R1CH
Forum Veteran
Forum Veteran
Removing Mikrotik elements from beacons
Sun Apr 15, 2018 6:17 pm
Is there a way to prevent RouterOS from advertising itself in the 802.11 beacon frames? It's not so great to publicly broadcast the radio name, model name and RouterOS version to the world. This makes exploiting of Mikrotik networks much easier, since an adversary doesn't even need to break the WPA2 key before knowing if the device is running a vulnerable version of RouterOS. Removing these beacon elements would also help make the beacons smaller and reduce interference.
R1CH
Forum Veteran
Forum Veteran
Re: Removing Mikrotik elements from beacons
Fri Jul 27, 2018 4:56 pm
Bump.. still annoyed by the fact that anyone can see the version numbers.
jarda
Fri Jul 27, 2018 5:21 pm
Very true. I am with you. Two so far... Not enough. But one parameter for that shouldn't be so big deal...
Cha0s
Forum Veteran
Forum Veteran
Fri Jul 27, 2018 5:24 pm
I agree. +1
eXS
Fri Jul 27, 2018 6:13 pm
Same here
juliokato
Fri Jul 27, 2018 7:29 pm
+1,
this should already exist since the moment they implemented this information.
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
xt22
Fri Nov 30, 2018 1:45 am
agree. +1
Joni
Fri Nov 30, 2018 4:28 pm
This is a vulnerability +1
whatever
Fri Nov 30, 2018 6:37 pm
Didn't even know they were doing this, that's definitely something I'd like to turn off. +1
2jarek
Fri Nov 30, 2018 9:34 pm
+1 good idea
Dude2048
Sat Dec 01, 2018 12:33 am
Agreed
meetriks
Wed Jan 02, 2019 12:26 pm
Wireshark does not have a decoder for the RouterOs beacon tag. I'm thinking of making one :-)
The field is filled with this:
0000   00 00 00 01 1e 00 00 00 00 0a 66 2a 06 00 00 44  ..........f*...D
0010   34 43 41 36 44 36 37 38 44 37 37 00 00 00 00 00  4CA6D678D77.....
0020   00 00 00 05 02 6c 09                             .....l.
The D4...D77 is the radioname/mac of the wlan interface.
I'm running 6.42.10
DEC to HEX
06 = 06
42 = 2A
10 = 0a
In the code I see: '0a 66 2a 06'. Seems to be in reverse with 66 added.
Any one already figured this out? Or made the dissector?
Cheers,
Harry
meetriks
Wed Jan 02, 2019 1:36 pm
Did some test with another board and the patron is as expected
6.42.9:
00 00 00 01 1E 00 10 00 00 09 66 2A 06 00 00 44 34 43 41 36 44 36 37 38 44 36 42 00 00 00 00 00 00 00 00 05 02 6C 09
..........f*...D4CA6D678D6B..........l.
6.40.8:
00 00 00 01 1E 00 10 00 00 08 66 28 06 00 00 44 34 43 41 36 44 36 37 38 44 36 42 00 00 00 00 00 00 00 00 05 02 6C 09
..........f(...D4CA6D678D6B..........l.
6.43.8:
00 00 00 01 1E 00 10 00 00 08 66 2B 06 00 00 44 34 43 41 36 44 36 37 38 44 36 42 00 00 00 00 00 00 00 00 05 02 6C 09
..........f+...D4CA6D678D6B..........l.
muetzekoeln
Thu Jan 17, 2019 12:27 pm
What about the lastest 6.44beta. Something different in the beacon?
irobot
Wed Sep 11, 2019 6:34 pm
+1, I would like to see it as an option to disable to make any mikrotik wifi device as generic wifi device as possible.
irobot
Wed Sep 11, 2019 6:35 pm
still see this behavior at least in 6.44.3
viewtopic.php?f=2&t=151859&p=749629
Users browsing this forum: No registered users and 22 guests
