1:59 am
This is normal because you've kept the src-port=!4500 in the dst-nat rule. This causes the first connection established through the client-side NAT to bypass the whole thing. The sole purpose of this is to reduce flash wear as the whole "overcomplicated thing" is necessary only if multiple clients are behind the same NAT. The fact that you can see it as 2nd in the list is not important, the list is not ordered by connection establishment time. And it also explains why the rules preventing one connection from affecting the next one do not count, as there is no conflict. The second connection through the NAT comes from a source port like 1024, and the locally assigned source address (10.0.0.1) is added to the address-list, but as no further connection comes in before the scheduled script changes the to-addresses value in the action=src-nat rule, the collision-preventing rule (drop new connections if coming from an IP currently on address-list) has no reason to kick in.
No idea here, it sounds to me as unrelated to the NAT-beating setup.
Can you show me the output of /ip firewall connection print where dst-address~":4500" (substitute the public IPs of course) while both connections are up (logged in)?
Can you add a 3rd device and show the same output?
dhcpy
Fri Dec 21, 2018 4:31 pm
Good day,
Great analysis and superb workaround!!
I had the same problem, came here googling. Now I know this is out of my league though so will find other solution.
Seems this is not a mikrotik issue, but a protocols and features limitation.
Would be nice though, to have the wiki updated on this things, giving that (to my knowledge) is the official mikrotik documentation, they should put a little effort in the guidance of this kind of common scenarios (roadwarriors behind NAT)..And if opting for betters solutions, as IKE is the trend, well then put that statement somewhere with emphasis.
I would have saved time not reading on solutions that require god level tweaking.
thanks again sindy!
sindy
Fri Dec 21, 2018 6:52 pm
It is actually not so complex once you draw it. The only complex thing in it is that you have to squeeze the functionality normally provided by two routers into just one.
Correct.
as IKE is the trend
A standalone IKEv2 (i. e. without the L2TP on top of it) is the trend, not IKE(v1) which is outdated, and the way it is used in the operating systems' native clients, IKEv2 has the advantage of leaving out one layer of tunneling so the confusion intirinsic to L2TP/IPsec doesn't exist: also here, packets from each of the clients behind a common public IP arrive from a different UDP port, but unlike in the L2TP/IPsec case, the information about that client-representing port is not lost.
What scares many people is the need to handle certificates induced by the fact that all OS-provided IKEv2 clients seem to insist on their use although a pre-shared key is also supported by IKEv2 as a protocol suite. If all you want is to connect the device to a single VPN "server", handling of certificates is actually not terribly complex. As soon as you need the same device to connect to several servers, it may be more tricky: I haven't seen any support of multiple own identities on e.g. Windows or Android, so I'm afraid the embedded client would use the same certificate to authenticate itself to all servers, and this causes a headache if the certificate is not signed by any public certification autority because all servers would have to accept certificates signed by the private CA used. Which constitutes a security hole from the point of view of the server administrator.
But unless one of the certificate-related points as mentioned above is an issue for you, IKEv2 is an easy substitution of L2TP/IPsec which doesn't suffer from the "multiple clients behind same public IP" trouble.
billybons2006
Fri Jan 11, 2019 12:43 pm
Thank you for information, explanation and example. I tested this, it works with iPhone and Windows and, really, Android can't connect to the server :(
sindy
Fri Jan 11, 2019 3:14 pm
I would suspect the Android connection issue to be related either to permitted encryption algorithms in peer profile and/or policy, or to some particular Android version. My variouos Android devices work well with this (except that after the initially suggested session time expires, they pretend to be connected but actually transport no data, but that's again unrelated to the multiple-clients-behind-same-NAT issue).
So as the first step, I'd disconnect all clients if possible, enable IPsec logging (/system logging add topics="ipsec,!packet"), run /log print follow-only where topics~"ipsec" file=ipsec-start, make an attempt to connect the Android, stop the log print once the Android reports failure, download the file and study it for encryption and authentication algorithm match between the devices.
pe1chl
Fri Jan 11, 2019 5:37 pm
Indeed you must set
/ip ipsec peer profile
enc-algorithm=aes-128,3des hash-algorithm=sha1
When you set other enc-algorithm like aes-256 or other hash algoritthm it will just fail on some Android versions.
For /ip ipsec proposal (phase 2 settings) you can have aes-256 enabled when you really think that the secret service is after you.
oreggin
Fri May 17, 2019 9:10 pm
Hi!
I build a hub and spokes IKEv2/rsa signature auth with L2TP over IPSec setup with Tik deivces.
There is one central HUB with static public address, and there are some spokes, one of them have a dynamic public address, and the other is behind NAT where NAT public address is dynamic as well.
Public addressed CPE is connect to the HUB Tik router without any problem, but the CPE behind NAT can't connect. I think because dynamic policy derived from template is always gets transport mode and I need tunnel mode. So IKEv2 not solve my problem :(
I using RoS v6.44.3 all of the devices.
Sorry if someone asked the same before, but is there a way to create a template which creating tunnel mode dynamic policies? Or it is impossible?
cheers,
oreggin
sindy
Fri May 17, 2019 9:21 pm
A policy generated from a template always accommodates to the tunnel or transport mode requested by the remote peer.
Independent from this, I didn't have in mind to use IKEv2 to transport L2TP instead of IKE(v1) but to use directly IKEv2, i.e. without the L2TP inside.
oreggin
Mon May 20, 2019 12:52 pm
How can I request tunnel mode, if both side has dynamic policies? I can't find this option in RoS :(
I using BGP inside L2TP to distribute (IPv4+IPv6) routes between hubs and spoke, so i think i can't drop L2TP, or can I? How?
Oh, and I missed the MPLS part inside the L2TP.
sindy
Mon May 20, 2019 1:13 pm
As you've mentioned IKEv2 and rsa-signature, I cannot see how you can use a dynamically created policy at both ends. Do you have use-ipsec=yes in the /interface l2tp-client settings? And if you do, doesn't the dynamically created IKE(v1) peer collide with the manually created IKEv2 one when it comes to which one of the two will be used to create the SAs used by the policy? I mean, the two pairs of peers (with exchange-mode=main and with exchange-mode=ike2) may run simultaneously, but as IP addresses of the endpoints are the same, I don't dare to guess which of the pairs of control SAs will be used to negotiate the transport SAs for the policy.
BGP would not be a problem with GRE or IPIP, but for MPLS you need L2TP or EoIP.
In any case, I think we've got quite far away from the scope of the topic - do you really have multiple spokes visible to the hub from behind a common IP address, and these spokes are road warriors, i.e. they connect from another place each time?
oreggin
Mon May 20, 2019 1:41 pm
Under "/interface l2tp-client" I set "use-ipsec=no" as if I'm right it supports only PSK based auth.
I configured dynamic policies under "/ip ipsec":
/ip ipsec peer set 0 exchange-mode=ike2
/ip ipsec identity set 0 auth-method=rsa-signature generate-policy=port-override
Unfortunately I didn't found better solution.
sindy
Mon May 20, 2019 2:36 pm
Wait. Are you saying that by setting generate-policy=port-override at both peers, if one of them wants to send a packet to the other one, a matching transport policy is automatically generated from the template? That doesn't make sense to me... I've always thought that at least one end must have a fixed policy, or use mode-config=request-only to request its local address from the remote peer and generate the local policy from the received mode-config instruction.
oreggin
Mon May 20, 2019 3:11 pm
I didn't mentioned IPSec is the outer and L2TP is inside of it. In the reverse situation the result performance is terrible.
Now I have dynamic policies on both end and it works if peers are not behind NAT.
I'm not an IPSec expert, so do you say I need set static policy on spokes? On spokes because I have only one fix IP and it has the HUB and I must set SA dest address in static policy? How policies generated on hub for each spokes? And how it will works if a spoke is behind NAT?
Thanks!
sindy
Mon May 20, 2019 3:47 pm
OK, I'm afraid I start understanding what's actually going on there.
I don't consider myself an IPsec expert either, just an advanced user. But my understanding is this:
  • to transport the actual data, you need a pair of security associations, which are basically unidirectional encrypted links
  • to choose which data to send via the security association and in which form, you need a policy, which is a combination of
    • the traffic selector - a combination of source and destination IP addresses or subnets and, eventually, protocol, and if protocol is specified and supports the notion of ports, also possibly of source and destination port
    • payload encapsulation mode (transport or tunnel)
    • encryption and authentication algorithms which may be chosen from (the "proposal")
    • the rules to create and use the SA - the address of the remote device which must be one of IPsec peers, the local address to use if it makes a difference, and the sharing mode, i.e. whether an existing SA to the same remote peer can be reused for packets matching other policies' traffic selectors
  • to control the establishment of the SAs needed to serve the policies, a "control" SA between the peers needs to be established first.
A "data" SA may be created only as late as when a packet matching policy's traffic selector appears, or in advance. But if the packet to be transmitted doesn't match the traffic selector of any existing policy, it is simply sent in plaintext. No comparison to peer addresses is done.
To accommodate for dynamic environments, you can use policy templates which are then used in one of the following ways:
  • if one peer has a manually configured policy (manually configured from the perspective of the IPsec astro clock), it offers its traffic selector to the other peer, which checks whether a mirror traffic selector fits to one of its policy templates and dynamically creates a policy if it does
  • if mode-config is used, the mode-config requestor (which is normally the initiator) gets the address and route list from the other peer and converts that into policies locally (so it needs to have generate-policy set to something else than no), and then offers the result to the other peer as in the case above
  • specifically for L2TP, EoIP, ... tunnels in Mikrotik, the code handling the tunnel interface creates the policy at client side, so from the perspective of the user it is a dynamically created one but the IPsec treats it as one provided from outside, so it handles it as in the first point
All the above leads me to a conclusion that when you start the hub and the spoke on public address, you'll likely find that no policy's traffic selector actually matches the L2TP transport packets, so they flow between the devices in plaintext. Which also explains why it doesn't work on spokes which are behind NAT.
When the policy is generated from a template, its sa-dst-address and sa-src-address are assigned dynamically to match those used by the "control" SA. This allows to traverse NAT if tunnel mode is used, and to certain extent also if transport mode is used - in particular, the combination of public IP and the port of the remote peer must be unique for each remote peer.
oreggin
Mon May 20, 2019 4:40 pm
Thanks for deep explanations, good to learn something new every day.
BTW your conclusion is not exactly right as our L2TP tunnels are encrypted, I checked it. Dynamic policies generated on HUB and spokes and SA counters increasing with the amount of trasmitted bytes. I don't say that I 100% understand why, but all of it works while all spokes has public IP. And you are right as I must have an additional firewall rule on HUB to drop unencrypted L2TP traffic.
My detailed configs over here:
HUB:
/ip ipsec peer add exchange-mode=ike2 local-address=192.0.2.1 name=Spokes passive=yes send-initial-contact=no
/ip ipsec identity add auth-method=rsa-signature certificate=cert_HUB generate-policy=port-override peer=Spokes
Spoke1:
/ip ipsec peer add address=192.0.2.1/32 exchange-mode=ike2 name=HUB
/ip ipsec identity add auth-method=rsa-signature certificate=cert_Spoke1 generate-policy=port-override peer=HUB remote-certificate=cert_HUB
192.0.2.1 is my HUB's address for the documentation. I know the certs part is not clear for now but working on it ;)
"ip ipsec policy print" on HUB shows every spokes has a policy with "DA" flag and "action=encrypt level=unique ipsec-protocols=esp tunnel=no ph2-count=1"
Do you think my setup would not work or it is bad conception?
sindy
Mon May 20, 2019 6:05 pm
I just don't get how these dynamically created policies came into existence out of blue. I'll have to check later how is that possible, but I'd prefer to see the full export and also the output of /ip ipsec policy print (anonymized along with the export as per my hint below to maintain consistence) from the hub and from one spoke on a public address.
oreggin
Mon May 20, 2019 7:14 pm
Here are my anonymised configs and print outputs:
[oreggin@HUB] > ip ipsec export verbose
# may/20/2019 17:52:51 by RouterOS 6.44.3
# software id = XXXX-XXXX
# model = XXX
# serial number = XXXXXXXXXXXX
/ip ipsec mode-config
set [ find default=yes ] name=request-only responder=no
/ip ipsec policy group
set [ find default=yes ] name=default
/ip ipsec profile
set [ find default=yes ] dh-group=xxx dpd-interval=xxx dpd-maximum-failures=xxx enc-algorithm=xxx hash-algorithm=xxx lifetime=xxx name=default nat-traversal=yes proposal-check=xxx
/ip ipsec peer
add disabled=no exchange-mode=ike2 local-address=192.0.2.1 name=Spokes passive=yes profile=default send-initial-contact=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=xxx disabled=no enc-algorithms=xxx lifetime=xxx name=default pfs-group=xxx
/ip ipsec identity
add auth-method=rsa-signature certificate=cert_HUB disabled=no generate-policy=port-override peer=Spokes
/ip ipsec policy
set 0 disabled=no dst-address=0.0.0.0/0 group=default proposal=default protocol=all src-address=0.0.0.0/0 template=yes
/ip ipsec settings
set xauth-use-radius=no
[oreggin@HUB] > ip ipsec policy print
Flags: T - template, X - disabled, D - dynamic, I - invalid, A - active, * - default
 0 T * group=default src-address=0.0.0.0/0 dst-address=0.0.0.0/0 protocol=all proposal=default template=yes
 1  DA  src-address=192.0.2.1/32 src-port=any dst-address=198.51.100.1/32 dst-port=any protocol=all action=encrypt level=unique ipsec-protocols=esp tunnel=no proposal=default ph2-count=1
[oreggin@HUB] >
Spoke1:
[oreggin@spoke1] > ip ipsec export
# may/20/2019 17:52:57 by RouterOS 6.44.3
# model = XXX
/ip ipsec profile
/ip ipsec peer
add address=192.0.2.1/32 disabled=no exchange-mode=ike2 name=HUB profile=default send-initial-contact=yes
/ip ipsec proposal
/ip ipsec identity
add auth-method=rsa-signature certificate=cert_Spoke1 disabled=no generate-policy=port-override match-by=certificate peer=HUB remote-certificate=cert_HUB
/ip ipsec policy
/ip ipsec settings
[oreggin@spoke1] > ip ipsec policy print
 1  DA  src-address=198.51.100.1/32 src-port=any dst-address=192.0.2.1/32 dst-port=any protocol=all action=encrypt level=unique ipsec-protocols=esp tunnel=no proposal=default ph2-count=1
[oreggin@spoke1] >
I hope you can find out why my setup works.
sindy
Mon May 20, 2019 11:48 pm
I cannot agree more :)
The answer is that it works because there really is this feature (which may be a brand new one or a repercussion of the past, I don't dare to even guess which one is correct - maybe the IPsec RFC even requires this behaviour) which creates a transport mode policy with protocol=all if those /ip ipsec identity rows at each peer which cause a successful establishment of phase 1 between the peers have generate-policy set to port-strict or port-override and there is no configured and enabled policy on any of the peers whose sa-dst-address would match the address of the remote peer, nor is mode-config=request-only set on any of the /ip ipsec identity rows involved.
So back to your issue - if you need to set up a tunnel encrypted using IPsec, NAT becomes an issue if transport mode is used and several remote peers share the same public IP from the perspective of the local peer. In these cases, you need to use a dirty trick which I have described here on the forum not longer than a month ago, so I may still be able to find that topic rather than describing it once again. It involves a statically configured policy on the spoke side with tunnel mode encapsulation, and also some NAT rules.
oreggin
Tue May 21, 2019 11:43 am
We have only one spoke behind every branch's ISP modem which are the NAT GWs, but spokes behind NAT with this configuration does not work.
There is no need any trick to supports more spoke behind the same NAT GW.
We need a trick to build tunnel mode (instead of transport mode) dynamic tunnels to works through NAT, if I'm right and it is possible.
BTW I made this config based on the L2TP "use-ipsec" mechanism ;)
oreggin
Tue May 21, 2019 4:31 pm
Now it comes into my mind I tried this HUB setup with cisco CPE and when it is connects to HUB it somehow generating tunnel mode policy but I can't figured out how did it do that :(
pe1chl
Tue May 21, 2019 5:01 pm
Cisco have their own protocol for that (DMVPN).
oreggin
Tue May 21, 2019 5:12 pm
Yes, high-end vendors has mGRE+NHRP based DMVPN which is good but not scalable above some thousands of tunnels and it is off topic over here.
sindy
Tue May 21, 2019 6:34 pm
No. If a single client is behind a NAT (or even behind several NATs in series), you don't need the tunnel mode of encapsulation - in fact, it makes the configuration simpler if you don't. Read the initial article of this topic, it explains why. So if it doesn't work the reason must be different. The L2TP/IPsec clients behind NAT work this way if you set use-ipsec=yes, the only difference to your setup, on top of the IKE type and authentication method, is that the policy at client side is not created by the IPsec stack itself but by the L2TP configiration handler, and if I remember right, it is restricted to UDP and ports 1701 at both ends. But that is not a difference which would affect the overall result.
So can you show me the /ip ipsec policy print and /ip ipsec policy print detail from the hub and the spoke behind NAT?
oreggin
Wed May 22, 2019 1:33 pm
Meanwhile I switched the cabelmodem to bridge mode for testing so now the spoke has public IP, but I will switch it back as cabelmodem in this mode has a reduced feature set.
Another thing I tried is a static policy on spoke with UDP:1701:1701 and tunnel mode, under identity "generate-policy=none", but unfortunately I must set the SRC to router source address in SRC option or at least the /8 or /4 subnet where that address is. On HUB dynamic policies generated with the same subnet and phase2 SAs address is my spoke's address. I don't know what will be happens if I sit this CPE back to behind NAT. BTW the configs now looks like:
HUB:
/ip ipsec identity
add auth-method=rsa-signature certificate=cert_HUB disabled=no generate-policy=port-strict peer=Spokes
/ip ipsec policy
set 0 disabled=no dst-address=0.0.0.0/0 group=default proposal=default protocol=udp src-address=192.0.2.1/32 template=yes
 0 T * group=default src-address=192.0.2.1/32 dst-address=0.0.0.0/0 protocol=udp proposal=default template=yes
 1  DA  src-address=192.0.2.1/32 src-port=1701 dst-address=198.0.0.0/8 dst-port=1701 protocol=udp action=encrypt level=unique ipsec-protocols=esp tunnel=yes sa-src-address=192.0.2.1
       sa-dst-address=198.51.100.1 proposal=default ph2-count=1
Spoke1:
/ip ipsec identity
add auth-method=rsa-signature certificate=cert_Spoke1 disabled=no generate-policy=no match-by=certificate peer=HUB remote-certificate=cert_HUB
/ip ipsec policy
set 0 disabled=yes dst-address=0.0.0.0/0 group=default proposal=default protocol=all src-address=0.0.0.0/0 template=yes
add action=encrypt disabled=no dst-address=192.0.2.1/32 dst-port=1701 ipsec-protocols=esp level=require proposal=default protocol=udp sa-dst-address=192.0.2.1 sa-src-address=0.0.0.0 \
    src-address=198.0.0.0/8 src-port=1701 tunnel=yes
 0 TX* group=default src-address=0.0.0.0/0 dst-address=0.0.0.0/0 protocol=all proposal=default template=yes
 1  A  src-address=198.0.0.0/8 src-port=1701 dst-address=192.0.2.1/32 dst-port=1701 protocol=udp action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=0.0.0.0
       sa-dst-address=192.0.2.1 proposal=default ph2-count=1
If two Spoke hase a near IPv4 address then I must set different SRC in policy on Spokes otherwise only one spoke can connect.
sindy
Wed May 22, 2019 2:12 pm
unfortunately I must set the SRC to router source address in SRC option or at least the /8 or /4 subnet where that address is, but in that case, only one of the spokes works at a time
Of course, because a mirror of each spoke's policy is created at hub side, so if the src-address of two spokes is the same, you end up with two policies with identical traffic selectors on hub side.
So when you use transport mode of encapsulation, the src-address of the policy is the same as its sa-src-address, and changes along the path with it. So it is the one assigned by the ISP modem at the spoke side, but silently changes into the public address of the ISP modem as it reaches the hub. So you'll see the policies not to mirror each other but nevertheless interwork properly.
When you use tunnel mode for encapsulation, you have to assign, to each of the spokes which uses tunnel mode, a unique private address and use it as src-address for the policy (and take measures that the L2TP packets would be sent from this address - the easiest way is to use an chain=srcnat action=srcnat protocol=udp src-port=1701 dst-port=1701 dst-address=the.public.ip.of.the.hub to-addresses=the.unique.private.ip rule as the first rule in /ip firewall nat). This way, the dst-address of policies at hub side will not end up with conflicting traffic selectors, and these unique addresses will be static ones so they won't depend on dynamically changing public IPs of the ISP modems. That address doesn't even need to be assigned to any interface on the spoke, the src-nat rule will do everything necessary.
Off topic, what is your native language if I may ask?
oreggin
Wed May 22, 2019 3:05 pm
Sure, my native lang is hungarian. I hope my english is not too wrong and you understand what I'd like to say. BTW we using worse, strange, mixed language in business that you shouldn't see/hear :-D
sindy
Wed May 22, 2019 3:36 pm
English is not my native language either so I'm not the one to judge on the "too wrong" part; I also believe that I've understood everything properly so far. I've asked only because I have noticed some minor inditia that English is not your first language but they didn't match any of the "national versions" of English I can recognize :-)
Rok1215
Fri Aug 23, 2019 11:38 am
I've been having a similar problem, with a remote VPN connection and a IP Phone connected on the same remote network, when the vpn connection is active, it drops the phone connection.
So I was recommended this topic, to solve my problem, and it seems like a solution. This is a lot more technical for me, than I am used so, so I apologize in advance for any stupid questions.
So I tried to follow your instructions, and from what I've read in this topic, the only thing that I would need to change is the "1.2.3.4", with my public IP?
And the first problem I ran into while trying to configure this, is with the line:
"add chain=input src-address=127.0.0.0/8 dst-address=127.0.0.0/8 action=accept place-before=right after the "accept established,related" rule
At place-before=right after the "accept established,related" rule" it gives me a syntax error, and I'm not sure if I'm supposed to change anything in this line?
sindy
Fri Aug 23, 2019 3:24 pm
At place-before=right after the "accept established,related" rule it gives me a syntax error, and I'm not sure if I'm supposed to change anything in this line?
Sure you are. The whole text right after the "accept established,related" rule has to be replaced with a rule number; however, you have to know that the numbers are generated dynamically in each management window. So you cannot look at the firewall rule listing in WinBox or WebFig and use the rule numbers shown there; instead, in the same command line window where you'll be entering the rule above, do first /ip firewall filter print chain=input. You'll get a listing of all rules in chain input; it is likely (but not guaranteed) that the rule saying action=accept ... connection-state=established,related... will be numbered as 0 in the leftmost column; in such case, you'll set place-before=1 in the rule you will enter. Unfortunately there is only place-before, not place-after, and the number substitutes a reference so you cannot determine a rule using [find chain=input action=accept connection-state~"established"] and then add 1 to the resulting number because the result of find is a reference, not a number.
If the configuration of your machine comes from some very old ROS version, it is possible that your firewall looks different. So if you cannot find a rule action=accept ... connection-state=established,related... in chain input of your /ip firewall filter, follow the hint in my automatic signature below.
pe1chl
Fri Aug 23, 2019 3:53 pm
Normally when trying to get people to add some rule at a specific place I just give them the rule as commandline without any placement reference, it will be added at the end of the list, and then direct them to move it up using the GUI (either winbox or webfig)...
thaideval
Fri Aug 23, 2019 5:32 pm
Is it still a thing? i mean if i have l2tp/ipsec vpn and i want to connect roadwarriors - i still have to do all this?.. well u did a hell of a job. respect for that.
But i honestly thought this bug would be fixed ..
btw what vpn u will advice for roadwarriors on mikrotik?
i can imagine its not l2tp/ipsec.. is it pure ipsec?
sindy
Fri Aug 23, 2019 10:05 pm
Only if you need several road warriors connected from the same LAN at the same time, which often means that the sessions come to the server from the same public address.
But i honestly thought this bug would be fixed ...
It is not a bug of RouterOS, it is a design choice of the gentlemen who have defined L2TP over IPsec.
If you don't mind the need to install a machine certificate on the Windows, it's definitely IKEv2, which is pure IPsec and doesn't suffer from the issue this topic deals with.
Plus it is currently the only VPN type for which Mikrotik can push routes to the Windows client, so you neither have to send all the client's traffic via the VPN nor you have to configure routes towards the VPN subnets manually on the client, because starting from 6.44, RouterOS responds to DHCPINFORM with a DHCPACK carrying an Option 249 which carries a route list generated from the split-include item in the /ip ipsec mode-config row referred to from the ip ipsec identity row.
thaideval
Sat Aug 24, 2019 5:00 pm
Thank you very much, man!
I will now try to setup ipsec/ikev2. I will try eap-radius (dont wonna struggle with client certificates).
Rok1215
Thu Aug 29, 2019 10:42 am
Thank you for your help, it was as you stated, and everything went as planned, and I got no other syntax errors, and I see the VPN connections go trough the IP tunnels now.
But it seems like this isn't a solution for my problem. If I understand correctly, this is a solution if you have 2 L2TP/IPsec connections from the same network, that connect to the same public ip. But in my case I have 1 VPN connection, and a VoIP telephone connection, and I am not sure what kind of encryption protocol it uses. So this is a standard Samsung IP Telephone, that just connects to our office public IP, and then goes to our MikroTik router and then to our OfficeServ phone server that uses the g.729a codec. For this to work, the following ports are opened and set for this on the router:
-6000 UDP = IP data SIP connection, -9000 UDP = IP connection setup, -30000-30030 UDP = IP channels.
Is there any way for the router to distinguish between the VPN connection and the VoIP connection? Because right now, it will always prioritize the VPN connection, and the phone disconnects when you connect trough the VPN, and then reconnects when the VPN connection is turned off.
sindy
Thu Aug 29, 2019 11:22 am
Not exactly but maybe it's just wrong wording. There is no problem if multiple clients connect to the same server (listening at a public IP); the problem which my setup overcomes is that the server receives both the clients' connections from the same IP address because both clients are behind the same NAT.
Words "standard", "usual", "normal", "typical" bear no useful information :)
If I get you right, the VoIP phone doesn't need the VPN to work, but once you start the VPN, the phone stops working. This suggests that the phone is connected to the LAN of the VPN client router and while the VPN is down, it connects to the public IP address of Mikrotik in the office directly; when the VPN connects, routing on the client Mikrotik changes accordingly and the packets from the VoIP phone start getting to the office via some other path or stop getting there at all.
So open a separate topic for this, and start from a drawing which removes any doubts regarding the interconnections and eventual NATs and port forwardings between the phone and the client router and also between the office router and the call server there.
oreggin
Fri Aug 30, 2019 2:54 pm
Meanwhile I tested a script for update ipsec policy behind NAT:
:global uplinkif "ether1"
:global poladdr [ /ip ipsec policy get [ find peer=HUB ] src-address ]
:global polip [:pick $poladdr 0 [:find $poladdr "/"]]
:global intaddr [ /ip address get [ find interface=$uplinkif and dynamic ] address ]
:global intip [:pick $intaddr 0 [:find $intaddr "/"]]
:if ($intip != $polip) do={
	:log info ("IPSec policy update...")
	/ip ipsec policy set [ find peer=HUB ] src-address="$ipinterf/32"
Router run this in every 5 minutes, and check.
Another issue what I faced for is the NAT in cabelmodem. Sometimes the translation entry stucked in and IPSecSA-s can't get established so I need to disable ipsec peer for some seconds and then reenable:
:global state [ /ip ipsec active-peers get [ find remote-address=1.2.3.4 ] state ]
:global phc [ /ip ipsec policy get [ find peer=HUB ] ph2-count ]
:if ($state != "established") do={
	/ip ipsec peer disable [ find name=HUB ]
	:delay 62
	/ip ipsec peer enable [ find name=HUB ]
} else={
	:if ($phc < 1) do={
		:delay 62
I assume that UDP translation timeout in camblemodem NAT implementation is 30sec, so I doubled it plus increased by 2 so I get 62. This is a rare situation and I survive 62+some seconds without VPN.
jaytcsd
Mon Sep 16, 2019 11:52 pm
Very informative, I just skimmed over it and will dive into it later today.
I had L2TP IPSEC working in 2011 under 5.4 but as the OS was updated I kept having to chase the changes to make it work, finally I gave up.
Dutchman
Wed May 20, 2020 1:51 pm
Hi Sindy,
Will this solution work if there is more than just 2 Road Warriors L2TP/IPsec clients behind NAT?
I have about 10 on a site and they use one central fibre line to connect to our main VPN server and from what I pick up is that it works as it gives one of the devices a Caller ID in the 10.0.0.0/20 range but the others still seem get the same public address and then reconnect after a bit.
Thanks!
sindy
Wed May 20, 2020 2:55 pm
That's the very purpose of this solution.
I don't understand from your description what the actual problem is. All L2TP clients' connections arrive to the Mikrotik with the same public source IP, that's correct. The solution depends, however, on the fact that the client-side NAT should assign a different UDP port at its WAN side to each of these connections, which is what NATs normally do, otherwise they would be unable to map incoming packets from the same remote server address and port to the proper pinhole (connection).
The whole solution is based on incrementing the internal src-nat address for each new connection. So post the export of your current configuration, and also the output of /ip firewall connection print detail where dst-address~"500\$" while multiple clients are attempting to connect.
Also bear in mind that the solution has been created at ROS 6.43 times, so it may be not only a mistake in configuration but something may have changed slightly.
Users browsing this forum: bastys, cruzo, pe1chl, sindy, topbanana, xvo and 46 guests
