lopar
CCR1009-7G-1C-1S+ Micro SD / Memory card
Mon Apr 23, 2018 7:32 pm
Greetings. Which cards for certs/Dude are supported? I tried 64GB Class10 cards from popular vendors, such as Sandisk, Samsung, Apacer and nothing worked. Is there any 100% supported card, or the full situation is total roulette?
pe1chl
Re: CCR1009-7G-1C-1S+ Micro SD / Memory card
Mon Apr 23, 2018 7:56 pm
What do you mean with "tried" and "not worked"?
Just inserted a card and expected magic move of Dude data to the card?
lopar
Mon Apr 23, 2018 9:18 pm
simple:
>disk print
# NAME LABEL TYPE DISK FREE SIZE
yes, i did full restart with powering off.
pe1chl
Mon Apr 23, 2018 9:39 pm
Did you partition and format it?
lopar
Thu May 03, 2018 4:02 pm
Yes. Tried ext3 and fat32 (as it was written on wiki). Tried without partitioning. Tried NTFS. Can't see it.
herdins
Mon Mar 18, 2019 7:59 pm
I have a device CCR1009-7G-1C-1S+ but the same problem is that the micro sd slot does not work, I have turned off the device and then entered the micro sd and then restarted the device but the micro sd remains unreadable. Already contacted Mikrotik Support but until now have not received a solution.
ist
Fri Apr 05, 2019 7:47 pm
I have three CCR1009-7G-1C-1S +, and none of them works with microSD cards.
It seems that this is not a card reader but a card holder. :?
The same "convenient" feature was in D-Link DFL-260 and 860 (with only USB ports)... you could store USB flash drives in them :lol:
pe1chl
Mon Apr 08, 2019 3:04 pm
You can use a USB drive on the CCR but it requires to use the (included) adapter cable... a little inconvenient since it dangles off the front.
In the RB1100 AHx4 it is much easier to add storage.
inseek
Sun May 17, 2020 9:23 pm
Any luck finding and using microSD card for Dude DB on CCR1009-7G-1C-1S+, anyone? What's the maximum capacity supported?
ist
Mon May 18, 2020 6:38 pm
You can put card of any capacity and any FS type into the CCR1009-7G-1C-1S+ . But you cant use them by design.
mozerd
Forum Veteran
Forum Veteran
Mon May 18, 2020 7:23 pm
I use SanDisk 32GB SD cards and 8GB Kingstone DataTraveler USB sticks and works nicely in many CCR1009xxxx
I have not tried large ones because I have no need for larger ones BUT I see no reason they would not work.
brg3466
Fri Aug 07, 2020 3:54 am
I tried ScanDisk 16G microSD card and it doesn't work. The CCR1009 cannot discover it.
magistryoda
Fri Aug 07, 2020 5:41 am
my ccr1009 always loses sdcard after firmware upgrade
but i discovered magic rule of 2(3) reboots
1. upgrade firmware, reboot. card lost
2. extact card, reboot
3. insert card and wooala!
its not directly connected to FW upgrade. any restart makes sdcard eliminated from disk menu. luckily need for reboot happens quite rare
