MUM Europe 2020
Olexandr999
After updating to 6.41.3, the signal strenght has been lowered.
Wed Apr 11, 2018 9:23 am
After updating AP (921GS-5HPacD r2) to 6.41.3, the signal strenght has been lowered in some clients (in 6.38 and 6.34 everything was okay).
Clients - SXT 5nD r2(6.38) and SXT Lite 5(6.38). Someone encountered this problem?
mbfound
Re: After updating to 6.41.3, the signal strenght has been lowered.
Wed Apr 11, 2018 12:34 pm
Did you check if there wasn't a country regulation update since 6.38? If you're not running superchannel :lol:
Olexandr999
Wed Apr 11, 2018 1:08 pm
I using superchannel.
n21roadie
Wed Apr 11, 2018 3:57 pm
How much lower?
Olexandr999
Wed Apr 11, 2018 4:44 pm
How much lower?
before the update
after the update
n21roadie
Wed Apr 11, 2018 9:14 pm
Wow - there is a big difference in signal levels between those versions ?
mbfound
Wed Apr 11, 2018 11:17 pm
Can you downgrade to bugfix or is there something you need to use on 6.41? I'll upgrade a link tomorrow to 6.41.4 and see what happens.
Here is 6.40.4 so long....
Olexandr999
Thu Apr 12, 2018 8:47 am
Yes
Olexandr999
Thu Apr 12, 2018 9:13 am
I downgrade AP to (6.40.7 bug fix), there was no change. 6.41.4 - Analogous.
Olexandr999
Thu Apr 12, 2018 9:39 am
Another client (frimware AP - 6.40.7 and 6.34.5). TХ from AP has decreased.
mbfound
Thu Apr 12, 2018 10:18 am
Upgraded to 6.41.4 and then downgraded to 6.34.6. No change at all. (Dynadish AR9888 chipset)
Might have to do with specific settings you have or maybe the chipset in the AP/Station. Can you post more info?
Olexandr999
Thu Apr 12, 2018 11:14 am
AP - RB 921GS-5HPacD r2 (AR9888 chipset), Client SXT Lite5(AR9300 chipset)
Setting absolutely not changed either before or after the firmware.
What information in the settings can be helpful?
Settings and equipment are typical for all. This bug occurs only in some.
mbfound
Thu Apr 12, 2018 2:38 pm
I have the same sector + sxt client, might downgrade it tonight as see what happens. Just had to switch to Nv2 and new freq, so don't wanna piss them off any more than what I have. :lol:
If it only happens on some clients, maybe open a ticket with Mikrotik and send them a Supout of the affected clients?
Olexandr999
Thu Apr 12, 2018 3:08 pm
Let's try and please downgrade to 6.34. If this is a bug in the firmware, I think that they fix it, but I would like to know if this problem is in my links or not only.
n21roadie
Thu Apr 12, 2018 10:48 pm
Yes
You appear to running Nstreme have you tried NV2 and check if you also have reduced signal level.
mbfound
Fri Apr 13, 2018 1:13 am
OK results as follows:
SXT 6.41 + Sector 6.40.6
SXT 6.34.6 + Sector 6.36.4 (came out with 6.35 so didn't want to downgrade too far and potentially break anything)
My settings:
Sector:
/interface wireless
set [ find default-name=wlan1 ] country="south africa" default-forwarding=no \
disabled=no frequency=5825 frequency-mode=superchannel mode=ap-bridge \
radio-name="xxx" ssid=zzz wireless-protocol=nv2 \
wps-mode=disabled
SXT:
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=client-mode band=\
5ghz-a/n country="south africa" disabled=no proprietary-extensions=\
pre-2.9.25 radio-name="xxx" ssid=zzz
Excuse the bad CCQ, still trying to find good frequency.....
TomjNorthIdaho
Fri Apr 13, 2018 2:04 am
Something to consider .....
After updating , are the wireless connection rates faster ?
Reason why I ask , Faster connection rates always have less TX power and lower receive sensivity.
Thus as connection rates increase, the signal strength decreases.
In your enviornment , after your upgrade , are you now getting better/faster throughput ? If so , then it could be partialy due to faster wireless conection rates - which then may look like a weaker signal.
FYI - An initail 6 Meg wireless connection could drop 15 db after the connection rate instreases to 54 Meg or 150 Meg or faster rates.
North Idaho Tom Jones
Olexandr999
Fri Apr 13, 2018 8:51 am
My settings:
Sector:
/interface wireless
wps-mode=disabled
SXT:
/interface wireless
OK, thank you for trying.
Olexandr999
Fri Apr 13, 2018 8:53 am
Yes
That at nstrem that at nv2 - levels are identical.
Olexandr999
Fri Apr 13, 2018 8:57 am
it's all right, but MCS have not changed. Therefore, this statement is not true in this case.
Users browsing this forum: Bing [Bot] and 27 guests
