IS0FFD
LDF 5 ac without dish... is possible?
Wed May 02, 2018 8:16 am
Hello everyone,
I would need to install a pto-pto link of about 200mt, my idea is to use two LDF 5 ac without the dish.
I preferred LDFs because they are small and for external use.
Ideas? tips? your experiences?
Thanks in advance!
normis
Re: LDF 5 ac without dish... is possible?
Wed May 02, 2018 8:21 am
At 200 meters it should work. But it will be difficult to mount it.
IS0FFD
Wed May 02, 2018 8:43 am
Thanks normis!
for the bracket I would have to try, it should be the last of the problems!! :D
mistry7
Wed May 02, 2018 9:41 am
You can get 16 dBi Antenna instead of 9 dBi in LDF for same price.
https://mikrotik.com/product/sxtsq_5_ac
chechito
Wed May 02, 2018 4:51 pm
i think is better idea to use less expensive LDF 5 (without ac)
maybe you cant get AC datarates at that distance and or using 80mhz channels
but i think is a very good idea to get a short and discreet ptp using LDF without dish
for mounting you will have to make some kind of bracket but not very difficult
I was thinking about that ptp scenario and another scenario maybe adding a L4 license you can get a 5ghz a for small area sectorial 5ghz wifi, the same for LDF 2 (when it arrives)
LDF have 9dbi gain without dish
How much gain will the LDF 2 without dish will have??
mistry7
Sat May 05, 2018 6:38 am
For PTP it US always better to use higher gain Antenna to get max. Clean signal.
LDF has 9 dBi and SXT 16dBi, you are loosing 7 dB
That is 4 times higher signal level! For cheaper price
Users browsing this forum: No registered users and 28 guests
