tomaskir
Trainer
Trainer
[Guide] Easy network-wide RouterOS upgrades
Mon Apr 30, 2018 4:00 pm
Hi everyone,
So with the latest RouterOS exploits, upgrading to a up-to-date RouterOS version is more important than ever.
I wrote an article/how-to on an easy way to update RouterOS across your entire network.
This article uses RouterOS Package Source feature to act as a local upgrade server.
Unimus is used to mass-configure the network to use the local package source and pull upgrades.
Full guide here:
https://unimus.net/blog/network-wide-mi ... grade.html
Good luck!
Hammy
Forum Veteran
Forum Veteran
Re: [Guide] Easy network-wide RouterOS upgrades
Mon Apr 30, 2018 8:45 pm
Tomas, making things easy since 1843.
emuell
Tue Mar 01, 2022 12:54 pm
Hi everyone,
Full guide here:
Good luck!
Can you confirm that this should still work under ROS 7.1x. ?
I did the steps manually and configure package-upgrade-source, do refresh and so on. i also see the connection to the host router which holds the packages will be established, but there are no update files will be listed on the client device.
https://mivilisnet.wordpress.com/2020/0 ... ment-11931
tomaskir
Trainer
Trainer
Wed Mar 09, 2022 2:50 am
Hi. Sorry, I have not tested this with v7. I will spin up a lab and validate. Will post an update here as soon as I test this.
SecCon
Tue May 03, 2022 12:45 pm
Sorry to barge in, but when you setup Unimus to handle upgrades - and other things - you give it the credentials to the Mikrotik devices. I am trying to figure out if Write or Full permissions are required for the upgrades and to be setup in Unimus?
tomaskir
Trainer
Trainer
Wed May 04, 2022 3:10 am
Write should be enough unless you also want to manage Users (or change passwords) with Unimus Config Push.
The main difference between the two is access to "policy", which gives user management access.
You can check this in "/user group", it will show you which policy group has access to what :)
Docs for which individual policies do are here: https://help.mikrotik.com/docs/display/ ... UserGroups
SecCon
Wed May 04, 2022 8:55 am
Thanks, I see you are the guy behind Unimus as well. Seems to be a great application.
I did go to the wiki to check what user permissions entailed, but there is no page, not on the old nor on the new wiki, that explains anything about the differences between the user permissions, except the obvious deductions.
Write it is then.
frankcale
Sun Jan 15, 2023 11:55 pm
Hi, i have built a software that can mass upgrade ROS and many other functions. Connection is made via API
Users browsing this forum: mkx, Seko777, uxertxo and 76 guests
