hruhoriy
disconnected, received deauth
Sat Apr 21, 2018 9:43 pm
Hello
I have CRS125-24G-1S-2HnD
RouterOS 6.42
But error in Wireless:
disconnected, received deauth: authentication not valid (2)
disconnected received deauth class 3 frame received (6)
disconnected received deauth class 3 frame received (7)
How to fix it?
Thanks.
neu
Re: disconnected, received deauth
Thu Apr 26, 2018 9:07 pm
This problem can be for many reasons, security key in your wireless profile, interference, poor signal, channel overload, access list restriction.
I hope this will some how helpful: https://wiki.mikrotik.com/wiki/Manual:W ... Debug_Logs
neuCRM (http://neucrm.com) is full featured ISP Billing CRM software package for Mikrotik RouterOS.
hruhoriy
Mon Apr 30, 2018 5:12 pm
Hello
security mode - None
All clients in one room.
All clients are allowed access.
The same situation at different frequencies
BartoszP
Mon Apr 30, 2018 5:21 pm
Someone is attacking your WiFi?
https://null-byte.wonderhowto.com/how-t ... a-0147919/
Step 5
Real admins use real keyboards.
To quote or not to quote, there is the topic: viewtopic.php?f=2&t=168474
hruhoriy
Mon Apr 30, 2018 5:27 pm
But error:
BartoszP
Mon Apr 30, 2018 5:37 pm
Have you changed anything in your configuration? Security changed from WPA PSK to none? And all clients have "remembered" settings for the old configuration and computers tries to connect with password?
hruhoriy
Mon Apr 30, 2018 5:39 pm
No changed anything in configuration.
dougunder
Wed May 02, 2018 5:41 pm
I see the same error for one of my clients since upgrading to 6.42.1
We are using wpa2
ay/01 10:02:14 wireless,debug wlan1: 68:84:70:3F:75:90 not in local ACL, by default accept
may/01 10:02:14 wireless,info 68:84:70:3F:75:90@wlan1: connected, signal strength -73
may/01 10:02:45 wireless,info 68:84:70:3F:75:90@wlan1: disconnected, received deauth: authentication not valid (2)
may/01 10:02:55 wireless,debug wlan1: 68:84:70:3F:75:90 attempts to associate
may/01 10:02:55 wireless,debug wlan1: 68:84:70:3F:75:90 not in local ACL, by default accept
may/01 10:02:55 wireless,info 68:84:70:3F:75:90@wlan1: connected, signal strength -72
may/01 10:03:26 wireless,info 68:84:70:3F:75:90@wlan1: disconnected, received deauth: authentication not valid (2)
may/01 10:03:30 wireless,debug wlan1: 68:84:70:3F:75:90 attempts to associate
may/01 10:03:30 wireless,debug wlan1: 68:84:70:3F:75:90 not in local ACL, by default accept
may/01 10:03:30 wireless,info 68:84:70:3F:75:90@wlan1: connected, signal strength -71
may/01 10:04:01 wireless,info 68:84:70:3F:75:90@wlan1: disconnected, received deauth: authentication not valid (2)
may/01 10:04:18 wireless,debug wlan1: 68:84:70:3F:75:90 attempts to associate
may/01 10:04:18 wireless,debug wlan1: 68:84:70:3F:75:90 not in local ACL, by default accept
may/01 10:04:18 wireless,info 68:84:70:3F:75:90@wlan1: connected, signal strength -77
may/01 10:04:49 wireless,info 68:84:70:3F:75:90@wlan1: disconnected, received deauth: authentication not valid (2)
may/01 10:04:52 wireless,debug wlan1: 68:84:70:3F:75:90 attempts to associate
may/01 10:04:52 wireless,debug wlan1: 68:84:70:3F:75:90 not in local ACL, by default accept
may/01 10:04:52 wireless,info 68:84:70:3F:75:90@wlan1: connected, signal strength -72
may/01 10:05:23 wireless,info 68:84:70:3F:75:90@wlan1: disconnected, received deauth: authentication not valid (2)
may/01 10:05:27 wireless,debug wlan1: 68:84:70:3F:75:90 attempts to associate
may/01 10:05:27 wireless,debug wlan1: 68:84:70:3F:75:90 not in local ACL, by default accept
may/01 10:05:27 wireless,info 68:84:70:3F:75:90@wlan1: connected, signal strength -70
may/01 10:05:58 wireless,info 68:84:70:3F:75:90@wlan1: disconnected, received deauth: authentication not valid (2)
may/01 10:06:02 wireless,debug wlan1: 68:84:70:3F:75:90 attempts to associate
may/01 10:06:02 wireless,debug wlan1: 68:84:70:3F:75:90 not in local ACL, by default accept
may/01 10:06:02 wireless,info 68:84:70:3F:75:90@wlan1: connected, signal strength -80
may/01 10:06:33 wireless,info 68:84:70:3F:75:90@wlan1: disconnected, received deauth: authentication not valid (2)
may/01 10:06:37 wireless,debug wlan1: 68:84:70:3F:75:90 attempts to associate
may/01 10:06:37 wireless,debug wlan1: 68:84:70:3F:75:90 not in local ACL, by default accept
may/01 10:06:37 wireless,info 68:84:70:3F:75:90@wlan1: connected, signal strength -69
may/01 10:07:08 wireless,info 68:84:70:3F:75:90@wlan1: disconnected, received deauth: authentication not valid (2)
may/01 10:23:56 wireless,debug wlan1: D0:DF:9A:43:D5:E6 attempts to associate
may/01 10:23:56 wireless,debug wlan1: D0:DF:9A:43:D5:E6 not in local ACL, by default accept
may/01 10:23:56 wireless,info D0:DF:9A:43:D5:E6@wlan1: connected, signal strength -52
may/01 10:41:24 wireless,debug wlan1: 68:84:70:3F:75:90 attempts to associate
dougunder
Wed May 02, 2018 6:45 pm
I'm seeing the same issues, on 2 out of 10 in my upgrade test group.
I've confirmed that the credentials are correct.
Ultimately she did get the phone connected,
09:31:01 wireless,debug wlan1: 68:84:70:3F:75:90 attempts to associate
09:31:01 wireless,debug wlan1: 68:84:70:3F:75:90 not in local ACL, by default accept
09:31:01 wireless,info 68:84:70:3F:75:90@wlan1: connected, signal strength -74
09:31:32 wireless,info 68:84:70:3F:75:90@wlan1: disconnected, received deauth: authentication not valid (2)
Repeated many times before
09:48:07 wireless,debug wlan1: 68:84:70:3F:75:90 attempts to associate
09:48:07 wireless,debug wlan1: 68:84:70:3F:75:90 not in local ACL, by default accept
09:48:07 wireless,info 68:84:70:3F:75:90@wlan1: connected, signal strength -86
I hear similar tales form other customers, primarily on 6.42rc6 not 6.42.1
marlab
Tue Aug 07, 2018 12:33 pm
I'm also having this issue on 6.42.6. Signal strength -63, so not too weak. Sometimes I also get deauth due to MIC failure (14), for the same device
Ferns9k
Tue Aug 07, 2018 10:07 pm
I have noticed this in my home wlan too...by any chance clients are android devices?
dougunder
Wed Aug 08, 2018 7:17 pm
This is mostly fixed for our customers.
Were using the setting in the script in post one of "Wireless woes and how to fix em :)"
It is caused by congestion.
When reported we look at the network; resolve if internal (such as getting those stupid Direct print printers on the network instead of competing with it}.
If not internal do a scan and determine the best channel; then modify the scan-list in order of preference.
It's a lot better in 6.42.3 as well, haven't tested newer.
hova888
Wed Nov 06, 2019 2:16 am
Me too log- disconnected, received deauth: class 3 frame received (7)
device Redmi note 7. Routeros 6.45.7
Mikrotik hap ac2
mukeshpatra96
Tue Mar 31, 2020 6:30 pm
i lave router
RB921GS-5HPacD r2
plz solve my problem
jszabolcs
Fri Jun 12, 2020 8:57 am
Same here.
Xiaomi Redmi Note 8 Pro / MIUI Global 11.0.4 / Android 10 (with 2020-05-01 security patch)
2.4GHz is working, but 5GHz drops.
Both with wAP AC lite on workplace and hAP AC lite at home.
Users browsing this forum: No registered users and 19 guests
