XTLMeth
Can't Login After Upgrade
Fri May 25, 2018 9:41 pm
After upgrading a couple routers to 6.43rc19 I can't login anymore. It's as if my accounts have been deleted. I know there were some security changes in the update but how do I fix my login issue?
jarda
Re: Can't Login After Upgrade
Fri May 25, 2018 10:06 pm
By which way you cannot log in? Don't forget to read release notes.
XTLMeth
Fri May 25, 2018 10:30 pm
I did read the release notes and I knew there were changes related to hashed passwords. I just upgraded another router and I can't login in using winbox/ssh/webfig when the router comes back up. It just says wrong password.
Shadeofspirit
Fri May 25, 2018 10:41 pm
use winbox 3.14
MTCNA, MTCWE
XTLMeth
Fri May 25, 2018 10:43 pm
I only see winbox 3.13 on the download page. Is there some other location I should be looking to get 3.14?
Shadeofspirit
Fri May 25, 2018 10:48 pm
https://www.mikrotik.com/download/share/winbox.exe
MTCNA, MTCWE
jarda
Fri May 25, 2018 10:49 pm
Everyone should read the release notes before he installs whatever version. Don't be blind and read.
viewtopic.php?f=21&t=133420&start=150#p664062
XTLMeth
Fri May 25, 2018 10:50 pm
That worked. Thank you!
Users browsing this forum: Bing [Bot], Dangermouse5000 and 70 guests
