ebugakov
CHR v6.42 with ESXI
Mon Apr 23, 2018 8:14 pm
Hi!
According to release notes, starting v.6.42 CHR supports open-vm-tools:
*) chr - added "open-vm-tools" on VMware installations;
Well, after the software upgrade and restart, indeed, it looks like vm-tools feature-set is supported, but also now I've got notification from ESXI with the text below:
"The configured guest OS (Other (64-bit)) for this virtual machine does not match the guest that is currently running (Other 3.x or later Linux (64-bit)). You should specify the correct guest OS to allow for guest-specific optimizations"
and of course, VMWare offers me to change VM guest OS software version and type to resolve the issue.
This CHR installed a year ago in line with the documentation on wiki (https://wiki.mikrotik.com/wiki/Manual:C ... stallation) where recommended OS type was "Other 64-bits".
So, what should I do next to resolve the issue and remove annoying notification from ESXI web interface?
Thanks in advance!
storp
Re: CHR v6.42 with ESXI
Mon May 28, 2018 7:47 am
I changed the Guest OS to "Other 3.x or later Linux (64-bit)" in ESXI and the message dissapeared.
Users browsing this forum: No registered users and 0 guests
