IS0FFD
HELP Firewall Rules
Sat Apr 28, 2018 11:32 am
Hi all!
I've a CRS125 with this firewall rules
17    ;;; Port Scanner Detect
      chain=input action=add-src-to-address-list protocol=tcp psd=21,3s,3,1 address-list=Port_Scanner address-list-timeout=1w
18    ;;; Drop to port scan list
      chain=input action=drop src-address-list=Port_Scanner
In my lan i've a RB750gr3 with Dude, but is continually inserted in the "Port_Scanner" list
How can I solve?
Anumrak
Re: HELP Firewall Rules
Sat Apr 28, 2018 12:37 pm
Extract Hex IP from list or deactivate the rule?
IS0FFD
Sat Apr 28, 2018 12:46 pm
I would like it if possible to make a white list with the addresses known to be excluded from the rule.
sorry but I'm trying to learn!
Anumrak
Sat Apr 28, 2018 1:08 pm
Try something like this:
chain=input action=accept protocol=tcp psd=21,3s,3,1 src-address="IP of HEx"
or with a white list:
chain=input action=drop src-address-list=!White_List
chain=input action=accept protocol=tcp psd=21,3s,3,1 address-list=White_List
"=!" - mean not what you point on.
IS0FFD
Sat Apr 28, 2018 1:43 pm
not work...
Anumrak
Sat Apr 28, 2018 2:21 pm
not work...
Sorry, but you assigned in src-address IP address of your Hex router or just words I wrote?
Anumrak
Sat Apr 28, 2018 2:32 pm
And I'm sorry for incorrect sequence:
chain=input action=accept protocol=tcp psd=21,3s,3,1 src-address="IP of your Hex"
msatter
Sat Apr 28, 2018 4:34 pm
Not....I mean you have to use not (!) so you need only one line.
add chain= input action=add-src-to-address-list protocol=tcp psd=21,3s,3,1 src-address=!"IP of your Hex" address-list=Port_Scanner address-list-timeout=1w
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.47 / Winbox 3.24 / MikroTik APP 1.3.14
ingdaka
Sat Apr 28, 2018 6:06 pm
I will suggest you an other thing, remove firewall roles from switch, because switches get more CPU usage form firewall roles!
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE | MTCWE | RIPE NCC Certified Professional
anav
Sat Apr 28, 2018 6:23 pm
Hi there, I do something very similar.........
(I have two WAN IPs, otherwise I would have probably used in-interface WAN)
IP Filter
{Port Scans TCP make list}
   chain=input action=add-src-to-address-list protocol=tcp dst ports=23, 53,123,445,8291 in-interface list-WAN address-list=port_scans_tcp-timeout=2d
{Port Scans UDP make list}
   chain=input action=add-src-to-address-list protocol=tcp dst ports=23, 53,123,445,8291 in-interface list-WAN address-list=port_scans_udp-timeout=2d
Then I use RAW fule (not filters) and PRE-ROUTING to kill the list entries before they enter the router at all (no tracking etc......)
IP RAW
{Drop Scans TCP}
   chain=prerouting action=drop src-address-list=port_scans_tcp
{Drop Scans UDP}
   chain=prerouting action=drop src-address-list=port_scans_udp
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Users browsing this forum: No registered users and 37 guests
