andrebernegozzi
RB941-2nD does not pass 20MBs Wireless
Mon Apr 16, 2018 4:43 am
Boa noite, tenho uma RB941-2nD RoS 6.41.4, já fiz todas as configurações possíveis no Wireless porem a banda no celular não passa de 20Mbs, sendo que em qualquer TP-Link 150Mbs 1 Antena, o teste no Wireless passa fácil os 40Mbs, fiz e todos os celulares com 1 antena a banda não passa de 20Mbs, porem celular com 2 antenas como Samsung S8 e Iphone 6 banda ultrapassa 70 Mbs normalmente.
by: Google Translate
Good night, I have a RB941-2nD RoS 6.41.4, I have already made all the possible configurations in the Wireless but the band in the cell phone does not exceed 20Mbs, being that in any TP-Link 150Mbs 1 Antenna, the test in Wireless passes the 40Mbs easy , I did and all cell phones with 1 antenna the band does not exceed 20Mbs, but cell phone with 2 antennas like Samsung S8 and Iphone 6 band exceeds 70 Mbs normally.
antonsb
Re: RB941-2nD does not pass 20MBs Wireless
Fri Apr 20, 2018 3:08 pm
6.43rc3
*) wireless - improved compatibility with BCM chipset devices;
Please upgrade and test - fixes soon will be included in current releases as well
andrebernegozzi
Wed May 02, 2018 9:06 pm
6.43rc3
Muito obrigado, sempre procurei usar as versões Current, e então ainda não tinha testado a Realise Candidate, atualizei para a 6.45rc5 e deu super certo, Download e Upload no Wifi agora bate 50/50 fácil.. Obrigado novamente.
Thanks a lot, I've always tried to use it as a Current version, and so I had not yet tested a Realize Candidate, upgrade to a 6.45rc5 and got super right, Download and Upload not Wifi now beats 50/50 easy .. Thanks again.
chechito
Thu May 03, 2018 12:15 am
6.43rc3
yes you only need to use current or bugfix on production environments
6.40.8 (old bridge implementation) and 6.42.1 (new bridge implementation)
also include the same fix
Users browsing this forum: No registered users and 22 guests
