jasim21
IPv6 DHCP Server Not Leasing IP
Sun May 20, 2018 10:41 am
I am trying to setup IPv6 DHCP server for my LAN of Windows 10 PC. But clients isn't receiving any lease. Following is the configuration example.What is the problem here ?
/ipv6 address print
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
 #    ADDRESS                                     FROM-POOL INTERFACE         ADVERTISE
 0 DL fe80::c4bc:fdff:fe9d:dbf7/64                          BRG_Office_LAN    no
 1 DL fe80::ec64:fff:feb5:a5ad/64                           loopback          no
 2 DL fe80::6e3b:6bff:fe22:e5a/64                           ether1_uplink     no
 3 DL fe80::6e3b:6bff:fe22:e5e/64                           ether5            no
 4  G 2000:5a40:0:11::2/126                                 ether5            no
 5  G 2000:5a40:0:12::1/64                                  BRG_Office_LAN    no
 /ipv6 dhcp-server print
Flags: D - dynamic, X - disabled, I - invalid
 #    NAME             INTERFACE           ADDRESS-POOL           PREFERENCE LEASE-TIME
 0    server1          BRG_Office_LAN      pool1                         255 3d
 /ipv6 pool print
Flags: D - dynamic
 #   NAME          PREFIX                                      PRE EXPIRES-AFTER
 0   pool1         2000:5a40:0:12::/64                          64
 /ipv6 nd prefix print
 0    prefix=2000:5a40:0:12::/64 interface=BRG_Office_LAN on-link=yes autonomous=no
      valid-lifetime=4w2d preferred-lifetime=1w
/ipv6 nd print
Flags: X - disabled, I - invalid, * - default
 0  * interface=BRG_Office_LAN ra-interval=3m20s-10m ra-delay=3s mtu=unspecified
      reachable-time=unspecified retransmit-interval=unspecified ra-lifetime=30m
      hop-limit=unspecified advertise-mac-address=yes advertise-dns=yes
      managed-address-configuration=yes other-configuration=yes
Routerboard
/system routerboard print
       routerboard: yes
             model: 450G
     serial-number: 72520662CD0E
     firmware-type: ar7100
  factory-firmware: 3.24
  current-firmware: 6.42.2
  upgrade-firmware: 6.42.2
docmarius
Re: IPv6 DHCP Server Setup
Sun May 20, 2018 1:24 pm
AFAIk, You need to use RA for address hand-out. The ROS DHCPv6 only hands out prefixes for PD, not individual addresses.
https://wiki.mikrotik.com/wiki/Setting_up_DHCPv6
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
jasim21
Wed May 23, 2018 7:43 pm
I fully followed the wiki you mention and configured RA as you can see. But it still not working. Can you point me to direction where it went wrong ?
Sob
Re: IPv6 DHCP Server Not Leasing IP
Thu May 24, 2018 6:41 pm
The managed-address-configuration=yes option tells client to request address from DHCPv6 server. DHCPv6 server in RouterOS doesn't support giving out addresses yet. So you either need external DHCPv6 server, or stick with autoconfiguration for now.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
Anumrak
Fri May 25, 2018 1:33 pm
turetto
Thu Nov 15, 2018 9:13 pm
Hi guys,
I have the same issue. I am novice in MT. It is very good, I started the configuration and it almost done, but this issue is my nightmare :)
I use PPPoE with a modem in bridge mode, so I configured my MT to make a PPPoE connection. All fine, the MT gets IPv4, but all devices on my LAN are not getting IPv6. Before the MT I have a Dlink DIR-878 with the same configuration(making the PPPoE connection) and all devices on my LAN gets IPv6, but with MT it just gets IPv4.
I follow many tutorials to configure it, but does not work. I spent more than 6 hours trying and no sucess.. :(
Sorry for my poor english and sorry if my questions are basic, because this is my first experience with MT devices. So I am very very appreciated if anybody can help me.
TheFox21
Thu Jun 27, 2019 12:14 am
Should this work now in RouterOS v6.44.3?
It's not working for me. I get an /48 range from Hurrican Electric ipv6 Tunnel. Everything works, but not the DHCP Server. I have set the address advertise=yes. But the firewall shows in the logs that there is no other traffic than ICMP. No DHCP traffic or anything else. What's the problem here?
Anumrak
Thu Jun 27, 2019 9:41 am
Because dhcpv6 doesn't working yet. Use router advertisment instead of dhcpv6.
TheFox21
Thu Jun 27, 2019 3:46 pm
Thank you for the information. This thing got me almost insain. I was really wondering what the heck I was doing wrong.
So that means you can create a DHCPv6 Server and Bindings and Pool and so on, but it's not working at all yet? So the UI is here but no functions behind implemented?
proximus
Thu Jun 27, 2019 10:00 pm
The current DHCPv6 server is for handing out prefixes to other routers (DHCP-PD) .... not host addresses. Refer back to post #2, #4.
I really wish MT would add the functionality.
rossi02
Sun Jul 07, 2019 6:05 pm
Hi all,
i've got the same issue. Nothing works, the Ipv6 Clients gets no IPv6 Adress or prefix from the FTTH modem. DHCPV6 Server didn't work ...
I spent a lot of time into this issue and i'm nearly to throw the Mikrotik onto the rubbish or i will drive over it with my car ...
It is realy frustrating.
If i connect my Fritzbox to the modem and the Mikrotik to the Fritzbox, the Mikrotik gets an IPv6 address, but if i connect the Mikrotik directly to the modem it receives nothing.
Rgds,
Marcus
idlemind
Wed Jul 10, 2019 7:50 am
Hi all,
Rgds,
Marcus
It depends on how it was implemented by your ISP. If your "modem" requires PPP you should get allocated a subnet via PPP and not DHCPv6-PD. You can tell MikroTik to assign this to a pool like you do with DHCPv6-PD and then distribute out a prefix for each VLAN on the inside.
siouxmaeb
Thu Mar 26, 2020 7:42 pm
FYI - just checked - still the same issue. dhcpv6 doesn't give ip adr
Users browsing this forum: GW156 and 124 guests
