strods
v6.42 [current]
Tue Apr 17, 2018 1:57 pm
RouterOS version 6.42 has been released in public "current" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.42 (2018-Apr-13 11:03):
!) tile - improved system performance and stability ("/system routerboard upgrade" required);
!) w60g - increased distance for wAP 60G to 200+ meters;
*) bridge - added host aging timer for CRS3xx and Atheros hw-bridges;
*) bridge - added per-port forwarding options for broadcasts, unknown-multicasts and unknown-unicasts;
*) bridge - added per-port learning options;
*) bridge - added support for static hosts;
*) bridge - fixed "master-port" configuration conversion from pre-v6.41 RouterOS versions;
*) bridge - fixed bridge port interface parameter under "/interface bridge host print detail";
*) bridge - fixed false MAC address learning on hAP ac^2 and cAP ac devices;
*) bridge - fixed incorrect "fast-forward" enabling when ports were switched;
*) bridge - fixed MAC learning for VRRP interfaces on bridge;
*) bridge - fixed reliability on software bridges when used on devices without switch chip;
*) bridge - hide options for disabled bridge features in CLI;
*) bridge - show "hw" flags only on Ethernet interfaces and interface lists;
*) capsman - added "allow-signal-out-of-range" option for Access List entries;
*) capsman - added support for "interface-list" in Access List and Datapath entries;
*) capsman - improved CAPsMAN responsiveness with large amount of CAP interfaces;
*) capsman - log "signal-strength" when successfully connected to AP;
*) certificate - added PKCS#10 version check;
*) certificate - dropped DES support and added AES instead for SCEP;
*) certificate - dropped MD5 support and require SHA1 as minimum for SCEP;
*) certificate - fixed incorrect SCEP URL after an upgrade;
*) chr - added "open-vm-tools" on VMware installations;
*) chr - added "qemu-guest-agent" and "virtio-scsi" driver on KVM installations;
*) chr - added "xe-daemon" on Xen installations;
*) chr - added support for Amazon Elastic Network Adapter (ENA) driver;
*) chr - added support for booting from NVMe disks;
*) chr - added support for Hyper-V ballooning, guest quiescing, host-guest file transfer, integration services and static IP injection;
*) chr - added support for NIC hot-plug on VMware and Xen installations;
*) chr - fixed additional disk detaching on Xen installations;
*) chr - fixed interface matching by name on VMware installations;
*) chr - fixed interface naming order when adding more than 4 interfaces on VMware installations;
*) chr - fixed suspend on Xen installations;
*) chr - make additional disks visible under "/disk" on Xen installations;
*) chr - make Virtio disks visible under "/disk" on KVM installations;
*) chr - run startup scripts on the first boot on AWS and Google Cloud installations;
*) console - fixed "idpr-cmtp" protocol by changing its value from 39 to 38;
*) console - improved console stability after it has not been used for a long time;
*) crs1xx/2xx - added BPDU value for "ingress-vlan-translation" menu "protocol" option;
*) crs212 - fixed Ethernet boot when connected to boot server through CRS326 device;
*) crs326 - fixed known multicast flooding to the CPU;
*) crs3xx - added switch port "storm-rate" limiting options;
*) crs3xx - added “hw-offload” support for 802.3ad and “balance-xor” bonding;
*) detnet - fixed "detect-internet" feature unavailability if router had too long identity (introduced in v6.41);
*) dhcp - improved DHCP service reliability when it is configured on bridge interface;
*) dhcp - reduced resource usage of DHCP services;
*) dhcpv4-server - added "dns-none" option to "/ip dhcp-server network dns";
*) dhcpv6 - make sure that time is set before restoring bindings;
*) dhcpv6-client - added info exchange support;
*) dhcpv6-client - added possibility to specify options;
*) dhcpv6-client - added support for options 15 and 16;
*) dhcpv6-client - implement confirm after reboot;
*) dhcpv6-server - added DHCPv4 style user options;
*) dns - do not generate "Undo" messages on changes to dynamic servers;
*) email - set maximum number of sessions to 100;
*) fetch - added "http-content-type" option to allow setting MIME type of the data in free text form;
*) fetch - added "output" option for all modes in order to return result to file, variable or ignore it;
*) fetch - increased maximum number of sessions to 100;
*) filesystem - implemented additional system storage maintenance checks on ARM CPU based devices;
*) flashfig - properly apply configuration provided by Flashfig;
*) gps - improved NMEA sentence handling;
*) health - added log warning when switching between redundant power supplies;
*) health - fixed empty measurements on CRS328-24P-4S+RM;
*) hotspot - improved HTTPS matching in Walled Garden rules;
*) ike1 - display error message when peer requests "mode-config" when it is not configured;
*) ike1 - do not accept "mode-config" reply more than once;
*) ike1 - fixed wildcard policy lookup on responder;
*) ike2 - fixed framed IP address received from RADIUS server;
*) interface - improved interface configuration responsiveness;
*) ippool - added ability to specify comment;
*) ippool6 - added pool name to "no more addresses left" error message;
*) ipsec - fixed AES-CTR and AES-GCM support on RB1200;
*) ipsec - improved single tunnel hardware acceleration performance on MMIPS devices;
*) ipsec - properly detect interface for "mode-config" client IP address assignment;
*) ipv6 - fixed IPv6 behaviour when bridge port leaves bridge;
*) ipv6 - update IPv6 DNS from RA only when it is changed;
*) kidcontrol - initial work on "/ip kid-control" feature;
*) led - added "Dark Mode" support for wAP 60G;
*) led - added w60g alignment trigger;
*) led - fixed unused "link-act-led" LED trigger on RBLHG 2nD, RBLHG 2nD-XL and RBSXTsq 2nD;
*) led - removed unused "link-act-led" trigger for devices which does not use it;
*) lte - added initial support for Quectel LTE EP06-E;
*) lte - added initial support for SIM7600 LTE modem interface;
*) lte - added support for the user and password authentication for wAP-LTE-kit-US (R11e-LTE-US);
*) lte - do not add DHCP client on LTE modems that doesn't use DHCP;
*) lte - fixed DHCP client adding for MF823 modem;
*) lte - fixed LTE band setting for SXT LTE;
*) mac-ping - fixed duplicate responses;
*) modem - added initial support for AC340U;
*) netinstall - fixed MMIPS RouterOS package description;
*) netinstall - sign Netinstall executable with an Extended Validation Code Signing Certificate;
*) netwatch - limit to read, write, test and reboot policies for Netwatch script execution;
*) poe - do not show "poe-out-current" on devices which can not determine it;
*) poe - hide PoE related properties on interfaces that does not provide power output;
*) ppp - added initial support for NETGEAR AC340U and ZyXEL WAH1604;
*) ppp - allow to override remote user PPP profile via "Mikrotik-Group";
*) quickset - fixed NAT if PPPoE client is used for Internet access;
*) quickset - properly detect IP address when one of the bridge modes is used;
*) quickset - properly detect LTE interface on startup;
*) quickset - show "G" flag for guest users;
*) quickset - use "/24" subnet for local network by default;
*) r11e-lte - improved LTE connection initialization process;
*) rb1100ahx4 - improved reliability on hardware encryption;
*) routerboard - added RouterBOOT "auto-upgrade" after RouterOS upgrade (extra reboot required);
*) routerboard - properly detect hAP ac^2 RAM size;
*) sniffer - fixed "/tool sniffer packet" results listed in incorrect order;
*) snmp - added "/caps-man interface print oid";
*) snmp - added "/interface w60g print oid";
*) snmp - added "board-name" OID;
*) snmp - improved request processing performance for wireless and CAP interfaces;
*) ssh - fixed SSH service becoming unavailable;
*) ssh - generate SSH keys only on the first connect attempt instead of the first boot;
*) ssh - improved key import error messages;
*) ssh - remove imported public SSH keys when their owner user is removed;
*) switch - hide "ingress-rate" and "egress-rate" for non-CRS3xx switches;
*) tile - added "aes-ctr" hardware acceleration support;
*) tr069-client - added "DownloadDiagnostics" and "UploadDiagnostics";
*) tr069-client - correctly return “TransferComplete” after vendor configuration file transfer;
*) tr069-client - fixed "/tool fetch" commands executed with ".alter" script;
*) tr069-client - fixed HTTPS authentication process;
*) traffic-flow - fixed IPv6 destination address value when IPFIX protocol is used;
*) upgrade - improved RouterOS upgrade process and restrict upgrade from RouterOS older than v5.16;
*) ups - improved communication between router and UPS;
*) ups - improved disconnect message handling between RouterOS and UPS;
*) userman - added support for ARM and MMIPS platform;
*) w60g - added "tx-power" setting (CLI only);
*) w60g - added RSSI information (CLI only);
*) w60g - added TX sector alignment information (CLI only);
*) watchdog - retry to send "autosupout.rif" file to an e-mail if initial delivery failed up to 3 times within 20 second interval;
*) winbox - added "antenna" setting under GPS settings for MIPS platform devices;
*) winbox - added "crl-store" setting to certificate settings;
*) winbox - added "insert-queue-before" to DHCP server;
*) winbox - added "use-dn" setting in OSPF instance General menu;
*) winbox - added 160 MHz "channel-width" to wireless settings;
*) winbox - added DHCPv6 client info request type and updated statuses;
*) winbox - added missing protocol numbers to IPv4 and IPv6 firewall;
*) winbox - added possibility to delete SMS from inbox;
*) winbox - allow to comment new object without committing it;
*) winbox - allow to open bridge host entry;
*) winbox - fixed name for "out-bridge-list" parameter under bridge firewall rules;
*) winbox - fixed typo from "UPtime" to "Uptime";
*) winbox - fixed Winbox closing when viewing graph which does not contain any data;
*) winbox - improved stability when using trackpad scrolling in large lists;
*) winbox - made UDP local and remote TX size parameters optional in Bandwidth Test tool;
*) winbox - moved "ageing-time" setting from STP to General tab;
*) winbox - moved OSPF instance "routing-table" setting in OSPF instance General menu;
*) winbox - removed “VLAN” section from “Switch” menu for CRS3xx devices;
*) winbox - show Bridge Port PVID column by default;
*) winbox - show CQI in LTE info;
*) winbox - show dual SIM options only for RouterBOARDS which does have two SIM slots;
*) winbox - show only master CAP interfaces under CAPsMAN wireless scan tool;
*) winbox - use proper graph name for HDD graphs;
*) wireless - added "realm-raw" setting for "/interface wireless interworking-profiles" (CLI only);
*) wireless - added initial support for "nstreme-plus";
*) wireless - added support for "band=5ghz-n/ac";
*) wireless - added support for "interface-list" for Access List entries;
*) wireless - added support for legacy AR9485 chipset;
*) wireless - enable all chains by default on devices without external antennas after configuration reset;
*) wireless - fixed "wds-slave" channel selection when single frequency is specified;
*) wireless - fixed incompatibility with macOS clients;
*) wireless - fixed long "scan-list" entries not working for ARM based wireless interfaces;
*) wireless - fixed nv2 protocol on ARM platform SXTsq devices;
*) wireless - fixed RB911-5HnD low transmit power issue;
*) wireless - fixed RTS/CTS option for the ARM based wireless devices;
*) wireless - fixed wsAP wrong 5 GHz interface MAC address;
*) wireless - improved compatibility with specific wireless AC standard clients;
*) wireless - improved Nv2 PtMP performance;
*) wireless - improved packet processing on ARM platform devices;
*) wireless - improved wireless performance on hAP ac^2 devices while USB is being used;
*) wireless - improved wireless scan functionality;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Please keep this forum topic strictly related to this concrete RouterOS release.
strods
Re: v6.42 [current]
Tue Apr 17, 2018 2:01 pm
Please note that improvements regarding upgrade process will become active only after an upgrade and will not affect upgrade to version 6.42.
Upgrade process happens on the old version, not the one which you try to put on your RouterOS instance.
jarda
Re: v6.42 [current]
Tue Apr 17, 2018 2:16 pm
Well. Looks awesome. Going to test how it helps to WiFi on hap ac2.
nin
Re: v6.42 [current]
Tue Apr 17, 2018 2:20 pm
just posted this in the v6.41.4 current thread, here again because the problem is still there... (and wasn't with v.6.41.2):
I just upgraded 2 minutes ago all of my devices to v6.42 [current].
I have one RB450G (configured as a pure switch) behind my CCR1016-12G router. Thus, the RB450G itself should not ask for and should not get any IP assigned from the DHCP server (CCR).
But since I updated the RouterOS, suddenly my logs on my CCR are flooded with
dhcp,warning dhcp1 offering lease 192.168.7.247 for <MAC_OF_RB450G_HERE> without success
Any idea what is wrong now?
Cheers, nin
strods
Re: v6.42 [current]
Tue Apr 17, 2018 2:36 pm
nin - You should send supout file to support. Is it possible that "Detect Internet" feature is enabled on your device?
nin
Re: v6.42 [current]
Tue Apr 17, 2018 2:43 pm
@strods: On the RB450G:
user@RB450G] /interface detect-internet> print
detect-interface-list: none
lan-interface-list: none
wan-interface-list: none
internet-interface-list: none
supout file of which device, the CCR?
Cheers, nin
squeeze
Re: v6.42 [current]
Tue Apr 17, 2018 2:44 pm
What Mikrotik devices support 160 MHz channel WiFi?
MartijnVdS
Re: v6.42 [current]
Tue Apr 17, 2018 3:09 pm
Cheers, nin
I'd send both the CCR one and the 450 one, while the problem is occurring. Just to be sure.
anuser
Long time Member
Long time Member
Re: v6.42 [current]
Tue Apr 17, 2018 3:10 pm
I´m awaiting your results...
zilf
Re: v6.42 [current]
Tue Apr 17, 2018 3:38 pm
RB850Gx2. After upgrade ROS to 6.42 does not show Tx rate when used Torch.
yhfung
Re: v6.42 [current]
Tue Apr 17, 2018 4:07 pm
It seems the results on hAP ac^2 using the new firmware v6.42 is more or less the same as v6.42rc52. Please take a look at the following five runs. The results are still not satisfactory as the average speed is around 130Mbps something, which is pretty far away from our expectations of over 300Mbps (stable and zero Retry count).
Please find sometime to see the last log which provides a lot of information of instability of download rate and packet retry count. Whenever the higher value of Retry count, the lower the speed.
Please help to resolve this issue as I have already brought 4 pieces of hAP ac^2. If you are able to resolve this issue, I am very sure that your sales of this product will be significantly increased.
YH
First Attempt
[ ID] Interval           Transfer     Bandwidth       Retr
[  4]   0.00-300.00 sec  9.22 GBytes   264 Mbits/sec  4236             sender
[  4]   0.00-300.00 sec  9.22 GBytes   264 Mbits/sec                  receiver
Second Attempt
[  4]   0.00-300.00 sec  5.25 GBytes   150 Mbits/sec  5845             sender
[  4]   0.00-300.00 sec  5.25 GBytes   150 Mbits/sec                  receiver
Third Attempt
[  4]   0.00-300.01 sec  5.44 GBytes   156 Mbits/sec  4605             sender
[  4]   0.00-300.01 sec  5.44 GBytes   156 Mbits/sec                  receiver
Fourth Attempt
[  4]   0.00-300.00 sec  4.79 GBytes   137 Mbits/sec  6206             sender
[  4]   0.00-300.00 sec  4.79 GBytes   137 Mbits/sec                  receiver
Fifth Attempt
[  4]   0.00-300.00 sec  4.90 GBytes   140 Mbits/sec  3702             sender
[  4]   0.00-300.00 sec  4.90 GBytes   140 Mbits/sec                  receiver
The following are the log showing the downloading rate and packet retry count due to errors (Retr)
Accepted connection from 192.168.55.70, port 60260
[  5] local 192.168.55.203 port 5201 connected to 192.168.55.70 port 60261
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec  41.1 MBytes   344 Mbits/sec   41    315 KBytes
[  5]   1.00-2.01   sec  42.1 MBytes   352 Mbits/sec    0    342 KBytes
[  5]   2.01-3.01   sec  30.8 MBytes   258 Mbits/sec   49    139 KBytes
[  5]   3.01-4.01   sec  12.6 MBytes   106 Mbits/sec   53   80.6 KBytes
[  5]   4.01-5.01   sec  14.4 MBytes   120 Mbits/sec   51   72.1 KBytes
[  5]   5.01-6.01   sec  8.08 MBytes  67.8 Mbits/sec   84   52.3 KBytes
[  5]   6.01-7.01   sec  8.08 MBytes  67.8 Mbits/sec   24   49.5 KBytes
[  5]   7.01-8.01   sec  7.46 MBytes  62.5 Mbits/sec   29   46.7 KBytes
[  5]   8.01-9.01   sec  9.94 MBytes  83.4 Mbits/sec   28   56.6 KBytes
[  5]   9.01-10.01  sec  8.70 MBytes  73.0 Mbits/sec   67   65.0 KBytes
[  5]  10.01-11.01  sec  7.02 MBytes  58.9 Mbits/sec   57   55.1 KBytes
[  5]  11.01-12.01  sec  2.49 MBytes  20.9 Mbits/sec    7   28.3 KBytes
[  5]  12.01-13.01  sec  6.21 MBytes  52.1 Mbits/sec   14   70.7 KBytes
[  5]  13.01-14.01  sec  8.08 MBytes  67.8 Mbits/sec    2   55.1 KBytes
[  5]  14.01-15.01  sec  17.2 MBytes   144 Mbits/sec   31    102 KBytes
[  5]  15.01-16.01  sec  27.0 MBytes   226 Mbits/sec    5    178 KBytes
[  5]  16.01-17.00  sec  21.3 MBytes   179 Mbits/sec   35    180 KBytes
[  5]  17.00-18.01  sec  26.5 MBytes   221 Mbits/sec    5    164 KBytes
[  5]  18.01-19.01  sec  13.2 MBytes   111 Mbits/sec   21    102 KBytes
[  5]  19.01-20.01  sec  7.52 MBytes  63.1 Mbits/sec    7   62.2 KBytes
[  5]  20.01-21.01  sec  5.65 MBytes  47.4 Mbits/sec    2   56.6 KBytes
[  5]  21.01-22.01  sec  9.32 MBytes  78.2 Mbits/sec   28   91.9 KBytes
[  5]  22.01-23.01  sec  17.8 MBytes   150 Mbits/sec    8   89.1 KBytes
[  5]  23.01-24.01  sec  25.9 MBytes   217 Mbits/sec    0    173 KBytes
[  5]  24.01-25.00  sec  20.1 MBytes   169 Mbits/sec    1    156 KBytes
[  5]  25.00-26.01  sec  19.0 MBytes   159 Mbits/sec    5    165 KBytes
[  5]  26.01-27.01  sec  8.89 MBytes  74.5 Mbits/sec    9    102 KBytes
[  5]  27.01-28.00  sec  28.0 MBytes   235 Mbits/sec    0    182 KBytes
[  5]  28.00-29.00  sec  29.8 MBytes   250 Mbits/sec    5    199 KBytes
[  5]  29.00-30.01  sec  22.3 MBytes   186 Mbits/sec   35    113 KBytes
[  5]  30.01-31.00  sec  27.2 MBytes   229 Mbits/sec    0    185 KBytes
[  5]  31.00-32.00  sec  29.7 MBytes   248 Mbits/sec    5    170 KBytes
[  5]  32.00-33.01  sec  12.1 MBytes   101 Mbits/sec    9   96.2 KBytes
[  5]  33.01-34.01  sec  7.52 MBytes  63.1 Mbits/sec    6   74.9 KBytes
[  5]  34.01-35.01  sec  6.84 MBytes  57.3 Mbits/sec   65   82.0 KBytes
[  5]  35.01-36.00  sec  12.7 MBytes   107 Mbits/sec    2   65.0 KBytes
[  5]  36.00-37.00  sec  23.9 MBytes   200 Mbits/sec    0    154 KBytes
[  5]  37.00-38.01  sec  15.5 MBytes   130 Mbits/sec    1    130 KBytes
[  5]  38.01-39.01  sec  14.9 MBytes   125 Mbits/sec    5    143 KBytes
[  5]  39.01-40.01  sec  8.26 MBytes  69.3 Mbits/sec   10   52.3 KBytes
[  5]  40.01-41.01  sec  9.45 MBytes  79.2 Mbits/sec    2   1.41 KBytes
[  5]  41.01-42.01  sec  12.5 MBytes   105 Mbits/sec   30    105 KBytes
[  5]  42.01-43.01  sec  11.5 MBytes  96.5 Mbits/sec    1    113 KBytes
[  5]  43.01-44.01  sec  6.21 MBytes  52.1 Mbits/sec   52   60.8 KBytes
[  5]  44.01-45.01  sec  24.7 MBytes   207 Mbits/sec    0    156 KBytes
[  5]  45.01-46.00  sec  28.0 MBytes   236 Mbits/sec   12    156 KBytes
[  5]  46.00-47.01  sec  30.0 MBytes   251 Mbits/sec    1    150 KBytes
[  5]  47.01-48.01  sec  16.9 MBytes   142 Mbits/sec   14    109 KBytes
[  5]  48.01-49.01  sec  6.28 MBytes  52.6 Mbits/sec   20   70.7 KBytes
[  5]  49.01-50.01  sec  4.97 MBytes  41.7 Mbits/sec    3   39.6 KBytes
[  5]  50.01-51.01  sec  4.97 MBytes  41.7 Mbits/sec    2   59.4 KBytes
[  5]  51.01-52.01  sec  8.70 MBytes  73.0 Mbits/sec   16   70.7 KBytes
[  5]  52.01-53.00  sec  23.4 MBytes   197 Mbits/sec    0    157 KBytes
[  5]  53.00-54.01  sec  19.5 MBytes   162 Mbits/sec   36    120 KBytes
[  5]  54.01-55.01  sec  12.1 MBytes   101 Mbits/sec   36   91.9 KBytes
[  5]  55.01-56.01  sec  1.86 MBytes  15.6 Mbits/sec   34   22.6 KBytes
[  5]  56.01-57.01  sec  6.21 MBytes  52.1 Mbits/sec    2   29.7 KBytes
[  5]  57.01-58.01  sec  9.94 MBytes  83.4 Mbits/sec    1   80.6 KBytes
[  5]  58.01-59.01  sec  1.86 MBytes  15.6 Mbits/sec    3   26.9 KBytes
[  5]  59.01-60.01  sec  6.84 MBytes  57.3 Mbits/sec   22   48.1 KBytes
[  5]  60.01-61.01  sec  3.73 MBytes  31.3 Mbits/sec   14   32.5 KBytes
[  5]  61.01-62.01  sec  1.86 MBytes  15.6 Mbits/sec    7   24.0 KBytes
[  5]  62.01-63.01  sec  4.97 MBytes  41.7 Mbits/sec    2   32.5 KBytes
[  5]  63.01-64.01  sec  10.6 MBytes  88.6 Mbits/sec    2   83.4 KBytes
[  5]  64.01-65.01  sec  9.45 MBytes  79.2 Mbits/sec   27   86.3 KBytes
[  5]  65.01-66.01  sec  18.1 MBytes   152 Mbits/sec    1    116 KBytes
[  5]  66.01-67.01  sec  20.4 MBytes   172 Mbits/sec    5   93.3 KBytes
[  5]  67.01-68.01  sec  21.6 MBytes   181 Mbits/sec    0    164 KBytes
[  5]  68.01-69.01  sec  15.2 MBytes   127 Mbits/sec   23    132 KBytes
[  5]  69.01-70.01  sec  8.89 MBytes  74.5 Mbits/sec    2   74.9 KBytes
[  5]  70.01-71.01  sec  1.86 MBytes  15.6 Mbits/sec    7   36.8 KBytes
[  5]  71.01-72.01  sec  2.49 MBytes  20.9 Mbits/sec    3   19.8 KBytes
[  5]  72.01-73.01  sec  3.11 MBytes  26.1 Mbits/sec    2   45.2 KBytes
[  5]  73.01-74.01  sec  9.32 MBytes  78.2 Mbits/sec   19   87.7 KBytes
[  5]  74.01-75.01  sec  16.2 MBytes   136 Mbits/sec    1    124 KBytes
[  5]  75.01-76.01  sec  17.8 MBytes   149 Mbits/sec    1    129 KBytes
[  5]  76.01-77.01  sec  18.5 MBytes   155 Mbits/sec    1    105 KBytes
[  5]  77.01-78.01  sec  22.9 MBytes   192 Mbits/sec    0    175 KBytes
[  5]  78.01-79.01  sec  15.0 MBytes   126 Mbits/sec   19    107 KBytes
[  5]  79.01-80.01  sec  14.5 MBytes   122 Mbits/sec   16    122 KBytes
[  5]  80.01-81.01  sec  8.70 MBytes  73.0 Mbits/sec    2   91.9 KBytes
[  5]  81.01-82.01  sec  6.84 MBytes  57.3 Mbits/sec    2   73.5 KBytes
[  5]  82.01-83.01  sec  25.7 MBytes   216 Mbits/sec    0    167 KBytes
[  5]  83.01-84.01  sec  21.3 MBytes   179 Mbits/sec   31    154 KBytes
[  5]  84.01-85.01  sec  18.0 MBytes   151 Mbits/sec   27    139 KBytes
[  5]  85.01-86.01  sec  15.7 MBytes   132 Mbits/sec    1    123 KBytes
[  5]  86.01-87.01  sec  19.7 MBytes   165 Mbits/sec   15    156 KBytes
[  5]  87.01-88.01  sec  31.8 MBytes   267 Mbits/sec    0    225 KBytes
[  5]  88.01-89.01  sec  26.0 MBytes   218 Mbits/sec    5    181 KBytes
[  5]  89.01-90.01  sec  12.7 MBytes   107 Mbits/sec    5    106 KBytes
[  5]  90.01-91.00  sec  17.2 MBytes   145 Mbits/sec   16    136 KBytes
[  5]  91.00-92.01  sec  12.7 MBytes   107 Mbits/sec    6   1.41 KBytes
[  5]  92.01-93.01  sec  7.52 MBytes  63.1 Mbits/sec   23   74.9 KBytes
[  5]  93.01-94.01  sec  13.8 MBytes   116 Mbits/sec    3    109 KBytes
[  5]  94.01-95.01  sec  15.2 MBytes   127 Mbits/sec   17    105 KBytes
[  5]  95.01-96.01  sec  22.7 MBytes   190 Mbits/sec    1    157 KBytes
[  5]  96.01-97.01  sec  7.52 MBytes  63.1 Mbits/sec   21   77.8 KBytes
[  5]  97.01-98.00  sec  16.7 MBytes   140 Mbits/sec    1   93.3 KBytes
[  5]  98.00-99.01  sec  16.6 MBytes   139 Mbits/sec    4    130 KBytes
[  5]  99.01-100.01 sec  10.2 MBytes  85.5 Mbits/sec    2   73.5 KBytes
[  5] 100.01-101.01 sec  6.84 MBytes  57.3 Mbits/sec   26   49.5 KBytes
[  5] 101.01-102.01 sec  13.1 MBytes   110 Mbits/sec    1   74.9 KBytes
[  5] 102.01-103.01 sec  7.46 MBytes  62.6 Mbits/sec    6   49.5 KBytes
[  5] 103.01-104.01 sec  8.08 MBytes  67.8 Mbits/sec    2   62.2 KBytes
[  5] 104.01-105.01 sec  13.9 MBytes   116 Mbits/sec   18    110 KBytes
[  5] 105.01-106.01 sec  27.2 MBytes   228 Mbits/sec    0    189 KBytes
[  5] 106.01-107.00 sec  20.2 MBytes   170 Mbits/sec   19    163 KBytes
[  5] 107.00-108.01 sec  31.8 MBytes   266 Mbits/sec    0    230 KBytes
[  5] 108.01-109.01 sec  34.9 MBytes   292 Mbits/sec    0    286 KBytes
[  5] 109.01-110.01 sec  31.9 MBytes   268 Mbits/sec   36    226 KBytes
[  5] 110.01-111.00 sec  14.4 MBytes   122 Mbits/sec   36    173 KBytes
[  5] 111.00-112.01 sec  8.26 MBytes  68.9 Mbits/sec   25   77.8 KBytes
[  5] 112.01-113.01 sec  4.35 MBytes  36.5 Mbits/sec   25   42.4 KBytes
[  5] 113.01-114.01 sec  1.86 MBytes  15.6 Mbits/sec   18   45.2 KBytes
[  5] 114.01-115.01 sec  10.6 MBytes  88.6 Mbits/sec    6   79.2 KBytes
[  5] 115.01-116.01 sec  15.5 MBytes   130 Mbits/sec    1    124 KBytes
[  5] 116.01-117.01 sec  29.1 MBytes   244 Mbits/sec    0    199 KBytes
[  5] 117.01-118.00 sec  13.9 MBytes   117 Mbits/sec   46   89.1 KBytes
[  5] 118.00-119.01 sec  7.52 MBytes  62.8 Mbits/sec    2   73.5 KBytes
[  5] 119.01-120.01 sec  14.4 MBytes   121 Mbits/sec    1    116 KBytes
[  5] 120.01-121.01 sec  20.6 MBytes   173 Mbits/sec    4   99.0 KBytes
[  5] 121.01-122.01 sec  19.7 MBytes   165 Mbits/sec    1   1.41 KBytes
[  5] 122.01-123.01 sec  8.76 MBytes  73.5 Mbits/sec   21   1.41 KBytes
[  5] 123.01-124.01 sec  13.2 MBytes   111 Mbits/sec    1    107 KBytes
[  5] 124.01-125.01 sec  15.8 MBytes   133 Mbits/sec    1    127 KBytes
[  5] 125.01-126.01 sec  29.4 MBytes   247 Mbits/sec    0    204 KBytes
[  5] 126.01-127.01 sec  22.9 MBytes   192 Mbits/sec    1   1.41 KBytes
[  5] 127.01-128.01 sec  13.8 MBytes   116 Mbits/sec   19   1.41 KBytes
[  5] 128.01-129.01 sec  25.4 MBytes   213 Mbits/sec    0    173 KBytes
[  5] 129.01-130.01 sec  26.2 MBytes   220 Mbits/sec    0    228 KBytes
[  5] 130.01-131.01 sec  20.3 MBytes   171 Mbits/sec    5    180 KBytes
[  5] 131.01-132.01 sec  31.4 MBytes   264 Mbits/sec   27    177 KBytes
[  5] 132.01-133.00 sec  34.0 MBytes   287 Mbits/sec    0    242 KBytes
[  5] 133.00-134.01 sec  23.3 MBytes   194 Mbits/sec    1    173 KBytes
[  5] 134.01-135.01 sec  11.4 MBytes  95.9 Mbits/sec   23    116 KBytes
[  5] 135.01-136.01 sec  11.4 MBytes  95.4 Mbits/sec   11   79.2 KBytes
[  5] 136.01-137.01 sec  26.0 MBytes   218 Mbits/sec    0    167 KBytes
[  5] 137.01-138.01 sec  8.39 MBytes  70.4 Mbits/sec    7   82.0 KBytes
[  5] 138.01-139.01 sec  7.46 MBytes  62.6 Mbits/sec    7   1.41 KBytes
[  5] 139.01-140.01 sec  10.6 MBytes  88.6 Mbits/sec    1   94.7 KBytes
[  5] 140.01-141.01 sec  6.21 MBytes  52.1 Mbits/sec    9   52.3 KBytes
[  5] 141.01-142.01 sec  13.7 MBytes   115 Mbits/sec    1   93.3 KBytes
[  5] 142.01-143.01 sec  5.65 MBytes  47.4 Mbits/sec    6   52.3 KBytes
[  5] 143.01-144.01 sec  6.90 MBytes  57.9 Mbits/sec    2   60.8 KBytes
[  5] 144.01-145.01 sec  10.7 MBytes  89.7 Mbits/sec    2   72.1 KBytes
[  5] 145.01-146.01 sec  8.76 MBytes  73.5 Mbits/sec   22   76.4 KBytes
[  5] 146.01-147.01 sec  15.3 MBytes   128 Mbits/sec    1    124 KBytes
[  5] 147.01-148.01 sec  4.41 MBytes  37.0 Mbits/sec    3   46.7 KBytes
[  5] 148.01-149.01 sec  10.6 MBytes  89.1 Mbits/sec    2   96.2 KBytes
[  5] 149.01-150.01 sec  15.7 MBytes   131 Mbits/sec   26    115 KBytes
[  5] 150.01-151.01 sec  22.2 MBytes   187 Mbits/sec    0    178 KBytes
[  5] 151.01-152.01 sec  9.45 MBytes  79.2 Mbits/sec    2   93.3 KBytes
[  5] 152.01-153.01 sec  8.70 MBytes  73.0 Mbits/sec    2   82.0 KBytes
[  5] 153.01-154.01 sec  4.35 MBytes  36.5 Mbits/sec    6   58.0 KBytes
[  5] 154.01-155.01 sec  1.86 MBytes  15.6 Mbits/sec   19   17.0 KBytes
[  5] 155.01-156.01 sec  5.59 MBytes  46.9 Mbits/sec    2   70.7 KBytes
[  5] 156.01-157.01 sec  7.46 MBytes  62.6 Mbits/sec   18   62.2 KBytes
[  5] 157.01-158.01 sec  6.21 MBytes  52.1 Mbits/sec    2   50.9 KBytes
[  5] 158.01-159.01 sec  13.8 MBytes   116 Mbits/sec    5    110 KBytes
[  5] 159.01-160.01 sec  17.0 MBytes   143 Mbits/sec    6    141 KBytes
[  5] 160.01-161.01 sec  29.8 MBytes   250 Mbits/sec    5    139 KBytes
[  5] 161.01-162.01 sec  30.1 MBytes   253 Mbits/sec    0    209 KBytes
[  5] 162.01-163.01 sec  35.5 MBytes   298 Mbits/sec    0    270 KBytes
[  5] 163.01-164.00 sec  37.5 MBytes   316 Mbits/sec   36    198 KBytes
[  5] 164.00-165.01 sec  10.4 MBytes  86.7 Mbits/sec   30   89.1 KBytes
[  5] 165.01-166.01 sec  3.11 MBytes  26.1 Mbits/sec   23   49.5 KBytes
[  5] 166.01-167.00 sec  23.2 MBytes   195 Mbits/sec    0    147 KBytes
[  5] 167.00-168.01 sec  30.0 MBytes   251 Mbits/sec    1    141 KBytes
[  5] 168.01-169.01 sec  12.7 MBytes   106 Mbits/sec    2   66.5 KBytes
[  5] 169.01-170.01 sec  24.5 MBytes   205 Mbits/sec    0    158 KBytes
[  5] 170.01-171.01 sec  15.3 MBytes   129 Mbits/sec    5    156 KBytes
[  5] 171.01-172.01 sec  12.6 MBytes   106 Mbits/sec   37    110 KBytes
[  5] 172.01-173.01 sec  18.9 MBytes   158 Mbits/sec   36    137 KBytes
[  5] 173.01-174.01 sec  29.9 MBytes   251 Mbits/sec    0    212 KBytes
[  5] 174.01-175.01 sec  12.2 MBytes   103 Mbits/sec    9   72.1 KBytes
[  5] 175.01-176.01 sec  23.8 MBytes   200 Mbits/sec    0    164 KBytes
[  5] 176.01-177.01 sec  9.45 MBytes  79.2 Mbits/sec    1    116 KBytes
[  5] 177.01-178.01 sec  4.97 MBytes  41.7 Mbits/sec   29   60.8 KBytes
[  5] 178.01-179.01 sec  1.24 MBytes  10.4 Mbits/sec    7   28.3 KBytes
[  5] 179.01-180.01 sec  1.24 MBytes  10.4 Mbits/sec    3   28.3 KBytes
[  5] 180.01-181.01 sec  5.59 MBytes  46.9 Mbits/sec    2   60.8 KBytes
[  5] 181.01-182.01 sec  5.59 MBytes  46.9 Mbits/sec    2   50.9 KBytes
[  5] 182.01-183.01 sec  13.8 MBytes   116 Mbits/sec    5    112 KBytes
[  5] 183.01-184.01 sec  12.6 MBytes   105 Mbits/sec   44   76.4 KBytes
[  5] 184.01-185.01 sec  16.9 MBytes   142 Mbits/sec    1    113 KBytes
[  5] 185.01-186.01 sec  5.78 MBytes  48.5 Mbits/sec    4   53.7 KBytes
[  5] 186.01-187.01 sec  3.73 MBytes  31.3 Mbits/sec    3   42.4 KBytes
[  5] 187.01-188.01 sec  10.0 MBytes  83.9 Mbits/sec    1   91.9 KBytes
[  5] 188.01-189.01 sec  4.97 MBytes  41.7 Mbits/sec   24   43.8 KBytes
[  5] 189.01-190.01 sec  10.1 MBytes  84.4 Mbits/sec    6   50.9 KBytes
[  5] 190.01-191.01 sec  8.08 MBytes  67.8 Mbits/sec    2   1.41 KBytes
[  5] 191.01-192.01 sec  20.4 MBytes   171 Mbits/sec    0    134 KBytes
[  5] 192.01-193.01 sec  17.9 MBytes   150 Mbits/sec    1    153 KBytes
[  5] 193.01-194.01 sec  20.3 MBytes   171 Mbits/sec   22    107 KBytes
[  5] 194.01-195.01 sec  6.21 MBytes  52.1 Mbits/sec    6   58.0 KBytes
[  5] 195.01-196.01 sec  4.35 MBytes  36.5 Mbits/sec    4   45.2 KBytes
[  5] 196.01-197.01 sec  8.08 MBytes  67.8 Mbits/sec    2   1.41 KBytes
[  5] 197.01-198.01 sec  3.73 MBytes  31.3 Mbits/sec    2   38.2 KBytes
[  5] 198.01-199.01 sec  9.94 MBytes  83.4 Mbits/sec    2   82.0 KBytes
[  5] 199.01-200.01 sec  17.6 MBytes   148 Mbits/sec    1    107 KBytes
[  5] 200.01-201.01 sec  10.0 MBytes  84.0 Mbits/sec   34   79.2 KBytes
[  5] 201.01-202.00 sec  15.2 MBytes   128 Mbits/sec    1    116 KBytes
[  5] 202.00-203.01 sec  6.34 MBytes  52.9 Mbits/sec    8   72.1 KBytes
[  5] 203.01-204.01 sec  1.24 MBytes  10.4 Mbits/sec   13   31.1 KBytes
[  5] 204.01-205.01 sec  1.86 MBytes  15.6 Mbits/sec    3   33.9 KBytes
[  5] 205.01-206.01 sec  4.97 MBytes  41.7 Mbits/sec    3   25.5 KBytes
[  5] 206.01-207.01 sec  6.84 MBytes  57.3 Mbits/sec    2   53.7 KBytes
[  5] 207.01-208.01 sec  10.6 MBytes  88.6 Mbits/sec   11   77.8 KBytes
[  5] 208.01-209.01 sec  17.5 MBytes   147 Mbits/sec    5    130 KBytes
[  5] 209.01-210.01 sec  17.6 MBytes   148 Mbits/sec    1    120 KBytes
[  5] 210.01-211.01 sec  16.0 MBytes   134 Mbits/sec    5    122 KBytes
[  5] 211.01-212.01 sec  13.9 MBytes   116 Mbits/sec   26    103 KBytes
[  5] 212.01-213.01 sec  20.4 MBytes   171 Mbits/sec    1    100 KBytes
[  5] 213.01-214.01 sec  12.8 MBytes   107 Mbits/sec    1    106 KBytes
[  5] 214.01-215.00 sec  12.6 MBytes   106 Mbits/sec    6    109 KBytes
[  5] 215.00-216.01 sec  18.3 MBytes   153 Mbits/sec   25    127 KBytes
[  5] 216.01-217.01 sec  18.3 MBytes   153 Mbits/sec   17    147 KBytes
[  5] 217.01-218.01 sec  23.0 MBytes   193 Mbits/sec    0    201 KBytes
[  5] 218.01-219.00 sec  26.3 MBytes   222 Mbits/sec   36    195 KBytes
[  5] 219.00-220.01 sec  20.5 MBytes   171 Mbits/sec    6   32.5 KBytes
[  5] 220.01-221.01 sec  14.3 MBytes   120 Mbits/sec    1    113 KBytes
[  5] 221.01-222.01 sec  3.11 MBytes  26.1 Mbits/sec   61   45.2 KBytes
[  5] 222.01-223.01 sec  4.35 MBytes  36.5 Mbits/sec    3   41.0 KBytes
[  5] 223.01-224.01 sec  15.0 MBytes   126 Mbits/sec    1   80.6 KBytes
[  5] 224.01-225.01 sec  8.82 MBytes  74.0 Mbits/sec    6   58.0 KBytes
[  5] 225.01-226.00 sec  24.0 MBytes   203 Mbits/sec    0    151 KBytes
[  5] 226.00-227.01 sec  29.1 MBytes   243 Mbits/sec    5    157 KBytes
[  5] 227.01-228.01 sec  14.8 MBytes   124 Mbits/sec   32   1.41 KBytes
[  5] 228.01-229.01 sec  15.1 MBytes   127 Mbits/sec   29   97.6 KBytes
[  5] 229.01-230.01 sec  28.9 MBytes   242 Mbits/sec   39    482 KBytes
[  5] 230.01-231.01 sec  47.3 MBytes   396 Mbits/sec    0    550 KBytes
[  5] 231.01-232.01 sec  45.9 MBytes   385 Mbits/sec   10    413 KBytes
[  5] 232.01-233.01 sec  44.8 MBytes   376 Mbits/sec    0    450 KBytes
[  5] 233.01-234.01 sec  39.0 MBytes   327 Mbits/sec   59    233 KBytes
[  5] 234.01-235.01 sec  34.1 MBytes   286 Mbits/sec   36    206 KBytes
[  5] 235.01-236.01 sec  16.9 MBytes   142 Mbits/sec   36    182 KBytes
[  5] 236.01-237.01 sec  5.90 MBytes  49.5 Mbits/sec   29    144 KBytes
[  5] 237.01-238.01 sec  31.1 MBytes   261 Mbits/sec    0    216 KBytes
[  5] 238.01-239.00 sec  19.4 MBytes   163 Mbits/sec   39   99.0 KBytes
[  5] 239.00-240.00 sec  17.0 MBytes   142 Mbits/sec    1    120 KBytes
[  5] 240.00-241.00 sec  28.6 MBytes   241 Mbits/sec    0    198 KBytes
[  5] 241.00-242.01 sec  20.4 MBytes   170 Mbits/sec    2    102 KBytes
[  5] 242.01-243.00 sec  9.20 MBytes  77.6 Mbits/sec   36   72.1 KBytes
[  5] 243.00-244.01 sec  13.5 MBytes   113 Mbits/sec    8    102 KBytes
[  5] 244.01-245.00 sec  28.3 MBytes   238 Mbits/sec    0    182 KBytes
[  5] 245.00-246.01 sec  20.1 MBytes   168 Mbits/sec   27    164 KBytes
[  5] 246.01-247.00 sec  21.4 MBytes   180 Mbits/sec   28    163 KBytes
[  5] 247.00-248.01 sec  31.7 MBytes   265 Mbits/sec    0    229 KBytes
[  5] 248.01-249.01 sec  37.7 MBytes   316 Mbits/sec    0    287 KBytes
[  5] 249.01-250.01 sec  39.2 MBytes   329 Mbits/sec    0    335 KBytes
[  5] 250.01-251.01 sec  43.2 MBytes   362 Mbits/sec    0    382 KBytes
[  5] 251.01-252.01 sec  44.7 MBytes   376 Mbits/sec    0    423 KBytes
[  5] 252.01-253.01 sec  43.3 MBytes   363 Mbits/sec   36    298 KBytes
[  5] 253.01-254.01 sec  41.0 MBytes   344 Mbits/sec    0    344 KBytes
[  5] 254.01-255.01 sec  36.0 MBytes   302 Mbits/sec   36    286 KBytes
[  5] 255.01-256.01 sec  37.8 MBytes   317 Mbits/sec    0    334 KBytes
[  5] 256.01-257.01 sec  40.1 MBytes   337 Mbits/sec   31    173 KBytes
[  5] 257.01-258.01 sec  20.2 MBytes   169 Mbits/sec    0    218 KBytes
[  5] 258.01-259.01 sec  18.3 MBytes   153 Mbits/sec   38    137 KBytes
[  5] 259.01-260.01 sec  7.83 MBytes  65.7 Mbits/sec   29   67.9 KBytes
[  5] 260.01-261.01 sec  11.4 MBytes  95.9 Mbits/sec   24    103 KBytes
[  5] 261.01-262.01 sec  10.8 MBytes  90.7 Mbits/sec    6   77.8 KBytes
[  5] 262.01-263.01 sec  16.8 MBytes   141 Mbits/sec    8    100 KBytes
[  5] 263.01-264.01 sec  18.0 MBytes   151 Mbits/sec    8    107 KBytes
[  5] 264.01-265.01 sec  28.0 MBytes   235 Mbits/sec    0    188 KBytes
[  5] 265.01-266.01 sec  15.0 MBytes   126 Mbits/sec   34    158 KBytes
[  5] 266.01-267.01 sec  20.5 MBytes   172 Mbits/sec    1    143 KBytes
[  5] 267.01-268.01 sec  17.2 MBytes   144 Mbits/sec   30    132 KBytes
[  5] 268.01-269.01 sec  29.1 MBytes   244 Mbits/sec    1    137 KBytes
[  5] 269.01-270.00 sec  29.8 MBytes   251 Mbits/sec    0    206 KBytes
[  5] 270.00-271.01 sec  28.7 MBytes   240 Mbits/sec    5    182 KBytes
[  5] 271.01-272.01 sec  33.1 MBytes   278 Mbits/sec    0    245 KBytes
[  5] 272.01-273.00 sec  30.8 MBytes   259 Mbits/sec   37    218 KBytes
[  5] 273.00-274.00 sec  34.1 MBytes   285 Mbits/sec    0    273 KBytes
[  5] 274.00-275.01 sec  37.3 MBytes   312 Mbits/sec   37    228 KBytes
[  5] 275.01-276.01 sec  34.9 MBytes   292 Mbits/sec    0    279 KBytes
[  5] 276.01-277.01 sec  20.3 MBytes   170 Mbits/sec   39    143 KBytes
[  5] 277.01-278.01 sec  11.1 MBytes  93.3 Mbits/sec    5   93.3 KBytes
[  5] 278.01-279.01 sec  21.3 MBytes   179 Mbits/sec    0    163 KBytes
[  5] 279.01-280.01 sec  7.08 MBytes  59.4 Mbits/sec   39   56.6 KBytes
[  5] 280.01-281.01 sec  14.7 MBytes   124 Mbits/sec    1   79.2 KBytes
[  5] 281.01-282.01 sec  24.7 MBytes   207 Mbits/sec    0    163 KBytes
[  5] 282.01-283.01 sec  30.6 MBytes   257 Mbits/sec    0    228 KBytes
[  5] 283.01-284.00 sec  34.5 MBytes   291 Mbits/sec   30    173 KBytes
[  5] 284.00-285.01 sec  24.9 MBytes   208 Mbits/sec    1    177 KBytes
[  5] 285.01-286.01 sec  32.7 MBytes   274 Mbits/sec    0    242 KBytes
[  5] 286.01-287.00 sec  18.3 MBytes   154 Mbits/sec   36    164 KBytes
[  5] 287.00-288.01 sec  17.9 MBytes   149 Mbits/sec   36    141 KBytes
[  5] 288.01-289.01 sec  22.9 MBytes   192 Mbits/sec    3    157 KBytes
[  5] 289.01-290.01 sec  23.3 MBytes   195 Mbits/sec    5    177 KBytes
[  5] 290.01-291.01 sec  21.6 MBytes   181 Mbits/sec    1   1.41 KBytes
[  5] 291.01-292.01 sec  7.02 MBytes  58.9 Mbits/sec   51   94.7 KBytes
[  5] 292.01-293.01 sec  3.42 MBytes  28.7 Mbits/sec    8   35.4 KBytes
[  5] 293.01-294.01 sec  3.42 MBytes  28.7 Mbits/sec    5   45.2 KBytes
[  5] 294.01-295.01 sec  4.23 MBytes  35.4 Mbits/sec   11   31.1 KBytes
[  5] 295.01-296.01 sec  11.9 MBytes   100 Mbits/sec    8    103 KBytes
[  5] 296.01-297.01 sec  6.21 MBytes  52.1 Mbits/sec   29   39.6 KBytes
[  5] 297.01-298.01 sec  2.73 MBytes  22.9 Mbits/sec   16   26.9 KBytes
[  5] 298.01-299.01 sec  1.37 MBytes  11.5 Mbits/sec    3   18.4 KBytes
[  5] 299.01-300.00 sec  2.05 MBytes  17.2 Mbits/sec    3   31.1 KBytes
[  5]   0.00-300.00 sec  4.90 GBytes   140 Mbits/sec  3702             sender
Server listening on 5201
spitkia
Re: v6.42 [current]
Tue Apr 17, 2018 4:10 pm
RB951Ui-2HnD. After the upgrade to 6.42, the first port does not work
jrpaz
Re: v6.42 [current]
Tue Apr 17, 2018 4:11 pm
No improvement on the hAP ac^2. Similar results to the ones above.
WirelessRudy
Re: v6.42 [current]
Tue Apr 17, 2018 4:14 pm
Previous versions don't support for these? What actually was not supported? We have one LHG-5ac that is in bridge mode but its UM assigned authentication is coming and going....
add admin-mac=E4:8D:8C:53:5A:9B auto-mac=no fast-forward=no name=bridge1
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=ether1-local
/interface pppoe-client
add add-default-route=yes disabled=no interface=bridge1 keepalive-timeout=60 max-mru=1500 max-mtu=1500 name=pppoe-out1 service-name=internet use-peer-dns=yes \
    user="**************************"
"************" is actually real name...
/interface pppoe-client> pr
Flags: X - disabled, I - invalid, R - running
 0  R name="pppoe-out1" max-mtu=1500 max-mru=1500 mrru=disabled interface=bridge1 user="************************" password="" profile=default
      keepalive-timeout=60 service-name="internet" ac-name="" add-default-route=yes default-route-distance=1 dial-on-demand=no use-peer-dns=yes
      allow=pap,chap,mschap1,mschap2
When we make a telnet to this router we see the client getting its assigned IP.
 /ip address> pr
 #   ADDRESS            NETWORK         INTERFACE
 0 D 192.168.226.80/24  192.168.226.0   vlan2_Gestion_P2MP
 1 D 192.168.201.210/32 192.168.200.1   pppoe-out1
It also creates the gw
/ip route> pr
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 ADS  0.0.0.0/0                          pppoe-out1                1
 1  DS  0.0.0.0/0                          192.168.226.1             2
 2 ADC  192.168.200.1/32   192.168.201.210 pppoe-out1                0
 3 ADC  192.168.226.0/24   192.168.226.80  vlan2_Gestion_P2MP        0
We had 6.42rc37 installed when the problem was noticed (We needed this version to have the 'arm' radio to connect anyway....
We managed to update it via de management network to 6.42 current
But the issue is still there.
We have several 'arm' units running with pppoe-clients but the pppoe client sits usually on the wlan1 interface. In this case it is on the bridge.
Anybody any suggestions?
normis
Re: v6.42 [current]
Tue Apr 17, 2018 4:17 pm
Previously you could not install User Manager server on ARM systems at all.
kowal
Re: v6.42 [current]
Tue Apr 17, 2018 4:18 pm
After upgrade, on hAP ac2 and cAP ac I see strange channel options, XXX :)
In CLI:
[admin@KowalCAP] > /int wire set 1 channel-width=
ChannelWidth ::= 10mhz | 20/40/80/160mhz-Ceeeeeee | 20/40/80/160mhz-XXXXXXXX | 20/40/80/160mhz-eCeeeeee | 20/40/80/160mhz-eeCeeeee | ...
Winbox:
I also installed 6.42 on friend's hAP ac^2, previously on 6.41.4 on 5GHz-AC with laptop card Intel DualBand 8260 has transfer 8-14 Mbit... Waiting for results. On TP-Link T4UH v1 (RTL8812AU chipset) I have transfers about 130 - 150 Mbit/s.
After work I will check performance with cAP ac and TP-Link T4UH.
R1CH
Re: v6.42 [current]
Tue Apr 17, 2018 4:20 pm
Upgraded a bunch of hEX r3, wAP AC and hAP AC (original) with no issues. Holding off on the CCR-1009 for a bit.
kez
Re: v6.42 [current]
Tue Apr 17, 2018 4:31 pm
Thanks for another great update.
How about this feature released at 6.42rc52?
*) chr - added support for "multi-queue" feature for "virtio-net" drivers
There is no mention on 6.42 changelog and it's a feature I've been waiting for.
Thanks again!
Redmor
Re: v6.42 [current]
Tue Apr 17, 2018 4:42 pm
I can't see any improvement in Nv2 PTMP, someone have some tests and can share AP and client configuration?
normis
Re: v6.42 [current]
Tue Apr 17, 2018 4:44 pm
I can't see any improvement on Nv2 PTMP, someone have some tests and can share AP and client configuration?
did you upgrade AP and stations, or only AP ?
strods
Re: v6.42 [current]
Tue Apr 17, 2018 5:00 pm
nin - Detect Internet was just a guess. We will look into the problem through support ticket and let you know about the findings. Please provide supout files from both devices within an e-mail to support@mikrotik.com.
squeeze - Currently there is no RouterBOARD with such built-in wireless functionality.
zilf - We will look into this problem. Are you sure that 6.41.4 did not have such problem?
yhfung,jrpaz - We are still working on improvements. Hopefully we will provide improvements as soon as possible within 6.43rc version.
spitkia - Do you mean that there is no link on ether1 which was working fine on 6.41.4? Please generate supout file on your router while ether1 is connected to other device but link is not established. Send this file to support@mikrotik.com.
kez - More improvements regarding this feature will be implemented within 6.43rc version.
Redmor - In order to see improvements you must upgrade AP devices. Please note that in most cases you can see the difference only, if there are more than 10 stations connected (number can vary, it can be more and it can be less than 10).
zilf
Re: v6.42 [current]
Tue Apr 17, 2018 5:05 pm
I did not install 6.41.4, but on 6.41.3 did not have such problem
nin
Re: v6.42 [current]
Tue Apr 17, 2018 5:13 pm
Strods,
wow you support is fast! Your Sergejs B. already helped me!
For some reason i cannot explain at all, I had this line in my RB450G (switch) configuration which certainly is completely obsolete.
/ip dhcp-client add dhcp-options=hostname,clientid disabled=no interface=bridge1
After removing the client entry, no problems anymore.
Whether it was sitting there all the time or not I cannot say. However I have used many months ago the quickset for a switch configuration and I never had changed this very simply setup...
Cheers nin!
planetcaravan
Re: v6.42 [current]
Tue Apr 17, 2018 5:40 pm
what is the detail of this update:
Does it involve also AC standard?
Does it require the NV security?
silenceleaf
Re: v6.42 [current]
Tue Apr 17, 2018 5:47 pm
Same as most post hAP ac2 has extreme poor performance after even update to 6.42. 5G wifi has 130Mbps only and very unstable.
eddieb
Re: v6.42 [current]
Tue Apr 17, 2018 5:51 pm
Updated RB1100, RB2011, CRS125, RB962 (hAP AC) (5x) without any issues, 2.4G/5G wifi work as expected, thanks !
honzam
Re: v6.42 [current]
Tue Apr 17, 2018 5:59 pm
viewtopic.php?f=21&t=132181#p649247
ErfanDL
Re: v6.42 [current]
Tue Apr 17, 2018 6:08 pm
Upgrade RB951Ui-2hND - RB2011UiAS2hND - hAP Lite. without any issue
xavierbt
Re: v6.42 [current]
Tue Apr 17, 2018 6:14 pm
Please, could you detail a bit more?
Thank you
xavier
Redmor
Re: v6.42 [current]
Tue Apr 17, 2018 6:16 pm
What do you mean with "upgrade", isn't 6.42 enough? I have to upgrade Routerboard's firmware?
I also have to upgrade clients to 6.42 and also RB firmware?
R1st0
Re: v6.42 [current]
Tue Apr 17, 2018 6:29 pm
Will there be hw-offload support for QnQ anytime soon?
MartijnVdS
Re: v6.42 [current]
Tue Apr 17, 2018 7:51 pm
Thank you
xavier
viewtopic.php?f=7&t=129616
(I presume)
bbs2web
Re: v6.42 [current]
Tue Apr 17, 2018 9:18 pm
Hi strods,
VirtIO multI-queue does not actually work on 6.42rc56. I've sent an email to support and posted information in the 6.42rc56 discussion forum, hope this is easily fixed by RouterOS calling ethtool to actually enable multi-queue.
Information available here:
viewtopic.php?f=21&t=129034&start=500#p653844
deividask
Re: v6.42 [current]
Tue Apr 17, 2018 9:20 pm
After upgrading from 6.41.3, RB850Gx2 started rebooting in a loop, reseting did help but only after 4th time, and still wasn't able to restore from backup, restoring from backup it started rebooting again.
with 6.41.4 IPTV (multicast) traffic started glitching, I had to switch back to 6.41.3...
strods
Re: v6.42 [current]
Tue Apr 17, 2018 9:30 pm
deividask - Please send supout file from your router to support@mikrotik.com. If you can reproduce the crash constantly, then we should be able to do the same and resolve issue quickly. Please also include description of your network traffic.
mszru
Re: v6.42 [current]
Tue Apr 17, 2018 9:36 pm
I face the same issue on hAP ac (RB962).
In my case Tx Rate is always zero for ethernet interfaces added to the bridge with hardware offloading enabled. Disabling hardware offloading for the bridge port fixes the issue, but you get another one - no hw offloading :)
hknet
Re: v6.42 [current]
Tue Apr 17, 2018 10:20 pm
it seems we lost packet fragmentation for EoIPs connecting bridges between two MTs we no longer can transport big pppoe-frames there; was working with 6.41.4
bbs2web
Re: v6.42 [current]
Wed Apr 18, 2018 12:59 am
RouterOS 6.42 does appear to include the VirtIO multi-queue driver but I assume information may have purposefully been left out of the change logs due to it not actually working. We left RPS enabled to distribute the IRQ events on the first queue to the various cores:
Hi strods,
Spirch
Re: v6.42 [current]
Wed Apr 18, 2018 5:56 am
WIFI on the cAP ac is WAY better, i dont need to update my hAP ac2 for now since the wifi on it only turn on when the hAP is down and that shouldn't happen often or never
if you can tweak it more, that would be nice but for now this local speed is more than my internet which is all i can ask for now
(the hAP got very very basic config, mostly a bridge and just a dhcp-relay by lan to my cAP)
D:\Download\Benchmark\iperf-3.1.3-win64>iperf3.exe -s -i 5 -V -d
iperf 3.1.3
CYGWIN_NT-6.1 Win7-PC 2.5.1(0.297/5/3) 2016-04-21 22:14 x86_64
get_parameters:
"tcp": true,
"omit": 0,
"num": 5120000000,
"parallel": 1,
"len": 131072
Time: Wed, 18 Apr 2018 02:42:23 GMT
Accepted connection from ****, port 42972
Cookie: ****
TCP MSS: 0 (default)
[ 5] local **** port 5201 connected to **** port 42973
Starting Test: protocol: TCP, 1 streams, 131072 byte blocks, omitting 0 seconds, 5120000000 bytes to send
[ 5] 0.00-5.00 sec 111 MBytes 186 Mbits/sec
[ 5] 5.00-10.00 sec 113 MBytes 189 Mbits/sec
[ 5] 10.00-15.00 sec 113 MBytes 190 Mbits/sec
[ 5] 15.00-20.00 sec 114 MBytes 191 Mbits/sec
[ 5] 20.00-25.00 sec 112 MBytes 188 Mbits/sec
[ 5] 25.00-30.00 sec 115 MBytes 193 Mbits/sec
[ 5] 30.00-35.00 sec 113 MBytes 190 Mbits/sec
[ 5] 35.00-40.00 sec 112 MBytes 189 Mbits/sec
[ 5] 40.00-45.00 sec 107 MBytes 180 Mbits/sec
[ 5] 45.00-50.00 sec 114 MBytes 191 Mbits/sec
[ 5] 50.00-55.00 sec 116 MBytes 194 Mbits/sec
[ 5] 55.00-60.00 sec 115 MBytes 193 Mbits/sec
[ 5] 60.00-65.00 sec 110 MBytes 184 Mbits/sec
[ 5] 65.00-70.00 sec 91.7 MBytes 154 Mbits/sec
[ 5] 70.00-75.00 sec 106 MBytes 177 Mbits/sec
[ 5] 75.00-80.00 sec 107 MBytes 180 Mbits/sec
[ 5] 80.00-85.00 sec 103 MBytes 172 Mbits/sec
[ 5] 85.00-90.00 sec 108 MBytes 180 Mbits/sec
[ 5] 90.00-95.00 sec 106 MBytes 178 Mbits/sec
[ 5] 95.00-100.00 sec 105 MBytes 177 Mbits/sec
[ 5] 100.00-105.00 sec 98.4 MBytes 165 Mbits/sec
[ 5] 105.00-110.00 sec 95.2 MBytes 160 Mbits/sec
[ 5] 110.00-115.00 sec 104 MBytes 174 Mbits/sec
[ 5] 115.00-120.00 sec 101 MBytes 170 Mbits/sec
[ 5] 120.00-125.00 sec 103 MBytes 172 Mbits/sec
[ 5] 125.00-130.00 sec 106 MBytes 178 Mbits/sec
[ 5] 130.00-135.00 sec 106 MBytes 177 Mbits/sec
[ 5] 135.00-140.00 sec 104 MBytes 175 Mbits/sec
[ 5] 140.00-145.00 sec 104 MBytes 175 Mbits/sec
[ 5] 145.00-150.00 sec 104 MBytes 174 Mbits/sec
[ 5] 150.00-155.00 sec 103 MBytes 173 Mbits/sec
[ 5] 155.00-160.00 sec 103 MBytes 173 Mbits/sec
[ 5] 160.00-165.00 sec 89.2 MBytes 150 Mbits/sec
[ 5] 165.00-170.00 sec 90.6 MBytes 152 Mbits/sec
[ 5] 170.00-175.00 sec 70.2 MBytes 118 Mbits/sec
[ 5] 175.00-180.00 sec 90.4 MBytes 152 Mbits/sec
[ 5] 180.00-185.00 sec 107 MBytes 179 Mbits/sec
[ 5] 185.00-190.00 sec 105 MBytes 176 Mbits/sec
[ 5] 190.00-195.00 sec 92.0 MBytes 154 Mbits/sec
[ 5] 195.00-200.00 sec 105 MBytes 177 Mbits/sec
[ 5] 200.00-205.00 sec 105 MBytes 177 Mbits/sec
[ 5] 205.00-210.00 sec 91.3 MBytes 153 Mbits/sec
[ 5] 210.00-215.00 sec 104 MBytes 174 Mbits/sec
[ 5] 215.00-220.00 sec 108 MBytes 182 Mbits/sec
[ 5] 220.00-225.00 sec 103 MBytes 173 Mbits/sec
[ 5] 225.00-230.00 sec 91.8 MBytes 154 Mbits/sec
[ 5] 230.00-235.00 sec 105 MBytes 176 Mbits/sec
[ 5] 235.00-235.15 sec 2.93 MBytes 168 Mbits/sec
Test Complete. Summary Results:
[ 5] 0.00-235.15 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-235.15 sec 4.77 GBytes 174 Mbits/sec receiver
CPU Utilization: local/receiver 20.1% (6.1%u/14.0%s), remote/sender 0.0% (0.0%u/0.0%s)
get_results
"cpu_util_total": 37.142600,
"cpu_util_user": 0.815528,
"cpu_util_system": 36.329200,
"sender_has_retransmits": 0,
"streams": [{
"id": 1,
"bytes": 5120111392,
"retransmits": -1,
"jitter": 0,
"errors": 0,
"packets": 0
send_results
"cpu_util_total": 20.074440,
"cpu_util_user": 6.058271,
"cpu_util_system": 14.016169,
"sender_has_retransmits": -1,
"streams": [{
"id": 1,
"bytes": 5119705644,
"retransmits": -1,
"jitter": 0,
"errors": 0,
"packets": 0
yhfung
Re: v6.42 [current]
Wed Apr 18, 2018 6:51 am
strods,
Please ignore the following post since I am able to get better reset after a hardware reset when the unit is no longer accessible by winbox. Now the unit is back to normal and I shall carry out the following tests.
Thank your reply for our problems encountered. In the past, we put our time on the ac, we did not put much time on 2.4GHz performance. In this morning, I would like to performance the complete test including 2.4GHz, I found that the performance was very very bad that I could not use it to edit post on MikroTik Forum.
For details, please take a look at other post that was written by within this Forum as follows:
viewtopic.php?f=7&t=132648&start=50#p654964
jarda
Re: v6.42 [current]
Wed Apr 18, 2018 7:15 am
Yep. My tests says that the hap ac2 is able to fluctuate around 40-100Mbits over ac with terrible ccq while the signal levels are good and band clear. Still nothing to be happy of.
amt
Long time Member
Long time Member
Re: v6.42 [current]
Wed Apr 18, 2018 8:06 am
Updated SXT Lite5 Ac from 6.40.5 to 6.42 and device down, After netinstall device work again...
yhfung
Re: v6.42 [current]
Wed Apr 18, 2018 8:33 am
After have hardware reset my unit, I repeated the tests on 2.4GHz and 5GHz bands. The results are
The download speed for 2.4GHz is 55Mbps, Retr=1481.
The download speed for 5GHz is 124Mbps, Retr=6418.
The target for 2.4GHz for n is 200Mbps with zero count in Retr
The target for 5GHz for ac is 500Mbps with zero count in Retr.
For details, please see the following link:
viewtopic.php?f=7&t=132648&p=654976#p654976
alibalalo
Re: v6.42 [current]
Wed Apr 18, 2018 9:22 am
Please tell us what devices support this addition
ErfanDL
Re: v6.42 [current]
Wed Apr 18, 2018 9:38 am
after upgrade to 6.42 on RB2011: can not show PPPOE Client on LCD. show interface as unknown ! and can not remove unknown interface
zilf
Re: v6.42 [current]
Wed Apr 18, 2018 9:56 am
I face the same issue on hAP ac^2 too.
mattjhaigh
Re: v6.42 [current]
Wed Apr 18, 2018 10:45 am
Install and upgrade via packages menu option crashed my 3011. Anyone else have issues. Now in constant boot loop. Cannot launch kernel. Any recommended next steps ?
Kindis
Re: v6.42 [current]
Wed Apr 18, 2018 10:52 am
I have updated two 3011 without issues. My guess is netinstall for you.
from which version did you upgrade? I want from 6.41.4
Simono
Re: v6.42 [current]
Wed Apr 18, 2018 11:13 am
Guys what this means:
nuffrespect
Re: v6.42 [current]
Wed Apr 18, 2018 11:20 am
Hi, updates to 6.42 without any problems from different versions 6.41--6.41.X (current)
CHR --> 1 pc | hEXr3 --> 15 pc | CCR1009-7G --> 2 pc | CCR-1009-8G --> 3 pc |
wAPac --> 30 pc | SXT5Lite --> 5 pc | SXT5 --> 5 pc | SXT5ac --> 2 pc |
Metal5ac --> 1 pc | RB2011 --> 6 pc
Chupakabra303
Re: v6.42 [current]
Wed Apr 18, 2018 11:41 am
I have failed to write in variable. Any way.
Chupaka
Re: v6.42 [current]
Wed Apr 18, 2018 11:48 am
In CLI, you can see interface-lists in "interface=" values when you press Tab.
Simono
Re: v6.42 [current]
Wed Apr 18, 2018 11:51 am
Chupaka Ahh waitng when it be available on Winbox.
JanezFord
Re: v6.42 [current]
Wed Apr 18, 2018 11:55 am
My rb850gx2 (early - non ipsec version) went into reboot loop for an hour ... then managed to stabilise itself and seems to be running stable now for more than an hour. Log reports: kernel failure in previous boot. Upgraded from 6.41.3.
Chupaka
Re: v6.42 [current]
Wed Apr 18, 2018 12:20 pm
Yeah, funny, WinBox shows "Unknown interface" when you add it via CLI with interface-list :)
csi
Re: v6.42 [current]
Wed Apr 18, 2018 12:21 pm
I get a some issues with bonding 802.3ad interfaces. First between BR3011 and CRS326. There is no traffic if bonding is configured with two activated interfaces. If I release one interface, traffic will pass the bonding interface and all is fine. When I reconnect the second interface, traffic is interrupted again. Within the bonding interface, a bunch of VLANs are configured.
On the CRS326 is a second bonding interface is configured without some VLANs. On this interface bonding works and balanced the traffic as expected, but the speed is not faster then 100 MBit/s per link. With RouterOS 6.42rc39 I get full GBit/s speed on this link.
As already mentioned the CRS326 was upgraded from 6.42rc39, the RB3011 from 6.41.4.
Many thanks
pietroscherer
Trainer
Trainer
Re: v6.42 [current]
Wed Apr 18, 2018 2:52 pm
Running fine on a RB941-2nD (hAP-lite) as SOHO (L2TP + IPSec). :D
wenasong
Re: v6.42 [current]
Wed Apr 18, 2018 2:55 pm
Same issue, can't generate supout. Even after Netinstall, RouterBOOT @ 3.24, and 6.41.3 before web upgrade.
csi
Re: v6.42 [current]
Wed Apr 18, 2018 3:59 pm
Many thanks
The performance issue is no longer a problem and has been solved. The RB3011 <- bond -> CRS326 is still open.
irghost
Re: v6.42 [current]
Wed Apr 18, 2018 6:04 pm
LTE Interface does not work in 6.42
Wave
Re: v6.42 [current]
Wed Apr 18, 2018 6:41 pm
When upgrade packages to v6.42 in CHR router (Hyper-V image), after reboot have:
Loading system with initrd
ERROR: could not find disk!
Please attach it somewhere else.
System hangs up.
When loading blank chr-6.42.vhdx, the same error.
Before v6.42 all works fine.
Something wrong with .vhdx image?
JohnTRIVOLTA
Re: v6.42 [current]
Wed Apr 18, 2018 7:29 pm
I have hap lite /smips/ with 6.41.2 . With 6.42 in station mode and WEP security /40bit/not work - can not connect. I downgrade to bugfix 6.40.7 and everything is fine - the routrboard is connected !
msatter
Re: v6.42 [current]
Wed Apr 18, 2018 8:42 pm
I am trying on the moment 6.42 with the new bridging setup. Had some problems to access websites and an other setup (NAT) than I used on 6.40.6 did solve that.
My L2TP/IPSEC is about 20 to 30 percent slower on 6.42 than on 6.40.6 and I will try 6.42 some more and try solve the slowness I experience in the new bridge setup. I have RTSP active and except for the slower VPN that drops from 90 Mbps to 70 Mbps.
Update: did some optimizing on the mangle and raw and I now get the same or more speed through L2TP/IPSEC than on 6.40.6.
stefanca
Re: v6.42 [current]
Wed Apr 18, 2018 9:50 pm
Hi All,
For the last couple of times every time I try to upgrade a map lite it crashed and I need to reinstall it through netinstall.
By design those are powered only through poe switch, but that doesn't seem to work for upgrading.
This time I expressly connected them to a normal network connection and usb power.
Still no luck boot loop after upgrade.
I've already contacted support but until now didn't really get an answer about this issue ?
Anybody else having the same issues with map lite ?
stefanca
Re: v6.42 [current]
Wed Apr 18, 2018 9:52 pm
Nightmare upgrade.
Considering previous upgrades this one didn't go smooth at all.
I was able to upgrade my ccr's / csrs without a problem.
However I have a small hex poe light witch powers a test setup with a cap lite / 2 rb2011 / netmetal.
In the past upgrades went without a problem. this time each device stayed in a boot loop.
I've even tried a rb 2011 directy connected to power and still same issue :(
Might want to be carefull in production for this one.. :(
Kindis
Re: v6.42 [current]
Wed Apr 18, 2018 10:27 pm
System hangs up.
I have updated two CHR running under Hyper-V (2012R2) without any issues at all. Much appreciated additions for CHR in this release so it should work. Which version of Hyper-v are you using?
artemk
Re: v6.42 [current]
Wed Apr 18, 2018 10:34 pm
After an upgrade of multiple devices to 6.42:
1. /ip neighbor discovery - is not working anymore on dynamic (L2TP) interfaces
2. OSPF is broken. Massive messages:
2018-04-18T22:23:14.504801+03:00 kv-per37k7-rtr01.sysadm.in.ua route,ospf,info Ignoring Link State Acknowledgment packet: wrong peer state
2018-04-18T22:23:14.504801+03:00 kv-per37k7-rtr01.sysadm.in.ua route,ospf,info state=Init
Other side routers shows that incorrect source IP is being used for OSPF packets.
OSPF is running in VRF but source is from main table!!!!
3. Log window (in winbox 3.13) shows only one last line. Which is the biggest pain in the ass as it does not give a chance to debug issues
I think more will come.
UPGRADE TO PRODUCTION DEVICES IS NOT RECOMMENDED!!
artemk
Re: v6.42 [current]
Wed Apr 18, 2018 11:23 pm
Resolved. Caused by wrong NAT rule :(
dravnieks
Re: v6.42 [current]
Thu Apr 19, 2018 1:04 am
Hard to tell is there any improvement. When running TCP bandwidt test on every client, 40-45 Mbit getting average 700Kbps per client. With less than 10 clients can get approx 50-55Mbps troughput.
There is bug in ping or in packet transmision. on every ping request there is 2 responses. packet loss -70%(minus)
w0lt
Long time Member
Long time Member
Re: v6.42 [current]
Thu Apr 19, 2018 2:08 am
Seems to work ok for me in various devices
-tp
raymondr15
Re: v6.42 [current]
Thu Apr 19, 2018 3:29 am
What is the wireless XX option under Channel width?
Jamesits
Re: v6.42 [current]
Thu Apr 19, 2018 3:45 am
I'm running into a similiar problem on RB3011. I have bonding configured on SFP and one Ethernet to CRS317 and a lot of VLANs on that bonding interface; RB3011 seems to be unable to handle traffice after booting for several hours. Bridging seems to be broken, downlink devices cannot get DHCP leases or cannot ping router. (but some devices still get some sort of network connectivity regardless of whether they can ping gateway.) Reboot usually solves the problem (not guaranteed).
AkaZLOY
Re: v6.42 [current]
Thu Apr 19, 2018 4:36 am
Upgrade SXT LTE without any problems.
sterling
Re: v6.42 [current]
Thu Apr 19, 2018 4:42 am
Is it just me, or can anyone else not Torch any Ethernet interfaces in a bridge on a CRS device?
Specifically CRS210-8G-2S+?
I'm using 6.42 but I think this also applies to some earlier versions as well.
Winbox 3.13
When I Torch any Ethernet interface it only shows a blank screen.
I can torch the bridge, but it just shows broadcast traffic, nothing specific to the interfaces belonging to the bridge.
glat
Re: v6.42 [current]
Thu Apr 19, 2018 10:05 am
Same issue here. Two CHRs: first on 2008R2 does not boot, second on 2012R2 is ok.
Please check.
Redmor
Re: v6.42 [current]
Thu Apr 19, 2018 10:18 am
I have upgraded 3 wAP and lte interface works, try to reset RB or downgrade to another stable and then upgrade again.
artz
Re: v6.42 [current]
Thu Apr 19, 2018 10:41 am
Jamesits, csi -
Please write to support@mikrotik.com
We will need to see your network topology and your supout.rif from both devices.
There is something specific in your configuration or your setup that might be causing these issues.
amt
Long time Member
Long time Member
Re: v6.42 [current]
Thu Apr 19, 2018 10:58 am
I am wondering too
Redmor
Re: v6.42 [current]
Thu Apr 19, 2018 1:30 pm
I've upgraded AP and two of three stations connected, only RouterOS
eworm
Re: v6.42 [current]
Thu Apr 19, 2018 1:33 pm
Same for me. Anybody should update the documentation in the wiki (and possibly add an example).
diablonet
Re: v6.42 [current]
Thu Apr 19, 2018 2:08 pm
How did you tried, I am also looking for this feature, thank you
WirelessRudy
Re: v6.42 [current]
Thu Apr 19, 2018 3:59 pm
It's been said somewhere in another tread, but the improvements are only noticeable in a P2MP network with more then lets say 15-20 connected CPE's.
We tried is on some with 28+ connected clients and indeed increased the total throughput by some 60-100% and each client also saw more speed, and the most importante feature, if one bad signal client consumes the 'airtime' of the AP a lot because of his low modulation rate and thus throughput and thus time needed for transport of data, under the new version ROS the bad client doesn't have no more effect.
I tried that last where we have had a -75dBm client that had only a couple of megabits of speed in a 28 client network where other had much more speed, some 30Mbps in a single client test, after the uprade not only could I run several clients at the same time with 30-60mbsp, a single client up to 80-90Mbps, and when I did start the bandwidth test of the 'bad' client he not only also went up from 1 to some 5Mbps but more important, it didn't have an effect on the other clients running their download bandwidth test.
It did have an disastrous effect while AP was still running the old software.
Only the AP needs the upgrade.
WirelessRudy
Re: v6.42 [current]
Thu Apr 19, 2018 4:00 pm
Indeed, that what I would like to know too.....
jarda
Re: v6.42 [current]
Thu Apr 19, 2018 4:13 pm
Ce - eC automatic selection? Just a guess.
rajo
Re: v6.42 [current]
Thu Apr 19, 2018 5:27 pm
@MikroTik:
Could you please add robustness to your DHCP and PPPoE clients. They are unreliable and I have had to add scripts to restore connectivity after a drop.
Right now, I've got a router with DHCP stuck in status "renewing..." and I have no default gateway. This should not happen. Monitor the DHCP request processes, with timeouts and follow-up actions.
I also have to deal with the same kind of crap with L2TP servers, whereby sometimes the service gets in a bad state and some clients are able to establish tunnels and some keep failing -- until I reboot the router that is the server.
Same goes for OSPF and some other routing/forwarding protocols sometimes misbehaving until a reboot... and on and on.
You are missing a lot of service health/status checks, problem detection and recovery routines in your code. Users shouldn't have to write so many scripts to recover operation of core functionality. This has pretty much been the routine over the past 6 years, for every routerboard line I have dealt with, and it gets frustrating.
We need greater stability.
And for any user who's going to respond about it all working great for them, keep it to yourself. You're not being helpful.
mrz
Re: v6.42 [current]
Thu Apr 19, 2018 5:52 pm
Do you actually reported to support?
If it is on the same router, then for me it looks like problem with interface driver not separate processes.
eddieb
Re: v6.42 [current]
Thu Apr 19, 2018 5:57 pm
DHCP client and server work as expected. PPPoE client also ... No problems on my RB2011 here
filzek
Re: v6.42 [current]
Thu Apr 19, 2018 7:02 pm
Problem with 6.42 on Whatsapp, if there more than 2 whatsapp connected the new ones will not connect will be offline, same problem with web.whatsapp can you guys check?
Guentha
Re: v6.42 [current]
Thu Apr 19, 2018 7:38 pm
Rb2011 lost wireless option after the upgrade. I see the wireless 6.42 package is still in the files. I added the wireless package from the extras package and it won't load either. Many reboots and still no install.
en1gm4
Re: v6.42 [current]
Thu Apr 19, 2018 9:08 pm
upgraded one RB951G-2HnD in office (running as an AP only) and it went fine
just upgraded another RB951G-2HnD at home (also an AP only) and it immediately went into a bootloop... beeping every 7 seconds or so. I was only upgrading the software and using winbox.
power on reset does not help
can not get it to netinstall either. never had tu use it before but have read many sets of online instructions and pretty sure i am doing everything right.. the RB never even shows up in the netinstall window
anyone else had this problem and solve it ?(my kids are cross with me now .. no wifi ;)
EDIT: managed to get it back in the end... netinstall to the rescue (change of cables and a switch between the MT and the PC got me there in the end)
steen
Re: v6.42 [current]
Thu Apr 19, 2018 10:18 pm
Hello Folks!
I tried two devices, rb411, one worked and the other disappeared from network will visit it physically tomorrow trying to figure out what happened.
The first device took unusual long time come back on network.
spookymulder84
Re: v6.42 [current]
Thu Apr 19, 2018 11:12 pm
no problems with update from 6.40.5 to 6.42 on hap lite with almost stock configuration
ErfanDL
Re: v6.42 [current]
Thu Apr 19, 2018 11:34 pm
Maybe set your wifi channel to combined ce and ec!
irghost
Re: v6.42 [current]
Fri Apr 20, 2018 12:35 am
i have SXT LTE
raymondr15
Re: v6.42 [current]
Fri Apr 20, 2018 1:17 am
I am wondering too
Was thinking that but would like to be sure :lol:
raymondr15
Re: v6.42 [current]
Fri Apr 20, 2018 1:19 am
I just realized earlier that after I updated to v6.42 that all my ip>firewall>raw rules were missing, not sure if that was the only config missing, I just restored a backup and everything was back.
WirelessRudy
Re: v6.42 [current]
Fri Apr 20, 2018 3:04 am
Just upgraded my rb2011 this afternoon and wireless just works..... try to downgrade and see if it comes back. If not, radio is dead. If yes, upgrade again and see what happens...
WirelessRudy
Re: v6.42 [current]
Fri Apr 20, 2018 3:07 am
?? How is that? It can only be Ce or eC. The eCe would make a 60Mhz wide channel which is not supported by 802.11ac
WirelessRudy
Re: v6.42 [current]
Fri Apr 20, 2018 3:10 am
For AP? Because for station any 20/40/80 setting wil work with AP. No matter what AP is using. As long as the frequency of the scan range can 'see' the AP it will adapt.
aiwo
Re: v6.42 [current]
Fri Apr 20, 2018 5:33 am
I'm pretty happy with this version so far. :)
Speedtest history shows the difference - upgrade at 4:10am. No configuration changes.
Sadly this will not protect my beloved RB from replacement - I have available 500Mbps downlink since 2 weeks. ;(
koolkid1935
Re: v6.42 [current]
Fri Apr 20, 2018 9:01 am
I'm having an issue upgrading a CHR instance from 6.42rc20 to 6.42 current/stable using
/system upgrade install
. I have it licensed at a P1 level and it shows it's current when I run
/system license print
prior to the upgrade but when it reboots after the upgrade, it says starting as it normally does then it says my demo license has expired on the console and powers off immediately after that. It's running on an ESXI 6.5 host.
Do I need to do a fresh install instead of attempting to upgrade?
xbipin
Re: v6.42 [current]
Fri Apr 20, 2018 9:06 am
first time in my life i had to downgrade back to 6.41.4 coz on this 6.42 my wifi signal was dropping every 15mins or so and in log was constantly seeing unicast key exchange time. Im using metal 52 with level 4 license.
Back on 6.41.4 and everything back to stable again
csi
Re: v6.42 [current]
Fri Apr 20, 2018 9:07 am
Jamesits, csi -
I have send out both supout files. Did you need more information? Btw. it would be helpful if you support area on your website would allow to upload more then one supout.rif file or allow zip files. I added the the secound supout as picture ;-)
timoid
Re: v6.42 [current]
Fri Apr 20, 2018 9:13 am
any changes in the group-ciphers settings in wifi?
I've had to change from
group-ciphers=aes-ccm
to
group-ciphers=tkip,aes-ccm
in order for my MT clients to connect.
... disconnected, group key exchange timeout
XaTTa6bl4
Re: v6.42 [current]
Fri Apr 20, 2018 9:45 am
PCC (Per Connection Classifier) load balancer totally broke after upgrade 6.40.5 -> 6.42.
Downgrade to 6.41.4 made it work again. Tested on two RB2011
amt
Long time Member
Long time Member
Re: v6.42 [current]
Fri Apr 20, 2018 10:07 am
I am wondering too
Still no any answer :) :) :)
pepek
Re: v6.42 [current]
Fri Apr 20, 2018 2:44 pm
I had same problem year or two ago. Reseting configuration to default/empty solved me the problem.
Institor
Re: v6.42 [current]
Fri Apr 20, 2018 3:49 pm
netwatch - limit to read, write, test and reboot policies for Netwatch script execution;
Maybe i don't understand something, but why?
Now we can not use /tool fetch (for example, telegram bots), can not set global variables!. Please add at least "ftp" and "policy"!
It's very annoying.
normis
Re: v6.42 [current]
Fri Apr 20, 2018 3:54 pm
It's very annoying.
If you had a "write" only account, you could make a netwatch rule, that executes a script, that creates a "full" user, or worse. Permission escalation bug.
Abdock
Re: v6.42 [current]
Fri Apr 20, 2018 4:16 pm
I upgraded 2 CCR and it went okay, when i upgraded 1 of my ospf routers, it went into loop, and would not boot up, tried another one and same, It looks something is wrong with CCR upgrade, other routerboards are working fine after upgrade but i just did couple of them.
Institor
Re: v6.42 [current]
Fri Apr 20, 2018 4:39 pm
Okay... understandable. Wrote a script using /file set contents. It works for now.
thanks for answer!
frank333
Re: v6.42 [current]
Fri Apr 20, 2018 4:50 pm
installed now 6.42,works fine on rb3011.
miencek
Re: v6.42 [current]
Fri Apr 20, 2018 6:52 pm
Hello :)
How to use this new feature
*) fetch - added "output" option for all modes in order to return result to file, variable or ignore it;
Simono
Re: v6.42 [current]
Fri Apr 20, 2018 6:54 pm
I can't connect to my cAP ac on 5GHz from my Nokia 6 and SGS3. Phones see 5GHz network but nothing happens when I tap connect. Router don't show antyhing on log. Anyone have the same problem?
sterling
Re: v6.42 [current]
Fri Apr 20, 2018 8:18 pm
I've upgraded a handfull of CCR units running OSPF and VPLS endpoints on MPLS and everything seems fine.
Also done a few of our CRS units and it seems to work fine.
Though on one CCR I noticed a few of the Ether interfaces on a bridge that were not connected were 'flapping' at Ethernet connected, then not connected, then connected, kind of randomly.
That was very odd, and the logs showed it, but nothing physical was actually connected to those ports, lol!
I don't see that anymore, so maybe it was a fluke.
Also, I'm still having an issue where I can't torch a lot of the interfaces.
It just shows a blank Torch screen, like it won't start or something.
But that goes back a few versions too, same thing on a lot of my CCRs on previous versions 6.41.x as well.
Quindor
Re: v6.42 [current]
Fri Apr 20, 2018 9:25 pm
Upgraded a CCR1009, 2xCRS226 and 4xwAP AC without any issues. Was running a previous build of v6.42RCxx --> v6.42 final.
steen
Re: v6.42 [current]
Sat Apr 21, 2018 12:59 am
Hello Folks!
Physical visit, unplugging and plugging back power worked, the device came back and we could continue with /system routerboard upgrade followed by the required reboot and the device come back on network afterwards.
However, the high number of rb411, ospf everywhere, tons of vpn tunnels of all kinds criss crossing our network islands, tons of nv2 p2mp setups with critical customers and so on, made us think once more before we roll it out everywhere. I do as learnt at IBM, waiting to ".2 version" of current came out. :-)
cdiedrich
Forum Veteran
Forum Veteran
Re: v6.42 [current]
Sat Apr 21, 2018 3:22 am
!) w60g - increased distance for wAP 60G to 200+ meters;
I can confirm and I am super-impressed. Just set up a 190m shot on a festival site with not perfectly clear LoS and got signal 90 @ MCS8.
Constantly pushing 850MBit.
Wow.
-Chris
strods
Re: v6.42 [current]
Sat Apr 21, 2018 9:11 am
mszru, zilf, sterling, sterling - Traffic within switch (between HW bridge ports) does not reach CPU and will not show up on Torch.
hknet, ErfanDL, irghost, JohnTRIVOLTA, artemk, dravnieks, Jamesits, filzek, Guentha, xbipin, XaTTa6bl4 - Please send supout files to support@mikrotik.com.
bbs2web, JanezFord, Chupaka, wenasong - You should try you 6.43rc where additional fixes are included.
Spirch, jarda, yhfung - We are constantly working on improvements regarding this matter. You will see changes in changelog when we will manage to fix these problems.
alibalalo - Few posts ago: "Currently there is no RouterBOARD with such built-in wireless functionality".
mattjhaigh, Abdock - Netinstall should resolve the problem. However, serial console output might be useful for support in order to see the cause of the problem.
Simono - You can now choose "interface-list" instead of "interface" under these settings. Use multiple interfaces at the same time.
Chupakabra303, eworm, diablonet, miencek - Unfortunately we still have a work to do regarding this feature. It is not 100% complete yet.
Wave, glat, rajo, raymondr15, timoid, Simono - Please report this to support@mikrotik.com.
stefanca - Is mAP lite powered by RouterBOARD device which is also upgraded at the same time?
raymondr15, amt, WirelessRudy, ErfanDL, raymondr15 - This feature allows to select channel automatically by selecting the best one from available.
koolkid1935 - Problem is with rc not this release. You will have to create a new CHR instance.
Copper
Re: v6.42 [current]
Sat Apr 21, 2018 6:04 pm
There is no NTP package in the all_packages-smips-6.42.zip (hAP mini, hAP lite) :(
jacobtoupe
Trainer
Trainer
Re: v6.42 [current]
Sat Apr 21, 2018 6:18 pm
You just have to upgrade AP and all connected clients ROS.
Further reading :
viewtopic.php?f=21&t=132181&sid=30d50ab ... 36ce6531f4
bongani
Re: v6.42 [current]
Sat Apr 21, 2018 6:58 pm
6.42 on a CRS125-24G-1S with Fastpath enabled blackholes traffic. Toggling Fastpath off restores connectivity.
Abdock
Re: v6.42 [current]
Sat Apr 21, 2018 9:08 pm
Netinstall will put the router backup but I am afraid i cannot upgrade these over the air, I tried to downgrade rb1100x2 and all went into same reboot cycle.
Jotne
Re: v6.42 [current]
Sat Apr 21, 2018 11:10 pm
That is correct observed.
karwos
Re: v6.42 [current]
Sun Apr 22, 2018 4:01 am
SXT bricked after 5.26 upgrade to 6.42
Please withdraw this release or add some warning on top.
BartoszP
Re: v6.42 [current]
Sun Apr 22, 2018 7:25 am
Does 5.26 to 6.41 upgrade go without problems? Jumping 43 versions ahead with MAJOR change of bridge and switch implementations? Brave move.
koolkid1935
Re: v6.42 [current]
Sun Apr 22, 2018 8:58 am
That seems to have worked. Created a new CHR instance using the 6.42 VMDK, restored config, transferred the P1 license to the new instance, all is well again.
mrtester
Re: v6.42 [current]
Sun Apr 22, 2018 10:40 am
I did test upgrade from 5.26 to this version. Just for testing. Everything went well. Upgrade failed for you due to configuration or something like thta. In general it works just fine.
Neovr
Re: v6.42 [current]
Sun Apr 22, 2018 11:16 am
After update some AP's i have cpu load 100% .... (Omnitik)
Disable wlan not solve problem....
Reset config ang manual set all settings not solve problem...
Latest 42rc have some bug... but disable SNMP solve problem ...!!??
Ping to affected router 100-1000ms, and router randomly rebooted, reboot reason in log is : router rebooted becouse critical program crashed
Downgrade to 6.40.7 solve problem
karwos
Re: v6.42 [current]
Sun Apr 22, 2018 12:58 pm
5.26 to 6.40 - no problems, Mr Smartie
karwos
Re: v6.42 [current]
Sun Apr 22, 2018 1:20 pm
My experience of new NV2 implementation:
1) Overall throughput increased, that's true. Previously, as I look on graphs on 2 test APs it didn't reached 40MBits. Now can reach 85mbits easily.
2) However there is some problem with TDMA timing.
For example, let run btest between AP with 6.42 and some 2 stations:
2) Do test with 1 tcp count to this 2 stations. Speeds will be almost equally splitted (as pre-6.42)
3) Do test with 20tcp count to 1st station, and 1tcp count to 2nd station. 1st station will get full speed, and 2nd station just 0.5-1.5mbits
So there is something wrong with new NV2 and tcp connections count.
pe1chl
Re: v6.42 [current]
Sun Apr 22, 2018 1:38 pm
Updated RB2011 and also installed Winbox 3.13
Now when I open bridge menu, ports tab the winbox hangs.
Don't know if it was the 6.42 or the Winbox update that causes it.
Bridge is configured with 4 VLAN's (not changed from 6.41)
en1gm4
Re: v6.42 [current]
Sun Apr 22, 2018 3:59 pm
perhaps not as important as some other bugs being posted, but i noticed that kid control in webfig seems to be broken
after adding a schedule in winbox, the times in webfig are showing as incorrect. it looks as though it is showing the end times as the same as the start times (?)
this is on an RB750Gr2
(am I correct in assuming that Mikrotik staff monitor this forum and these things don't need to be reported somewhere else?)
sindy
Re: v6.42 [current]
Sun Apr 22, 2018 4:13 pm
They do but don't rely on that, this is not an official feedback channel. An e-mail report to support@mikrotik.com will be properly tracked by a trouble ticket tracking system.
netflow
Re: v6.42 [current]
Sun Apr 22, 2018 4:26 pm
I am really surprised you don't get more out of this device. Could you identify what is the limiting factor ?
bcall
Re: v6.42 [current]
Sun Apr 22, 2018 8:41 pm
Same here. I have the RB850Gx2 with hardware IPsec capabilities. Software update to 6.42 was fine. Firmware update to 6.42 resulted in a loop that eventually resolved itself (no more than 5 minutes later). After it came back up, Winbox reported the firmware was 6.42. I tried the upgrade again just to see what would happen, and it failed in the same manner, a couple reboot cycles. Kernel failure on boot is reported each time. Winbox UI still says firmware is at 6.42. Perhaps this is a bug with one of the post-upgrade checks that fails while the rest of it succeeds?
bcall
Re: v6.42 [current]
Sun Apr 22, 2018 9:15 pm
Just tossing in a +1 here for this happening to me, too. Winbox crashes in my case. Both Winbox 3.12 and 3.13. It only happens on my RB850Gx2. My RB750gl and NetMetal5 are fine.
These devices aren't critical to any business, so I haven't reached out to support. If the crash is unusual among folks here and anyone on the support team wants more details, feel free to reach out to me.
abcwarbot
Re: v6.42 [current]
Mon Apr 23, 2018 3:07 am
Hi all,
Slow performance even uploading a package file.
Regards,
strods
Re: v6.42 [current]
Mon Apr 23, 2018 7:35 am
Copper, Jotne - There never have been one. SMIPS platform devices does hot have a NTP package since devices are designed for simple home usage and there is not enough space on router to store such packages.
bongani, Neovr, karwos, en1gm4, abcwarbot - Please send supout files to support@mikrotik.com and report this problem.
Abdock - Please provide serial console output to support@mikrotik.com from the router which is rebooting itself and can not boot up properly.
karwos - Please write to support@mikrotik.com and provide your configuration which was used on 5.26 version. We will try to reproduce the same problem locally.
pe1chl, bcall - We already recieved such problem report which is most likely caused by Winbox. We will fix it as soon as possible.
bcall - Problem should be resolved in 6.43rc version.
A9691
Re: v6.42 [current]
Mon Apr 23, 2018 10:49 am
There is bug finding a disabled ppp-client interface.
[admin@PinceGW-teszt] > /interface ppp-client
[admin@PinceGW-teszt] /interface ppp-client> print
 0 X  name="modem" max-mtu=1500 max-mru=1500 mrru=disabled port=usb1 data-channel=0 info-channel=1
      apn="lant" pin="0000" user="" password="" profile=default phone="" dial-command="ATDT"
      modem-init="" null-modem=no dial-on-demand=no add-default-route=yes default-route-distance=1
      use-peer-dns=yes keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
[admin@PinceGW-teszt] /interface ppp-client> /delay 20; set modem disabled=no
no such item (4)
Notice the /delay 20 command before trying to enable the interface. The problem occurs only if
there is a pause after the last reference to the interface.
I observed this bug in v 6.41, reported and sent supout.rif on 2018-apr-14.
(I'm using RB951G 2HnD)
martincs
Re: v6.42 [current]
Mon Apr 23, 2018 11:10 am
Does anyone have tried to run CHR 6.42 with more than 7 connected NICs on vsphere? After upgrade to 6.42 I am getting reboot loop... before upgrade reboot loop was only if 10NICs are connected...
So I can't understand if that is related with my vsphere/VM configuration or RouterOS... More or less no response from support...
The error what I can see in shell before reboot is "No irq handler for vector...."
astraliens
Re: v6.42 [current]
Mon Apr 23, 2018 12:57 pm
RB2011UiAS-2HnD after upgrade works fine for 4 days, but found some strange thing after 22 hours uptime I've got >3000 Sector writes.
Can anyone check is it for everyone or only my config. The same situation was about a year or two ago in latest v5 or earlier v6 versions of ROS and was fixed, maybe those problem returned.
msatter
Re: v6.42 [current]
Mon Apr 23, 2018 1:10 pm
Should that not be :delay 20;?
A9691
Re: v6.42 [current]
Mon Apr 23, 2018 1:33 pm
..hmm. Interesting. I didn't knew that commands with : can be used with / instead of : ... or something like that.
[admin@pincegw] > :global a 10; /set a 5; /put $a
5
Is there any difference between for example :put and /put ?
xbipin
Re: v6.42 [current]
Mon Apr 23, 2018 3:05 pm
i managed to fix my wifi drop issue on 6.42, had to reduce transmit power by 10 dB by inserting this value in antenna gain, day by day its getting impossible to use a mikrotik AP in a noisy environment, i was better off using my previous UBNT AP which was much more immune to noise.
the second complaint being since i bought this metal 52ac device more than a year back, i was told in future updates it would show the current transmit power table which till date hasnt been implemented at all.
strods
Re: v6.42 [current]
Mon Apr 23, 2018 3:23 pm
Version 6.42.1 has been released in current channel:
viewtopic.php?f=21&t=133535
uldis
Re: v6.42 [current]
Mon Apr 23, 2018 6:05 pm
What is your AP - also RouterOS or some other equipment?
strods
Re: v6.42 [current]
Thu May 31, 2018 9:49 am
Everyone who complained about the Netwatch issue - Please see this topic viewtopic.php?f=2&t=134538
