steger
l2tp-client per script enable not consistent working
Wed May 23, 2018 10:21 am
hello there,
i have made a customscript for the tr069 client to reach the server either over lte1 or ether1 for failoverreasons.
to reach the management on the lte1 side i did an l2tp-client successfuly.
to only establish the l2tp-client (via lte1) i do it on availibilitybases - so if primay target is not reachable, enable the l2tp-client.
:local i 0; {:do {:set i ($i + 1)} while (($i < 5) && ([/ping 8.8.8.8 interval=3 count=1 interface=vlan31-hsi ]=0))};
:if ($i=5 && [/ip route get [find comment="floating-hsi"] distance]=255) do={:log info "Primary hsi down";
/ip route set [find comment="floating-hsi"] distance=1
/ip route set [find comment="floating-mgt"] distance=4
/interface l2tp-client enable 0
its not reproduceable but from time to time the script cannot enable the l2tp-client (which is disabled if primary is available again).
the error i receive on the cli (when i try to execute is:
no such item (4)
if i try to enable it a second time its no problem to enable the client.
any ideas? - may this is a bug?
thank you!
christian
wil
Re: l2tp-client per script enable not consistent working
Wed May 23, 2018 3:02 pm
I had the same issue. If I added a "/interface l2tp-client print" before accessing the element it worked for me every time. Looks like the interpreter needs to evaluate the elements in a category first before you can reliably access the elements. It makes no difference if you try to access via element number or name.
Bye,
wil
steger
Wed May 23, 2018 3:25 pm
hey wil!
wow! great help!
yes it works with this workaround!
thank you!
christian
steger
Sun May 27, 2018 10:48 am
hey again,
jfyi:
/interface l2tp-client find name XX
is also working.
greetings
christian
msatter
Sun May 27, 2018 10:59 am
hey again,
jfyi:
is also working.
greetings
christian
Can you try and see if this also works?
/ip route set [find where comment="floating-hsi"] distance=1
/ip route set [find where comment="floating-mgt"] distance=4
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.47 / Winbox 3.24 / MikroTik APP 1.3.14
steger
Sun May 27, 2018 11:10 am
hi,
just checked it out. - no its not working.
christian
msatter
Sun May 27, 2018 12:55 pm
hi,
christian
Thanks for checking out.
Running:
Users browsing this forum: otter4 and 41 guests
