nichky
PWR-Line AP
Thu May 03, 2018 9:38 am
I just want to get two of them i was surprised when the MikroTik staff on MUM in USA said that can communities each other via ELECTRICITY.
Can i get more information how esaclu it works or if you have web link where can i get more information abouth that will be appreciate
normis
Re: PWR-Line AP
Thu May 03, 2018 9:39 am
The device is not yet for sale. More information will be coming in a few months.
mkx
Re: PWR-Line AP
Thu May 03, 2018 4:06 pm
I can only guess, but my guess is that it will be using power-line communication standard for one of it's interfaces. If done correctly, it will be compatible to other similar products to mix in same network.
Trisc
Re: PWR-Line AP
Fri May 04, 2018 11:45 am
Normis, will it have interchangeable plugs - 2 pin, 3 pin European/UK/US etc?
Wyz4k
Re: PWR-Line AP
Tue May 22, 2018 5:05 am
I also hope this has interchangeable plugs.
normis
Re: PWR-Line AP
Tue May 22, 2018 2:16 pm
No, but there will be different models for different regions.
Bjesomar
Re: PWR-Line AP
Thu Jun 14, 2018 4:20 pm
Hi, do you know what wireless specs will this device have? How many chains on which bands?
ntblade
Re: PWR-Line AP
Thu Jul 26, 2018 6:33 pm
Hi all,
Any news when these will be available?
epjvdpalen
Re: PWR-Line AP
Thu Aug 02, 2018 3:16 pm
Any update on this, Normis? Looking forward to this device!
And.... 'a few Months' have passed already now... :-)
hutsch
Re: PWR-Line AP
Sat Sep 08, 2018 4:57 pm
... another month passed and no news on this "PWR-Line AP".
Hey Mikrotik staff. C'mon, post some news!
Hutsch
whatever
Re: PWR-Line AP
Sun Sep 09, 2018 11:33 am
2.4Ghz b/g/n, dual chain. See https://fccid.io/TV7PL64112ND
Simono
Re: PWR-Line AP
Wed Oct 24, 2018 7:47 pm
When this device will be possible to buy?
ntblade
Re: PWR-Line AP
Wed Oct 31, 2018 7:10 pm
Any availability update please?
muetzekoeln
Re: PWR-Line AP
Thu Nov 01, 2018 12:59 pm
Well, it would make sense if it would use G.hn for power-line communications and 5 GHz WiFi. So you could place one in each room and not having too much interference, especially when the device will have low gain antennas (less disturbance from other WiFi signals).
muetzekoeln
Re: PWR-Line AP
Mon Nov 05, 2018 12:52 pm
It would also be nice to have a power supply (24V/48V DC) with builtin power-line communications bridge. So to connect any MT device (Router, Switch, AP, ...) to this network. It would have two connectors: DC out and Ethernet. Just swap the orginal power supply against this new one and connect the additional LAN port to your MT device.
mkx
Re: PWR-Line AP
Mon Nov 05, 2018 6:26 pm
Single connector - ethernet. And have selectable PoE: either 48V 802.3af or 24V passive ...
ntblade
Re: PWR-Line AP
Mon Nov 05, 2018 6:30 pm
The recent posts seem like feature requests but still no news if these actually exist!
Pea
Re: PWR-Line AP
Sat Dec 01, 2018 1:35 am
According to this shop PL7411-2nD will come 12.12.2018:
https://www.wifihw.cz/default.asp?cls=s ... stiid=4329
Product code: PL7411-2nD
CPU: QCA9533
CPU: nominal frequency 650 MHz
PLC chipset: AR7420
Size of RAM: 64 MB
Memory: 16 MB Flash
10/100 Ethernet ports: 1
Wireless Built-in: 2.4 GHz 802.11b/g/n, dual-chain
Antenna gain: 1.5 dBi
Antenna beam width: 360°
Wireless chip model: QCA9533
Supported input voltage: 100 V - 240 V
Dimensions: 50 x 68 x 33mm
Operating temperature: -20°C .. +60°C
ROS license level: 4
Operating system: RouterOS
Max power consumption: 7 W
Power plug type: EU type (C)
ntblade
Re: PWR-Line AP
Mon Dec 03, 2018 5:53 pm
Thanks for that!
Simono
Re: PWR-Line AP
Mon Dec 03, 2018 6:11 pm
Waiting for devices with Power Line from Mikrotik.
pcunite
Re: PWR-Line AP
Wed Dec 12, 2018 3:47 am
Can I use this without the Wifi feature? I only want to use it as a virtual ethernet cable. So, one near the router, and one near the PC. Then plug in a short cat5 cable out of the second unit to the PC.
Pea
Re: PWR-Line AP
Wed Dec 12, 2018 8:23 am
There will be RouterOS so many possibilities for setup are expected. It should be possible to simply disable wifi interface if not needed.
normis
Re: PWR-Line AP
Wed Dec 12, 2018 9:58 am
yes
ntblade
Re: PWR-Line AP
Wed Dec 12, 2018 3:42 pm
We just need a release date! ;)
allstarcomps
Re: PWR-Line AP
Thu Dec 13, 2018 8:57 am
Can the APs be controlled by capsman? That would be nice, quick setup.
Wish it was dual band and had POE out.
normis
Re: PWR-Line AP
Thu Dec 13, 2018 10:12 am
Like any MikroTik wifi AP, yes, they can be controlled by CAPsMAN
alexjhart
Re: PWR-Line AP
Thu Dec 20, 2018 8:38 am
Is this sold just as single unit, or a pair?
normis
Re: PWR-Line AP
Thu Dec 20, 2018 9:03 am
Sold single, so you can purchase any number of them, depending on what you plan to build.
jonthorpe
Re: PWR-Line AP
Mon Dec 24, 2018 8:45 am
Any chance of there being a model with the Australia/New Zealand IEC Plug Type I will be available any time soon?
ringlet
Re: PWR-Line AP
Sun Jan 06, 2019 10:37 pm
why only Ethernet port 10/100? which routerOS supports PWR-Line ? is there any manual ?
tangram
Re: PWR-Line AP
Mon Jan 07, 2019 12:41 pm
Hi Normis,
I've previously used the ones that work in pairs, but don't really understand how do these connect to each other.
If you have 5 you'd be able to add 3 of them in a bridge and 2 in another or ... ?
There's special ROS menu to manage this ?
normis
Re: PWR-Line AP
Mon Jan 07, 2019 12:47 pm
You sync the new device with the sync button. Then all the PWR Line units get added to one bridge. Here is more info:
https://wiki.mikrotik.com/wiki/Manual:I ... e/PWR_Line
LBNL
Re: PWR-Line AP
Fri Jan 25, 2019 5:05 pm
I've just contacted one of my distributors regarding availability and delivery in the UK. I was told that this product won't be coming to the UK as Mikrotik have no interest in marketing this product in the UK.
Can someone from Mikrotik please confirm if this is the case? I've repeatedly asked for a delivery date on this thread with no reply.
deanMKD1
Re: PWR-Line AP
Fri Jan 25, 2019 10:52 pm
Waithing this device with 1Gbps LAN Ethernet Connection.
pcunite
Re: PWR-Line AP
Sat Jan 26, 2019 12:49 am
I was told that this product won't be coming to the UK as MikroTik have no interest in marketing this product in the UK.
Can you hook it up to a short cable convertor, naturally suitable for your environment?
mkx
Re: PWR-Line AP
Sat Jan 26, 2019 3:17 pm
Probably it woukd be better to use a rigid plug adapter so that RB device stays nicely upright.
Plus, my experience is that extension cord, using braided wires (lo allow flexibility), really hurts PLC performance. Not sure how plug adapters perform though.
GuJack20
Trainer
Trainer
Re: PWR-Line AP
Sun Jan 27, 2019 8:36 am
I got the chance to test and use them. I didnt expect much though, since power line communication is an old standard, BUT i’m surprised
You can leave them in default and they connect with each other, and you can clear the config and experiment.
https://youtu.be/T7Lzh8zO88w
Will put them in CAPsMAN etc. with these devices you have all the routerOS features, without the need for ethernet cables. 😄😄☺️
kos
Re: PWR-Line AP
Tue Jan 29, 2019 1:46 pm
Is there a way to prioritize HomePlug AV control packets?
ebreyit
Re: PWR-Line AP
Tue Jan 29, 2019 6:28 pm
+1 I would also be interested to know if there will be a UK option
Different countries/regions have different frequencies that Powerline kit can run on, or notches may also be cut out depending on local regulations etc. Running one with a band plan from a different country might be sub optimal or cause interference.
https://en.wikipedia.org/wiki/HomePlug
nichky
Re: PWR-Line AP
Mon Jul 29, 2019 1:11 pm
Questions regarding Power-Line
1. What is the max range that i can connect two Power-Line?
2. Can i connect more than 2 devices?
3. Is there any chance to block button? (for protection purposes)?
normis
Re: PWR-Line AP
Mon Jul 29, 2019 1:36 pm
Distance depends on your power line quality and other many factors, similar to wireless, where range is never clearly defined. Mostly less than 200 meters.
Yes, you can make a network of up to 8 powerline devices.
anav
Re: PWR-Line AP
Mon Jul 29, 2019 5:10 pm
What I don't understand is why they didn't update the powerline chipset from circa 2012 to at least circa 2015 as already noted by several 10/100/1000. Adding a more recent av2 standard or H.gn standard with the wifi on many mikrotik units the QCA9533 chip and ROUTEROS, would result in a much more attractive product.
https://www.qualcomm.com/products/qca7500
THere is also the G.hn standard that develo (german) has adopted and extello (north american) as well whereas most of the tplink and others are using the AV2 standard.
krisjanisj
Re: PWR-Line AP
Tue Jul 30, 2019 8:49 am
You mean this?
anav
Re: PWR-Line AP
Tue Jul 30, 2019 7:37 pm
Okay, can I first say, - this angry bloated bird thing is OUTTA control!! :-)
Yes, thanks finally joining this decade on power line LOL.
Now just mate it with decent wifi and routerOS and you will find the promised land! I BELIEVE................
I like what Devolo (a german company) is doing on their professional line by exploring G.hn on some products and by adding POE and VLANs on their models.
Thus its a business ready proposition.
https://www.devolo.com/business-solutions/products
However you throw in decent wifi and RouterOS and Mikrotik is a much better value proposition.
ebreyit
Re: PWR-Line AP
Mon Aug 05, 2019 12:04 pm
I like that you've finally gone with a clover leaf power connector rather than a country specific plug, makes for easy use in all countries without a specific socket version.
Puzzled why you left out RouterOS, as mentioned it has so many possibilities.
My wish list for future expansion on this would be as follows
  • Full RouterOS implementation
  • A version with multiple ports (retain POE out)
  • 802.3at POE output
  • Dual band 802.11ac
  • Wall mountable
  • Basicly something like Hap ac or Wap ac with power line built in would be great
andriys
Re: PWR-Line AP
Mon Aug 05, 2019 1:28 pm
PWR-LINE PRO looks interesting. However I'd love to see a version that is mountable in place of a standard power socket (in a case similar to wsAP ac lite). Possibly even with the power pass-through.
lprasil
Re: PWR-Line AP
Sat Aug 10, 2019 9:09 am
what is a maximum throughput for 8 adapters if all traffic will be send over main adapter used for sharing internet for 7 clients?
pe1chl
Re: PWR-Line AP
Sat Aug 10, 2019 12:57 pm
Manufacturers don't like that as much as you do, because they would have to manufacture several different types for usage across the world, and also would have to comply with several regulations applying to power products.
With the device as it is now, they can use different line cords for different countries. And regulations for pluggable devices are often less stringent than for wall-mounted permanently connected things.
complex1
Re: PWR-Line AP
Sat Aug 10, 2019 2:54 pm
Is there anyone who can tell me if the MikroTik PWR-Line AP can be used with a Devolo Powerline product?
MikroTik PWR-Line AP as master and connected to a MikroTik router and Devolo as slave?
Thank you.
vortex
Re: PWR-Line AP
Wed Apr 08, 2020 12:49 am
PRO ac version?
More gigabit ports?
Power socket (although it is likely a better idea to focus on the PRO style) ?
