redalg
Unable to upgrade
Thu May 24, 2018 4:45 pm
My current CRS125-24G-1S has firmware version 6.42rc52. I was trying upgrade to 6.42.2 or 6.43rc17 but it didn't succeed. System reboots but still with old firmware and there is nothing in the logs. System has 66% of free in disks. What could cause this? How do I fix it?
redalg
Re: Unable to upgrade
Sun May 27, 2018 10:01 pm
Where should I look for problem when logs doesn't show anything wrong?
macsrwe
Long time Member
Long time Member
Sun May 27, 2018 10:52 pm
First, I assume you mean OS version, not firmware.
Given that you have provided absolutely no details, file names, or screenshots, I have to take a stab in the dark. Are you loading upgrade packages for the correct CPU architecture of your router? If you load packages for the wrong CPU, they will just get ignored or discarded.
redalg
Thu May 31, 2018 9:31 am
Sorry about wrong terms I used.. What I was doing is clicking dowload&install from quickset as specified in this wiki page https://wiki.mikrotik.com/wiki/Manual:U ... ic_upgrade . There is nowhere any log entry or anything that it would fail but version number just doesn't change after router downloads, installs and reboots. Could it be possible that quickset auto upgrade would download incorrect files?
chechito
Thu May 31, 2018 9:47 am
try system packages --> check for updates
dont install RC versions in production devices
If you need to go to previous version you have to manually download .npk file form https://mikrotik.com/download and copy it to files, then go to system packages and click downgrade
redalg
Fri Jun 01, 2018 11:42 pm
Tried everything you suggest. Didn't help..
macsrwe
Long time Member
Long time Member
Sat Jun 02, 2018 1:02 am
After you download, the packages should appear in /files. Verify this. After you reboot, are those packages still in /files, or are they gone?
redalg
Wed Jun 06, 2018 8:48 pm
No. All files exists still in files.
redalg
Mon Jun 11, 2018 3:53 pm
Could it be that some kind of malware is blocking routeros update?
redalg
Thu Jun 14, 2018 6:02 pm
I was able to upgrade RouterOS via Netinstall but Routerboard firmware fails to upgrade.
Any ideas how should I proceed?
redalg
Thu Jun 14, 2018 7:45 pm
After some reboots and re-try, routerboard has been upgraded. Finally. Case closed.
Users browsing this forum: Google [Bot] and 101 guests
