Fri Jul 03, 2020 1:49 pm
I know that is pretty old - however - if you decrease the range ROS is going to kind of reverse (i.e. lets say instead 192.168.0.1-192.168.0.254 just use 192.168.0.100-192.168.0.200). That should give you the first dynamic of 192.168.0.100, second one 192.168.0.101, etc.
You can play with the bands once you have the logic....
Regards,
Georgi
