starbuck
Correct steps to downgrade RouterOS?
Tue Apr 24, 2018 3:46 pm
The wikipage documentation on downgrade is incomplete or outdated. The few forum posts here do not lay out the exact steps to perform a downgrade. I think the procedure is as follows. Can anyone confirm it before I try it? I'm trying to go from 6.42.1 back to 6.41.3 on a RBSXT5nDr2 because after upgrading today I'm having some issues (Winbox access from the internal LAN side) and need to determine if it is the firmware.
•Upload routeros-mipsbe-6.41.3.npk
•Upload all the .npk packages from the all_packages-mipsbe-6.41.3.zip file (is this required???)
•Use the system/packages downgrade command from CLI or from Winbox ???
Or do I simply use system/packages downgrade and it will roll back to the last version?
Also, if I can't connect via WinBox, can I FTP in and just place the files in the root level?
leoservices
Trainer
Trainer
Re: Correct steps to downgrade RouterOS?  [SOLVED]
Wed Apr 25, 2018 6:53 am
Step by step
Back up your settings.
 system backup save dont-encrypt=no
export file=BkpScript
In Winbox - Files
Copy the 2 backup files to your computer.
Save at root level
/system package downgrade;
/system reboot;
Reboot, yes? [y/N]:
See if this video helps you
https://www.youtube.com/watch?v=N3YBZipH4-U
I try to help !
Leonardo Vieira
https://youtube.com/contractti
Like Facebook.com/contractti
Users browsing this forum: Google [Bot], sdegler and 150 guests
