ngo222
SCRIPT TO RESET-COUNTERS OF SPECIFIC USERS
Mon May 28, 2018 2:25 pm
I am trying to use the script below to reset counters of users whose profile is called "students".
/tool user-manager user reset-counters [/tool user-manager user find where actual-profile ="student"]
However, when i try running this on the terminal, i get the attached error message after a long wait:
I am using Mikrotik OS Version 6.42.2 on an x86 device. Please what am i not doing correctly?
ADahi
Re: SCRIPT TO RESET-COUNTERS OF SPECIFIC USERS
Mon May 28, 2018 6:40 pm
RouterOS v6.40.8 Bugfix
/tool user-manager user reset-counters numbers=[find where actual-profile="xyz"]
working 100%
ngo222
Mon May 28, 2018 7:43 pm
Ok. Tried your code but it still gives me the same error. Is it a problem of the version of Mikrotik OS i am using, or a problem related to the number of users in that query script returned.
The total number of users in my database is 29,000. Can that be the problem???
ADahi
Mon May 28, 2018 9:29 pm
maybe version
or maybe the space before and after " = " is not accepted in ROS script grammar
actual-profile ="xyz"
ngo222
Wed May 30, 2018 1:09 pm
Thank you for all your replies. But i have tried removing the space, but still getting the same error message.
Kindly send me a link to your version of the OS so i can downgrade and try again.
Thank you.
ngo222
Thu May 31, 2018 12:02 pm
Hi ADahi,
I have gotten OS version 6.40.8 bugfix. I have downgraded to that version of the software but when i run the command, i am still having the same error.
Do you have any other suspicion and solution please?
Thank you.
ADahi
Fri Jun 01, 2018 10:16 pm
contact mikrotik support
Users browsing this forum: No registered users and 37 guests
