millenium7
Re: LHG 60G experience
Wed Feb 17, 2021 7:46 am
I always use 64800 if the links are above about 250m and often even less than thag
58320 is complete garbage. It theoretically should go much further but we've had radios drop out daily at only ~170m (LHG60G units) when it rains. Others have dropped when it's just overcast it doesn't even need to rain
Moving to 64800 fixes them most of the time, it should even be the default frequency
When co-locating radios I often still leave them all on 64800 as I find they really don't interfere much at all, radios 1m apart and I can run bandwidth test and still see ~1800mbit/s with the same error rate if both radios are running on same or different frequency. As long as the link never drops I can afford any potential reduction in speed anyway since almost all our 60ghz setups exceed the bandwidth on the 1gbit/s port, but so far havnt seen interference be a problem
If I don't even want to risk it I'll run next frequency down, but never use 58320, it has so many issues, not worth it
mp3turbo
Sun Mar 21, 2021 1:34 pm
dare to share any worst collocation setup you have ? I'm interested in couple of short 60GHz and it really seems like that lower channels are serious garbage due to oxygen/rain. This is of course not LHG 60G limited, I'm generally interested in any 60GHz experience. Sure I know crappy plastic LHG is something different to professional grade all-metal antennas/devices etc. but Im interested in any experience. Found two other topics related to this (viewtopic.php?f=7&t=143618&p=811170) and viewtopic.php?f=7&t=148687) and will read them carefully.
I lack the personal experience of how much co-location is possible. Your post has been very convincing and put a lot of hope - those radios "1m apart" you mention, are they pointing in the same direction ? Even if not, my head somehow can't accept that coming from 5GHz world :)
Possible to share any photo(s) and more details, please ?
millenium7
Mon Mar 22, 2021 1:59 am
Actually it is specifically a problem with the MikroTik 60ghz. The signal isn't so bad it would actually not work, the signal is definitely getting through. However I presume the beamforming or other mikrotik implementation causes periodic dropouts and it just so happens to be significantly worse at the lower frequency (auto picking the 'first' free channel means it also picks the worst one)
Plastic has nothing to do with it, infact its one of my favourite dishes for installation. You can partially see through the dish which makes alignment by eye much, much, much better. You don't even need the included little plastic scope thing, just use it like iron-sights and align holes in the dish with the front arms and center of the radio, gets you within a bees dick if the other side is visible. Still worth using a solidmount however, mostly because the crappy stock mount WILL move when you tighten it down to some degree
co-location is fantastic, I can have them on the same mast only separated by ~50cm or so and see no drop in performance even on the same channel
They do work well when used exclusively as a point-to-point and you get it dead nuts aligned (in which case you can leave beamforming turned off entirely if it causes problems) and follow a certain procedure. The problem is when you just slap them in, then you get all kinds of black magic, they work, they don't work, there's no explanation for why, and you are given incorrect readings (like the distance to center is woefully wrong, its just garbage, mikrotik please just disable it entirely it doesn't do the 1 job its supposed to)
sirbryan
Tue Mar 23, 2021 8:47 am
I have both MikroTik and Ubiquiti 60GHz gear at several locations. I had a GigaBeam Plus working just fine at 1.2km on 58320 for a long time before I realized it was on that channel. But few if any of my wAP60's are using that channel for anything. As millenium7 said, it's worthless on MTik's radios.
I also have AP's and backhauls sitting right close to each other, using the upper three channels, and I try to reserve 68400 for the APs with customers the furthest out. I have seen the modulation rates jump all over the place at one site with multiple radios configured for the same frequency, but its hard to say whether that was related to the hardware+channel combination, the number of devices on that channel, or external environmental factors affecting the channel.
I mainly use LHG60's as CPE, but have a couple deployed as PTP links. I haven't gone through the gyrations millenium7 mentioned to get them aligned; I use my phone's camera to align wAP60's and Cubes visually, and use the alignment tool that comes with the LHG60's, verifying any tweaks on the web interface and/or with the LED's. All MikroTik-based PTMP links are under 800m, and PTP are 1km or less.
If I want to do PTP over 1km, I use GigaBeams or AirFiber 60. The alignment tools and visual feedback of the UI radios' link performance are superior to the confusion of bouncing numbers and unstable beamforming details in RouterOS.
The best equipment is the tool that gets the job done.
Users browsing this forum: saaremaa and 37 guests
