MUM Europe 2020
soomanyquestions
802.11ac required ratarate
Sat Apr 28, 2018 6:13 pm
I have a hAP ac lite and I would like to set the 5Ghz wifi so that the required data rate is atleast VHT MCS 2.
In the wireless interface "Data Rates" tab there is only an option of MCS 0-9, MCS 0-8 and MCS 0-7 for the VHT Basic MCS. So is there any way to do what I want?
Thanks.
mbfound
Re: 802.11ac required ratarate
Sat Apr 28, 2018 6:36 pm
You mean like this?
hapi
Sat Apr 28, 2018 10:32 pm
This is for N, not for AC.
R1CH
Forum Veteran
Forum Veteran
Wed May 02, 2018 4:32 pm
You cannot configure 802.11ac rates in RouterOS (yet?)
normis
Wed May 02, 2018 4:49 pm
You are in the wrong menu. Check Data Rates menu, there "VHT" section is for 802.11ac
wfuzatto
Sun May 06, 2018 5:28 am
@Normis, I need a solution to this too. Even when you are in the VHT menu there is no option to select a minimal or maximum data rates, you can select only 0-7~0-9. Right?
I was wondering that I could stablish a connection like 5-7 VHT or for example static 585Mbps on 80Mhz...
Is it possible?
hapi
Sun May 06, 2018 12:35 pm
It would be possible to set the minimum and maximum HT / VHT and not have it split in several menus.
And it took me a while to figure out that two lines in basic VHT are 2 streams. A totally sloppy display.
wfuzatto
Wed May 09, 2018 8:02 am
Any ideas?
soomanyquestions
Wed May 09, 2018 1:32 pm
Yes but in the "VHT" menu there is only the option of MCS 0-7 and MCS 0-9.
I agree with this. Its pretty annoying to set the rates on multiple places.
Petri
Wed May 09, 2018 2:20 pm
Those are the only options in IEEE 802.11ac. There is no way to enable or disable rates individually.
wfuzatto
Wed May 30, 2018 6:57 am
Could it be a improvement for ROS 7?
normis
Wed May 30, 2018 11:26 am
This is hardware limitation for ac.
Users browsing this forum: No registered users and 39 guests
