blackzero
I want my Mikrotik to use external DNS but with non-standard Port 53
Mon Apr 09, 2018 7:06 am
My Mikrotik can't use other IP Addresses than my ISP's on IP->DNS setting.
Basically outgoing port 53 is blocked TCP/UDP by my ISP. I'm forced to use theirs. I want to use Google / Cloudflare's DNS 8.8.8.8/1.1.1.1
On Windows, I can use DNSCrypt, but that's not the case. I'm sure Mikrotik can use other non-standard port so it can resolve properly? How to do that?
squeeze
Re: I want my Mikrotik to use external DNS but with non-standard Port 53
Mon Apr 09, 2018 9:20 am
Nevermind.
BartoszP
Mon Apr 09, 2018 10:46 am
What about DST-NAT rule which changes router's DNS queries from ISP_IP:53 to NEW_IP:OTHERDNSPORT ?
Real admins use real keyboards.
poizzon
Mon Apr 09, 2018 1:53 pm
add action=dst-nat chain=dstnat dst-port=53 protocol=udp to-addresses=208.67.222.222 to-ports=5353
add action=dst-nat chain=dstnat dst-port=53 protocol=udp to-addresses=208.67.220.220 to-ports=5353
add action=dst-nat chain=dstnat dst-port=53 protocol=tcp to-addresses=208.67.222.222 to-ports=5353
add action=dst-nat chain=dstnat dst-port=53 protocol=tcp to-addresses=208.67.220.220 to-ports=5353
OpenDNS example
poi
mkx
Mon Apr 09, 2018 2:04 pm
OpenDNS example
Is there any benefit in having two dst-nat rules for same connection criteria? If here applies same principle as with firewall filters, then the second rule (the one with to-address=208.67.220.220) will never be used? Or are these rules used in round-robin fashion?
BR,
Metod
BartoszP
Mon Apr 09, 2018 3:09 pm
The first one will cacth all DNS queries but you can add src-address to pass queries to different DNS servers.
E.g. all traffic from LAN devices could be sent to OpenDNS, queries originating from router itself could be send to the second DNS server ... etc.
mkx
Mon Apr 09, 2018 3:16 pm
@BartoszP ... but in that case, those NAT rules would not be exactly as shown. There would be some other criteria involved, such as src-address-list or something similar. My question was about the exact rules as posted by @poizzon.
And constructing rules as per your suggestion: if "first-rule-match" principle applies here, one would have to be very careful about proper order of rules, e.g. place more specific first and more general later.
BR,
Metod
BartoszP
Mon Apr 09, 2018 3:19 pm
The first one catches all for UDP traffic to port 53 and the third one all for TCP queries to port 53
mkx
Mon Apr 09, 2018 3:29 pm
Exactly.
So why would one put also 2nd and 4th rule as they are?
My guess is that they are simply misleading (or redundant at best), but I may well be wrong and there might be somebody who knows it better.
BR,
Metod
BartoszP
Mon Apr 09, 2018 4:06 pm
IMHO they are dummy rules as 1st and 3rd will catch all traffic.
anav
Mon Apr 09, 2018 6:03 pm
To funny mkx, you are asking BARTOZ about rules somebody else (poizzon) posted.
It seems clear that piozzon was just listing the two often cited/recommended addresses for OPEN DNS.
In case the first one was not available the traffic could be sent to the second is I suppose the thinking.
The right question is......... if the first DNS query rule does not work because the OPEN DNS adddress is not functional will the router still pass the traffic using the second rule (address)????
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Sob
Mon Apr 09, 2018 6:29 pm
No, it won't. Dstnat only changes destination address, router has no way how to monitor if server responded or not (well, maybe some hack would be possible).
But if poizzon's config would be changed from to-addresses=208.67.222.22x to dst-address=208.67.222.22x, and two 208.67.222.22x would be configured on client as resolvers, then the failover would work.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
Sob
Tue Apr 10, 2018 7:14 pm
Hey, I swear there was a new post here just now and it dissapeared before I finished the reply...
Anyway, what I meant was:
add action=dst-nat chain=dstnat dst-port=53 protocol=udp dst-address=208.67.222.222 to-ports=5353
add action=dst-nat chain=dstnat dst-port=53 protocol=udp dst-address=208.67.220.220 to-ports=5353
add action=dst-nat chain=dstnat dst-port=53 protocol=tcp dst-address=208.67.222.222 to-ports=5353
add action=dst-nat chain=dstnat dst-port=53 protocol=tcp dst-address=208.67.220.220 to-ports=5353
So only requests to specified servers will get destination port changed from 53 to 5353.
What I don't like is that router will be left out (not just with this, but anything you can currently do), it won't be able to use these resolvers and you can't use it as cache. It could be done, but unlike Linux, RouterOS doesn't support dstnat in output chain.
Users browsing this forum: johnnie502 and 40 guests
