schadom
CCR - Mikrotik Bridge usage with multiple Vlans
Thu Apr 12, 2018 12:47 am
I'm wondering about the new bridge implementation since 6.40.x. Is it recommended to have a single or multiple bridges when a bunch of tagged vlans should be bridged to different ether ports? For example, let's assume we have three physical ether ports (and no switch-chip) and three tagged vlans;
Vlans:
/interface vlan
add interface=ether1 name=ether1-vlan100 vlan-id=100
add interface=ether1 name=ether1-vlan200 vlan-id=200
add interface=ether2 name=ether2-vlan200 vlan-id=200
add interface=ether2 name=ether2-vlan300 vlan-id=300
add interface=ether3 name=ether3-vlan100 vlan-id=100
add interface=ether3 name=ether3-vlan300 vlan-id=300
1) Dedicated bridge for each vlan:
add name=bridge-vlan100
add name=bridge-vlan200
add name=bridge-vlan300
add bridge=bridge-vlan100 hw=no interface=ether1-vlan100
add bridge=bridge-vlan100 hw=no interface=ether3-vlan100
add bridge=bridge-vlan200 hw=no interface=ether1-vlan200
add bridge=bridge-vlan200 hw=no interface=ether2-vlan200
add bridge=bridge-vlan300 hw=no interface=ether2-vlan300
add bridge=bridge-vlan300 hw=no interface=ether3-vlan300
2) Single bridge with all vlans assigned to the same bridge and bridge vlans:
add name=vlan-bridge
add bridge=vlan-bridge hw=no interface=ether1-vlan100
add bridge=vlan-bridge hw=no interface=ether3-vlan100
add bridge=vlan-bridge hw=no interface=ether1-vlan200
add bridge=vlan-bridge hw=no interface=ether2-vlan200
add bridge=vlan-bridge hw=no interface=ether2-vlan300
add bridge=vlan-bridge hw=no interface=ether3-vlan300
/interface bridge vlan
add bridge=vlan-bridge tagged=ether1 vlan-ids=100,200
add bridge=vlan-bridge tagged=ether2 vlan-ids=200,300
add bridge=vlan-bridge tagged=ether3 vlan-ids=100,200
Is there any benefit (besides better manageability)?
Is there any performance difference (on an CCR for Example)?
schadom
Re: Mikrotik Bridge usage with multiple Vlans
Sat Apr 14, 2018 4:30 am
Anyone?
dhcpy
Sat Apr 14, 2018 7:49 am
Which one does this work for you?
Because I'm having trouble making it work...at all
almdandi
Sat Apr 14, 2018 12:57 pm
Here is a presentation from the MUM in Berlin, explaining the new bridge implementation pretty well: https://www.youtube.com/watch?v=ZMMpza-O7_w&
schadom
Sat Apr 14, 2018 3:45 pm
Thanks!
squeeze
Unless you have a switch chip, its single bridge for all VLANs. Also, why are you explicitly disabling hardware offloading?
You may also need to add the bridge name itself to the "tagged=" list for trunks to other devices.
schadom
Sat Apr 14, 2018 4:05 pm
Thanks for the hint. The example given is from a CCR which does not support hw-offload.
Users browsing this forum: admiralchoy, bpwl, LSan83, w32pamela and 48 guests
