dvdalmeria
Kernel panic CCR1072-1G-8S +
Tue May 29, 2018 4:30 pm
Good morning, I have a good problem with the model CCR1072-1G-8S +, it took 48 hours with multiple kernels panic.
- I have replaced the router(backup and restore) with another identical model and the problem continues, so it is not a hardware problem.
- I upgrade routeros to: 6.42.3 and packges to 6.42.3 and the problem continues.
- The router is well temperature and the sources are correct.
Log in last reboot:
may/29 13:44:44 system,error,critical kernel failure in previous boot
may/29 13:44:54 interface,info sfp-sfpplus3 link up (speed 1G, full duplex)
may/29 13:45:00 interface,info sfp-sfpplus5 link up (speed 10G, full duplex)
may/29 13:45:00 interface,info sfp-sfpplus5 link down
may/29 13:45:04 interface,info sfp-sfpplus6 link up (speed 10G, full duplex)
may/29 13:45:04 interface,info sfp-sfpplus6 link down
may/29 13:45:08 interface,info sfp-sfpplus7 link up (speed 10G, full duplex)
may/29 13:45:08 interface,info sfp-sfpplus7 link down
may/29 13:45:12 interface,info sfp-sfpplus8 link up (speed 10G, full duplex)
may/29 13:45:12 interface,info sfp-sfpplus8 link down
may/29 13:45:12 interface,info ether1 link up (speed 1G, full duplex)
may/29 13:45:12 interface,info sfp-sfpplus2 link up (speed 1G, full duplex)
may/29 13:45:12 interface,info sfp-sfpplus4 link up (speed 1G, full duplex)
may/29 13:45:12 interface,info sfp-sfpplus5 link up (speed 1G, full duplex)
may/29 13:45:12 interface,info sfp-sfpplus6 link up (speed 1G, full duplex)
may/29 13:45:12 vrrp,info r7 now BACKUP
may/29 13:45:12 vrrp,info r8 now BACKUP
may/29 13:45:12 vrrp,info r9 now BACKUP
may/29 13:45:12 vrrp,info r10 now BACKUP
may/29 13:45:12 vrrp,info r11 now BACKUP
may/29 13:45:13 route,bgp,info TCP connection established
may/29 13:45:13 route,bgp,info RemoteAddress=10.68.0.2
may/29 13:45:13 interface,info sfp-sfpplus7 link up (speed 1G, full duplex)
may/29 13:45:13 interface,info sfp-sfpplus8 link up (speed 10G, full duplex)
I was especially struck by this error: may/29 13:45:44 interface,warning sfp-sfpplus3 excessive or late collision, link duplex mismatch?
[david@R10] /interface> ethernet monitor sfp-sfpplus3
;;; R8
status: link-ok
auto-negotiation: disabled
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
sfp-module-present: yes
sfp-rx-loss: no
sfp-tx-fault: no
sfp-type: (unknown)
eeprom-checksum: good
A bug in a spf module can cause a panic kernel?
Module installed is mikrotik S-31DLC20D
Very thanks by your help.
abn
Re: Kernel panic CCR1072-1G-8S +
Sat Jun 02, 2018 4:06 pm
hello
i am am also facing this problem
vgdorneles
Sun Jun 03, 2018 2:12 pm
I'm have this problem on the CCR1036-8G-2S +. I am using version 6.42.2. Upgraded that 2 weeks ago, and since then, have been at least 15 reboot due to kernel failure.
I did not find anything abnormal in my log, other than, of course, the "kernel failure on previous boot".
vecernik87
Forum Veteran
Forum Veteran
Mon Jun 04, 2018 1:46 pm
if it is happening repeatedly, I guess you should send autosupout.rif to mikrotik Support. they will investigate.
btw: I just had first kernel failure about 40 minutes ago on hAP ac^2 running 6.42.1. I will upgrade to 6.42.3 and if it happens again, then I will submit it as well.
interpoint
Sun Jun 17, 2018 12:36 am
I also have the same problem. CCR1072-1G-8S+ 6.42.2 (stable)
Rebooted twice in the past 20 hours.
02:44:08 system,error,critical router was rebooted without proper shutdown, probably kernel failure
02:44:08 system,error,critical kernel failure in previous boot
I have supout files and am going to send them to MT.
If anyone has any info / progress on this please share..
Shane Hartigan
Director - Integrated Media Solutions
MikroTik Certified Trainer
MTCNA, MTCRE, MTCWE, MTCINE, MTCTCE, MTCIPv6E
mukesh4us
Thu Mar 07, 2019 6:56 am
I am using CCR1036-8G-2S+EM and i was using v6.42 and update to 6.43.4 and had the same reboot issue "kernal failure", i have again upgraded the router to 6.44 now
I am observing this now
However i have send multiple support.rif files to MikroTik support i have no reply from them.
Users browsing this forum: a.devecerski, Bing [Bot], Google [Bot], Zacharias and 164 guests
