Jotne
Re: v6.42.1 [current]
Tue Apr 24, 2018 8:07 pm
My PC Bios is not 10 as in Windows 10
Our Cisco 3650 switches at work is on Hw version 3.56 and IOS-XE is on 16.3.5b
I can make a long list where hw is not in sync with os.
But the list for where it is in sync will be short.
As of know, it's confusing and extra reboot for nothing?
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Pea
Tue Apr 24, 2018 8:13 pm
pe1chl: yes, this is clear.
The report about problem in this version is due to missing feedback in log after pressing the Upgrade button.
This "Firmware upgraded successfully, please reboot for changes to take effect!" did not appear in log. And this is unusual.
This information line was always there after pressing the button but this time was missing. That is all.
doneware
Trainer
Trainer
Tue Apr 24, 2018 10:26 pm
stumbled upon a strange stuff after upgrade.
[me@hgw2] > /log print follow-only
21:20:46 ssh,error Corrupt host's key, regenerating it! Reboot required!
it happens when i'm trying to access the router from my freebsd box
debug1: Local version string SSH-2.0-OpenSSH_7.2 FreeBSD-20160310
debug1: Remote protocol version 2.0, remote software version ROSSSH
debug1: no match: ROSSSH
debug1: Authenticating to 192.168.1.1:222 as 'me'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: diffie-hellman-group-exchange-sha256
debug1: kex: host key algorithm: ssh-dss
debug1: kex: server->client cipher: aes192-ctr MAC: hmac-sha2-256 compression: none
debug1: kex: client->server cipher: aes192-ctr MAC: hmac-sha2-256 compression: none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(2048<8192<8192) sent
debug1: got SSH2_MSG_KEX_DH_GEX_GROUP
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
Received disconnect from 192.168.1.1 port 222:3:
Disconnected from 192.168.1.1 port 222
whereas if i use my mac with a more recent SSH version, it just works. lucky me, otherwise i would be locked out.
debug1: Local version string SSH-2.0-OpenSSH_7.6
debug1: kex: host key algorithm: ssh-rsa
debug1: got SSH2_MSG_KEX_DH_GEX_REPLY
debug1: Server host key: ssh-rsa SHA256:N3zKod3ejAr1GLrtPPxf0ySdhQpwSVh3qo1tIdf88zU
debug1: Host '[192.168.1.1]:222' is known and matches the RSA host key.
the routerOS ssh config is as follows:
[me@hgw2] > /ip ssh print
           forwarding-enabled: no
  always-allow-password-login: yes
                strong-crypto: yes
                host-key-size: 2048
and no, reboot doesn't fixes the stuff, opposed to what the log message states.
#TR0359
Beone
Tue Apr 24, 2018 11:57 pm
ARM upgrade from 6.42 to 6.42.1 will fail if another architecture package is also found on the flash... sometimes required to upgrade caps...
in the past it would upgrade correctly and just ignored the extra architecture packages. Is this a bug or just intentional now?
/system routerboard> /log print
22:41:35 system,info installed routeros-arm-6.42.1
/system resource print
uptime: 3m28s
version: 6.42 (stable)
macsrwe
Long time Member
Long time Member
Wed Apr 25, 2018 12:27 am
I haven't worked with caps, but working with /system upgrade I learned that if you put npks in a subfolder, they will show up as "available" for other MikroTiks to fetch to upgrade themselves, but will not appear as available to upgrade the host MikroTIk on reboot, nor be consumed in doing so. Perhaps if you put your caps npks in a subfolder, this would solve your issue.
raymondr15
Wed Apr 25, 2018 2:01 am
Just updated my RB2011UiAS-RM to 6.42.1
After updating and rebooting I go back and check for updates, it shows 6.42 instead of 6.42.1, this does not happen on any of my other routers.
mt99
Wed Apr 25, 2018 3:24 am
Just updated one of our Metal G-52SHPacn to new v6.42.1 RouterOS.
tools/netwatch does not work anymore. When the tested server is "up", we run [:global srvstat "up"] to set the variable srvstat. Did work with 6.41.2
Looks like up event is not working.
Version 6.42 has this changelog entry:
*) netwatch - limit to read, write, test and reboot policies for Netwatch script execution;
I guess that breaks your use case.
Yes, netwatch is no longer usable to start scripts. Even to write to global variables fails. Only write to .txt files works. On up event, I need to write the server status up to a variable or file and start a script.
Still did not find a solution for that use. A high interval schedule is no option.
I haven't installed 6.42.x yet but I use Netwatch to run scripts on all my devices. I use local variables in these scripts, will they no longer work after this update?
hknet
Wed Apr 25, 2018 3:50 am
EoIP Ethernet Frame issue is still there (introduced in 6.42 breaking fragmenting big frames somehow broken) verified on RB2011 and sent supout to MT-support.
Xymox
Wed Apr 25, 2018 4:59 am
I wanted to follow up... Yes my Netwatch is not working.. This is really annoying as its sets up my DDNS. we need a 42.2 that fixes this..
Im not sure what happened last night, but, somehow none of my scripts would run from scheduler. I could run them manually. Its like scheduler somehow was not running, or did not have permissions to run scripts.. I always use 2 partitions and flipped back to 41.3 and all was well. Netwatch also worked of course.
I copied over 41.3, overwriting the 42.1.. Then switched to that.. All was well.. Then upgraded 41.3 to 42.1.. I lost Netwatch but gained back scheduler.
Ive gained a even weirder issue... I cant get around this...
/system leds> add leds=user-led type=on
input does not match any value of type
I can do off,,, but not on.. It seems to have lost on...
Xymox
Wed Apr 25, 2018 5:30 am
I can get on from Winbox,,, just not from command line or scripting..
macsrwe
Long time Member
Long time Member
Wed Apr 25, 2018 7:46 am
You know, I’ve been working with Support on an issue exactly like this. I have discovered that scheduler will often not start a script anymore if you just use the name of the script in the action, but if you say /system script run scriptname, it runs fine. Try that.
Xymox
Wed Apr 25, 2018 7:49 am
This change to Netwatch MUST BE REVERSED... Im REAALY UNHAPPY... I use this for a great many things. This change in what it can run seems, well, STUPID and POORLY THOUGHT OUT.. Mikrotik can't just take away features like that.
I cant even imagine a reason to do that.
Put this back ASAP or im gonna be REALLY VOCAL about this.
If your going to take away this big a feature that has been present in RouterOS for so many years at least provide a rationale for implimenting such a devastating reduction in functionality.
Xymox
Wed Apr 25, 2018 7:50 am
I will... Thank you :)
bennyh
Wed Apr 25, 2018 8:52 am
We have two 912UAG-5HPnD in bridged configuration. All of them was upgraded yesterday from 41.4. Until the upgrade, i could switch between nv2 and Nstreme protocol without problems (the Nstreme is faster but high packet losses, I always try after upgrades with Nstreme if there is any changes with packet losses, and then I switch back to NV2).
After upgrade, when I tried to switch to Nstreme on local AP, the webfig connection lost (local side, with UTP cable between AP and local router), and I could not ping from the router the local AP's IP address (the Layer2 connection seemed to be OK, there was Ethernet link, connected with 1GBps). After a power cycle and 5-10 minutes the network came back and the AP was reachable. I tried to switch back to NV2, but the AP connection was lost again, and I had to make a new power cycle, but the AP stayed at Nstreme. I had to revert to the backup config, and after reboot the AP switched back to NV2. It seem there is some problem with the bridge, the radio and the ethernet port is in same bridge. The IP address is connecting to unknown interface and i cannott change it to the bridge, the interface switchbox is empty at the address config page.
PS: After I loaded back the config backup again, now the adress is belong to the right bridge. Strange, maybe unsuccessful restore at first time or the Webfig is sick.
astraliens
Wed Apr 25, 2018 9:17 am
After upgrade to 6.42 (and the same after 6.42.1) found a problem with high sector writes values. More than 4000 writes for less than 24 hours.
Is it normal or not.
Somewhere but Nowhere
WebDev
Genkun
Wed Apr 25, 2018 10:40 am
Got 2 separate issues. One is verified and can be duplicated. Other is still being investigated:
When there is a AP Bridge / Station(Station Bridge) with a RB433 on either the AP or Station in 802.11 the station will not connect Rx rates whatsoever.
This is true regardless of password, connect list or access list settings. This is also true for bridged or non-bridged setups.
Will supply supout when available for the above.
Second issue is a PowerBox with a CPE connected to it. Lose all connection to the CPE. Still investigating the cause as we need to get on site to see what is causing this issue. Also don't see anything in particular in forums for RB750 issue. Could be unrelated.
icsterm
Wed Apr 25, 2018 11:45 am
RouterOS version 6.42.1 has been released in public "current" channel!
*) led - added "dark-mode" functionality for hAP ac and hAP ac^2 devices;
Still can't turn off the port led indicators in the hap ac2, winbox returns error that the board doesn't have this functionality.
WirtelPL
Wed Apr 25, 2018 11:51 am
In mAP is the same. Is it possible to add such functionality also for this model?
RB951G-2HnD for home production
RBmAP2nD | RB952Ui-5ac2nD-TC for home lab
lomayani
Wed Apr 25, 2018 12:31 pm
I have upgraded my core routers CCR1036-12G-4S. Am running mpls,ospf and bgp within these routers. One ccr keeps rebooting after like 15-20 minutes.
the rest are ok. the router which keep rebooting is acting head of mpls traffic engineering tunnel and is pushing traffic via this tunnel. On tail side am not pushing traffic via the tunnel. Upload from client is following the normal path chosen by ospf. these routers are not rebooting
I remember we used to have similar problem in this router before mikrotik fixed mpls relating issue last year
Other routers are working fine. Downgraded this router to 41.4 and it is stable now
vytuz
Wed Apr 25, 2018 12:49 pm
improved compatibility with BCM chipset devices
Looks huge improvement for mobile devices. 2.4G speed increased from ~10-20Mbit to 2-3x more. We use as endpoint devices for consumers. 2.4G had poor perfomance if several devices use traffic, much more better now so far.
Xymox
Wed Apr 25, 2018 1:27 pm
Ive verified on 3 different models, with 6.42.1 I cannot turn on a LED from command line or script. I can turn it off however. I use the LED control to drive a relay to control power to another device. So this functionality is important to me. Its more then just a LED to me. Completely repeatable on any model of router I have tried.
add led=sfp-led type=on
Kraken2k
Wed Apr 25, 2018 2:43 pm
Just a small thing: when you change Comment of an item, it is really necessary to "disable and enable" ("device changed" message is logged) the commented item? For example when I change comment to IPsec policy or wireless interface, it gets restarted which is annoying, because clients will disconnect. For other settings I can understand it, but comment should not affect any item settings, right?
vecernik87
Long time Member
Long time Member
Wed Apr 25, 2018 2:59 pm
I have same issue on RB951Ui-2HnD (with ROS 6.42.1 upgraded just today). I can imagine there are writes if you are using it a lot (you have over 2M writes total so obviously writes are happening a lot). However, my total is 30k for whole lifetime and I own this device over 5 years. Something definitely must be wrong:
I noticed there are random writes each 1-2 minutes. after enabling debug log, some of these writes corresponds with "skip Router Advertisement sending on XXXX: no prefixes to send" (where XXXX is bridge / eth). Some writes appear without any log entry - cant figure out...
my whole "/export" config is following:
# apr/25/2018 21:22:42 by RouterOS 6.42.1
# software id = 0HA0-YFNN
# model = 951Ui-2HnD
# serial number = 4AC7024C3DBE
add fast-forward=no name=bridge1
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=bridge1
/system clock
set time-zone-name=Australia/Hobart
/system logging
add topics=debug
/system routerboard settings
set silent-boot=no
/tool romon
set enabled=yes
edit: In addition I noticed missing "switch" menu in winbox connected to hAP ac^2 (last update added this menu to cAP, not quite sure why not hAP ac^2)
edit2: Just checked one another RB951 and noticed it has same issue with older ROS:
This one was AP in busy restaurant for over 2 years. Then about 5 month ago upgraded and deployed elsewhere ... Since deployment the ROS is same, so if last 18 days caused 70k writes, then it means those 660k writes would happen during approximately 5.6 month ... what a coincidence :( This makes me believe that increased writes are happening since earlier ROS.
edit3: I believe I found culprit! default setting now enables "cloud - update time". so in default setting, mikrotik is sending request to cloud.mikrotik.com (seems unsuccessfully) and that is causing useless memory writes! (actually i noticed that those queries often fail so it is better to enable SNTP client)
edit4: nope. requests to cloud are just part of those writes. writing rate decreased significantly but it is still happening (around 3k within last 9 hours)
nichky
Long time Member
Long time Member
Wed Apr 25, 2018 3:20 pm
How can i check which interface support fast-path on 6.42.
Like on previous versions, i was getting that kind info from
interface pr detail fast-path=yes/no ................. "What about on 6.42? how can i check?
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
!) Safe Mode is your friend;
vytuz
Wed Apr 25, 2018 3:21 pm
Confirm, that type=on is not recognisable( 4 changed via winbox to type - on):
/system leds> print
Flags: X - disabled, * - default
# TYPE INTERFACE
0 * interface-activity ether1
1 * interface-activity ether2
2 * interface-activity ether3
3 * interface-activity ether4
4 * (unknown)
Second question: we use custom startup script(easy modified), earlier QuickSet showed Dual Home AP mode, now it detects WISP AP mode and only one 5G wifi in QuickSet. I understand QuickSet is used rarely, but sometimes it is useful. Just question, how QuickSet identifies work mode? Totaly same exported scripts when QuickSet selected Home AP Dual and WISP AP.
It could be usefull option to disable QuickSet somewere at all. Just add option QuickSet=1 or 0. User can control by script if there are several bridges or specific firewall, QuickSet could be disabled.
rkadmins
Wed Apr 25, 2018 3:42 pm
in the winbox, BRIDGE section is showing NOTHING in PORTS section.
If you select Detail Mode - ports are showing.
Winbox - last verstion, RouterOS 6.42.1 .
On the 6.42 version everything was ok.
Any ideas???
deadmaus911
Wed Apr 25, 2018 3:52 pm
When I just open and immediately close without saving the quick settings, the configuration on the device changes. hap ac^2
pe1chl
Wed Apr 25, 2018 3:58 pm
I reported that before and the report was acknowledged and they are investigating.
atlanticd
Wed Apr 25, 2018 4:06 pm
I'm not sure if this issue happened after upgrading to v6.42.1, but on my hAP ac^2 the write-sect-since-reboot and the write-sect-total is missing in Winbox v3.13 / System Resources screen. /system resource print shows the values. Routerboard firmware is v6.42.1
cmwv6
Wed Apr 25, 2018 4:21 pm
I upgrade to v 6.42.1 SXT 5 ac, but not work > BRIDGE > Filter, until v6.41.3 is working well .
/interface bridge filter
Please FIX this bug.
Thank so much
Xymox
Wed Apr 25, 2018 5:23 pm
I assume someone is keeping track of this epic list of serious faults with a production "stable" release ?
Does Mikrotik have any bug tracker web URL ?
I have a suggestion, apply the security patch to 6.41.3 and lets roll back to 6.41 and skip 6.42.. There are really serious issues covered and confined in this thread, its time to take a serious stand and get things fixed.
Ive been doing Mikrotik a LONG time and ive never seen a mess like this. Normally even the Release Candidates are way more stable then this.
Im also really unhappy they took away the ability to use netwatch to monitor things and send a email alert.. This loss of functionality is honestly unfathomable. I want a official response here on the forum please.
GaToMaLaCo
Wed Apr 25, 2018 6:05 pm
You mean if you set the SNTP client to a NTP server then "Cloud update-time" must be set to "YES" ?
mkx
Wed Apr 25, 2018 6:11 pm
@bennyh: I assume that you have RB's IP address set on bridge. Do you have admin-mac statically set and auto-mac=no?
If not, bridge will assume mac address from one of member interfaces and if that member interface (momentarily) drops from bridge (I can imagine that happening when you change properties of wifi device), anything can happen.
BR,
Metod
jarda
Wed Apr 25, 2018 6:14 pm
Do not update the time from cloud. Use reliable time server instead.
xbipin
Wed Apr 25, 2018 6:22 pm
tried it on metal 52ac international and wireless became almost useless on 24ghz and clients dropping every few mins, reverted to 6.41.4
not to mention still waiting for the day when ill be able to see current tx power table as well be able to set tx power mode to card rates or manual
GaToMaLaCo
So "Cloud update-time" must be set to "No" right?
bratislav
Wed Apr 25, 2018 6:43 pm
I checked this on all our routers upgraded to 6.42 or 6.41 ...
And In ROS 6.41 and 6.42 Mikrotik Neighbor Discovery protocol outgoing traffic is actually allowed to bypass firewall altogether and cannot be caught in any chain, not something that any process should be IMHO ...
And for me this is actually pretty serious issue because I used firewall (as I should with any outgoing traffic) to control this on all of our routers ...
Not related to Winbox security issue, but seems like a bug ...
On 6.41.x and 6.42.x MNDP trafic is not visible anymore in firewall output chain ...
For example I am using this rules
/ip firewall raw> print
 0    chain=output action=passthrough log=yes log-prefix="" protocol=udp
 1    ;;; MT discovery
      chain=prerouting action=notrack dst-port=5678 log=no log-prefix="" protocol=udp dst-address=255.255.255.255
 2    ;;; MT discovery
      chain=output action=notrack dst-port=5678 log=no log-prefix="" protocol=udp dst-address=255.255.255.255
And on 6.40.x it works as expected
print stats
 #    CHAIN        ACTION                            BYTES         PACKETS
 0  D ;;; special dummy rule to show fasttrack counters
      prerouting        passthrough                  55 903 342         279 167
 1    prerouting        notrack                         295 008           2 176
 2    output        notrack                          25 870             195
But on 6.41.x and 6.42.x no packet is ever detected in output chain
 print stats
 0    output        passthrough                     226 965           1 663
 1    ;;; MT discovery
      prerouting        notrack                          99 706             724
 2    ;;; MT discovery
      output        notrack                               0               0
So is this some undocumented new feature and if so what is the benefit, or is it just a bug?
Regards
WirtelPL
Wed Apr 25, 2018 7:48 pm
I have too high write value. What is this and how to diagnose it ?
msatter
Wed Apr 25, 2018 8:18 pm
 1    ;;; MT discovery
 2    ;;; MT discovery
print stats
 print stats
 1    ;;; MT discovery
 2    ;;; MT discovery
      output        notrack                               0               0
Regards
It was discussed in a closed thread:
viewtopic.php?f=21&t=133533&start=150#p656843
It seem to be feature.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta59 / Winbox 3.20 / MikroTik APP 1.3.7
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
Fangcz
Wed Apr 25, 2018 8:19 pm
Having same issue with alot sector writes but here is catch - I've tried solution mentioned by vecernik87 but simply IP > Cloud setting is not there on x86 or am I missing something here?
gotsprings
Forum Veteran
Forum Veteran
Wed Apr 25, 2018 8:25 pm
Updated a CRS125 to 6.42.1.
Broke a few things.
Bridge changed.
Arp disabled
DHCP server moved to wrong interface.
etc
etc
Took a bit... but got it back on line.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
pe1chl
Wed Apr 25, 2018 8:32 pm
I know that updating from 6.40 or below to 6.41 automatically reconfigures the ethernet master-port config to a bridge with ports and hw accel on.
Could it be that this upgrading support has been dropped from 6.42? When I upgraded a router from an older release (I think 6.39.2) immediately to 6.42.1 the master port config was deleted but it wasn't converted to a bridge, I had to do that manually.
coylh
Wed Apr 25, 2018 10:01 pm
I'm seeing two things:
1. ssh keys are being regenerated as part of the upgrade.
2. Looks like netwatch is gone. Was this planned, or part of vulnerability mitigation?
macsrwe
Long time Member
Long time Member
Wed Apr 25, 2018 10:20 pm
Let us know if this works for you. Support is still nonplussed, and it never hurts to make them aware that multiple people are seeing the same problem.
ac6529
Wed Apr 25, 2018 10:36 pm
6.42.1 has caused a noticeable bump in disk usage on CCR1009-7G-1C.
Is that normal (expected?)
rzz
Wed Apr 25, 2018 11:17 pm
Upgraded to 6.42.1 and for some reason almost all switch ports were removed from bridges (luckily admin. bridge remained w. 1 port attached so I regained access to the router).
Device is RB2011iL-IN.
pe1chl
Wed Apr 25, 2018 11:41 pm
Did you upgrade from a pre-6.40 version? The you may be seeing the same thing as I mentioned in message #93 above. Like you, I was lucky I could recover the router.
vecernik87
Long time Member
Long time Member
Thu Apr 26, 2018 1:02 am
Not quite sure why you dont see it. I believe it should be accessible through console as well:
# to see what is currently set
/ip cloud print
# to disable update time from mikrotik cloud
/ip cloud set update-time=no
today morning i checked my both RB951. On both, write-rate decreased a bit (but still many times higher than pre-update)
Before i disabled update-time, first router was showing around 1000 writes per hour and second was showing 161 writes per hour.
Currently, one shows about 300 writes per hour and second shows 50 writes per hour.
I am well aware that according to viewtopic.php?t=128904#p634198 , this write rate is not going to cause any issues, however, I have to wonder why there is such increase after update. Both those RB were in use for several years without any significant writes while using some older ROS. After I took care of both and upgraded them, suddenly, they need to write so much...
Sure thing :) trick is, that not everyone knows about this feature and it is by default enabled (even after reset config with no-defaults). Everyone has to manually disable this.
I can confirm that it is not visible on 6.42 as well. Unfortunately I don't have any of my devices on older ROS so I can't check right now if it was missing earlier.
Also, the switch menu is not visible for hAP ac^2
I can see plenty of "bugreports" in this topic. Is there some summary or are we expected to report each of them to support@mikrotik ? Obviously, same bug will get reported many times by multiple people.
r00t
Thu Apr 26, 2018 1:43 am
Can see the same on RB600, big jump in disk usage:
Used automatic download from packages in Winbox to update it.
105547111
Thu Apr 26, 2018 4:05 am
Nice one that is the source of rewrites! Thank you
gonyotuya
Thu Apr 26, 2018 8:39 am
my hAP(hAP AC) have 1 meterouter. upgrade 6.42.1,
reboot system, deleted metarouter PKG file in nand.
this is bug?
erased file openwrt-mr-mips-rootfs.tar.gz
daras
Thu Apr 26, 2018 8:42 am
I ‘ve installed the latest version 6.42.1 in my RB3011 UiAS-RM and suddenly my router started to do cyclic reboots.
I ‘ve tried to netinstall but I cannot see the router.
In the console I can see a message “kernel not found or data is corrupted”.
Does anyone has the same problem ?
Before the update i didnt have any problem, do you think that the update crashed the router ?
whitbread
Thu Apr 26, 2018 10:08 am
No significant change in disk usage nor disk writes on RB2011, Upgraded from 6.41 to 6.42.1
bennyh
Thu Apr 26, 2018 10:11 am
I sent a reply in the morning, but disappered. So, Thats true what you wrote, there was not static admin MAC address, but with this config I doesnt have similar problem till v6.42.1. I dont find auto-mac section at the bridge properties, only the static admin MAC. Which MAC address range should I use?
SnakeSK
Thu Apr 26, 2018 1:04 pm
Integration services for hyper-v completely broke CHR, router refuses to communicate after 10GBs of routed data. Reverted back to 6.41.4
More here: viewtopic.php?f=2&t=133716
CZFan
Thu Apr 26, 2018 1:39 pm
WAN IP Lease expires on daily basis
Since upgrading to 6.42.1, I noticed that on a daily basis I get the following log entries
apr/24 15:16:35 dhcp,critical,error dhcp-client on ether1 lost IP address <WAN IP> - lease expired
12:28:52 dhcp,critical,error dhcp-client on ether1 lost IP address <WAN IP> - lease expired
Is DHCP not suppose to already start renewing from about 50% of lease time?
Is this related to the update or is my service provider stuffing up?
MTCNA, MTCTCE, MTCRE & MTCINE
pe1chl
Thu Apr 26, 2018 2:06 pm
Probably a combination of the two. I would start by running a packet sniffer for DHCP traffic on your link and save it in a file, download the file and examine in detail using wireshark or mail it to support.
sindy
Thu Apr 26, 2018 2:26 pm
I was thinking about the same, but there is an issue - sniffing on an interface breaks fasttracking so throughput falls down. So port mirroring on a switch and sniffing externally is needed.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Xymox
Thu Apr 26, 2018 3:43 pm
Stupid question. Where do I get 6.41.4 ?
Im moving all my clients back to a stable release. 42.1 just looks way to unstable to me.
Xymox
Thu Apr 26, 2018 3:44 pm
vytuz
Thu Apr 26, 2018 3:52 pm
I guess new kid control function is not working full yet. Added device with MAC, kid, and nothing happening when pause or resume user. No firewall rules appears. When I Pause it shows Paused, when I Resume it shows Blocked, still full access from this MAC.
Xymox
Thu Apr 26, 2018 4:00 pm
6.41.4 needs the security patch and 42.x needs to be reverted to RC.
eddieb
Thu Apr 26, 2018 4:06 pm
No problems with 6.42.1 over here, tnx for the great work MT !
Running 6.45.7 (stable) on :
CCR1009-8G-1S (2x ipsec/l2tp site-to-site, ipsec/l2tp roadwarrior, dhcpd, dns), CRS125-24G-1S, RB1100, RB962UiGS-5HacT2HnT (10pc), RB931-2nD, RB951, RB750GL ,RB2011UAS-RM, CHR running dude (CHR running in VirtualBox on OSX)
pe1chl
Thu Apr 26, 2018 4:07 pm
You don't need traffic on the link. You can sniff it during the night when you are sleeping.
aaronvonawesome
Thu Apr 26, 2018 5:35 pm
I have OpenVPN (ovpn) set up on my MikroTik home router (RB951G-2HnD), and I just updated to 6.42.1.
I'm noticing entries in my log:
ovpn, info TCP connection established form 125.212.217.215
That's an example of one of the IP addresses.
I may not have noticed these prior to updating, but I'm definitely seeing the afterwards.
Does this indicate that my OVPN has been compromised??? I've disabled my ovpn in the meantime.
td32
Thu Apr 26, 2018 5:53 pm
nope just service scanners
aaronvonawesome
Thu Apr 26, 2018 6:03 pm
Thank you very much for the response.
So I'm seeing a port scanner attempt? I guess I'm worried about the "established" part. Do you believe the connections are rejected ultimately? I can't see an indication either way.
I'm newer to Mikrotik, so I'm just trying to understand.
mrz
Thu Apr 26, 2018 6:21 pm
You should be worried when you see OVPn user logged in message :)
aaronvonawesome
Thu Apr 26, 2018 6:43 pm
Thank you :)
Xymox
Thu Apr 26, 2018 8:03 pm
Ive spent the morning downgrading all my clients from 6.42.1 to 6.41.4.. Over the last few days ive seen a number of weird things on client systems that are previously reported on this thread. I do not consider 42.1 "stable"... The other BIG deciding factor to revert to 41.4 is Netwatch. I use this extensively to monitor lots of gear on the clinet network and send email alerts & update DDNS or take other network actions. As Mikrotik decided to take away Netwatch without any reason or notice I have been forced back to a insecure version of RouterOS. I also use the on/off functions of the LED controls to control a relay that I can do various things with like power cycle the modem. As ON does not work from command line or scripting I also need to roll back. bugs and issues.
Ive been doing Mikrotik a LONG time, back when they only had PC boards, and ive never seen a stable release this riddled with bugs and issues like 42.1 is. I would hope Mikrotik is working very hard to correct this issue. Its cost me a bunch of time and money.
CZFan
Thu Apr 26, 2018 9:28 pm
Thx both, I have configured the sniffing tool in Mikrotik for bootps and bootpc for both directions, filter option to or and interface on ether1 and to be saved to a file. created a schedule to start this tomorrow morning at 03:00 so it does not affect performance through the evening while streaming movies, etc
bennyh
Thu Apr 26, 2018 9:36 pm
After I set static MAC address there is no difference. The router showed the neighbor AP with the new MAC address, but when I changed the the wireless protocol on AP, the webfig had beeen unreachable. After power cycle and config restore, now working again.
daras
Fri Apr 27, 2018 9:17 am
Hi All,
What steps can i perform to check if the RB3011 is not bricked ?
bennyh
Fri Apr 27, 2018 10:12 am
Hi All,
Maybe usefull for 3011 too:
viewtopic.php?t=132483
kaspi4
Fri Apr 27, 2018 1:14 pm
I ‘ve installed the latest version 6.42.1(sw and fw) in my RB3011 UiAS-RM and suddenly my router started to act strange. All ports are in one vpn bridge and some stopped to translate web and misticly random shares, if i put in diff port same pc problem is gone. One port refuses to translate any grafics(MC for example) only text mode. Winbox is not working any more through SSTP tunel(hangs on plugin download).It seems that this update killed a lot of RB3011's(QCA 8337).
frank333
Fri Apr 27, 2018 1:17 pm
I switched from 6.42 version to 6.42.1 I have a wisp pppoe connection I have this error
Default Route Distance 0, should mean route type 0, connected,then the value should be corrected.
Because instead it is highlighted in red as error or missing?
Somebody knows something?
Does it happen to you too?
mkx
Fri Apr 27, 2018 2:18 pm
Default route distance should be 1 or more. It used to be 0 and upgrade magic doesn't fix it.
BR,
Metod
zichovsky
Fri Apr 27, 2018 3:56 pm
this could happen if master port is not part of any bridge.
e.g. I have ether1 as gateway, ether2 as master port, ether3-5 slave to ether2. No bridges. All config (ip, firewall, dhcp etc) done to ether1 or ether2. Everything working, ports 2-5 swithcing, routing between ether1 and switchgroup ether2-5.
After upgrade to 6.41 and above it eliminatete master/port, but don't create new bridges. So I have only ether1 and ether2 working (routing), but ether3-5 are unconfigured and not working.
You have to create new bridge, add ports, reconfigure other things (ip, dhcp etc).
I'd be scared of upgrading some CRS's which could have more switch groups without bridges, and after upgrade I will get only few ports working.
So if you are using master-port, then before upgrade always check, that every master port is added to some bridge.
CZFan
Fri Apr 27, 2018 4:16 pm
Ok, seems Mikrotik / 6.42.1 is in the clear here
At 05:00 I can see router requesting new IP from previous DHCP server with no response from ISP
At 09:29 router WAN address starts broadcasting for new IP
At 12:29 router starts DHCP Discover process and ISP responds
Seems ISP is stuffing up
frank333
Fri Apr 27, 2018 5:11 pm
I changed from 0 to 1 the value and it seems to work. the manual indicates distance :0 connection 1 static address . (I have no static but dynamic address though??)
hapi
Fri Apr 27, 2018 5:18 pm
Everywhere RB OmniTIK U-5HnD, NSTREME, fail
client disconnect with "disconnected, too many poll timeouts". Sometimes all client, sometimes only part disconnected.
Sometimes they connect back, sometimes not.
Switching to NV2 is ok.
apr/27/2018 01:29:49 system,error,critical router was rebooted without proper shutdown
apr/27/2018 01:29:49 system,error,critical kernel failure in previous boot
apr/27/2018 01:29:49 system,error,critical out of memory condition was detected
hapi
Fri Apr 27, 2018 6:01 pm
Mikrotik DHCP client request for ip not in 50% expires time but in 10-15% expires time?
mk dhcp-client
# INTERFACE USE-PEER-DNS ADD-DEFAULT-ROUTE STATUS ADDRESS
0 bridge1 yes yes renewing... 192.168.0.22/24
10 minutes leases time. In 5 minutes expires renewing ip and in 1 minutes 15 second expires bound ip.
CZFan
Fri Apr 27, 2018 6:04 pm
No, the manual says:
0 - Connected "Routes" - Meaning directly attached, i.e. interface on router
1 - Static "Routes" - i.e. Default Gateway Route, not static / dynamic IP Addresses
frank333
Fri Apr 27, 2018 6:20 pm
now it is clear to me.
thanks Czfan
pe1chl
Fri Apr 27, 2018 6:57 pm
In my experience, when I updated configs like that (e.g. on a RB750) from 6.39 or 6.40 to 6.41 they got converted into a bridge config just fine.
However now I upgraded a similar system fro 6.39 immediately to 6.42.1 it did not happen. The ether2 was still configured but the ports 3-5 became detached from it.
I had to create a bridge, put ports 2-5 into it, and move the IP address from ether2 to the bridge for good measure (it works either way).
Therefore I wonder if the "masterport to bridge migration" may be only in 6.41 and not in 6.42
squeeze
Fri Apr 27, 2018 7:10 pm
@Xymox
Should you be using Release (Current) branch instead of Bugfix (Stable) branch for business of any kind?
coylh
Fri Apr 27, 2018 7:29 pm
It looks like netwatch is in the advanced-tools package.
IbleedDialtone
Sat Apr 28, 2018 12:05 am
We're seeing RB2011UiAS-2HnD's on version 6.32.2 upgraded to 6.42.1 by using winbox>packages>check for updates then download and install and reboot are missing the wireless interface and menue when they come back online. They end up with three separate wireless NPK files in the files section. wireless, wireless cm2, and wirelessfp. To fix it, we're deleting the cm2 and fp wireless npk files, rebooting, and then reconfiguring the wireless interface. It will come back as disabled, a client instead of an ap bridge, and the frequencies, protocol, and security profile set incorrectly. The SSID is also changed to the system identity. Plus, the port in the local bridge that used to to be wlan1 shows up as unknown and needs to be changed back to wlan1.
If we drag and drop the upgrade package into it via Winbox or use /tool fetch url="https://download.mikrotik.com/routeros/ ... 6.42.1.npk" mode=http the wireless issue doesn't occur.
Same thing happens with 6.32.2 to 6.40.8 bugfix
aoakeley
Sat Apr 28, 2018 8:11 am
Finding these changes introduced back in 6.41 to be most inconvenient
*) lte - automatically add "/ip dhcp-client" configuration on interface;
Can we have a way to turn off this behavior completely?
*) lte - changed default values to "add-default-route=yes", "use-peer-dns=yes" and "default-route-distance=2";
OR ability to adjust the dynamic options to set use-peer-dns=no and default-route-distance to a higher numbered route of our choosing.
I know 6.42 introduced the following setting. But suddenly having routers with unexpected IP Addresses and routes that were not there before is annoying.
*) lte - do not add DHCP client on LTE modems that doesn't use DHCP;
Andy
macsrwe
Long time Member
Long time Member
Sat Apr 28, 2018 8:15 am
@Xymox
When the Release (Current) branch has the exploit patch available, and the Bugfix (Stable) branch still does not... sometimes you do. But never again, my friend.
gcsuri
Sat Apr 28, 2018 8:20 am
do you have any news about the eoip issue?
best regards, Gabor
hapi
Sat Apr 28, 2018 8:21 am
A big problem with devices that have a 32MB ram.
jrpaz
Sat Apr 28, 2018 2:49 pm
I am seeing the same issue.
It gets the DHCP Lease information but doesn't rebind at the specified time.
I just downgraded to 6.40.8. and it's working as expected.
UGHHHHH
jarda
Sat Apr 28, 2018 3:48 pm
What exactly?
teslasystems
Sat Apr 28, 2018 4:10 pm
There is a problem with dude fonts in this release. I have some font files placed in dude/files directory and now it's impossible to select these fonts in dude settings, it only shows fonts from dude/files/default directory (which is read-only). Earlier everything was great, and it was possible to select the fonts from dude/files. Can you fix this?
pe1chl
Sat Apr 28, 2018 6:51 pm
After some of the above messages I checked a router that has DHCP client on LTE stick and I find the client in state "renewing...".
There is definitely something wrong there.
jrpaz
Sat Apr 28, 2018 8:09 pm
It's happening to me on all routers (RB2011,HEX2,CRS125) running 6.42.1.
The DHCP client is stuck on renewing until the lease expires.
I opened a support ticket lets see what they say.
CZFan
Sat Apr 28, 2018 8:13 pm
Sometimes I get this on my RB2011 (6.42.1, but think I it was same on 6.41.4) connected to ONT (Fibre) also. when I then manually release / renew, it changes to bound
coffee
Sat Apr 28, 2018 10:07 pm
My box also got owned ... phew.
hapi
Sat Apr 28, 2018 10:24 pm
What exactly?
Disconnect WiFi client. Disconnect capsman clie
nt...
Several omnitik. All of them had to switch to nv2 otherwise clients refused to join.
CZFan
Sat Apr 28, 2018 10:29 pm
UGHHHHH
Does not seem to be same problem as mine then, mine requests, but does not get back until lease has expired, see screenshot from packet analyzer
itmethod
Sat Apr 28, 2018 10:30 pm
this broke UPNP for me. it worked before I upgraded
Xymox
Sat Apr 28, 2018 10:58 pm
@Xymox
I have only been using stable. 42.x is not stable. 41.x is stable but not secure now. 43.x does not have Netwatch or a fixed LED ON script command.
I made sure the routers are not available to the outside world, so the security issue should not effect me.
I now wait for a solution to the debacle.
Xymox
Sat Apr 28, 2018 11:09 pm
Ive got 2 older routers I can't downgrade. There is not enough disc space. 42.1 seems to have taken up so much space I cant transfer firmware in. I will have to go on site and Netinstall them.. Thats annoying.. Both are RB1000AHx2
Looking thru the thread,, jeeze,, I think this "stable" 42.1 broke, well, everything. It even broke UPnP.. Killed off Netwatch... Caused DHCP to not work.. Everyday there is a new post here about something completly different that is broken..
Also, so far, there are no official Mikrotik posts about this faceplant and what they are going to do about it.
Ive never seen a RC this bad,, and this is a STABLE release... What a mess...
I am happy tho on 41.4.. Ive disabled everything but WInbox and put that on a random port and restricted it LAN side use only. So I guess im mostly safe from the security issue..
SnakeSK
Sat Apr 28, 2018 11:20 pm
Yea I had to do that also, 6.42.1 broke a lot of things, namely it completely broke the router on the Hyper-V platform, so this is a no go for me.
jspool
Sat Apr 28, 2018 11:21 pm
Downgrading a RB1100AHx2 from 6.42.1 to 6.40.8 bricked it. Will have to make a trip to the mountain to fix that one. At least I had a backup router in place!
Xymox
Sat Apr 28, 2018 11:45 pm
This has cost a lot of people time and money..
BUT.. We should all step back and think about how stable RouterOS has been for many years. For me its like 10 years of very stable and very reliable operation. So in my mind, its OK to have a accidental mess like this. Its just fine as long as they work hard to fix it very quickly. Its also important to step forward and admit the mistake and provide a plan on what they are going to do to fix the issue.
Why did they cripple Netwatch ? This needs to be put back in any fix they are working on now. It was crazy to remove this.
My 2 cents on what should happen.. Take 41.4 and apply a security patch for this new issue. Turn that into stable release 44.0.. Push that out right away.. Make RC 43.x into 45.1 and FIX IT. Then release 45 once its at like RC45.30 and all these issues are worked out...
vasilevkirill
Trainer
Trainer
Sat Apr 28, 2018 11:51 pm
hi
i use this construction
add name=ISP_1
add name=ISP_2
add include=ISP_1,ISP_2 name=ISP
add interface=ether1 list=ISP_1
add interface=vrrp-mts-ISP1 list=ISP_1
add interface=vrrp-rt-ISP2 list=ISP_2
add interface=ether2 list=ISP_2
I used list ISP for firewall rules in filter
if router rebooted, rules not action = not working
if you edit a list, for example, add a comment
set  comment=aaa ISP
The rules begin to work
problem only list = ISP
Vasilev Kirill
( MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCINE, MTCIPv6E, MTCSE )
MikroTik Certified Trainer & Consultant
Trainer Сertificate Number TR0417
https://www.mikrotik.me
Cell:+7 (905) 207-35-78
jrpaz
Sun Apr 29, 2018 3:16 am
UGHHHHH
That's the same problem as you are seeing it mirrors your cap. I notice that it only accepts the request when the source address is 0.0.0.0, not the public IP.
Modestas
Sun Apr 29, 2018 2:01 pm
UGHHHHH
Hi
Would be interesting to see more details in this capture: how does transaction look like, flags set, mac addresses etc etc.
Seems, DHCP server is not happy with unicast requests (renewal messages) sent from mikrotik router if these are sent out.
So far this DHCP issue seems to be quite serious defect in 6.42.1
Modestas
Sun Apr 29, 2018 6:25 pm
I did few DHCP tests with CHR versions 6.42, 6.42.1, 6.40.5 and cisco soapbox.
MT routers running 6.42, 6.42. send out all DHCP renewal requests towards specific DHCP server with wrong destination MAC address (namely, own MT router MAC address). Only following broadcast requests are sent to "all 1". No surprise, DHCP server would not receive such renewal requests until broadcasts arrive.
When broadcast domain is large and contains devices with ARP proxy feature, some more side effects may be observed.
DHCP renewal on Cisco and MT router running 6.40.5 works as expected.
Mikrotik engineers may want tolook into DHCP client behaviour at least on 6.42 and 6.42.1.
sindy
Sun Apr 29, 2018 6:33 pm
Please send the above to support@mikrotik.com (or shout loud, you're closer to Mikrotik premises than most of us :-) ), but don't rely on Mikrotik staff picking this information from this forum.
Modestas
Sun Apr 29, 2018 7:26 pm
I have no formal support contract with Mikrotik, but will try to do so.
Anyway, there was once SW defect in new version when router was not able to boot due to certain line in configuration. I wrote in this forum and Mikrotik engineers responded promptly.
Here are my lab captures if someone is interested.
sindy
Sun Apr 29, 2018 7:47 pm
After some discussion with @strods in one of these "current" or "rc" topics here, my understanding of the repelling sentence regarding support contract is that Mikrotik is not obliged to assist you in resolving simple configuration issues or alike but always welcomes meaningful bug reports such as this one. After all, the worst what can happen to you is that they won't answer.
pe1chl
Sun Apr 29, 2018 7:51 pm
MikroTIk is not like Cisco. Anyone can write a mail to support, no need for a formal support contract.
typicalwisp
Sun Apr 29, 2018 8:18 pm
Does 6.42.1 force SSH host key renewal on first login after the upgrade? The SSH host keys are changing on every router I upgrade and I want to rule out the unlikely MITM.
It would be nice to see ***Router SSH host keys will change after upgrade*** in the change logs of the next revision if this is expected behavior.
It would also be helpful if you uploaded all of the release files to virustotal.com under a Mikrotik account so we have an independent verification that your servers are providing a valid file. The hashes on the download page are really useful, router verification of the packages is too, and using SSL on the site is also most welcome, but when there is a major hole in the OS it's nice to have independent sources to verify the authenticity of the files. This is especially important when re-flashing a potentially compromised router. Thanks!
ivanfm
Sun Apr 29, 2018 10:47 pm
A few of my devices have changed keys, many of them retained the old key. I did not find motive to rebuild key in some and not in others.
typicalwisp
Sun Apr 29, 2018 10:54 pm
As I update more devices I am seeing the same thing. Some change keys, others don't. The ones that change keys take longer to respond to SSH. I assume that is because they were generating the new keys when the connection was initiated. Other than that, I haven't noticed a pattern.
Paternot
Long time Member
Long time Member
Sun Apr 29, 2018 11:40 pm
Some versions ago, the upgrade forced the new SSH key. Don't remember why, but it did. And the key was generated on the first reconnection, not just after the reboot. Perhaps You have some units with older versions, and some with newer?
typicalwisp
Mon Apr 30, 2018 5:12 am
Here is a random sampling of a few recent updates to 6.42.1:
1. 6.41: New key generated
2. 6.42: Key not changed
3-10. 6.41: Key not changed
11-14. 6.40.4 Key not changed
15-16. 6.40.4 New key generated
I suppose this might be caused by the router generating a different key type (like only having DSA and then generating RSA). Nope. #15 and 16 started off as an RSA key and finished as a new RSA key. This just happened to me locally so it's not likely MITM. Anyone have any idea why this is happening?
bbs2web
Mon Apr 30, 2018 11:53 am
Two problems with 6.42.1:
IP Neighbour discovery settings in Winbox are shown correctly as !external (ie negate 'external' list; aka all interfaces which are not a member of the 'external' interface list) but 'export' does not include the negate (exclamation mark):
Second problem is that the interface list in Winbox keeps on reloading. This most probably relates to a CCR1036-8G-2S+ router where we have more than 1000 interfaces defined. This occurs in Winbox 3.12 and 3.13, even after clearing cache.
PS: Yes, we have submitted emails to support@mikrotik.com
CZFan
Mon Apr 30, 2018 3:19 pm
Ticket#2018043022003403 sent sniffed data and suppout file
jrpaz
Mon Apr 30, 2018 3:40 pm
Same here lets hope they fix soon.
Alloca
Mon Apr 30, 2018 6:38 pm
Also interested. I had missed 6.42, but upon upgrading to 6.42.1 EOIP started falling over. This issues isn't highly referenced, so I missed it in any notes I looked for. Had to downgrade but would like to get back to running on the latest releases.
best regards, Gabor
Xymox
Mon Apr 30, 2018 7:33 pm
After having given up on 42.1 for all my clients and moved back to 41.4 I have decided to try out the RC. 43.5.. As Mikrotik has not responded to any of the issues listed in this thread that i know of, I think we might want to assume 42.1 is dead and that the next step will be 43.x ... So I suggest if you can you give that a test and see if that helps or ressolves any of the issues in 42.1..
I moved my home router, a CCR1009 over to 43.5.. As expected Netwatch is still dead and the LED On script command does not work. But I dont seem to be having any immd issues with a simple home router setup. Its been up for 3 days and seems to be doing OK so far in my limited home use.. NAT, some firewall rules, DHCP client and server. NTP client and server.. All that seems to be working OK.
So that was a upgrade from 41.4 to RC43.5 and everything seemed to move over well. BUT, its a very limited SOHO use.
gkostov
Tue May 01, 2018 5:53 am
After upgrade to 6.42.1 from 6.40.1 I experience strange behavior with our RB2011UiAS.
Some of connected devices can ping default gateway (which is on router) and some - can not. Those who can not, can ping another IP address on the same interface?!?
I'm experiencing strange things like: half of internet sites are unreachable, including many of google sites (but not all).
After many hours of testing I can not determine a reason for all weird things that happened after upgrade.
I'm going to downgrade the router and then will investigate issues, with a second router. Can i downgrade from 6.42.1 to 6.40.1 (that was my previous version) without losing my config? I have no use of master/slave ports (which I know are major change, reflecting configuration of bridges). I know that I can backup and restore config, but I hope to be able to do downgrade from remote site, not having to travel 50 km. for that...
tristanedward
Tue May 01, 2018 11:50 am
6.42.1 killed my metal2..package was updated and every time I upgrade the routerboard to current version, the rb simply stops and doesn't reboot anymore...will just go back to 6.41.3 and forget 6.42..it broke everything
steen
Tue May 01, 2018 2:34 pm
I have the dude problems, is this correct place for announcing this ?
However the dude device box does not recognize snmp -> interface, snmp -> ip, snmp -> routing, snmp -> storage for Linux, and Cisco ASA devices.
I have a parallel run with dude 3.x and the new 6.42.1 version, in old dude it works but not in the new, please see link below:
viewtopic.php?f=8&t=133884
It was solved by using snmp v.2 for the troublesome devices, dude default is snmp v.1 which it always has been.
Something has changed regarding snmp in the dude, snmp discovery is very slow in comparison to the legacy versions 3.x and 4.x (which had a nasty aggressive snmp that could overload devices).
jarda
Tue May 01, 2018 2:37 pm
Don't forget to send your finding to the support@mikrotik.com directly.
Redmor
Wed May 02, 2018 12:12 am
I saw that now I can download automatically the new RB firmware with "Auto upgrade", there's also a way to auto reboot?
105547111
Wed May 02, 2018 2:12 am
Not at this time must reboot a second time after updating RoS version, then a reboot second time after firmware for firmware update...
105547111
Wed May 02, 2018 2:13 am
Post doubled itself :-(
105547111
Wed May 02, 2018 2:16 am
Also there was talk of perhaps suppressing the firmware reboot message if not needed.
jspool
Wed May 02, 2018 2:30 am
There was also talk of v7
macsrwe
Long time Member
Long time Member
Wed May 02, 2018 3:12 am
Indeed, every router I have attempted to downgrade from 6.42.1 to 6.39.3 (what we were running fine two weeks ago) gets bricked, regardless of how carefully the downgrade is prepared, and whether it is done via the Dude or completely by hand. In most cases, it comes up without the wireless package installed (my guess is because one of them has an @ in its name for some mysterious reason, and the other one doesn't)... but an attempt to correct by adding the wireless package and rebooting has generally resulted in a router that flaps its ether port forever and has to be replaced, since it is no longer reachable by any method short of a netinstall (and that means a roof climb anyway, so we just replace).
The 6.42.1 caused many of my subscribers with older, single-pol units to go offline, and we had to replace all of them with dual-pol units because I couldn't downgrade. Now I am stuck in a mixed network with no recourse -- I cannot go backwards, and I cannot move forwards.
This upgrade has been a disaster for us. We are still not back to the subscriber speeds we had ten days ago. I am never moving off the stable release again, I don't care what security holes there are. I doubt that a hacker attack could have cost me more time and effort than this hacker patch already has.
macsrwe
Long time Member
Long time Member
Wed May 02, 2018 3:16 am
My experience indicates that this release does not get along well with single-pol devices -- it trashed a dozen units on our network and every one of them has been single pol. In a network with only about 16 single pol units, that's pretty definitive.
Xymox
Wed May 02, 2018 4:59 pm
I think a bunch of the same issues we are seeing in 42 are also present in the RC 43. In my test in my own SOHO arrangement at home my ccr1009 is clearly having DHCP issues with my ISP cable modem. It was showing renewing when there did not appear to be any reason to, This issue was previously covered in the this thread.
So ive moved by to 41.4, which for me is stable.
If your device has enough room to have 2 partitions, I recommend copying a known good config and saving the config to it. Activate that partition and then play with 42 or 43. That way its easy to swap back to your known stable state.
I am dissapointed that Mikrotik has not commented on this thread and let us all know what they are doing. They have not provided a plan. In all my time doing Mikrotik ive never see this. We really need a official response from Mikrotik and a plan of action.
bbs2web
Wed May 02, 2018 5:13 pm
We have had 3 instances today alone of routers rebooting themselves with the following message:
14:20:40 system,info router rebooted
14:20:40 system,error,critical router rebooted because some critical program crashed
Please would MikroTik consider backporting the Winbox security fix and releasing 6.41.5?
PS: We run two CCR1036-8G-2S+ as a highly available pair. The issue occurred on 'A' first which shifted traffic to 'B'. 'B' then had the same problem about 1:15 hours later, at which 'A' again became primary. Problem occurred a third time on 'A'. ie: This does not appear to be hardware related...
We have provided support@mikrotik.com with the autosupout.rif file from all 3 instances.
NB: Downgrading from 6.42.1 to 6.41.4 resulted in sfp-sfpplus1 dissapearing. Needed to do a '/sys reset-configuration no-defaults=yes' and reconfigure HA thereafter. We'll force a failover to the router now running 6.41.4 later tonight, if it doesn't happen earlier and downgrade the other router thereafter...
dougunder
Wed May 02, 2018 5:47 pm
When is the .2???????
disconnected, group key exchange timeout
Were a municipal ISP btw; I seeing this error on every hAP AC I've upgraded across spectrum of devices primarily cell phone from what I've been able to glean.
the update interval is 1h
jrpaz
Wed May 02, 2018 6:56 pm
So the DHCP issue will be addressed in the next RC as per support's replies.
Xymox
Wed May 02, 2018 8:32 pm
So the next RC is what will address the long list of issues discussed in this thread ? So no security patched 41.4 ? What issues will be addressed ? WIll Netwatch be put back ? When is the scheduled next RC going to be released ? Does 42.1 stay as the current stable ? Or does it get withdrawn ?
dasvos
Wed May 02, 2018 10:03 pm
Have you sent emails to support@mikrotik.com to report the issues you have picked up?
pe1chl
Wed May 02, 2018 10:59 pm
Netwatch is available as always. What has been removed is the capability of Netwatch to call scripts that perform actions that require write permission.
I use Netwatch with scripts that do only a /log action and it still works.
macsrwe
Long time Member
Long time Member
Wed May 02, 2018 11:07 pm
I've run into an issue with the newest releases where the scheduler will not invoke a script if given only its name, but will invoke it if given a full command line of /system script run... I'm still working this issue with support.
I've never used netwatch with a script (just with single command lines), so bear with me if I'm off-target, but is it possible you're running into the same bug? If you have specified only the name of the script, have you tried substituting the full "run" command line? If that doesn't work, have you tried invoking an intermediate script that doesn't require write, and having that script invoke the full command line to run the other script that does? (I think that currently does an end-run around the permission chain, as long as the use actually HAS that permission himself.)
Hope one of these suggestions works for you.
dougunder
Wed May 02, 2018 11:08 pm
Some new issues Ive discovered today.
We have seen many international hAP AC with disappearing 5g
We set all of them to to country="united states3" frequency-mode=regulatory-domain.
We thought they were not following the country so we have been testing a manual scan-list
Turns out there is a problem with 5775000
was running a scan list of 5180-5240,5745-5805 (IE UNII-1 and UNII-3)
Had a user call saying his Iphone and chromecast couldn't see the 5g
His wlan2 was at 5775, should be fine. remove 5745-5805 Boom he connects.
OK, test it to 5180-5240,5745-5765; Hap chooses 5765000 he connects fine.
Kind of odd but OK, so it set 5180-5240,5745-5765,5785. Hap chooses 5785000 and the devices connect
Confirmed 5775 has issues..
To be sure I down and up the interface a couple of times. Low and behold it ends up on 5775 anyway and nothing will connect.
go back to 5180-5240,5745-5765 and all is well.
I'm now quite sure this is the underlying issue, not the regulatory setting.
vytuz
Re: v6.42.1 [current]
Thu May 03, 2018 10:31 am
Maybe it detects radar? Check for 5.8G state. It is common issue in noisy environment. I had this problem earlier, autoselect channel works strange even in 2.4G. If there are many other wifi ap's, it selects same channel, because there is no load, but usualy load may rise and mikrotik would not change its channel until reboot.
vytuz
Thu May 03, 2018 2:46 pm
DHCP client updates acting as not supposed normaly. With 6.40 version, DHCP request is send after 50% lease time. With 6.42.1 version i.e. lease time is 48h, request is send after 42h.
Joni
SNMP
Thu May 03, 2018 4:08 pm
SNMP: Looks like running Dude (on CCR1009-7G-1C-1S+, v6.42.1) and enabling IPv6 (in addition to IPv4) on it makes Dude unable to SNMP poll IPv4 agents (any make and model), however snmpwalk (from Dude) on same agent works (presumably uses / defaults to IPv4, which is obviously also wrong). Once you disable IPv6 on Dude (or enable IPv6 on agents) it works again normally, not firewall rules, single subnet LAN only.
juliokato
Thu May 03, 2018 4:36 pm
Just curious, how this issue was introduced?
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
netmouse
Thu May 03, 2018 8:36 pm
RB2011UiAS-2HnD
I get the Internet by DHCP
After upgrade to 6.42.1 :
On 6.42.0 work fine...
dsnyder
Thu May 03, 2018 11:51 pm
You can add another unhappy customer to the Netwatch limitations. I was calling a script to failover to a secondary internet connection and disable/enable policies and rules for VPNs for the alternate IP address. This morning the primary internet went at an office and they went dead, no failover. So now I have to explain that this fancy contraption that I sold them really does work, just not this one time because they changed the way it works...
pe1chl
Fri May 04, 2018 12:40 am
There are better ways to do that than with Netwatch and scripts...
Xymox
Fri May 04, 2018 7:00 am
There may be better ways then Netwatch, but, Netwatch worked great for him and Mikrotik deprecated the functionality. I use it to send me alerts via email, is there a better way to do this ?
Im curious how all these really varied issues were introduced, DHCP is just one of them. But YEA this DHCP one is really curious. Why would the DHCP code be played with for this stable version release ?
vytuz
Fri May 04, 2018 10:21 am
RB2011UiAS-2HnD
if ISP (or router before this) dhcp lease is short (i guess it is 5minutes in Your case), with 6.42.1 version mikrotik asks for ip ~30seconds before lease (not ~2min). If there are many dhcp users, a lot broadcast, that may be dropped and i guess it just has no time to repeat for another request.
netmouse
Fri May 04, 2018 12:48 pm
RB2011UiAS-2HnD
I get real static IP address from provider DHCP
michnzee
Fri May 04, 2018 2:19 pm
After upgrade to RoS 6.42.1 crashed bonding (LACP, 802.3ad, 4 gigabit ports) with Synology DS1517+ (4 gigabit ports). All ports are online but without traffic, dhcp... restart not working :(
Solution - disable bonding interface, withdraw one port from bonding, disable bonding interface in bridge and make only one lan port active.
Any suggestion? do you use also LACP and bondig?
RB: CRS326-24G-2S+RM
LACP config:
::RouterLEGOBoard::
mkx
Fri May 04, 2018 2:51 pm
RB2011UiAS-2HnD
If you get "real static IP address" from your ISP, then I wonder why you're configuring DHCP client - you should be configuring static address on your RB and be done with it.
If you're getting "pseudo static" IP address (is in: getting always the same IP address via DHCP lease), then all the DHCP woes still apply to your RB, including short lease times and what not ... Your RB has no way of knowing that it will get exactly the same IP address in next lease.
BR,
Metod
pe1chl
Fri May 04, 2018 3:10 pm
The advantage of using DHCP is that it configures the address, netmask, gateway (default route) and DNS resolvers (and maybe even NTP servers) automatically and without error.
So it is best to use DHCP when possible. However, to work around the current issue I would temporarily configure those items manually and disable the DHCP client until MikroTik fixes it.
mkx
Fri May 04, 2018 3:23 pm
I understand the benefits of using DHCP in case of assigning "static" addresses. But there's a big gotcha: if customer changes router (different MAC address of its WAN port), this will break setup. Some ISPs just don't bother with static DHCP leases (my parents are victims of one of those) so one has to configure everything by hand.
As to my understanding of benefits: only recently I was bitten ... ISP decided to split their /16 customer network to two /17 parts ... and I'd have to change GW address. Which I didn't as I never received any announcement from them (and neither have my parents). Ended up with driving 50 km there and back one Sunday afternoon to fix the internet for my parents. In this case, DHCP would do miracles :wink:
BR,
Metod
pe1chl
Fri May 04, 2018 4:08 pm
This depends on the ISP configuration. It is also possible to assign the address to a "Circuit ID" instead of the MAC address. That is the wellknown DHCP option 82 that is always asked for in the feature request topics. But when the ISP doesn't use MikroTik, they can do it already.
Chupaka
Fri May 04, 2018 4:15 pm
Just to be honest, we were using DHCP Option 82 on RouterOS since 2008 (up to 2017, when we sold our ISP) - so if you're large enough to allow you to run RADIUS - you can use Option82 on MikroTik DHCP Server :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
mkx
Fri May 04, 2018 4:50 pm
In the case of my parents I doubt they do anything fancy beyond simplest dynamic DHCP leases. They are running FTTH network (over own fibres) and xDSL (local-loop sharing). The equipment on customer premisses is simple (managed?) ethernet switch with one optical interface (in case of my parents optical port is fixed, not SFP) and many electrical RJ45 ports. It doesn't matter which RJ45 port is used. If there's other equipment (VoIP gateway, IPTV set-top box) it is connected to the same ethernet switch. I guess that I could plug in another device (e.g. laptop) and would get dynamic DHCP address just fine. They must know about "Circuit ID" though to enforce bandwidth limitations (when doing speed tests, it is obvious they are doing traffic shaping as throughput in uplink quickly increases above cap, but after a few seconds it settles at subscribed rate).
When my parents upgraded from VDSL (simple ethernet tunneling, no PPPoE or anything) to FTTH, they had dynamic address ... which didn't change as they continued to use same router. Which indicates that their core network infrastructure is quite flat. They never played any games about changing IP addresses after DHCP lease expired (to prevent customers from seting-up own internet servers) ...
BR,
Metod
sindudas
Fri May 04, 2018 5:30 pm
This issue is breaking some scripts. On terminal:
/system leds set numbers=0 type=
align-down align-right ap-cap flash-access interface-... modem-technology on poe-out wireless-status
align-left align-up fan-fault gps-valid modem-signal off poe-fault wireless-signal-strength
It show "on" as an option, but it refuses to use it:
/system leds set numbers=0 type=on
input does not match any value of type
Chupaka
Fri May 04, 2018 5:52 pm
Not sure what you mean, but "numbers=0" is incorrect in scripts.
Xymox
Fri May 04, 2018 8:14 pm
I believe this si what i already reported..
/system leds set leds=user-led type=on 1 does not work in scripting or from command line on 42.x RC43.x /system leds set leds=user-led type=off 1 does work.. You can however turn on/off LEDs from Winbox.
cocktail
Sat May 05, 2018 2:48 am
I discovered that MikroTik hAP ac2's DHCP client on wlan1 in station mode cannot receive an IP address from a wireless router after upgrading to 6.42.1
DHCP client on wlan1 is stuck at `Status: searching...`
It takes a few minutes to renew DHCP client lease on ether1 which is the WAN interface.
steen
Sat May 05, 2018 9:52 am
Hello Folks!
I have problem backing up configuration on practically all devices using ros 6.42 or bigger, just discovered it today.
The message I got is: "backup,critical error creating backup file: could not read all configuration files"
There is no full filesystems and other visible errors.
tdw
Sat May 05, 2018 12:25 pm
I'm also seeing "backup,critical error creating backup file: could not read all configuration files" messages after upgrading on several devices.
2x RB750 v6.39.3 -> v6.42.1
2011UAS-2HnD v6.41.4 -> v6.42 (may also have produced the same message) -> v6.42.1
All appear to be operating fine, backup worked beforehand, /export verbose doesn't report any errors before or after.
steen
Sat May 05, 2018 9:08 pm
Hello Folks!
I face another issue.... this time our wireless 802.11bgn office landscape is crippled.
Wireless speed drops down to nothing and they got disconnected all the time.
The various mikrotik devices CPU rushes up to 100% when wifi traffic starts to flow, and wifi speed drops to nothing.
There is also another issue, sometimes when a user copies some big files over wifi network, all seem fine, but when another user does the same the wifi crashes for both of them.
I some other situations CPU does not go sky high, but the wifi network behaves in the same way.
We never saw this issue from before ever, it has been _rock solid_ for years, this issue come directly after last upgrade...
The devices are multiple RB411, RB433, it started to happen after upgrading to 6.42.1 (also observed at 6.42 but it did not kill the networks like now).
Yes, they are old devices, but we have plenty in operation and in stock.
We tried by disabling snmp, but it did not make any difference.
Some addition, we took out one device and re-imaged it with 6.42.1, using netinstall and then restored back the original configuration.
Unfortunately it did not make any difference at all, wifi is still unstable.
Last addition for today, by rolling back to 6.41.3 stabilized the WiFi network, there has clearly happened something with WiFi between 6.41.3 and 6.42.1.
Other observations, the device boots up faster, response on command line is much faster in 6.43.1 than 6.42.1 which boot up is slower and command line is sluggish and lagging.
Currently I try to generate support files for mikrotik to take a look on, the support is generated and will be delivered to Mikrotik.
Anyone who have seen Wifi get killed from RoS 6.42-6.42.1 ?
rzirzi
Sat May 05, 2018 9:42 pm
After update to 6.42.1 I have a BIG problem with x86 platform with additional Intel LAN i350 card. When I want to connect to MikroTik via that Intel i350 LAN - theMikroTik ROS is rebooting!! - EVERY TIME!! so - there is a problem with MikroTik ROS 6.42.x with Intel I350. There is no problem at ROS 6.41 - it works OK, but after update to 6.42.x - there is a problem! Please repair!
eworm
Sat May 05, 2018 10:00 pm
Hello Folks!
I saw the same on three devices. Contacted support, they told me to netinstall. I did and restored the backup. Everything was there except system note and setting for auto-upgrade (which changed from 'yes' to default 'no').
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
steen
Sat May 05, 2018 10:38 pm
Hello Folks!
Okidoki, we just reimaged one device using netinstall, and then the backup completed without the error message.
tdw
Sun May 06, 2018 1:27 am
Hello Folks!
That's fine if the device is local, not much use if the tik is several hours drive away. As three out of three upgrades are exhibiting this behaviour I'm reluctant to upgrade ~25 others scattered around the country if backups can no longer be made successfully without visits to reinstall.
Xymox
Sun May 06, 2018 6:49 am
And the incredibly wide ranging and completely unrelated issues just keep coming. Backup issues, weird wifi issues and a different sort of DHCP issue.. I can confirm the backup issue and the wifi issue. I updated a mAP and im not sure of everything that failed, but I know wifi was really weird because it was not connecting with the same signal strenght by 75%, I could not get a IP from DHCP and it was not obtaining a IP on its wan side. I fact reset it and that got me connected to it, then I downgraded and restored the backup from just before the upgrade and it came right back to fully normal.
Apollo 13 mission: "Lets look at this from a standpoint of status.. What do we have on the spacecraft thats good ?"
https://www.youtube.com/watch?v=Z0h2Wk6-C_I
This problems people are seeing are serious, 42.x needs to be deprecated, 43 looks like mostly the same issues. As I keep saying 41.4 needs a security patch then make that the stable. Work on 43 and get it all fixes with this long list of issues and then release it in a month or 2 once its truly tested stable.
steen
Sun May 06, 2018 9:23 am
It took us whole Saturday evening finding out that a rollback was only option to stabilize the WiFi network and the platform.
I will also issue a direct warning, we could not downgrade the devices without netinstall, you will need to netinstall them to get back on track again.
In the serial console we would see the devices get stuck at boot, directly after generating some ssh-host-keys, with a message saying "to many nested links".
A good thing was at least backups worked, 6.42.1 claimed configuration files could not be read.
We have however a some devices not showing any signs of problems with this versions, but they all claim backup, "critical error creating backup fule: could not read all configuration files"
And yes, I finally managed to get some support file and made a report to Mikrotik who hopefully solves this issues quickly so we can get back on track again.
Modestas
Sun May 06, 2018 3:23 pm
RB2011UiAS-2HnD
Hi
I don't share this view.
Please note that DHCP renewal use unicast messages (see example in https://www.cloudshark.org/captures/0009d5398f37 and appendix B at https://www.netmanias.com/en/?m=view&id ... cs&no=5998). While unicast communication with DHCP server is working properly binding will not expire and there will be no transition to rebinding phase with excessive broadcasts.
It's also DHCP server (let's say, network designer) decision to offer and approve certain lease time. Clients have not so much other options than respecting server policy.
I don't think single unicast request/ack transaction per 1 min can be considered as serious load in 2018.
However, Mikrotik releases 6.42.* seem to have something broken in DHCP client or maybe fastpath code. This affects DHCP renewal messages delivery to DHCP server and consequent transition to rebinding.
steen
Sun May 06, 2018 4:47 pm
!Correction!:
I have to correct myself, the devises not showing any signs of problems had the local WiFi disabled and acting as router for the wired network only.
So with that in mind, _all_ devices upgraded to 6.42.1 (starting with 6.42), has problems with WiFi. All of them had to be downgraded with netinstall, they all get stuck in the boot process.
It now goes for, rb411, rb433 and rb435., around 10 devices in total before we discovered it due to its creepiness nature. All actually look fine after an upgrade, problem comes when someone starts to use the WiFi, then the whole device is affected, CPU peaks in bursts making console sluggish ultimately the device ends up with 100% cpu all the time and hence becomes unresponsive.
sovaby
Sun May 06, 2018 7:45 pm
Hi ! in the wiki documentation for pptp
default-route-distance (byte [0..255]; Default: 1)	sets distance value applied to auto created default route, if add-default-route is also selected
Range of distance from 0 to
And so it was before this version .
And after the upgrade to v6.42.1 , I get an error !
Dynamic routing stops working
And my ISP requires that you get the settings from DHCP. Not having received auto settings, the connection will not get the provider's authorization.
What to do ?
It's good that I had a stoped duplicate connection.
If you do not touch it, it will work with the old value default-route-distance = 0.
If in the settings of this connection, something to change you will not be able to save it!
sindy
Sun May 06, 2018 8:19 pm
I'd say change the default-route-distance parameter in your /ip dhcp-client settings to 2, and the pptp dynamic route will win with default-route-distance=1. It doesn't need to be exactly 0 for pptp and 1 for dhcp, it can be 5 and 7 and you're still good. Distance 0 is reserved for directly connected networks so the change was towards a more systematic behaviour.
sovaby
Sun May 06, 2018 8:27 pm
I was played with manual routing
distance 2 (3 ...) for ethernet and for the pptp client distance 1.
This does not work! The provider says, until you get the settings automatically from DHCP, you do not get the authorization for passing packets.
And from the provider the distance 0 is flying for ethernet!
pptp sets distance 1 for default route and does not work because the packets leave through the ethernet default route!
sindy
Sun May 06, 2018 9:01 pm
You have clarified enough that you have to use the DHCP client to get your WAN address, otherwise the provider won't enable your connection, that was crystal clear to me already before.
What I was trying to say was that the same setting which you were using on /interface pptp also exists on /ip dhcp-client and other interfaces/protocols with dynamic configuration. So instead of setting lower-than-default distance at pptp, you can set higher-than-default distance at dhcp-client.
Of course, distance 0 for the local subnet between you and the provider will always be there, but the default route is for 0.0.0.0/0 and its distance will be set according to the default-route-distance parameter. And you don't need to access the subnet between you and the ISP via the PPTP tunnel, do you?
sovaby
Sun May 06, 2018 9:20 pm
I'll try it! Thanks, I found =)
It works, thanks!
eworm
Sun May 06, 2018 10:17 pm
Hello Folks!
Whoever suffers this should consider to contact support as well. Perhaps they become aware that this is a real issue and fix the cause. If anybody wants to reference me... Ticket#2018041822006577
BTW, I saw this happen first time on 6.42rc52.
macsrwe
Long time Member
Long time Member
Sun May 06, 2018 10:31 pm
I’m pretty confident that MikroTik can correct this issue without forcing everyone in the world to netinstall their devices. This exact behavior and message was occurring on about a dozen CPEs on our network for a year after the SXT was introduced, which was around the time of ROS 5.25. I reported this in June 2013, ticket number 2013061466000351. Upon the advice of MT support, I netinstalled a handful of them, and the problem went away on those, though it reoccurred on some of them within weeks. After about a year, that message had totally disappeared from our network, and not because of anything we did, so it must’ve been fixed in ROS. It’s time to do that again.
S4bulba
Mon May 07, 2018 12:51 am
Hi ,
I am a user of a 951Ui-2nD and i want to give some feedback regarding this update.
I ve bought the router few months ago as new and since i ve updated the default OS everytime a new version showed up , never paid attention to the firmware upgrade though ,untill this OS update - 6.42.1 .
I am using the device as a pppoe client to the ISP.
Default firmware was 3.36.
Prior to this update i was using 6.42.with firmware 3.36 (the factory one).With 6.42 i was having some rare timeouts (connnection was dropping) in aquiring the dynamic pppoe adress from the ISP, so i updated to 6.42.1 to see if this issue goes away and increase device security as well.
For one day the device run this update with firmware 3.36 and it looked ok , so i ve decided to upgrade the firmware as well from the winbox interface ,now it s 6.42.1 in the routerboard page .
After this the ISP drops would be 2-3 times at every 12 hours , so i wanted to roll back in some way and decided to roll back to the previous version , so i ve clicked the Downgrade button from Package list page ,nothing hapened , so again i ve decided to test the bugfix build from the package channel and i ve downgraded to 6.40.8.
Device rebooted , looked like working and i could log in via winbox ,but the router would push errors in log window ( was creating some Samba shares ?!? as per log for example) and would reboot after some minutes after each new boot , a delayed continuous loop .
As such i ve decided to go back to 6.42.1 right after a fresh reboot and i was lucky enough to do it :).Router did some automatic installation checking routine afterwards , corrected some errors and everythoing was and is now ok ,7 days with no ISP connection drop.
So maybe there is a realtion between the firmware used and OS used and /or maybe the firmware should be updated prior to the OS.
It s strange that the downgrade button did nothing. :)
No special issues for me with this build as a casual user
LE:
I would have a suggestion also
Maybe by default the firewall rule ""defconf: drop all from WAN not DSTNATed"" (for the INPUT chain) which by default is in the lower side of the page of the firewall, should be placed by default in the upper side of the ruleset ,after the dummy rule so the BAD traffic is dropped properly .Where it was put by default would not pick up any packets.
Over & Out !
dynek
Mon May 07, 2018 9:15 am
Regarding message poping up when generating a backup file, same problem, same answer (netinstall) but I don't feel like it honestly...
viewtopic.php?f=2&t=73610&p=658544#p658544
steen
Mon May 07, 2018 9:47 am
We stopped rolling out 6.42.1 and the other with same problem 6.42, and rolled back by using netinstall.
netinstall is doable for few devices or in your private home network where you can reach all devices by simply walking around.
but in a bigger scale it is not an option, except in a disaster, in our case it is equivalent with start replacing customer devices including ladders, elevators and roof walks.
As anyone could understand it would be a very costly operation.
cocktail
Mon May 07, 2018 9:53 am
My issue with 6.42.1 actually turned out to be an issue with another router from another manufacturer.
ricake24
Tue May 08, 2018 7:51 am
im trying 2 upgrad on that lol
Jotne
Tue May 08, 2018 8:26 am
No one else has this problem?
DHCP does not log to external server any more: viewtopic.php?f=2&t=134092&sid=345291ea ... d0515cef3e
Should I post a support ticket?
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
jarda
Tue May 08, 2018 8:46 am
You always should.
dynek
Tue May 08, 2018 9:15 am
Answered your thread - It did work for me.
hapi
Tue May 08, 2018 11:32 am
drop client and never connecting back.
after reboot:
Only NV2 is function. This is not the only case.
nkm
Wed May 09, 2018 9:46 am
i had problem.
my throughput was low
so , i checked my config and i saw the fast forward in bridge interface goes "No" by default,
in the older versions and wiki site ( https://wiki.mikrotik.com/wiki/Manual:I ... Properties ), it's "Yes" by default.
Did change it in the new version?
kaspi4
Wed May 09, 2018 3:56 pm
Got similar issue on my 3011, disabling hardware offload(new feature from your 6.40.1 version) on all bridge ports helped me.
adik777
Wed May 09, 2018 5:31 pm
Hi!
Problem with LEDs type on v6.42.1 with CCR1009,CCR1016,RB2011,RB3011:
LED "user-led"=off
[vadym@PPC-5_CCR1009] /system leds> :put [/system leds get [find where leds="user-led"] type]
off
LED "user-led"=on]
(unknown)
set LED "user-led"=on
[vadym@PPC-5_CCR1009] /system leds> /system leds set [find where leds="user-led"] type=on
Chezgendron
Wed May 09, 2018 5:43 pm
I just updated my routerboard 2011UiAS-2HnD to the latest firmware 6.42.1 version. Before that it ran on factory firmware 3.22 and used the hotspotserver without any problem. After updating I get the message "Hotspot Setup - setup failed to setup dhcp server: failed to add DHCP server: can not run on slave interface (6) (8)" if I want to finish the hotspot setup in the webfig. Can anybody tell me why I get this message now and never before with the old firmware?
Thanks,
Alex
sovereignt
Thu May 10, 2018 11:45 am
I use eoip to build L2 tunnel between two switches. In earlier than 6.41 version the bridge can receive LLDP, LACP, RSTP and transport to remote switch via eoip tunnel, it's working fine. But after upgrade ros to 6.41, all of the above packet is block. In the 6.42.1 version changelogs, I find it fixed LLDP packet receiving bug and it's working fine for LLDP when I upgrade ros. But LACP and RSTP is also block. I have already set /interface bridge protocol-mode=none.
Anyone can help?
kodzikirus
Thu May 10, 2018 3:12 pm
# may/10/2018 13:40:52 by RouterOS 6.42.1
# software id = VUPQ-V2AI
13:31:55 system,info router rebooted
13:31:56 system,error,critical router rebooted because some critical program crashed
3 causes after upgrade to 6.42.1 ( CCR1036-8G-2S+ with 60-70 OVPN tunnels)
26-th of April, 4-th of May, 10-th of May
P.S.: Other CCR1036-8G-S+ taht is upgraded to 6.42.1 too, has no this problems (uptime and works 16 days), but he has'nt OVPN's - he is reserv with a 2 ISP's and main site works from him.
Have any ideas?
Son1c
Thu May 10, 2018 7:22 pm
Returning to the increase of the parameter "Sector write since reboot" on 6.42.1, i have about 3k writes instead of about 700-800 on 6.43.rc3 after 12 hours uptime. Is it a bug or a feature?
RB951G-2HnD
lomayani
Thu May 10, 2018 7:46 pm
I have upgraded my core routers CCR1036-12G-4S. Am running mpls,ospf and bgp within these routers. One ccr keeps rebooting after like 15-20 minutes.
the rest are ok. the router which keep rebooting is acting head of mpls traffic engineering tunnel and is pushing traffic via this tunnel. On tail side am not pushing traffic via the tunnel. Upload from client is following the normal path chosen by ospf. these routers are not rebooting
I remember we used to have similar problem in this router before mikrotik fixed mpls relating issue last year
Other routers are working fine. Downgraded this router to 41.4 and it is stable now
I confirm this issue is fixed in 6.43rc11. I tested for couple of hours and am not seeing crashes
JimmyNyholm
Fri May 11, 2018 9:13 am
still waiting for the bugfix only update
This vulnerability isn't much of a problem. The problem is administrators leaving their firewall services (API, Winbox, SSH, etc.) exposed to untrusted networks. It's better to apply firewall filters to the input chain that will protect against this and other future attacks.
On a pure Router it is better to not enable the Firewall AT ALL and have Fastpath enabled still. IPRestrict IPSERVICES in their setting (Disable services that you will not use) and IPRESTRICT USERS login from in their setting. We don't need any firewall for that basic security.
WirtelPL
Fri May 11, 2018 12:07 pm
RB951G-2HnD
I reported the problem to Mikrotik ([Ticket#2018042722002867]). In response I got:
"...Sector write value which shows NAND lifetime, but more precisely you can read in these articles: https://wiki.mikrotik.com/wiki/Manual:R ... bad_blocks, https://wiki.mikrotik.com/wiki/Manual:S ... Properties ..."
My actually values are:
RB951G-2HnD for home production
RBmAP2nD | RB952Ui-5ac2nD-TC for home lab
leon84
Fri May 11, 2018 12:45 pm
Hi to all,
I updated RouterBoard 450 from 5.26 to 6.42.1 and now the routerboard doesn't boot. It reboot continously !
Can you help me?
maxfava
Fri May 11, 2018 1:23 pm
With 6.42.1 we noted the following issues:
a) Marking assured and related packet as fast track, after a while some SIP client is not able to receive the calls even if seems registered. The connection tracking table has the entry of the UDP packet, and it receive from the server SIP the call but seems that router NAT does not forward to internal host. I have removed the fast track rule (action fast track for packets that are assured and related in filter rule) and it solves the issue.
b) But after the fast track firewall rule disabled the UDP connections with dst-port 5060 are not marked as sip connection-type but as general UDP stream, applying on connection tracking table 3 minutes timeout instead of 60 minutes. I have not rebooted yet, since is a production router, I have planned reboot this night, hope can solve.
TestCRS
Fri May 11, 2018 4:47 pm
Please answer: switch crs317 dont forwards the qinq packets at wire-speed, why ?
Chupaka
Fri May 11, 2018 4:59 pm
How do you check it? Was it working at wire-speed in previous versions?
rzirzi
Fri May 11, 2018 7:52 pm
I think ROS 6.42.1 i VERY buggy version :( Many,many things not working or working randomly. For instance - next NOT working: Intel i350 miniPCIe cards at x86, working "randomly" Queues. Today I have had NOT working Simple Queues at one x86 machine. I was looking for a problem long time, and..... after disable and enable all Queues - they starded working again. VERY, very strange problems...with ROS 6.42.1
TestCRS
Fri May 11, 2018 8:06 pm
You ask because you have such switch and everything works ? our switch crs317 never worked with qinq.
I will be glad to hear a confirmation that someone have working qinq on switch crs317.
But I think it is not.
pe1chl
Fri May 11, 2018 8:50 pm
Then please don't discuss it in this topic!!! This topic is only for issues specific for 6.42.1
Open a new topic in another section and fully explain you problem and configuration.
TestCRS
Sat May 12, 2018 6:42 pm
viewtopic.php?f=1&t=134316#p661270
Basdno
Sun May 13, 2018 3:06 pm
Just updated my RB2011UiAS-RM to 6.42.1
After updating and rebooting I go back and check for updates, it shows 6.42 instead of 6.42.1, this does not happen on any of my other routers.
I have same problem on a RB2011UAS-2HnD!
Whatever kind of upgrade of ROS if Current 6.42.1 or RC version, the RB just seems to ignore that there is an update package downloaded in files and reboots to 6.42.
Has any1 else had this problem, and/or solved this?
Its kinda frustrating not getting it updated now since there actually is a voulnarability!
maxfava
Sun May 13, 2018 3:43 pm
add more info
after playing with fast track and non fast track i confine i’m seeing the issue of packet marked sip and non sip wrongly.
After a reboot all work fine.
the issue we are seeing is the vpls interface associated to pppoe server are not listed. but i noted is going to be fixed since rc showing fixed dynamic interfaces
macsrwe
Long time Member
Long time Member
Mon May 14, 2018 12:11 am
I am also experiencing a flood of supouts from previously content CPEs (SXT, 911) since installing 6.42.1 on April 24. Two examples:
macsrwe
Long time Member
Long time Member
Mon May 14, 2018 12:19 am
Your report is believable, but the issue is not new to 6.42.1. For ten years I have been "solving" inexplicable queueing problems by exporting queues (both simple and tree), wiping out all queues, then reimporting. Someday I'm sure they will find this problem.
RN3QTB
Mon May 14, 2018 11:41 am
Hello!
Help me please! After updating SXT 5nDr2 from version 6.40.8 to version 6.42.1, the router dies! I have to restore the firmware via netinstall! After restoring the firmware to the initial version 5.26, the update on the Internet is up to 6.40.8, the router reboots and offers to update to 6.42.1 current if you click "update" the router downloads the update, reboots and does not turn on again! Tried it 2 times. What to do?
MartijnVdS
Mon May 14, 2018 1:23 pm
Hello!
Have you tried netinstalling 6.42.1?
akavousa
Mon May 14, 2018 5:14 pm
All good after upgrade on RB435G.
Keep checking for hickups.
Xymox
Mon May 14, 2018 9:12 pm
Ive been testing 43RC11.. It addressed a huge number of issues posted in this thread. Good job Mikrotik.
It does not address the short sighted feature neutering of Netwatch tho. I still cannot send a alert or change a LED state based on a ping of a target. Because I use Netwatch for many things, I still cant use firmware past 41.5 because of this.
While im really impressed all the other bugs introduced in 42 have been so quickly addressed, I am upset Netwatch has not been addressed.
marcin21
Mon May 14, 2018 11:16 pm
wireleswire link ~150m, after upgrade rate/signal loss.
are there any options I should tweak after upg ?
mt99
Tue May 15, 2018 2:07 am
Mikrotik at the very least needs to explain what is and what isn't supported after 6.42 in their Netwatch documentation. It's not that much to ask. I got the sense that calling a script which requires certain permissions doesn't work anymore. But if you put the entire script in the Netwatch code block instead of simply calling the script, does that work? I haven't upgraded from 6.41.4 so haven't tested this. Apologies if you've already given this a try.
strods
Thu May 17, 2018 3:35 pm
Version 6.42.2 has been released in current channel:
viewtopic.php?f=21&t=134522
strods
Thu May 31, 2018 9:49 am
Everyone who complained about the Netwatch issue - Please see this topic viewtopic.php?f=2&t=134538
Users browsing this forum: Google [Bot] and 14 guests
