godzillante
IPv6 BGP unreachable nexthop through loopback
Fri May 18, 2018 11:55 am
I'm running v6.38.1 on a CCR1036 and have the following scenario (real addresses and AS obscured for privacy):
- loopback address set on a bridge
/ipv6 address add address=aaaa:bbbb:ffff::1/128 advertise=no interface=bridge_myprovider_ipv6
- static route to provider's loopback:
/ipv6 route
add !bgp-as-path !bgp-atomic-aggregate !bgp-communities !bgp-local-pref !bgp-med !bgp-origin !bgp-prepend !check-gateway \
    distance=1 dst-address=cccc:dddd:0:e::/128 gateway=fe80::aa:bb:cc:1%ether12_WAN-myprovider
I can ping the gateway without problems
> ping cccc:dddd:0:e::
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 cccc:dddd:0:e::                             56  55 30ms  echo reply
    1 cccc:dddd:0:e::                             56  55 30ms  echo reply
    sent=2 received=2 packet-loss=0% min-rtt=30ms avg-rtt=30ms max-rtt=30ms
But when I receive the default route via cccc:dddd:0:e:: (through multihop BGP), it's deemed "unreachable":
/ipv6 route print detail
1  Db  dst-address=2000::/3 gateway=cccc:dddd:0:e:: gateway-status=cccc:dddd:0:e:: unreachable distance=20 scope=40 target-scope=30
        bgp-as-path="00000" bgp-origin=igp received-from=myprovider_IPv6_peer
What am I doing wrong?
Thanks!
mrz
Re: IPv6 BGP unreachable nexthop through loopback
Fri May 18, 2018 11:59 am
Currently recursive routing will not work if gateway is link local address.
godzillante
Fri May 18, 2018 12:17 pm
thank you mrz. so what's a possible solution?
I have other peers which allow BGP through a /126 or /127 ptp, but this one provider is not going to allow me.
patrick7
Fri May 18, 2018 3:07 pm
The solution offered by MikroTik: If you are lucky, it will be solved with RouterOS v7!
viewtopic.php?f=14&t=42268#p425845
godzillante
Fri May 18, 2018 4:06 pm
I was aware of that thread :lol: just hoping there might be some alternative solution... or even an hack :(
sri2007
Fri May 18, 2018 5:18 pm
Or maybe the next solution will be to re-design using WANs only instead of loopbacks, at least until RouterOS 7 arrives :)
MikroTik Support and Consultancy - Español / English +593 93 924 1262
https://www.safenet.ec/consultoria.html/ support@safenet.ec
JimmyNyholm
Sat Aug 04, 2018 11:07 am
I'd say Recusive routing is totally broken for ipv6 in RosV6 having route coming in from ospfv3 process, ibgp session but MP bgp route can't get active because the gateway is unreachable according to the ipv6 route print where active (none) and print detail tells gateway unreachable, ping gateway from same cli works like a charm and is a globaly uninqe adress on a router several hops away.
So as we now have it. RouterOS can't be used for ipv6 and this is what holding us back implementing ipv6. FIX NOW!
I do not run the latest bugfix version on the router mentioned here but I have Also not seen anything in release notes stating that it would work with a later version.
pe1chl
Sat Aug 04, 2018 3:24 pm
Unfortunately it looks like the IPv6 engineer at MikroTIk has retired or is on extended leave.
Some minor display issues aside, there have been no changes in IPv6 for a year and a half, and no appreciable feature changes for several years.
Even the features that have changed (the announcement of DNS via RA) are in a half-baked state.
New features introduced usually lack IPv6 support. It looks like IPv6 is not a topic at MikroTik, unfortunately.
mafiosa
Mon Aug 17, 2020 8:19 pm
After banging my head for last 2 days finally I figured out that it is mikrotik's fault.
Users browsing this forum: No registered users and 173 guests
