strods
Winbox 3.13 released!
Tue Apr 10, 2018 12:12 pm
What's new in v3.13:
*) abandoned support for connecting to older RouterOS versions (older than v6), no DLLs will ever be downloaded;
*) winbox.exe is now signed executable;
If you experience version related issues, then please report them to support@mikrotik.com.
Winbox is available here:
http://www.mikrotik.com/download
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
Chupaka
Re: Winbox 3.13 released!
Tue Apr 10, 2018 12:28 pm
If you click on saved router entry in list, focus still jumps to Password field, so mouse scrolling doesn't work :(
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
squeeze
Tue Apr 10, 2018 1:20 pm
Thank you.
dtoffo
Trainer
Trainer
Tue Apr 10, 2018 1:36 pm
+1 for older focusing scheme: from 3.12 it's unusable
ErfanDL
Tue Apr 10, 2018 1:59 pm
WOW big changes!!! [emoji23] adding night mode to winbox
Sent from my C6833 using Tapatalk
strods
Tue Apr 10, 2018 2:50 pm
Have you contacted support regarding the scrolling issue? Do I guess correctly that you use laptop and touchpad? Does the same problem persist if you use mouse?
andriys
Tue Apr 10, 2018 3:25 pm
I, personally, find focus jumping to the Password field very handy.
Also I've just checked, scrolling works for me just fine with both mouse scroll-wheel and two-finger scrolling on touchpad no matter what field has focus (Windows 10 pro).
Melbar
Tue Apr 10, 2018 4:40 pm
Also this version does not work for me. Error message in the event log:
Exception code: 0xc0000005
Error offset: 0x0001fa55
ID of the failed process: 0x3924
EventType=APPCRASH
EventTime=131678397830824664
ReportType=2
Consent=1
UploadTime=131678397838832880
ReportStatus=268435456
ReportIdentifier=380addb9-b5b4-4b20-8005-d8bf77c67140
IntegratorReportIdentifier=fb85217e-a0bd-449f-b115-9be832955db0
Wow64Host=34404
Wow64Guest=332
NsAppName=winbox3.13.exe
AppSessionGuid=00003884-0007-002a-e627-820bced0d301
TargetAppId=W:0006aa496f71e491f3063a5e75198cf6af8c0000ffff!00005d97cafd31963ab6360c9b056f6ba26b825a4a2f!winbox3.13.exe
TargetAppVer=1999//11//14:22:30:45!190b1d!winbox3.13.exe
BootId=4294967295
ServiceSplit=110
TargetAsId=4244
Response.BucketId=3258da2c08c67cf811d7757ba9cacc12
Response.BucketTable=1
Response.LegacyBucketId=1285625392627633170
Response.type=4
Sig[0].Name=Anwendungsname
Sig[0].Value=winbox3.13.exe
Sig[1].Name=Anwendungsversion
Sig[1].Value=0.0.0.0
Sig[2].Name=Anwendungszeitstempel
Sig[2].Value=382f3815
Sig[3].Name=Fehlermodulname
Sig[3].Value=winbox3.13.exe
Sig[4].Name=Fehlermodulversion
Sig[4].Value=0.0.0.0
Sig[5].Name=Fehlermodulzeitstempel
Sig[5].Value=382f3815
Sig[6].Name=Ausnahmecode
Sig[6].Value=c0000005
Sig[7].Name=Ausnahmeoffset
Sig[7].Value=0001fa55
The operating system is Windows 10, CPU / hardware is AMD Phenom2 X6, 8Gb RAM ...
k6ccc
Forum Veteran
Forum Veteran
Tue Apr 10, 2018 5:45 pm
At least you can save entries. Both 3.12 and 3.13 allow me to save entries, but next time WinBox is opened, none of the saved entries are there.
RB4011iGS+, RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Warning: I know enough to be dangerous...
Jim
Chupaka
Tue Apr 10, 2018 6:15 pm
Nope, this 'cosmetic' bug was mentioned many times in 3.12 topic :)
It's on PC and mouse. In Windows 10, the problem appears with disabled "Settings -> Devices -> Mouse -> Scroll inactive windows when I hover over them".
Chupaka
Tue Apr 10, 2018 6:17 pm
Sorry, works fine for me both on Windows and MacOS.
What if you play with File -> New... / Open...?
k6ccc
Forum Veteran
Forum Veteran
Tue Apr 10, 2018 6:45 pm
Interesting, I have never needed to do that before. With that said, your suggestion worked, but needs a little explanation. Quite some while ago I had set a Master Password in WinBox on this computer. For my purposes, l that did not really serve any useful purpose as it makes no difference if I need to type the master password or the individual for the router I'm connecting to - I'm still typing one password. So I wiped out the Master Password. Just a couple minutes ago I typed in the connection information for my three routers and added each one, and then saved from Menu > File > New, then exited WinBox and re-opened it. The three saved routers were listed and the Master password box was grayed out and said "Set Master Password". So what I suspect was that WinBox still was operating under the belief that there was a Master Password - however nothing would work as a password because I had eliminated the Master Password. Apparently saving actually convinced WinBox that I was no longer using a Master Password.
So, Thank you.
Jim
deathandtaxes
Tue Apr 10, 2018 9:53 pm
3.12 thread is here:
viewtopic.php?f=21&t=130319
The issue for me is that the focus jump to password field breaks arrow key and pageup/pagedn of the managed list. This is very annoying for me when I have dozens of managed hosts.
freemannnn
Long time Member
Long time Member
Tue Apr 10, 2018 10:49 pm
same for me. focus jump to password field. mikrotik please fix it.
GuillermoHA
Tue Apr 10, 2018 11:27 pm
Great work ^^
It would be interesting if some day winbox would allow to save "a default view" with the customized configuration of columns, fields, views, etc ... and each time you enter a new routerOS imports automatically your personal "saved" configuration. You could add export / import between winboxes or restart to defaults.. but any time you connect to a routerOS see the same firewall view.
strods
Wed Apr 11, 2018 7:16 am
Melbar - When do you see this error? I recommend that you contact support@mikrotik.com and explain step-by-step how you reproduce such problem. We will try to resolve it as soon as possible.
k6ccc - Do you run Winbox with administrator permissions?
Chupaka, deathandtaxes - This problem does not affect everyone. Please contact support@mikrotik.com and provide more information (video would be the best option). Focus goes to connect form for purpose.
GuillermoHA - Not everything, but you can already save layouts, etc. by using sessions on Winbox loader.
k6ccc
Forum Veteran
Forum Veteran
Wed Apr 11, 2018 8:22 am
The computer I was having the issue on is running Windows XP and yes, the normal account that is used on that computer has admin.
Jim
Chupaka
Wed Apr 11, 2018 11:26 am
Okay, as it was mentioned earlier, just launch WinBox, click on the list of saved routers and try to use arrow keys to select necessary router.
Moreover, don't even try to use mouse cursor, just launch WinBox, press Shift+Tab twice (to select the list) and try to select any router in the list by using only your keyboard :) Focus just moves to Password field, so it's impossible to use only keyboard in that window.
freemannnn
Long time Member
Long time Member
Wed Apr 11, 2018 11:59 am
i have a support ticket about this...
Ticket#2018020922004376
please fix winbox to save tab positions in romon neighbours and neighbours.
> *i have to resize them everytime i connect to a romon device.*
> also scrolling up-down with mouse wheel when many addresses saveed is not
> impossible in 6.12. it was possible with 6.11.
strods
Wed Apr 11, 2018 12:13 pm
Chupaka - As mentioned before - "Focus goes to connect form for purpose". As for scrolling with the mouse/trackpad within managed routers list - we can not reproduce such problem locally.
andriys
Wed Apr 11, 2018 12:17 pm
As Chupaka mentioned above
freemannnn
Long time Member
Long time Member
Wed Apr 11, 2018 12:26 pm
it would be nice if someone from support would like to connect with teamviewer or anydesk to my windows 7 pc or my windows 10 pc to check it.
this happens also in windows 7.
Chupaka
Wed Apr 11, 2018 12:30 pm
You'd probably add an option to [not] move the focus for people who want to use only keyboard on WinBox login. Because your 'purpose' makes some probabilities useless, so you'd better forbid the list to catch focus at all :)
normis
Wed Apr 11, 2018 12:35 pm
This reminds me of https://xkcd.com/1172/
Previously, lots of people requested the focus to go to password, so that clicking on an entry would give you possibility to write password right away. I never imagined that you use keyboard in that list, sorry about that.
freemannnn
Long time Member
Long time Member
Wed Apr 11, 2018 12:37 pm
strods please also...
fix winbox to save columns width in romon neighbours and neighbours tab.
take a look at image
https://www.dropbox.com/s/ujui1slax3uqk ... e.JPG?dl=0
strods
Wed Apr 11, 2018 12:40 pm
Yes, this behavior of focus is the best solution for most of the users.
Guys, please remember - this is an user forum. If you have a bug - report it to support@mikrotik.com. If we can not reproduce problem from your forum post, then support ticket is necessary.
In this case, we can not reproduce issue with scrolling locally. We have seen it once, but in that case problem was only with touchpad and worked just fine with mouse.
Chupaka
Wed Apr 11, 2018 1:10 pm
https://www.thestar.com/news/insight/20 ... rages.html
Don't do something for most of the users, make it customisable so all users can use it the way they like ;)
It's obvious that if "Scroll inactive windows when I hover over them" is disabled, then scrolling will scroll an element having focus, not the list hovered by the cursor (just because one cannot scroll two windows simultaneously).
bajodel
Long time Member
Long time Member
Wed Apr 11, 2018 3:24 pm
+ 1000 .. I'm with Chupaka, winbox now always needs lot of weirds mouse interventions ..not good for me
R1CH
Forum Veteran
Forum Veteran
Fri Apr 13, 2018 12:52 am
Still no signature checking or HTTPS... man in the middle can easily compromise administrator's PC.
https://i.imgur.com/TX7G9pq.gifv
squeeze
Fri Apr 13, 2018 3:34 am
I was wondering what you meant. I did a Wireshark http monitor after pressing Check for Updates in Winbox:
GET /routeros/winbox/LATEST.3 HTTP/1.1
HTTP/1.1 200 OK (application/octet-stream)
GET /routeros/winbox/3.13/CHANGELOG HTTP/1.1
So, you're right, that could be improved.
manuzoli
Sun Apr 15, 2018 9:55 pm
Anyone already created a working bundle for Linux or MacOS?
Chupaka
Sun Apr 15, 2018 11:46 pm
A bundle?.. I simply installed Wine in Mac OS - and Winbox.exe runs just perfect
normis
Mon Apr 16, 2018 8:41 am
Caci99
Mon Apr 16, 2018 8:05 pm
Moving the focus on the password field while you're browsing the managed list does not make sense to me.
The purpose of having the managed list is to save the credentials of your own routers along with their addresses, so moving to the password to insert the password does not make sense, I already have it saved.
-Toni-
Don't crash the ambulance, whatever you do
Chupaka
Mon Apr 16, 2018 8:44 pm
Follow these simple steps exactly:
https://wiki.mikrotik.com/wiki/Manual:Winbox#Homebrew
By the way, with XQuartz 2.7.11 font smoothing does not work, I had to downgrade to 2.7.9 to fix it - you should probably mention it in Wiki.
honzam
Wed Apr 18, 2018 4:46 pm
How to connect with winbox 3.13 to client with ROS 5.26 ?
ERROR: RouterOS version does not support this winbox, please upgrade.
Client is rb133c. It is not possilble upgrade ROS. I think with winbox 3.12 it works
LAN, FTTx, Wireless. ISP operator
Chupaka
Wed Apr 18, 2018 4:53 pm
*) abandoned support for connecting to older RouterOS versions (older than v6);
5.26 is technically younger that v6.0, but v5 is still older than v6 :)
honzam
Wed Apr 18, 2018 5:55 pm
It is true :) But how to connect to ROS 5.26 now? Winbox 3.12 is not on download page. Winbox 2.2.18 is also not on web page.
I don´t like unofficial links to winbox 2.2.18
Chupaka
Wed Apr 18, 2018 6:05 pm
Use link to 3.13, just edit it to point to necessary version :)
https://download.mikrotik.com/routeros/ ... winbox.exe
etc
manuzoli
Thu Apr 19, 2018 8:50 am
Thats the reason why I don‘t like this emulation things. And they are compareable slow
honzam
Thu Apr 19, 2018 10:52 am
Thanks for link. This is the only way how to connect to clients with rb133 and others clients with ROS 5.26
normis
Thu Apr 19, 2018 10:58 am
Remember that if you want to keep these old devices, you must have a really good firewall on them, since there are serious vulnerabiltities affecting your PC and other people networks. I know they can't be upgraded, so at least use a good firewall and follow the practices here: https://wiki.mikrotik.com/wiki/Manual:S ... our_Router
Chupaka
Thu Apr 19, 2018 11:59 am
I'm not sure if it's completely about emulation :)
And... What do you do with WinBox so it's slow for you? %)
P.S. At least Warcraft 3 many years ago was running smoothly both in Windows and Wine, but under Wine it started much quicker.
manuzoli
Sat Apr 21, 2018 12:34 pm
Startup is slow. Once it runs its ok but uses way more memory then it should
rushlife
Tue Apr 24, 2018 11:09 am
still no shortcuts ?
neu
Thu Apr 26, 2018 12:27 pm
New version is really nice.
neuCRM (http://neucrm.com) is full featured ISP Billing CRM software package for Mikrotik RouterOS.
gcs
Sun Apr 29, 2018 7:25 pm
How do you connect by Mac address in winbox 3.13? it only shows address and there is not the ... that older version had by the connect to box to search by mac address if you did not know the address.
Pea
Sun Apr 29, 2018 10:11 pm
Click on Neighbors card and then simply click on MAC address (or IP address) of the device you want to connect to...
Simono
Thu May 03, 2018 12:21 am
Now F-Secure show me "PotentiallyUnwanted:W32/App.[variant]!Online " for winbox 3.13 :shock:
ziegenberg
Fri May 04, 2018 12:36 pm
Yupp. Mine got delete automatically. And downloading winbox again makes F-Secure suspiciously looking at the file "What's that?!?" and it deletes it again.
BartoszP
Fri May 04, 2018 1:55 pm
So what do you expect from Mikrotik? Antivirus patterns are dynamic ... today Winbox is "suspected" and tommorow will be "good".
Real admins use real keyboards.
To quote or not to quote, there is the topic: viewtopic.php?f=2&t=168474
pe1chl
Fri May 04, 2018 2:17 pm
You need to report it to F-Secure instead. They are responsible for this.
Spidlacz
Wed May 16, 2018 3:40 pm
Why does Winbox look for neighbors when running with parameters and directly connecting to a device? There is always a delay of about 2 seconds.
tippenring
Wed May 16, 2018 4:17 pm
Great work ^^
It does on Windows. It's the session profile. I have all my windows, columns, etc set in my session profile, and have that session profile set for all 100 or so of my Mikrotik devices. I redirect my Mikrotik settings and address list to my google drive and everything syncs between my various computers without issue. It works perfectly.
tippenring
Wed May 16, 2018 4:23 pm
Wow. Although relatively low risk, I can't think of a reason for not verifying the cert but laziness. Good thing I don't upgrade from Winbox I guess.
pe1chl
Wed May 16, 2018 5:34 pm
Is it possible to share a single session profile for all different devices even when you have many windows open to different devices at the same time?
How does that behave when you change something in the views?
Chupaka
Wed May 16, 2018 6:51 pm
The last one closed wins? :) Anyway, synchronization and race condition is out of topic. Like "What should happen if you do two opposite changes in two simultaneously opened windows?"
macsrwe
Forum Veteran
Forum Veteran
Wed May 16, 2018 7:44 pm
If you keep the "Autosave Sessions" box unchecked, each router will open with the stock session layout, and any changes you make to windows for each individual router as you work will not affect your saved layout. If you ever do want to change the saved layout, just use "Save" in the File menu in the router window.
pe1chl
Wed May 16, 2018 8:37 pm
I'll have to give it a try to see how it works out... in my experience, layouts are sometimes even lost when doing updates of RouterOS
(when a column is added to some list everything falls back to defaults) so it is to be tried how well this works in a network mixed
of bugfix/stable/testing versions. But other than that, I really hate to have to setup all the views for every new router.
(e.g. delete all those pesky FP columns that are completely useless because I always disable fastpath and fasttrack)
macsrwe
Forum Veteran
Forum Veteran
Wed May 16, 2018 8:43 pm
I operate Winbox in this manner daily. I keep one session file for each *type* of router (CPE, edge, AP, station, relay) and save one of those session names in the entry for each router in the list. A have a couple routers with custom layouts all their own, but very few. It works very well for me.
strods
Mon May 28, 2018 11:13 am
Winbox v3.14 has been released:
viewtopic.php?f=21&t=134940
Users browsing this forum: Bing [Bot] and 11 guests
