Insider
LHG 60G experience
Thu Apr 19, 2018 1:12 pm
How are we going there? Pretty good by the way! Heavy porn!
We are having installed link for 1200m, pretty good and clear link, I hadn't believed it, but this piece of metal really kicks ass!!
Ok this is CLI of 6.43, so you need not to ask, WTH is that..
connected: yes
frequency: 58320
remote-address: 30:07:4D:XX:XX:XX
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -59
tx-sector: 15
tx-sector-info: right 1.4 degrees, down 1 degrees
rx-sector: 96
How about you?
Frequency microwave transvertors, design, development, manufacture
http://Pojitko.cz
mlenhart
Re: LHG 60G experience
Thu Apr 19, 2018 2:24 pm
How were you able to obtain it? AFAIK it is not in sale anywhere in europe yet...
Your comment is highly expected :)
normis
Thu Apr 19, 2018 2:28 pm
Nice comments, thanks! I'm glad to see it works as expected.
mlenhart
Thu Apr 19, 2018 2:29 pm
6.43???
Insider
Thu Apr 19, 2018 2:37 pm
Simply we posses those without any comments,
http://Pojitko.cz
Insider
Thu Apr 19, 2018 2:42 pm
6.43???
Ooops?
http://Pojitko.cz
blingblouw
Thu Apr 19, 2018 3:00 pm
I am very jealous.
Our distributors have no idea when they are getting. Damn
MonkeyDan
Thu Apr 19, 2018 9:29 pm
That's awesome! Love the PHY rate and alignment info. How does it handle the rain?
server8
Fri Apr 20, 2018 9:47 am
Hope to have soon a feedback in a rainy day :-)
Insider
Mon Apr 23, 2018 4:27 pm
Rain rain rain.. We need more real live testing. But.. Todays situation about 40-45mm/h link was down for 4 minutes going from -56 to -70 in few seconds. The wet antenna takes -4dB!! Link length 1300m.
The link nearby with WAP for 400m was doing well all the time loosing approxiamtely 1-2 on RSSI scale looding from -66 to -68, and already working as before the rain. LHG is 15 minutes after rain still -59 and once dry has to come up to -56.
http://Pojitko.cz
server8
Mon Apr 23, 2018 6:28 pm
Thank you for the feedback
manuzoli
Wed Apr 25, 2018 8:27 pm
Where did you buy them?
Insider
Thu Apr 26, 2018 12:48 pm
Sorry, no comment
http://Pojitko.cz
mlenhart
Fri Jun 22, 2018 11:48 pm
400m link, ROS 6.42.4:
1st side:
[admin@MikroTik] > /interface w60g monitor 0
connected: yes
frequency: 58320
remote-address: XX:XX:XX:XX:XX:XX
mcs: 8
phy-rate: 2.3Gbps
signal: 95
rssi: -53
tx-sector: 45
tx-sector-info: right 0.6 degrees, up 0.6 degrees
rx-sector: 96
2nd side:
connected: yes
frequency: 58320
mcs: 8
phy-rate: 2.3Gbps
signal: 70
rssi: -64
tx-sector: 58
tx-sector-info: left 0.6 degrees, up 1.4 degrees
rx-sector: 96
MCS and also signal is VERY unstable when link is under load, signal is jumping between 20 to 100 approx. each second, same as MCS - between 1 up to 8
Also, after a load, MCS will remain at low values 1-2 same as signal - from 80 before load to only 20 after a load
mistry7
Sat Jun 23, 2018 2:07 pm
@mlenhart
try 6.43 RC there are a lot of improvements
mistry7
Sun Jun 24, 2018 12:22 am
Here our results on first long link
brasileottanta
Wed Jun 27, 2018 4:24 pm
Hello ,
our first long link. Great !!! firmware 6.42.5
Last edited by brasileottanta on Thu Jun 28, 2018 11:12 am, edited 1 time in total.
mistry7
Wed Jun 27, 2018 6:03 pm
Hello ,
Try to set channel to 64800 in CLI, the attenuation in O2 is smaller in higher frequency
blue
Wed Jun 27, 2018 7:58 pm
Wow, this looks promising for my future 2100 meters link :)
Sent from my iPhone using Tapatalk
server8
Wed Jun 27, 2018 8:56 pm
Mistry7 remember report us from rainy days :-)
brasileottanta
Thu Jun 28, 2018 11:10 am
Hello ,
Hi ,
How I can do that ? manually ?
thanks
brasileottanta
mistry7
Sun Jul 01, 2018 3:42 pm
Hello ,
Hi ,
thanks
brasileottanta
@brasileottanta
open terminal in winbox
go to
interface w60g
set 0 frequency=64800
mistry7
Sun Jul 01, 2018 3:44 pm
the next 20 days no rain
server8
Fri Jul 06, 2018 9:49 am
Now during heavy downpour our 1491m link gained from 2 to 5 db both side, frequency 64800, WOW :-)
server8
Fri Jul 06, 2018 10:37 am
I have to correct partially myself it's no rained on the link but very very close, the strange think that this morning we gained a lot of db before rain start, and now with light rain the signal is from slightly better than normal to 4 db worst
server8
Fri Jul 06, 2018 10:47 am
Now light rain stopped signal gained around 2/3db
frequency: 64800
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -57
tx-sector: 48
tx-sector-info: left 1.4 degrees, up 1 degrees
rx-sector: 96
distance: 1491.42m
frequency: 64800
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -57
tx-sector: 48
tx-sector-info: left 1 degrees, up 1.4 degrees
rx-sector: 96
distance: 1491.42m
mistry7
Fri Jul 06, 2018 12:27 pm
I hope Mikrotik update there Site Survey Tool,
the wireless wire dish is choosable, but there is no 60Ghz Band to choose.
Hopefully we are able to calculate rssi , that i think is best way to know what finally alignment
gives us.
We don´t know LHG gain, we don´t know Output Power, we know nothing....
How to probably do alignment if we don´t know the goal rssi?
normis
Thu Jul 12, 2018 8:00 am
gives us.
You don't need to calculate anything. The distance limit is specifically indicated. If you have clear line of sight, link will work. 60GHz is completely different from 2GHz, so the traditional calculators will not be useful.
cohprog
Thu Jul 12, 2018 8:47 am
Over a few hundred meters, 60Ghz links are heavily dependent of rain condition. So yes, a link calculator based on ITU rain zone calculator is really needed. It's not perfect but it will still give an indication if you can expect the link to stay-up nearly always or if it will drop as soon as there is some rain.
You rate them for 1.5Km but under which condition? Perfect clear weather with little humidity in the air? Will it works with a reduced speed when raining or will it stop working all together because there is simply no margin at this distance? With other devices, I saw drop of 15-20dB on links over 1Km during storm. Those links stayed up but because there was a lot of margin. There is just no way to know if it will be the same for LHG60 without testing because we don't have any information about the expected signal level at a given distance under clear weather. If you say that a 1.5Km link should work with a rssi of -50 under clear weather, that's not at all the same as if you say it should have a rssi of -65. In the first case, you know that it should continue working even with some rain. In the second case, the link is probably going to drop.
A link calculator is also usefull to know if a new link is working more or less as expected or if there is really a problem with the installation.
ste
Thu Jul 12, 2018 9:06 am
With this kind of gear and this pricing it is best to do some labour and test it for yourself. Do a testlink and see how it behaves and how the signals fluctuate with rain/snow.
cohprog
Thu Jul 12, 2018 4:40 pm
Sorry but that's not a good enough excuse not to provide any information. Depending where you are located, it's not that easy to set-up a test link. I agree those devices are very cheap but I would rather avoid wasting time if I could know in advance that there is no hope to get a stable link in a given situation.
I have links I know will work with Metrolinq devices but, if some of the values posted here with LHG60 are the best that can be done, there is nearly no hope to achieve the same results with the LHG60. Based on those data only, I am rather doubtful about spending the time (and money) to do a test that will probably fail. I may rather go directly with a solution that I know will work. If Mikrotik was publishing some data, we would at least have an idea if there is a point in making a test or if it's hopeless.
Based on Ignitenet information, the Metrolinq need a RSSI of -60 for 2Gbps and -65 for 1Gbps. Still based on their data, you can expect (with ML-60-35) a RSSI of -50 at 1.5Km without rain. It's easy to see that you have some margin left. Now, if -65 is really what you can expect of a LHG60 at 1.5Km when not raining, that mean there is nearly no margin at all. If that's the case, it's just not worth to even make a test for that distance
Even if you do a test, without any data there is no way to know if the results you are getting are what is expected or if there is a problem with the setup. There is a reason why people are making threads asking people to post results of their installations.
On a side note, Ignitenet claims 2.2Km for 2Gbps and 2.6Km for 1Gbps when no rain.
PS: Those values are for channel 4. For channel 1, the expected RSSI of ML-60-35 is -63. The maximum distance for 2Gbps drop at 1350m without rain and the distance for 1Gbps to 1620m. That's quite a difference between the 2 channels.
ste
Thu Jul 12, 2018 5:01 pm
I have some Ignite links. I never get calculates values. Often they fluctuate or are far off. Their scope is crap (enough for a first shot but far from beeing exact) and a lot of their gear need to be replaced. So dont expect from wifi-based cheap gear to match the calculations (as you get with expensive licensed gear). Even the production tolerance might kill your calculations (Just see an open ignitenet and you know why. Clipped in USB-Stick ... ).
This Ignitenet claims are ... puh. Just do it ... This is why I say what you test is what you get.
cohprog
Thu Jul 12, 2018 5:23 pm
Nobody ever claimed that the scope is good enough for alignement. It's only useful to point the antenna at each others so they will at least establish a link that will let you do alignement. You can do without but, imho, at 1km+ it makes things easier.
I am not expecting to get the exact theoretical values but a rough idea is a lot better than nothing. I have several Metrolinq lines and the values aren't that far off. Perhaps they are cheap gear, as you say, but I haven't got a single one that failed yet and the links, all between 1Km and 1.3Km never droped even during storm. But I did saw them go from 2.5Mbps to 1Mbps for a few minutes in the worse cases. As it is, I am perfectly happy with those devices which is why I am doubtful into investing money and time into something that seems to have nearly no chance of working (based on the few results that people posted as there is nothing official from Mikrotik).
How hard is it to list the signal needed for a few speed rates and what RSSI you "may" expect based on the distance? Answering "they are rated for 1.5Km so they will work at this distance" is just plain false: we all know that it heavily depend of weather condition, whatever the gear you are using.
cohprog
Thu Jul 19, 2018 4:51 pm
Just installed a LHG 60G link:
Distance: 1160m
Alignment based on RSSI and not on led or TX sector info: I could systematically gain 4-5 dbm over a "center" TX sector value. As some people pointed out, we really need to be able to disable beam forming for alignement: Sure, beam forming can compensate for some poor alignment but a correctly aligned link with beam forming beats a poorly aligned link with beam forming.
Side A:
frequency: 64800
mcs: 8
phy-rate: 2.3Gbps
signal: 85
rssi: -55
tx-sector: 55
tx-sector-info: right 1.4 degrees, up 1 degrees
rx-sector: 96
distance: 1166.34m
Side B:
frequency: 64800
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -58
tx-sector: 56
tx-sector-info: left 1.4 degrees, up 1.4 degrees
rx-sector: 96
distance: 1166.36m
I am now waiting on the predicted storm this week-end to see how the link behave.
Comment:
- It was a lot easier to get a working link "by sight" than with Metrolinq 60-35. (Metrolinq have a much narrower beam)
- Fine alignement still need to be done based on signal, like with the Metrolinq.
- The LHG60 "mast bracket" is pretty crappy for 60Ghz. Even with the beam width of the LHG60, half a degree can make a difference of several dbm. We really need a bracket that let do fine adjustment once it's firmly fixed to the mast.
- The RSSI (and the tx-sector info) can vary quite a lot from one moment to another even with good weather and even with the link running since several hours, without touching the antenna. (The above data shows "left 1.4 degrees, up 1.4 degrees" but sometime it shows "center". The RSSI can vary from -57 to -61 on that link. -61 is when tx-sector shows "center")
- For a slightly longer link (1290m), at the same location, using the same frequency (64800), Metrolinq 60-35 reports a RSSI of -45 with nearly no variation (+/- 1dBm)
I will check how the link compare to the Metrolinq one during the upcoming thunderstorm.
PS: Can't people resize their pictures, before posting them, so they don't mess the whole page?
ste
Thu Jul 19, 2018 5:39 pm
Comment:
The dish sizes of Metrolinq 35 and LHG60 are quite the same. LHG is a bit wider. So I guess the RSSI difference is due to different TX power or different measurement of the chipset. The mesh antenna might be a factor but not that big. Would be interesting to compare how both modulate down with distance/weather.
cohprog
Thu Jul 19, 2018 6:30 pm
The size is about the same but the geometry is different. As I said, the Metrolinq have a much more focused beam. Getting 2 Metrolinq to link at 1km just by more or less pointing them at each others by sight is nearly impossible. I really doubt that both antenna have the same gain.
I will post the results after this weekend's storm. Both LHG60 and Metrolinq links are in the same area, with about the same length and on the same channel so it will be easy to compare them (in fact, both links are back to back).
Edit: I think the Metrolinq 60-35 have an antenna gain of 42 dBi and a max TX power of 14 dBm
Edit: I think that, in Europa, the max EIRP for 60Ghz is +55 dBmi with a minimum antenna gain of +30 dBi. In USA, it's a lot higher (+82 dBmi)
vectieba
Thu Jul 19, 2018 7:32 pm
Here is my results from a 700m connection in good weather. It seems the rssi improved and the link was more balanced after putting load on the link. I also expected more throughput at that distance.
antonsb
Thu Jul 19, 2018 7:52 pm
Currently You are testing one core performance - Use Traffic generator or generate traffic externally.
vectieba
Thu Jul 19, 2018 8:10 pm
Thanks Anton, I was looking at the Hawaii link and realized that. Thanks, this is much better :D
vectieba
Fri Jul 20, 2018 5:20 pm
Here is a second link we have put up at 1km
cohprog
Fri Jul 20, 2018 10:36 pm
First thunderstorm of the weekend. Here is the results:
LHG60 link:
Length: 1166m
Frequency: 64800
RSSI no rain: -55 to -58 dBm
Rate no rain: 2.3Gbps
Metrolinq 2.5 60-35 link:
Length: 1290m
Frequency: 64800
RSSI no rain: -45 dBm
Rate no rain: 2.5Gbps
Both links are in the same area so have the same weather conditions (they both end-up at the same location).
Results:
LHG60:
RSSI during "normal" rain: around -63 dBm
Rate during "normal" rain: 2.3Gbps. Sometime drop to 1.9Gbps
RSSI during "heavy" rain: Minimal recorded -71 dBm
Rate during "heavy" rain: Often around 1Gbps. Sometime as low as 390Mbps
Metrolinq:
RSSI during "normal" rain: -47 dBm
Rate during "normal" rain: 2.5Gbps
RSSI during "heavy" rain: Minimal recorded -57 dBm
Rate during "heavy" rain: 2.5Gbps
The good thing is that during this storm neither links disconnected (which is better than I expected). But the LHG60 rate dropped a lot for most of the storm while the Metrolinq rate stayed at a full 2.5Gbps during the whole time.
In nearly 1 year, I saw the Metrolinq RSSI drop down to as low as -65 dBm which resulted in some very brief rate drop (to 1.9Gbps or even 1Gbps for a few seconds). That's about 8 dBm less than during this storm. It's very probable that the LHG60 link would disconnect under the same condition as the RSSI would be around -79 dBm...
Imho, I wouldn't use LHG60 for links above 1Km except if you are in an area with very little rain or if you don't care about losing the connection from time to time...
cohprog
Fri Jul 20, 2018 10:42 pm
Something weird I noticed: It stopped raining since around 30 mins and suddenly the LHG60 link dropped to MCS 1 even with a good RSSI (-55 dBm):
frequency: 64800
mcs: 1
phy-rate: 385.0Mbps
signal: 20
rssi: -55
tx-sector: 41
tx-sector-info: left 1 degrees, up 0.6 degrees
rx-sector: 96
distance: 1166.37m
The link stayed like that until I passed some heavy traffic through it and then it when back to more normal values:
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -55
tx-sector: 47
tx-sector-info: right 1.4 degrees, up 0.6 degrees
rx-sector: 96
distance: 1166.36m
No idea what is causing that...
ste
Sat Jul 21, 2018 12:06 pm
LHG60 link:
Length: 1166m
Frequency: 64800
Length: 1290m
Frequency: 64800
Results:
LHG60:
Metrolinq:
What is your tx-power setting for lhg60? I guess this makes the signal difference.
cohprog
Sat Jul 21, 2018 3:04 pm
How should I know? Mikrotik didn't gave any information about those devices. In Europa, the max EIRP authorized is 55 dBmi with an antenna gain that need to be at least +30 dBi. Metrolinq has a TX power of 14 dBm. Any reason to believe that the LHG60 are set to less than that 14 dBm by default and that the default isn't the maximum they can do?
Nobody reported a better RSSI for LHG60 links at 1Km+ yet...
I am not sure why you say the only difference can only be the TX power when those antenna don't have at all the same geometry. Imho, the Metrolinq have a much higher gain, that's all.
Also, I am not sure the grid design is a good idea: As others reported, even when it stops raining, the RSSI stay much lower until the antenna dry. I don't have at all this problem with the Metrolinq radom.
Edit: I tried to set the tx-power manually instead of "default". The maximal value accepted is 15. I didn't noticed any change in RSSI so I guess the default must already be 15 or, perhaps, 14 (Which is the same as Metrolinq).
ste
Sun Jul 22, 2018 12:27 pm
I cant believe the LHG Antenna is so much lower gain. I would expect no more than 3db difference which would be huge. But I dont have any data.
@MT could you please step in with some facts/data on Antenna Gain / TX Power.
cohprog
Sun Jul 22, 2018 4:48 pm
Considering how easy it is to set-up a LHG link "by sight", I am not really surprised. Also, the antenna shape/size can result is a much bigger gain difference in the 60Ghz than it would in the 5 or 2.4Ghz.
We really don't have any info about the max EIRP of the LHG so it's hard to say. Based on their spec, Metrolinq 60-35 max EIRP is 55-56 dBmi. Based on their link calculator, with those antenna, you should get a RSSI of -42 dBm at 1Km and -50dBm at 1.5km +/- 10% error margin (for channel 4 and no rain). From my experience, this is doable in practice. Nobody reported anything near those values with the LHG (yet).
ste
Mon Jul 23, 2018 5:46 pm
New Link only aligned by sight. Needs fine adjustment:
> interface w60g monitor wlan60-1 once
connected: yes
frequency: 58320
remote-address: 04:D6:AA:XX:XX:XX
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -58
tx-sector: 52
tx-sector-info: right 0.2 degrees, up 1 degrees
rx-sector: 96
distance: 1296.07m
connected: yes
frequency: 58320
mcs: 8
phy-rate: 2.3Gbps
signal: 50
rssi: -69
tx-sector: 35
tx-sector-info: center
rx-sector: 96
distance: 1296.06m
What is strange: How could the RSSI on both sides differ that much. Misalignment on one side should affect both rssi values. LOS is free. No reflections. Is Beamsteering doing some magic here which works only in one direction?
mistry7
Tue Jul 24, 2018 6:47 am
Did you measure with traffic on link?
ste
Tue Jul 24, 2018 10:16 am
Yes. No difference.
madmax
Tue Jul 24, 2018 11:51 am
ROs v.6.42.6 , link up with low rain and wind 28 kts.
Notice no Tx-sector info in master device using winbox window, I must use monitor via terminal.
If I tryed to center the devices , RSSI value increses. I have a good RSSI without center the devices.
ste
Tue Jul 24, 2018 11:53 am
Please show the other side.
server8
Wed Jul 25, 2018 10:31 am
Hi guys
what version of firmware is ok for LHG60? I 'm not sure but with 6.42.6 the RSSI level is worst than 6.42.5 and I read on the forum that 6.42.4 is better than 6.42.5
Any advice?
Thank you
MonkeyDan
Wed Jul 25, 2018 6:42 pm
We’re sticking with 6.42.3. We never tried 6.42.4 before we tried 6.42.5 and .6, but .4 should be OK as the only w60g change was “improved RAM memoy allocation processes”
russman
Thu Jul 26, 2018 9:54 pm
frequency: 64800
mcs: 1
phy-rate: 385.0Mbps
signal: 20
rssi: -55
tx-sector: 41
rx-sector: 96
distance: 1166.37m
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -55
tx-sector: 47
rx-sector: 96
distance: 1166.36m
I'm seeing this as well in 6.42.6 with no rain and full LOS. I'm not sure why on first boot and install the MCS, signal, and phy-rate is pretty stable but over time it jumps around for no apparent reason.
cohprog
Sat Jul 28, 2018 10:47 am
Distance: 1166.37m
Frequency: 64800
RSSI without rain: -56
Just had a thunderstorm: lost the connection 5-6 times in 20 minutes.
FezzFest
Sat Jul 28, 2018 11:00 pm
We have a 1.2km link with LHG 60G's, properly aligned, with signal around -68dB. Link drops immediately with the slightest rain. Since we're using BFD and have a 5GHz link as a backup it's not an issue, but I wonder where the signal difference with some others (e.g. @cohprog) in this topic comes from. It seems most people have signals in the -50's at the same distance.
       connected: yes
       frequency: 64800
  remote-address: 04:D6:AA:BC:98:29
             mcs: 8
        phy-rate: 2.3Gbps
          signal: 80
            rssi: -68
       tx-sector: 20
  tx-sector-info: right 0.2 degrees, down 0.6 degrees
       rx-sector: 96
        distance: 1188.2m
       connected: yes
       frequency: 64800
  remote-address: 04:D6:AA:BC:98:75
             mcs: 8
        phy-rate: 2.3Gbps
          signal: 80
            rssi: -66
       tx-sector: 44
  tx-sector-info: right 0.2 degrees, up 0.6 degrees
       rx-sector: 96
        distance: 1188.21m
cohprog
Sun Jul 29, 2018 1:00 am
Did you aligned based on the tx sector info or the rssi? Imho, result is better when using rssi. The sector info randomly vary from "center" to +/- 2 degree in my case. With the wAP60, it's a lot worse: over 50m, the sector info vary by +/- 20 degree or so.
mlenhart
Sun Jul 29, 2018 2:12 pm
I am running on 6.42.6, frequency is set to auto. Disconnects are too often - 230x for 4 days uptime is insane... Distance about 340m.
Clear LoS, no rain for 4 days... any idea what else should I check?
venthyl
Sun Jul 29, 2018 6:16 pm
1950 meters link
rrssi sta/ap / chanel
-63/-64 chanel 58g
-68/-68 chanel 60g
-68/-66 chanel 62g
-58/-57 chanel 64g
Heavy Rain comparision lgh60 1950m (58ghz), lhg60 650m (auto), siae 17g, airfiber 24g
venthyl
Sun Jul 29, 2018 6:37 pm
LHG 60 left/right alligment tool :)
size of clamping is 90-110 cm
It helps a lot
remember correct alligment requre
- set 58ghz (not auto)
- do bandwith test UDP 500Mbit symmetric between two lHG 60
- monitor via terminal interface w60g monitor interval=1s numbers=0
on both sides
- you should have same rssi on both side (eg 1950meter link has ~~ -62 rssi on 58Ghz and -57 on 64Ghz)
RSSI is only one real information to correct link alligment
differrent link rssi to frequency on 1950m link
-63/-64 chanel 58g
-68/-68 chanel 60g
-68/-66 chanel 62g
-58/-57 chanel 64g
And its my simple clever helper to left/right allign ( its fu... u... in original mounting)
venthyl
Sun Jul 29, 2018 6:54 pm
Hi you should make correct alligment,
i had same problem on 1950m., after correct alligment link works stable
server8
Sun Jul 29, 2018 8:06 pm
FezzFest
Mon Jul 30, 2018 3:42 am
We aligned it based on tx-sector-info (more specifically, one device was aligned by the LEDs indicators on the device, the other was aligned from the terminal because the LEDs drove me crazy).
cohprog
Mon Jul 30, 2018 11:03 am
Try to align based on the RSSI. You should be able to get a much better signal.
slarner
Mon Jul 30, 2018 12:40 pm
we are having loads of disconnects. Up and down constantly signal is solid at -53.
If we load 6.43rc5 no disconnects at all.
All the newer versions constant disconnects. Any ideas on how to solve this?
We are currently on 6.43rc45
http://www.countybroadband.net
Provider of wireless broadband in Essex and Suffolk UK
server8
Mon Jul 30, 2018 12:46 pm
Try 6.42.4 seems to be stable
mstead
Thu Aug 02, 2018 8:43 am
Same here. 6.43rc40 and 6.43rc44 both have constant disconnects on links that are definitely not overlimit - one is only 25 metres!!
macgaiver
Thu Aug 02, 2018 6:40 pm
FYI 6.43rc51:
*) w60g - added distance measurement feature;
*) w60g - fixed random disconnects;
*) w60g - improved MCS rate detection process;
*) w60g - improved MTU change handling;
*) w60g - properly close connection with station on disconnect;
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
MonkeyDan
Fri Aug 03, 2018 10:34 pm
rc51 seems OK (so far) for point-to-point. Still seeing a lot of disconnects on multipoint. :(
6.42.3 continues to be my favorite firmware for these radios.
FYI 6.43rc51:
beeonline
Wed Aug 08, 2018 8:01 am
Greetings all! Couple of questions straight away:
How does LHG 60 act with interference? As soon as it was announced in the shops, I see them almost on every tower now (We have A LOT of competitors). Taking into account that it has 2Ghz bandwidth I can only imagine what is going to happen. And no one knows exact antenna pattern, how wide it is. If it is flashing all around, for sure it will affect link across op opposite or even...somewhere. Ok, it is well known that on this freq there is a lot of attenuation, but locally it may cause (or not?) problems.
Ok, we have siklu 60G band relays, and those guys all around started to mount LHGs, how they co-exist? Taking into account that they like to overpower radios, I am very worried that a 200 bucks toy can affect an expensive piece of hardware, which is a bint unfair first of all.
Anyways, I have ordered 3 pairs of them, because it is sure a good value for the money to replace or backup overloaded 5Ghz links, but still..To me it seems like I bomb in monkeys hands.
cohprog
Wed Aug 08, 2018 10:05 pm
60Ghz signal drop very fast with distance because it's absorbed by oxygen so even links that are very near to each others don't interfere much. I didn't try with LHG60 but I didn't had any problem running 2 Metrolinq back to back on the same channel (and they don't have gps synch).
tramker
Tue Aug 14, 2018 4:11 pm
v6.42.3 is indeed much more stable than 6.42.6. I had fluctuating signal quality and MCS and many 8s linkdows. With 6.42.3 the signal quality is stable 80-95, MCS mosty 8, and only one 1s linkdown a day. Link length 386m.
sergesa
Tue Aug 14, 2018 6:23 pm
Nice work, thanks Mikrotik, update from RC51 to RC56
blue
Sat Aug 18, 2018 3:57 pm
Is this the distance record?
Link is working perfect! I am hitting 1gbps on Ethernet interface with iperf!
estar
Sat Aug 18, 2018 5:22 pm
Testing a point to multipoint setup. 4 clients all under 240 meters. Speed is great but disconnections are very often. In my experience if one link has poor signal -70dbm and it disconnects it caused all the other stations to disconnect just after the poor signal station disconnects. This behaviour is repeatable. I think once MT can perfect the software it will be very good but right now seems a little unstable.
E-star.uk - presents:
Star-charge - Cloud based user self-service billing system - including self-service secure WPA2 hotspot - Signup and try instantly - Made for Mikrotik OS.
https://e-star.uk/hotspot-routers.html
gcsuri
Sat Aug 18, 2018 6:43 pm
connected: yes
frequency: 58320
remote-address: 04:D6:AA:A7:MN:S7
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -60
tx-sector: 22
tx-sector-info: right 1 degrees, down 0.6 degrees
distance: 539.35m
with rc56 random disconnections gone.
slarner
Tue Aug 21, 2018 12:33 pm
Hi
I can also confirm random disconnects have gone in RC56 thanks guys. Here is our link it drops out instantly in heavy rain :( yet our MetroLinq 2.5 of same distance carry's on working fine.
connected: yes
frequency: 64800
remote-address: 04:D6:AA:AF:D5:0E
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -55
tx-sector: 36
distance: 1088.42m
ste
Tue Aug 21, 2018 3:00 pm
Hi
connected: yes
frequency: 64800
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -55
tx-sector: 36
distance: 1088.42m
Sure the ML is within allowed EIRP ...
cohprog
Tue Aug 21, 2018 11:50 pm
The Metrolinq has certification.
muldeegg
Wed Aug 22, 2018 7:49 am
We have the same setup with several PTMP tests, clients all under 200m:
- when one client reboots or loses a connection, all clients drop connection for a few seconds
- latency / jitter doubles every time a client is added
- RC56 has not made much of a difference
We also have several PTP test links under 1000m:
- RC56 seems to have helped a lot with random disconnects
- Struggling to get good RSSI reading which also seems worse after upgrading firmware
- Still dropping in heavy rain
We found that the installation location is more important than one would assume on a building or roof (was expecting the narrow beam pattern to do the work)
rakeshbagla
Thu Aug 23, 2018 1:25 pm
as my experience when rain is started its always going down , Pls looking and support
taylag
Thu Aug 23, 2018 3:20 pm
       connected: yes
       frequency: 64800
             mcs: 8
        phy-rate: 2.3Gbps
          signal: 80
            rssi: -68
       tx-sector: 20
       rx-sector: 96
        distance: 1188.2m
       connected: yes
       frequency: 64800
             mcs: 8
        phy-rate: 2.3Gbps
          signal: 80
            rssi: -66
       tx-sector: 44
       rx-sector: 96
        distance: 1188.21m
Hi, How did you configure the 5ghz back up? Im hoping to do the same with a pair of powerboxes and a pair of powerbeams to back up the LHGs. Im not familiar with BFD.
Cheers,
GT
Bergante
Thu Aug 23, 2018 4:11 pm
Multiple reflections can be a problem I guess.
wispwest
Re: LHG 60G experience - MAX DISTANCE?
Fri Aug 24, 2018 12:23 am
I've seen max distance specs on the products and testing for WAP60 to WAP60 and LHG to LHG, but what about WAP60 to LHG 60? I assume that would cut the 1500m limit down to what, 1000m?
slarner
Fri Aug 24, 2018 1:18 am
With rain fade I wouldn’t go any more than 800m on the LHG to LHG
Our 1000m is dead as soon as you get a downpour
DynStatic
Tue Aug 28, 2018 5:42 pm
Distance: 1166.37m
Frequency: 64800
cohprog,
What monitoring software is that?
DynStatic
Tue Aug 28, 2018 5:43 pm
1950 meters link
-63/-64 chanel 58g
-68/-68 chanel 60g
-68/-66 chanel 62g
-58/-57 chanel 64g
venthyl ,
wispwest
Tue Aug 28, 2018 6:11 pm
1950 meters link
-63/-64 chanel 58g
-68/-68 chanel 60g
-68/-66 chanel 62g
-58/-57 chanel 64g
venthyl ,
So looks like channel 64g is best in the rain?
DynStatic
Tue Aug 28, 2018 6:39 pm
We have found that if you lock the tx-sector using the cli and do the alignment, once you unlock the tx sector, the rssi gets better by 2-5 db. Not sure if it would get there without this procedure tho. Since there are 64 sectors, we lock it to the middle. We don't bother with the arrows, we look at rssi only.
The problem we have is the feedback loop is to long. When you make an adjustment, the rssi won't update for seconds. I assume this is because the chipset is evaluating all the sectors rx signal. If we could lock the tx and rx for alignment mode and have more frequent rssi updates it would help to get a proper alignment. In my opinion the process should start with aligning the radios for dead center with locked tx/rx. Once it's dialed in then turn on the beam forming.
blue
Tue Aug 28, 2018 9:23 pm
Me also lost a lot of time trying to get my 2,2km link working. Info from cli and winbox is very slow. From time to time i had to wait for 15-20 seconds for information to settle down. Hope that we will get some more precise alignment tool. I hope that 802.11ad don't end up like spectral scan on 802.11ac.
BR...
mistry7
Tue Aug 28, 2018 9:28 pm
BR...
Did you set channel to 64800?
blue
Tue Aug 28, 2018 9:29 pm
Yes. Other channels don't work on such a long distance.
mistry7
Tue Aug 28, 2018 9:37 pm
Right.....
I hope for some more features in 802.11ad
- Smaller channel width
But the hope is gone almost for 802.11ac
cohprog
Wed Aug 29, 2018 1:15 am
cohprog,
Zabbix. There is no pre-made template for LHG60 but it's easy to do one. (there is a script that will do a snmpwalk and generate a Zabbix template based on it)
Bergante
Wed Aug 29, 2018 9:56 am
6.42.7 and 6.43rc64 have very important enhancements to the tx-sector selection.
I have been following the betas and the stability has improved a lot since rc56.
yurisokol
Wed Aug 29, 2018 4:23 pm
The original bracket is not convenient for smooth adjustment. I use this one : http://www.cdr.pl/p6418,uchwyt-precyzyj ... adkit.html but with the addition tool from Metrolinq.
wispwest
Wed Aug 29, 2018 7:10 pm
Is the new channel still only available in CLI or did they finally add it to winbox in the latest RC?
blue
Wed Aug 29, 2018 7:41 pm
You can choose 4 channels in winbox
Lakis
Forum Veteran
Forum Veteran
Thu Aug 30, 2018 11:22 pm
Nice dude 1950m stable link good news, I've done 1560m link works very stable, I was sceptic about 1750m but now I m going for it.
Lakis
Forum Veteran
Forum Veteran
Mon Sep 17, 2018 4:44 pm
1750m LHG60 ROS 6.43
Freq:
58320 -59
60480 -63
62640 -62
Ivoshiee
Mon Sep 24, 2018 10:13 am
The LHG 60G pointing to proper direction is impressively imprecise, which is strange with that beam forming and all. The link signal will cut off by only minor adjustments thus these "0.2 degrees left or right" are almost funny. What is the antenna pattern and how that device is using it?
server8
Tue Sep 25, 2018 4:58 pm
Just to make a quick experiment: unsoldered LDF patch antenna and put it in the centre of the LHG60, The loss is high 8 to 10 dB compared to the LHG 5AC but easy solutions to make a cheap 5GHz backup using the same antenna :-)
The copper on the bottom is the reflector for the patch I don't make any calcultions only I just made it.
miochoice
Fri Sep 28, 2018 7:48 pm
any suggestions?
Michaelcrapse
Mon Oct 01, 2018 11:14 pm
Freq:
58320 -59
60480 -63
62640 -62
Dang! I think you won a certain type of silicon lottery! We have 750m link at ~-50dBm signal. Yours at 1km more should see an additional ~-22dBm fade over ours so expected would be -72. I wonder, if you found the magical beamforming TX sector. Because in reality we took down an ML2.5 link which was connected at calculated RSSI of -33dBm, replaced with this one and now only -49 at best.
draguzet
Tue Oct 02, 2018 10:21 am
Freq:
58320 -59
60480 -63
62640 -62
We are suprised also with results (Signal) from Lakis ? Can you please share procedure to align, we have difficulties with proper aligning LHG 60G...
antonsb
Tue Oct 02, 2018 10:51 am
Don't trust RSSI readings too much. You should be able to get same distances with ease - upgrade to latest versions, there a lot of changes that affect receive sensitivity
blingblouw
Tue Oct 02, 2018 8:19 pm
So what exactly do we trust? What are we aiming for, centre? If so, I have seen centre on different tx-sector. 36, 26/27, etc
whoknew
Tue Oct 02, 2018 8:45 pm
I have asked this exact question in another thread. I have had answers about my radios being too close etc. I thought it was an alignment problem but we have tweaked and tweaked and cannot get any better results. We are seeing a lot of Link Downs on the Station side of our 60Ghz Mikrotik links.
Lakis
Forum Veteran
Forum Veteran
Thu Oct 04, 2018 1:06 am
Dude its very hard.
DynStatic
-When you make an adjustment, the rssi won't update for seconds.
blue
-From time to time i had to wait for 15-20 seconds for information to settle down.
------------------------ Thats why!!!
muldeegg
Jokes aside I hate this problem Mikrotik please fix this
mblfone
Thu Oct 04, 2018 1:28 am
I am as well having issues getting these things aligned...
1) Using the LED method absolutely won't work. If I use this my dish is physically aligned 20 degrees off of the remote dish.
2) MT provides few definitions on what we are seeing on the monitor/status menus. Signal, what is this exactly? Is this is db? What are the TX-SECTOR and RX-SECTOR numbers referring to?
3) RSSI stops responding after a while and is not reliable.
4) How do I turn beam forming off? I cannot figure out the nomenclature in terminal mode to do this and again there is no documentation on this. I think if I add a number to TX-SECTOR to set it as NOT auto, that turns of beam forming, but I can't figure out what to type to get that to happen.
My goal today was to change the TX-SECTOR to 32 thereby turning off beamforming and using RSSI while it responded to align our dishes. Is there a better TX-SECTOR number to use to get alignment handled than 32?
I don't like forums, but in the absence of decent wiki docs or online documentation I am forced to admit defeat and ask for input from those who have had better luck.
A better alignment procedure would be very helpful including CLI commands. We are using 6.43.2 presently.
Thanks to anyone who can help!
mblfone
Thu Oct 04, 2018 4:05 am
I think that the correct command to shut down beamforming is /interface w60g set 0 tx-sector=32... I have no idea what the "0" is in the set command however.
Updating my prior post...
wispwest
Thu Oct 04, 2018 4:52 am
I'm be putting up a LHG-60 PTP tomorrow at ~ 1300m, will I have fade? That's about 0.85 mi or so, which in my world is across the street.
Also, upon bench testing how do I see the PHY and other stats people posted on here? I even upgraded to the latest RC (development says N/A)
wispwest
Fri Oct 05, 2018 4:39 am
Pretty annoying actually, not even the station displays ANY sort of signal, MCS rates, PHY, NOTHING all is blank, with the latest RC! How has nobody seen this yet??
MonkeyDan
Fri Oct 05, 2018 4:56 am
The testing branch is in beta these days, not RC.
I recommend 6.42.9 for production deployment.
mblfone
Fri Oct 05, 2018 8:23 am
You are using the most recent beta. I get that too, I used montior 0 on the CLI to get around that.
mblfone
Fri Oct 05, 2018 8:29 am
"The testing branch is in beta these days, not RC.
I recommend 6.42.9 for production deployment."
I haven't tried 6.42.9 yet. I have been going between the current and testing versions and am neither having much luck keeping a stable link nor am I confident in my alignment.
Would you please provide an alignment procedure that works for you? Apparently we shouldn't use RSSI and the LED method has not worked for me; it sends me way off a bore sighted path.
Also, can anyone tell me the significance of what the SIGNAL, RX-SECTOR and TX-SECTOR data is and how this might help an alignment?
Tepelensi
Fri Oct 05, 2018 11:33 am
v6.43
connected: yes
frequency: 58320
remote-address: xx:xx:xx:xx:xx:xx
mcs: 4
phy-rate: 1155.0Mbps
signal: 40
rssi: -71
tx-sector: 30
tx-sector-info: right 1 degrees, down 0.2 degrees
distance: 1845.78m
Not tested in rain conditions yet.
slarner
Fri Oct 05, 2018 12:13 pm
v6.43
connected: yes
frequency: 58320
mcs: 4
signal: 40
rssi: -71
tx-sector: 30
distance: 1845.78m
You will loose that in rain!
Tepelensi
Fri Oct 05, 2018 12:26 pm
v6.43
connected: yes
frequency: 58320
mcs: 4
signal: 40
rssi: -71
tx-sector: 30
distance: 1845.78m
will see :)
antonsb
Fri Oct 05, 2018 3:59 pm
4th channel should be much better in this distance
vladimirslk
Sat Oct 06, 2018 12:33 am
i am still waiting from MT LHG60+5ghz in one unit, 5ghz for backup, price per unit should not go a lot even if add price of sxt lite into it.
setting kit with additional sxt unit, poe switch is kind of crazy..
Steveocee
Wed Oct 10, 2018 11:35 am
Interesting experiences.
I have some test kit going up soon which is by Google mapping 2.63Km clear LOS tower to tower.
I'm not expecting full PHY rates but am wondering what it will reach and how any rain will affect the link. My hope is that it folds back and doesn't go off completely.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
MonkeyDan
Wed Oct 10, 2018 6:52 pm
Mikrotik is now claiming 4km (https://mum.mikrotik.com/presentations/ ... 743074.pdf) but I’m reluctant to try. Maybe with the new 66000 MHz channel?
ste
Wed Oct 10, 2018 8:02 pm
What is this: "Enabled 6GHz testing..." ??
antonsb
Thu Oct 11, 2018 1:58 am
typo of 66GHz
Much higher distances are available by using 64800 and 66000 MHz frequencies
digitalpilot
Trainer
Trainer
LHG 60 tx-power missing Re: LHG 60G experience
Thu Oct 11, 2018 3:57 am
Hi, Running 6.44Beta20
No tx-power setting for the 60Ghz interfaces.
I've got several links that are very close and I suspect we can improve the quality by turning down the TX power.
Any idea when it will be a configurable option again ??
I've checkd, WinBox, WebFIg and CLI
Thank you
blue
Thu Oct 11, 2018 8:17 am
66000 GHz is non standard freq for this band? Will You implement 66960 GHz and 69120 GHz?
server8
Fri Oct 12, 2018 10:09 am
woow grat news form mikrotik I am curios if someone has stable link over 1500+ during rain events, 4000m is very long link for 60ghz technology
antonsb
Fri Oct 12, 2018 12:38 pm
it's not a standard channel
server8
Fri Oct 12, 2018 12:47 pm
Without more data on stability in rain events @66000 it's not safe to pay a licensed link :-)
it's not a standard channel, special permissions usually are required to operate at this frequency.
Lakis
Forum Veteran
Forum Veteran
Sun Oct 14, 2018 12:11 am
server8 I have very stable link at 1750m
From MUM UK
• Major received signal sensitivity improvements
• LHG60G can reach up to 4000 m distances (depending on
used frequency)
4 km what?
Is it like LHG60G signal reached 4000m but throughput was eh, than the rain start and we lost signal.
Can someone from Mikrotik give us more info.
server8
Sun Oct 14, 2018 9:30 am
What firmware version are you running on this link? Are you using 64800 or 66000?
Lakis
Forum Veteran
Forum Veteran
Sun Oct 14, 2018 11:51 am
OS 6.43.2 Freq:58320. On Freq:64800 I got best RSSI around -56dB
LHG60G does not support 66000.
blue
Sun Oct 14, 2018 2:43 pm
Yes it does with newest beta and only from CLI.
Lakis
Forum Veteran
Forum Veteran
Sun Oct 14, 2018 5:04 pm
but
if 66Ghz is Central freq. its illegal to use.
blue
Sun Oct 14, 2018 9:29 pm
Use it for testing purposes only!
Stril
Mon Oct 15, 2018 12:00 pm
Hi!
66GHz sounds great, but if I'm right, LHG60 uses 2000 MHz Channel bandwidth.
In this case, 65GHz would be perfect...
mistry7
Mon Oct 15, 2018 12:10 pm
Hi!
Channel 64800 is near to 65000 so no need
mariocelija
Tue Oct 16, 2018 4:08 pm
Has anyone got OID values for RSSI? It would be nice to graph the signal during the rain, just to see how much it changes.
I've only got this from CLI:
mode=.1.3.6.1.4.1.14988.1.1.1.8.1.2.1
ssid=".1.3.6.1.4.1.14988.1.1.1.8.1.3.1"
frequency=.1.3.6.1.4.1.14988.1.1.1.8.1.6.1
ryny24
Tue Oct 16, 2018 4:59 pm
This works for me.
SNMPv2-SMI::enterprises.14988.1.1.1.8.1.12.1 = INTEGER: -66
mariocelija
Tue Oct 16, 2018 5:20 pm
so it does, thank you!
the full value i've entered in PRTG is 1.3.6.1.4.1.14988.1.1.1.8.1.12.1
This works for me.
hercules30
Wed Oct 17, 2018 10:01 pm
Hi all
I'm starting in this world of 60Ghz .. And I'm quite surprised ... I have some doubts, since there is little information about mikrotik antennas at 60Ghz ..
For example:
The Mikrotik wAP 60G, the array says 60º. Vertical and Horizontal, or only Horizontal? . And if it were Horizontal, what is the Vertical Angle of the beam?
In the LH60G, what is the Beam?
If someone can answer me, I would like it
Thank you
Lakis
Forum Veteran
Forum Veteran
Thu Oct 18, 2018 2:55 pm
Hi all
For example:
Thank you
Yes there is so little info about LHG60, I want to know that too. Last update was now LHG60 can do 4000m, they added 66Ghz channel so I m not sure if 4000m is only possible on 66Ghz or you can use all channels which I m sceptic about that.
Mikrotik is like '' Oh yes we made some signal improvements now you can go for 4km '' What about rain, what data rate should we expect, signal level and etc. there is so much lack of information.
server8
Thu Oct 18, 2018 4:13 pm
https://www.youtube.com/results?search_ ... lin++video if you search you 'd find a video about wap 60g that explain that coverage angle vertical/horizontal is close to 180°
cjohnson0692
Fri Oct 19, 2018 10:26 am
What are the commands to set 66000 and add 66000 in the scan list on the client and AP sides?
marekm
Fri Oct 19, 2018 1:20 pm
This source mentions 6 channels (ch5 = 66960, ch6 = 69120 MHz):
https://en.wikipedia.org/wiki/Wireless_ ... e#Channels
"Regional spectrum allocations vary by region limiting the available number of channels in some regions. The US is the only region supporting all six channels. " - is this true?
On the other hand, I've seen some other standard (intended for China) with four 1.08 GHz wide channels numbered 5, 6, 7, 8 in the same frequency range as channels 2, 3 (allowed in China).
Any chance we will see support for narrower channels? Not everyone needs a full gigabit of throughput, often can't be fully used due to the max 8 stations per AP limit.
server8
Fri Oct 19, 2018 1:28 pm
+100
mistry7
Fri Oct 19, 2018 10:43 pm
+100
+100
without narrower channels, the devices with Fastethernet are not needed
miltont
Sat Oct 20, 2018 3:56 am
Greetings
Does someone have this radios on a 2500 meter distance?
What is the bandwidth of link?
mistry7
Sat Oct 20, 2018 12:06 pm
Greetings
with probably alignment you will see full gigabit bandwidth, but it will drop during rain/snow.
LBNL
Sat Oct 20, 2018 6:54 pm
@server8 Have you tried this out yet? Great idea.
Could the patch be mounted on just above or below the aperture on the 60G feed? It wouldn't be the exact focal point but it might be close enough to get some gain back.
Worth a try?
LBNL
server8
Sun Oct 21, 2018 6:18 pm
I have no time to make test on field just an idea, around 2 max 3 km the link loss of the solution is high but the signal is enough to have a good 5 ghz backup in rain events
Feel free to copy it :-)
mblfone
Wed Oct 24, 2018 4:26 am
I am still waiting for a descent alignment procedure. This is the biggest downfall.
ryny24
Wed Oct 24, 2018 4:34 am
+1
wispwest
Wed Oct 24, 2018 5:21 am
Still need these Chris?
Mikrotik 60Ghz CLI commands
STA
/interface w60g set wlan60-1 frequency-list=58320,60480,62640,64800,66000
AP
/interface w60g set wlan60-1 frequency=66000
Elliot
Wed Oct 24, 2018 12:20 pm
I'm just want to share my experience with PtP W60G link.
We've deployed this link about 45 days ago. Since then we have experience HEAVY rain (2 days non-stop) and light snowing. Link hasn't disconnected once and lowest MCM was 6.
I've read that people have problems with allignment but we all have because it's not easy and even 0.5 degree can make a difference. You should use terminal to see both sides and everytime you make change wait about 20-30s until information is updated. Also use ping to see if the link is table and once you feel like you got it just do BT Test.
on station side:
Freq: 64800
Signal:80
MCS:8
PHY Rate:2.3 Gbps
RSSI: -55
TX Sector: 16
RX Sector 96
Distance:399m
On bridge side
Freq: 64800
Signal: 80
MCS: 8
RSSI: -57
TX: Sector 36
RX: Sector 96
Dostance: 399
RouterOS 6.43.4 = very nice and stable
This link is in City with a clear view (from building to church)
antonsb
Wed Oct 24, 2018 12:37 pm
New beta versions has alignment mode included (it will update information much faster)
to use run from CLI:
/interface w60g align wlan60-1
nz_monkey
Thu Oct 25, 2018 1:52 pm
Thanks guys.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
Lakis
Forum Veteran
Forum Veteran
Fri Oct 26, 2018 12:17 pm
Pictures and Specifications.... Please.
mistry7
Fri Oct 26, 2018 2:03 pm
https://www.ip-sa.com.pl/doc/datasheet/LHG_Lite60.pdf
artferrr
Fri Oct 26, 2018 4:20 pm
We use LHG-60G on link ~900 meters. We have 1 gbit/sec in duplex mode bandwith-test. We try to establish link in 1.5km - fail.
marcin21
Fri Oct 26, 2018 10:56 pm
Dear users, what is Your real world bandwidth usage?
Is lhg60 in short distance ptp scenario really able to push ~1gbps ?
I just put up a 370m link to feed few hundred users from 1gb/s fiber and I wonder if it's gonna work or should I look for more sophisticated FDX solution?
server8
Sat Oct 27, 2018 9:18 am
At 370m with good alignment a couple of LHG 'd work close to gigabit FD due to alignment problem with the standard bracket I suggest to you to use this http://www.cdr.pl/p6418,uchwyt-precyzyj ... adkit.html
marcin21
Sat Oct 27, 2018 1:26 pm
Thanks for reply, but I see it quite expensive bracket. And with my brick chimney 50m high, windload gives a lot of instability overall.
So i'm not sure if it will help.
1/As for now I see signal 90-105 and mcs 8 to 11, are higher mcs even possible?
2/And what about pps or tcp is this arm cpu capable of doing 1gbps TCP traffic? I've seen some iperf test to fill 950mbps of tcp but seen only tests.
3/Anybody use this gear in real world and achieves such bandwidth?
artferrr
Sat Oct 27, 2018 4:36 pm
we have use lhg 60g on link 900 meters. All OK. throughput ~1 gbit/sec in duplex test.
Lakis
Forum Veteran
Forum Veteran
Mon Oct 29, 2018 12:41 pm
artferrr
I m running link 1750m freq:64800 37days not a single ''link down''
If you have time please read all posts on this topic
Those are the top three records :)
1. venthyl 1950m
2. Tepelensi 1845m
3. mistry7 1812m
blue
Mon Oct 29, 2018 1:32 pm
My working link is 2205m. Rain haven't fall in more than a month, so I don't know how it will behave. 5GHz is backup.
Please look at this post:
viewtopic.php?f=7&t=133374&start=50#p680529
Lakis
Forum Veteran
Forum Veteran
Mon Oct 29, 2018 3:30 pm
How did I miss that. Nice Blue nice alignment I was going to test 2000m next week.
With that signal moderate rain should not case any problems.
Top distance records
1. Blue 2205m
2. venthyl 1950m
3. Tepelensi 1845m
4. mistry7 1812m
honzam
Mon Oct 29, 2018 4:03 pm
LAN, FTTx, Wireless. ISP operator
whoknew
Mon Oct 29, 2018 4:19 pm
For all of you that don't seem to be dropping, how are you aligning your LHG's and even WAP60G's if using those. My disconnects have to be coming from an alignment issue.
Are you using Signal, RSSI, sector info?
blue
Mon Oct 29, 2018 4:23 pm
Few days ago I tested on around 6000 meters, but no luck. One side was fixed on tower, and other side was aligned from hand.
blue
Mon Oct 29, 2018 4:25 pm
I am looking at RSSI.
marekm
Mon Oct 29, 2018 5:44 pm
These long-range links use a non-standard and illegal 66000 frequency. Any chance for MT to implement 66960 and possibly 69120 too? Still illegal in many parts of the world, but at least standard (channels 5 and 6), doesn't interfere with 64800 which may need to work at the same location too. Or is this beyond the capabilities of current hardware?
MonkeyDan
Mon Oct 29, 2018 9:27 pm
Just an FYI, the bandwidth test tool doesn't max out the capacity of the link. For a full-speed test use the traffic generator.
jainge
Mon Oct 29, 2018 11:48 pm
Is the Left/Right - Up/Down - Center alignment working properly using this with latest 6.44Beta28 ?
blue
Tue Oct 30, 2018 7:25 am
I don't believe what it reports. I am looking only at RSSI. It is tricky to align it without precise alignment kit, but spend a little more time than usual since beam is very narrow (that is a good thing).
Elliot
Tue Oct 30, 2018 12:47 pm
1/ not at the time
2/ it's capable of doing 1 Gbps in TCP
3/ we use this gear and it works fine. Clients (about 150 clients) don't fully utilize aggregation of this link. There's about 60kpps in TCP of traffic.
As with everything in networking the quality of your network depends on your needs. Are your Clients even capable to fully aggregate PtP 60G link ? I think you should deploy one PtP link (it's cheap af) and test it or just look at your switch and look how many pps and what size they are using.
gr0mit
Tue Oct 30, 2018 1:23 pm
Trying to work out if I should waste my time trying a 320 metre link with a pair of Wireless Wires?
Don't need 1Gbit - I'd be happy with 200 bit. Is this going to fly based on people's experience with latest firmware?
Best Regards
Tim Robinson
TxRx Communications Ltd
http://www.txrxcomms.co.uk
MTCNA MTCRE
miltont
Tue Oct 30, 2018 5:22 pm
Yesterday we installed 1 New Link using the 60Ghz PTP Radios
Strange thing is the date it states its November and we still in October
This is the results:
jainge
Tue Oct 30, 2018 9:47 pm
This is what I am seeing when running the align test from the Bridge unit:
connected: yes
frequency: 64800
tx-mcs: 8
tx-phy-rate: 2.3Gbps
signal: 90
rssi: -57
tx-sector: 36
distance: 1473.14m
tx-packet-error-rate: 0%
However, after I ran the align test, the Bridge unit defaulted back to Frequency 58320... Why does it change frequency?
connected: yes
frequency: 58320
tx-mcs: 8
signal: 90
rssi: -54
tx-sector: 27
distance: 1473.19m
server8
Wed Oct 31, 2018 8:10 am
.... and why you have a better rssi with the lower channel 1473m is a long link
jainge
Wed Oct 31, 2018 11:00 am
connected: yes
frequency: 64800
tx-mcs: 8
signal: 90
rssi: -57
tx-sector: 36
distance: 1473.14m
connected: yes
frequency: 58320
tx-mcs: 8
signal: 90
rssi: -54
tx-sector: 27
distance: 1473.19m
I found the problem... Do Not go to QuickSet screen to check on frequency or try to select the 64800 frequency. If you do, you will notice that 64800 is not listed. And if you then exit the QuickSet screen by selecting OK, the radio will revert back to Auto and select a different frequency. You have to go back to wlan60-1 interface and select the 64800 frequency there. Or go to Wireless interface to select 64800 frequency. - - I believe that you should look at having the 64800 show up in the drop down of the QuickSet screen.
Elliot
Wed Oct 31, 2018 11:50 am
Dude read the fcking post here. I've post that I have 399m link working 1Gbps and no disconnect with HEAVY RAIN. We talking Noah Ark biblical rain here right.
So read my post and like Nike commercial says "just do it".
cohprog
Wed Oct 31, 2018 12:04 pm
RSSI: -55
Distance:399m
Uh... your link is 400m. I certainly hope that it won't drop with such a short distance. Most problems start with links above 1km. 60Ghz is nothing like 5Ghz: the signal fades _a lot_ faster with distance. That's why you can't do long distances and that's why there is little or no interferences between two links.
At 400m, you can just align by sight and get a pretty good result. In fact, -55db for 400m is not a good signal. You should be able to get much better.
cliffordjames
Wed Oct 31, 2018 12:06 pm
Not really professional or appropriate to speak to other people that way when they are asking for help.
blingblouw
Wed Oct 31, 2018 12:32 pm
Especially since he says Wireless Wire (i.e. Wap60) and not Wireless Wire Dish (LHG60). To answer, no. I would not use Wireless Wire at that distance
Lakis
Forum Veteran
Forum Veteran
Wed Oct 31, 2018 2:56 pm
lol Eliot you wrote " PtP W60G link." gr0mit wrote "Wireless Wires" so I m confused there is LHG60G and wAP-60G
I know I know Mikrotik stupid names everything begins with Wireless Wires Fiber Optic UP PoE 4km also 200m+ so + is like 100m or 500m you figure it out.
LHG60G-Wireless Wire Dish-RBLHGG-60adkit
wAP60G-Wireless Wire-RBwAPG-60adkit
whoknew
Wed Oct 31, 2018 11:20 pm
RSSI: -55
Distance:399m
So does this mean if I have it @ 200m or 20m I should see -20db? When I was testing in our office (we can get up to 25m) I was only ever able to get them to -49db, at 426m I am sitting around -58db on the 58320 frequency.
cohprog
Thu Nov 01, 2018 11:42 am
With the dish (LHG60G)? Should probably be around -30/-35. At 400m, it should be around -45 and at 1km, -55 (with channel 4). With channel 1, it's probably going to drop to -55 for 400m and -65 for 1km.
Elliot
Thu Nov 01, 2018 12:24 pm
RSSI: -55
Distance:399m
Problem is with beamforming, but there's tun of tutorials on internet to show you how to do it if you know how to google. As for my PtP link I didn't do beamforming and link is stable, that's why I've post my experience since this Topic is named "LHG 60G experience".
If Gromit wanted to use wAP 60 he should ask in appropriate topic.
So my whole point is. In my "experience" you shouldn't need to do beamforming at 400m link and you should be totaly fine even in rainstorm. And as I've already said, everything in networking depends on you needs. If you need maximum performance you should allign and set-up your link properly, but if you don't need more than 600Mbit/s and you prefer low latency and no interference you should be fine.
whoknew
Thu Nov 01, 2018 3:15 pm
I've been running down through the thread, where is the disable beam forming at? I will try to align without it, I am guessing we have been impatient with the alignment process, or beamforming is causing us to have a poorly aligned link and correcting it for us. its the set tx-sector=0 ?
server8
Thu Nov 01, 2018 3:49 pm
viewtopic.php?f=3&t=136455
whoknew
Thu Nov 01, 2018 4:36 pm
Lakis
Forum Veteran
Forum Veteran
Sat Nov 03, 2018 8:38 am
Honzam how is 4173m link, any luck with the rain is it stable?
Thanks.
mistry7
Sat Nov 03, 2018 9:19 am
Thanks.
No you will need backup
MoeWa
Wed Nov 07, 2018 12:56 pm
Hi Ladys and Gentlemen,
we are new to Mikrotik Devices and also new to 60GHz Links - so please be gracious to us, if we did a major mistake...
To give you a short info who we are and what we are doing:
We are the IT of a german Civic Administration. Most of time we need short connections around 500-1000m for our numerous outstations to connect for example City Halls, Libraries or Daycare Facilities for Childrens with the civic network. Till now we use a mix of 40GHz licensed (Connection between our 2 Town Halls and some Distribution Points), 23GHz licensed (Town Hall Backup) and 5GHz free equipment to connect our outstations.
As we are always willing to learn more and experiment with less expensive stuff we tried out a couple of LHG 60G that we installed 2 weeks ago for a link between one Town Hall and Waterworks. This is the Result we are getting - Station:
Signal: 80
MCS: 8
PHY-Rate: 2.3Gbps
RSSI: -69dB
TX Sector: 32
RX Sector: 96
Distance: 905.36m
Peer:
Signal: 55
MCS: 6
PHY-Rate: 1540 Mbps
RSSI: -69dB
TX Sector: 52
RX Sector: 96
Distance: 905.36m (would be surprising if it would differ from stations distance)
LoS-Test is good - no Trees, Houses or anything else between both points that should reach or effect the fresnel zone.
Do you have any ideas what is wrong here? We are getting ~90 Mbps/90 Mbps with Bandwith Test for Tx/Rx 10s Average.
We tried the different frequencies as mentioned here in this thread with winbox, but that didn't change anything. The connection seems to be bad with all frequencies and settings. Best for us is 58320
We also tried to test the native data throughput and was reaching 8MB/s as a max. So the data from this test seem to be real.
For the moment based on this data we would try to calibrate the Peer again - any other idea? Faulty device maybe?
As many of you say don't calibrate on behalf of RSSI - what should the Tx / Rx Sector be if we use them for calibration?
Regards
Daniel
normis
Wed Nov 07, 2018 1:12 pm
Yes, bandwidth test is the first mistake :)
Have you tried actual traffic through the link?
Also, you running latest RouterOS on both units?
server8
Wed Nov 07, 2018 1:13 pm
You alignment is bad @1000-the RSSI 'd be aorund -53 or less. Try this kit to have a "professional" allignment bracket for LHG 60 http://www.cdr.pl/p6418,uchwyt-precyzyj ... adkit.html
amt
Long time Member
Long time Member
Wed Nov 07, 2018 2:00 pm
what is dublex mode ? on LHG 60 you have choice for full dublex and half-dublex ?
MoeWa
Wed Nov 07, 2018 2:05 pm
Thanks for fast replys. You are deploying that tool for us, so you really should expect us to use it :lol: 8)
But as we know from other installations and devices that can test there throughput we never expect such tests to be real. So yeah, we tried actual traffic - maybe it was a misspoke here. We tested file transfer with a folder and round about 70 GB of Files with different sizes. Also we had iperf running which was also match with our tested data.
Totally forgot about to mention the version we are using: We run them with 6.43.4
I think we will have a look on our alignment again.
@server8
Is this a set of 2 or do we need to order it twice?
Lakis
Forum Veteran
Forum Veteran
Wed Nov 07, 2018 3:21 pm
@server8
One of your ethernet may be connected at 100mbit speed.
Lakis
Forum Veteran
Forum Veteran
Wed Nov 07, 2018 3:22 pm
Thanks.
What about 3km link, if I use 66Ghz do I need backup?
MoeWa
Wed Nov 07, 2018 4:33 pm
@server8
:oops:
I am a bit depressed - should have checked that myself.
Your expectation is right - Peers interface is however set to 100MBit/s. We'll investigate that when we check alignment...
amt
Long time Member
Long time Member
Thu Nov 08, 2018 2:23 pm
on version 6.44beta28 there is no any info at link status
blue
Thu Nov 08, 2018 2:50 pm
Unfortunately no! They broke it! Use terminal for all of the information...
amt
Long time Member
Long time Member
Thu Nov 08, 2018 2:55 pm
I tried to use align option for alignment the links and update devices to beta version and it's seems broken... when I use align in cli mode rssi and signal change so rapid for ex 50- to -58 but so quick when use monitor its better. which one should I use ?
and what should I check first while align, tx-sector-info ? or RSSI ? or Signal ? :) too much option on it
blue
Thu Nov 08, 2018 6:13 pm
I don't use align for same reason - to fast and all-over-the-place update of data. Use normal monitor, but be patient. Move lhg slightly and then wait couple of seconds. I look only at RSSI...
server8
Thu Nov 08, 2018 6:19 pm
Maybe with the precision kit the alignment tool works well
sasskass
Thu Nov 08, 2018 7:10 pm
To all who have aligment problems!
Use this method and You never miss:
https://www.aliexpress.com/item/10000m- ... a4f512def4
1. Install just the LHG mount
2. Allign the mount with the laser
3. Install the dish to the mount.
4. Enjoy
Kind Regards
Aleksander
amt
Long time Member
Long time Member
Fri Nov 09, 2018 8:44 am
AP A;
connected: yes
frequency: 64800
remote-address: mac deleted
tx-mcs: 8
signal: 95
rssi: -54
tx-sector: 26
tx-sector-info: left 0.6 degrees, down 0.2 degrees
distance: 720.68m
tx-packet-error-rate: 5%
Client A;
connected: yes
frequency: 64800
tx-mcs: 8
signal: 95
rssi: -48
tx-sector: 13
tx-sector-info: right 0.6 degrees, down 1 degrees
distance: 720.68m
tx-packet-error-rate: 3%
do you have any idea if dissonect on heavy rain ? and ping is more then 3ms on this link, may frequency ?
On Link B AP;
connected: yes
frequency: 60480
tx-mcs: 8
signal: 95
rssi: -56
tx-sector: 28
distance: 911.35m
Link B Client;
connected: yes
frequency: 60480
tx-mcs: 8
signal: 95
rssi: -56
tx-sector: 35
distance: 911.33m
On link B tx-packet-error-rate %0 but on Link A its changes betwen %3 and %5. what can be wrong ?
Thanks for suggestion
mistry7
Fri Nov 09, 2018 9:08 am
AP side is not aligned 100%
Client shows - 48 and AP -54 so there is a little difference
amt
Long time Member
Long time Member
Fri Nov 09, 2018 10:10 am
thanks mistry7 for your help
I worked on it too much to set :) I should work more you mean :) there are 2 LHG 60 on same tower but diffrend frequency, and one of them bridge mode and other client. is that situation make problem ? or should I caution on something ?
Thanks.
Stril
Fri Nov 09, 2018 11:23 am
4. Enjoy
Hi!
But how do you mount the laserpointer to the LHG-mount?
Stril
Fri Nov 09, 2018 11:50 am
Hi!
My precision kit just arrived, but CAUTION: it's not a kit! It's only for one side of the link!!
SpanMG
Fri Nov 09, 2018 12:57 pm
Hi guys, here are my results:
[admin @ AP]> int w60g monitor wlan60-1
connected: yes
frequency: 64800
remote address: 24: 18: 1D: 92: 09: C5
tx-mcs: 8
signal: 80
rssi: -59
tx-sector: 19
tx-sector-info: left 0.2 degrees, down 0.6 degrees
distance: 2312.3m
[admin @ CYBERA]>
[admin @ SM]> int w60g monitor wlan60-1
connected: yes
frequency: 64800
remote address: 24: 18: 1D: 98: A2: CE
tx-mcs: 7
tx-phy-rate: 1925.0Mbps
signal: 70
rssi: -61
tx-sector: 13
distance: 2312.31m
I liked the devices, but borgadas complain about fastening, as it is not very convenient.
There is also a big problem with software, on a stable 6.43.4 RSSI 64/68 was.
Probel upgrade-firmware beta: 6.44beta28 became RSSI 60/59
antenna pointing is very difficult, as the signal is updated with a delay.
Steveocee
Fri Nov 09, 2018 2:27 pm
My 2.6Km link does not want to link up. I'm using 64800 as not totally sure about legalities of 66Ghz in the UK yet. Little bit gutted as I expected at least something.
SpanMG
Fri Nov 09, 2018 3:11 pm
Apparently you do not direct the antenna. We previously worked with SIKLU so there is experience.
The main thing that would be direct visibility and accurate guidance. There are more people who have if the link and 4 km.
Steveocee
Fri Nov 09, 2018 3:49 pm
15M & 20M AGL at the 2 locations with very clear LOS. The Siklu links we have were easier than this!
anav
Fri Nov 09, 2018 4:45 pm
Hi Steve,
Just send me the airline tickets and I will be glad to stand at one end of the connection to move things around. I am really lucky ;-)
On the other hand the fetid vapours of intoxicated Brits (on warm beer) may be a cloud to dense for your traffic ;-PP
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Steveocee
Fri Nov 09, 2018 6:11 pm
Hi Steve,
That's it. Must be the toxicity of the climate of this damn island. You got room for Me+5 at yours right?
amojak
Sat Nov 10, 2018 9:20 pm
We should be getting up to 70 GHz in the UK , will the hardware support this i wonder? There is no "country code" option at the moment. 70GHz would be nice to use.
Bill
blue
Wed Nov 21, 2018 7:48 am
Finally, rain in Serbia after few months. 60GHz is doing great!
npero
Wed Nov 21, 2018 9:19 am
Yes after two months first rain in Serbia but here it is light rain with little snow. With this new version is working great on my short link 240 and 340m with wAP i LHG no disconnect.
We will see on heavy rain or show when is happens, backup link is ready ;).
antonsb
Wed Nov 21, 2018 10:40 am
Each version of RouterOS includes a lot of changes, it would help us, if you write versions you are using.
nimbo78
Wed Nov 21, 2018 2:00 pm
dear MikroTik guys... plz add 60GHz products to your Wireless Calculator! :)
blue
Wed Nov 21, 2018 6:29 pm
You are completely right:
6.44beta28
2205 meters
-57 rrrsi
honzam
Wed Nov 21, 2018 7:15 pm
First problems with snow. Links on 800m distances are down :(
https://translate.google.cz/translate?s ... t=&act=url
Lakis
Forum Veteran
Forum Veteran
Thu Nov 22, 2018 4:04 pm
Does it work on 66Ghz?
Stril
Fri Nov 23, 2018 4:27 pm
Hi!
Today, I tried to install my first LHG 60G - with not so much success...
399m, perfect LOS. No rain.
RSSI is only -48 NO MATTER, if it is really centered or no, NO matter which frequency. I could not get more than -48.
BUT: rx-phy-rate is changing all the time from 2.3 Gbps to lower values to "connected: no". tx-packet-error-rate is showing crazy values (between 0 and 2000%).
I am using RouterOS 6.44beta28
Can you give me a hint, what was my fault?
EDIT: Just disabled beamforming (tx-sector=36). Now, the link is stable at 2.3 Gbps phys, but still at -47 to -50db. Did you ever see better RSSIs?
Thank you
Stril
server8
Fri Nov 23, 2018 5:56 pm
Try to use this http://www.cdr.pl/p6418,uchwyt-precyzyj ... adkit.html to align with better rssi
Stril
Fri Nov 23, 2018 6:05 pm
Hi!
I am already using this kit on both sides, but its really strange:
I can see a wide window, where RSSI is about -50db! I just cannot get more than -40 to -50 - no matter if "perfectly alligned" or not.
One more, strange thing:
With 6.43.4, PHY-RATE is sometimes going down, IF there is no traffic on the link. If I start the bandwidth-tester, phys-rate is stable at 2.3 Gbps. Without traffic, it is fluctuating...
mistry7
Fri Nov 23, 2018 11:27 pm
Hi!
-48 is very good rssi !!
cohprog
Fri Nov 23, 2018 11:59 pm
Hi!
And what kind of RSSI do you expect at this distance?!? o.O
Stril
Sat Nov 24, 2018 9:07 am
I found that post and thought, -50db is not good for 400m...
If -50db is o.k.: Do you have any idea, why I do not get a stable tx-phy-rate, although RSSI is good? I tried different channels, beta-firmware and stable-firmware, with and without beam-forming.
I am also confused, that RSSI is the same - no matter, if I align the antenna to center or some degrees left/right and that it is not very stable. It goes up and down all the time for +- 2-3 db
mistry7
Sat Nov 24, 2018 9:53 am
You need to know that LHG60 has an Antenna array not only one,
So there Are more positions to get max RSSI
The fluctuation you see on data rate , you see the same on all 802.11ac Radios from MT if you not use the Link.
cohprog
Sat Nov 24, 2018 10:34 am
Those values were based on theoretical values for another device and adjusted to LHG based on real life experience. If you have more than -50dB, that's fine. The line won't start to drop before around -70dB so that's plenty margin.
LHG have beam forming so they don't need to be exactly aligned. Also, during the beam forming, values are going to change. You have to wait many seconds for the ligne to stabilize when you do alignment. If you reboot the devices, you will often not get the exact same values.
Stril
Sat Nov 24, 2018 11:01 am
Hi!
But do you have any idea, why the phys-rate is not stable although RSSI is good?
It is best at 64800 MHz, but not perfect stable at 2.3 Gbps.
At lower frequencies, RSSI is still at -50, but phys-rate drops sometimes to 386 Mbps
mistry7
Sat Nov 24, 2018 12:20 pm
Hi!
Do you run Data over the link when you see this?
Stril
Sat Nov 24, 2018 4:39 pm
Hi!
I tried it with and without traffic. After some time of traffic, phys-rate is mostly 2.3 Gbps but not always. Do you see drops without traffic?
...and what about the error-rate? What do you see here, or are most of you using the stable firmware?
blue
Sat Nov 24, 2018 6:18 pm
Another record!
Master side:
connected: yes
frequency: 66000
tx-mcs: 4
tx-phy-rate: 1155.0Mbps
signal: 50
rssi: -62
tx-sector: 58
tx-sector-info: left 0.6 degrees, up 1.4 degrees
distance: 4332.52m
Slave side:
connected: yes
frequency: 66000
tx-mcs: 3
tx-phy-rate: 962.0Mbps
signal: 40
rssi: -65
tx-sector: 22
distance: 4332.49m
blue
Sat Nov 24, 2018 6:19 pm
It was to cold today to play with link and finetune it. We are waiting for one day without wind to play with antenna aliment.
Stril
Sat Nov 24, 2018 8:30 pm
Another record!
Master side:
connected: yes
frequency: 66000
tx-mcs: 4
signal: 50
rssi: -62
tx-sector: 58
distance: 4332.52m
Slave side:
connected: yes
frequency: 66000
tx-mcs: 3
signal: 40
rssi: -65
tx-sector: 22
distance: 4332.49m
Wow! Congratulations!
@tx-packet-error-rate:
I do not really understand, which is the cause for theses errors? I have a better RSSI on a short link, but still see up to 10% tx-packet-error-rate. Is somebody else here seeing that behaviour? BUT: the tx-packet-error-rate goes to 0-2%, if tx-sector=36 on the master-side.
RSSI is also 4db higher without beam-forming...
autostoper76
Sat Nov 24, 2018 8:43 pm
Another record!
Master side:
connected: yes
frequency: 66000
tx-mcs: 4
signal: 50
rssi: -62
tx-sector: 58
distance: 4332.52m
Slave side:
connected: yes
frequency: 66000
tx-mcs: 3
signal: 40
rssi: -65
tx-sector: 22
distance: 4332.49m
Wow! Congratulations! +1
How does it work when you test real data transfer / Kako se ponasa link kad testiras realan prenos podataka (Sunce, kisa, sneg, vlaga u vazduhu)
blue
Sat Nov 24, 2018 10:00 pm
Thanks for the congratulations :)
Link was deployed today. It is too early to say anything about it, but 5GHz AC will be backup. I didn't had adequate equipment for test, and btest is useless these days. I need another day without wind to finalize aligning. For now only one test user is using/testing it.
BTW this link is a part of two p2p links to span over 6km. Few weeks ago we tried that distance but it didn't work. So, now we have 4332 metres plus 2679 metres.
So it is to early to give you guys some results.
Ali u svakom slucaju drzite mi palceve da sve proradi kako treba.
BR/Pozdrav...
blue
Sat Nov 24, 2018 10:04 pm
Here is the info from other part of that 6km link:
Master:
connected: yes
frequency: 66000
remote-address: 24:18:1D:XX:XX:XX
tx-mcs: 8
signal: 65
rssi: -63
tx-sector: 32
tx-sector-info: left 1.4 degrees, up 0.2 degrees
distance: 2679.32m
Slave:
connected: yes
frequency: 66000
tx-mcs: 8
signal: 80
rssi: -62
tx-sector: 59
tx-sector-info: left 0.2 degrees, up 1.4 degrees
distance: 2679.31m
blue
Sat Nov 24, 2018 10:07 pm
As You can see, both links are working on 66.000! On the central location. antennas are almost back to back, and it looks like it doesn't bother them :) I tried shorter link at 64ghz, but connection was not stable. I assume that is misalignment related.
gemb
Sat Nov 24, 2018 11:49 pm
Record with LHG60 ?
blue
Sun Nov 25, 2018 9:28 am
Congratulations Gemb! How much time did You spent on aligning? I have another 5130 meters link and didn't want even to try, but Gemb give me something to think about :)
server8
Sun Nov 25, 2018 10:01 am
I can't understand why mikrotik/ignitenet don't have a 60cm version? Maybe it's a regulatory problem?
blue
Sun Nov 25, 2018 10:13 am
My humbly opinion is that oxygen absorption is an obstacle to build devices with bigger dish. I hope that I am wrong. But there is no obstacle to implement 5ghz backup in same device...
server8
Sun Nov 25, 2018 10:23 am
Only a 5 ghz feed to use with external radio :-)
blue
Sun Nov 25, 2018 10:50 am
You don't need external radio. 5ghz is implemented in same cpu with 60ghz. So, only feed!
gemb
Sun Nov 25, 2018 12:05 pm
Well its just for testing purposes, nothing else. Its not even stable....i was just curious how far can it get. Usable distance with pair of LHGs is about 1800m at 66GHz or 1400m with 64,8GHz. Stable in rain about 50mm/h. But for now we need protective cover for whole LHG because the grid of LHG is nicely holding snow and kills every longer link.
amt
Long time Member
Long time Member
Mon Nov 26, 2018 12:30 pm
is better to use frequency: 66000 for long distance ? do you have any experience with your tests ?
blue
Mon Nov 26, 2018 1:02 pm
66GHz is mandatory on 2200+ meters!
antonsb
Mon Nov 26, 2018 2:50 pm
Not exactly true -
connected: yes
frequency: 64800
remote-address: 04:D6:AA:AF:D3:C6
tx-mcs: 8
signal: 80
rssi: -57
distance: 2409.94m
amt
Long time Member
Long time Member
Mon Nov 26, 2018 3:39 pm
Not exactly true -
connected: yes
frequency: 64800
tx-mcs: 8
signal: 80
rssi: -57
distance: 2409.94m
so ? I can use 66Ghz for 900m link also for better performance.
blue
Mon Nov 26, 2018 4:58 pm
Not exactly true -
connected: yes
frequency: 64800
tx-mcs: 8
signal: 80
rssi: -57
distance: 2409.94m
Great info! I correct myself :) So, what is maximum theoretical distance for 64800?
RemiR
Mon Nov 26, 2018 5:13 pm
Hello
A colleague tried to install the Wireless Wire Dish kit (RBLHGG-60ADKIT), from mainland to an island. Mounted at 3 and 6 meter height, 700 meter over a lake, clear sight and so forth.
Also tried a different kit, same results. Default configuration, but no connection at all. Kits works without problems if next to each other. (ROS within 6.43.*). Used a couple of hours trying to align them with no success at all.
0.7 km with 60 Ghz should give maximum 0.93 m radius on the freznel zone ?
(Freznel zone calculator / formula).
How accurate must the alignment be for a successfull link to take place?
Other than alignment issues what could the problem be?
I would expect to see contact/link after trying long enough, even just for a short while ?
Next try we'll keep these tips in mind:
- Better mounting kits and/or lasers
- Disable beamforming: /interface w60g set 0 tx-sector=36
- Using CLI alignment (quicker/too quick): /interface w60g align wlan60-1
ryny24
Mon Nov 26, 2018 7:27 pm
Hello
from our experience, the most important thing is to put a good amount of traffic over the link during the alignment. If you don't, the readings are not updated fast enough. Even in alignment mode.
marcin21
Mon Nov 26, 2018 10:00 pm
Hello
If You could try downgrade to 6.43rc17 and see if it helps, I stumbled on very similar situation and downgrade to rc17 works like a charm.
And there is few similar situation in my deployments that rc17 works with stable mcs8 when newer fw wont even connect.
So If You would confirm rc17 as a solution I wouldn't feel alone :)
paulct
Tue Nov 27, 2018 8:20 am
Yup also using the latest beta. On two separate links of +-1800m and 2000m cannot even make a single link. Using 64800 and 66000. You would think after aiming for a while there would at least be a connection - a bad one at least.
blue
Tue Nov 27, 2018 8:32 am
Yes, You have to wait a little (a lot) for link to establish. Be patient. First, connect devices in lab conditions, and after that take them to the field. Be sure to use 64800 or 66000. Aiming of LHG is very critical since it has only 2°. That 2° is very different from 5GHz. 60GHz have instant cut-off when You misalign the link. Once again: be patient. And put some traffic between devices while aiming - it would help a little (thanks to ryny24 for the tip).
And one last thing - I am using latest beta (6.44beta28) on all of my 60ghz links...
Stril
Tue Nov 27, 2018 9:57 am
Hi!
Aligning is a real pain compared to other 60G-devices... I was using two Bridgewave-Links which could be aligned with a multimeter - easy process.
The LHG 60G are crazy:
- Without alignment-mode:
It takes 5 minutes! until the signal gets stabilized! RSSI dances up and down within the first 300s. Then, it is getting stable.
- With alignment-mode:
Signal varies A LOT! I wrote a script that averages the RSSIs of the last 10s to be able to see anyhing...
- After every restart of the link, it shows another RSSI...
I am using the precision-bracket, which is expensive but GREAT, but as the signal is not stable, its hard to find the right position...
antonsb
Tue Nov 27, 2018 12:25 pm
please check if scan-list on "station-bridge" device includes frequencies you are trying to use. Alignment needs to be very precise for connection to be established.
Upcoming Beta version (will be released today or tomorrow) will include rolling avg of RSSI value - "10s-average-rssi"
amt
Long time Member
Long time Member
Tue Nov 27, 2018 3:44 pm
and relased :)
blue
Tue Nov 27, 2018 4:34 pm
Already updated :)
Stril
Tue Nov 27, 2018 9:11 pm
Hi!
Can you tell me, what kind of grounding you are using with the LHG60?
Option 1:
Use shielded patch-cable and a surge-protector like the UBNT ETH-SP-G2 to ground the patch-cord.
Option 2:
Add second cable to the antenna with grounding-cable
Option 3:
Option 1+2
Thank you for your hint!
blue
Tue Nov 27, 2018 10:15 pm
Wherever I can I use second grounding cable in combination with Schrack outdoor s/ftp cable. Anyhow, for me grounding is a must - regardless what many others are telling.
autostoper76
Fri Nov 30, 2018 12:51 am
+1
Earthing is mandatory
and ethernet protector !!!
https://3.imimg.com/data3/HP/FL/MY-1033 ... 00x500.png
Stril
Mon Dec 03, 2018 9:23 am
Hi!
Do you see ANY updates on RSSI, when the link is running?
I had much fluctuation within the first 5 minutes, but then, I do not see ANY change - no matter if it's dry or wet.
autostoper76
Mon Dec 03, 2018 1:02 pm
what are the experiences ?
with the new 6.44RC40 version
paulct
Thu Dec 13, 2018 9:57 am
Got out link working on 66ghz at 1892.47m. Getting a mcs of 8 and 2.3Ghz. It can still be aligned quite a bit better - we will try on a less windy day.
interface w60g monitor wlan60-1
connected: yes
frequency: 66000
remote-address: 30:07:4D:43:06:E5
tx-mcs: 8
signal: 50
rssi: -68
tx-sector: 16
tx-sector-info: left 1.4 degrees, down 0.6 degrees
distance: 1892.47m
solelunauno
Thu Dec 13, 2018 10:54 am
Does anyone have some experience in the use of LHG 60G with wAP 60G AP ?
SL1 Systems srl MTCNA MTCRE
mistry7
Thu Dec 13, 2018 10:55 am
@ Distance XXX????
solelunauno
Thu Dec 13, 2018 11:17 am
@ Distance XXX????
Yes. I suppose there will be less gain, perhaps 6dB less, so I could suppose a reduction of 50% in distance, 1500m-> 750m. In 750m there is also less fading, so I could suppose that a link from wAP 60G and one or more LHG 60Gs over 500-800m could work at least the same than a 1500m link composed by two LHG 60Gs. Is it right?
mistry7
Thu Dec 13, 2018 11:43 am
@ Distance XXX????
Depends on needs for Link,
with WAP to WAP wo go to 100m
With WAP to LHG we go to 300m
With LHG to LHG we go to 600m
all this cases without Backup link, we saw no drops in rain with this distances, waiting for some snow.....
solelunauno
Thu Dec 13, 2018 12:03 pm
@ Distance XXX????
So, you divided distances by two? Why? Did you experienced a completely down link during rain over nominal distances (ex 200m wap to wap)? Or did you experienced only a reduction in Throughput? And what about wap to SXTsq lite 60?
mistry7
Thu Dec 13, 2018 1:56 pm
@ Distance XXX????
I have SXTsq 60 here but not deployed, gain difference to WAP60 is unknown.
WAP with 150m we see downtime in hard Rain, also with LHG at 800m
SpanMG
Fri Dec 14, 2018 9:13 am
Friends, I ask for advice.
It is necessary to make a link to 250m. Traffic is assumed not much, up to 100 Mbps. What is better to deliver, LHG-LHG, or LHG-WAP
It is required in 60G, because. 5GHz is very noisy.
mistry7
Fri Dec 14, 2018 9:38 am
LHG ist 50€ more, and for this your link would be near 99% available......
SpanMG
Fri Dec 14, 2018 10:08 am
The price in this case is not very important, because the difference is not big. I understand that if you put two directional antenna LHG, then accessibility will have to be 99.9999%
But what will be the availability if you put two WAP or WAP-LHG
mistry7
Fri Dec 14, 2018 11:52 am
WAP to WAP will drop every rain /snow
WAP to LHG will drop on heavy rain
autostoper76
Mon Dec 24, 2018 1:11 am
LHG 60 real 4000+ m ? how ?
blue
Mon Dec 24, 2018 7:36 am
66000 GHz is working on 4000+. Tested in real life...
mistry7
Mon Dec 24, 2018 8:57 am
Shure it will work, but it drop every rain
ste
Mon Dec 24, 2018 9:06 am
We have seen snow is a killer for 60GHz. Even light snow fall killed our 1200m link completely.
nimbo78
Mon Dec 24, 2018 11:13 am
[admin@lhg60-ap] > int w6 monitor wlan60-1
             connected: yes
             frequency: 58320
                tx-mcs: 8
                signal: 95
                  rssi: -55
             tx-sector: 1
        tx-sector-info: left 1 degrees, down 1.4 degrees
              distance: 1167.48m
snowing for 2 days
hapi
Mon Dec 24, 2018 11:50 am
ok. Whats rain? Range for nice day is ok but bad day?
1200m is ok, You have it wrong targeted.
blue
Mon Dec 24, 2018 1:06 pm
For my links, falling snow was not issue at all. Only that sticky snow that got stuck on antenna is causing trouble. And of course that You need 5ghz backup for 60ghz link
autostoper76
Tue Dec 25, 2018 4:27 pm
Please, post printscreen Link LHG 60GHz of real +4000m
blue
Tue Dec 25, 2018 5:42 pm
Please use search or go to viewtopic.php?f=7&t=133374&sid=47ddbc29 ... 00#p699697
BR...
autostoper76
Tue Dec 25, 2018 11:12 pm
autostoper76
Tue Dec 25, 2018 11:13 pm
BR...
pease Givme your Skype or viber plesae
autostoper76
Tue Dec 25, 2018 11:20 pm
I've heard that Mikrotik has released the new LHG 60 Ghz R2 review
for range up to 6000m and embedded wifi 5GHZ
blue
Tue Dec 25, 2018 11:29 pm
BR...
Pitaj Jocu da ti da moj broj - ja sam Deki iz firme DDNet...
autostoper76
Tue Dec 25, 2018 11:42 pm
e pa da, pricao mije da tebe da ima odlicna iskustva
063/7320073
kuckamo se tamo na Vieru
BR...
autostoper76
Wed Dec 26, 2018 11:24 am
BR...
server8
Wed Dec 26, 2018 12:04 pm
autostoper76 ?????
autostoper76
Wed Dec 26, 2018 2:26 pm
BR...
Users browsing this forum: usern and 29 guests
