sjafka
L2TP IPSec speed
Wed May 30, 2018 3:24 pm
Dear MikroTik Community,
i"ve set up an l2tpipsec vpn, but the speed is really slow, what should i check?
Thank you in andvance!
sjafka
Re: L2TP IPSec speed
Wed May 30, 2018 3:41 pm
i searched and found a forum, where they said, lowering MRU did for them, so for me. Whats the impact now, thath i lowered MRU? Could someone pls explain?
normis
Thu May 31, 2018 9:46 am
Some devices have special IPsec acceleration hardware built in. Like the hEX, new cAPac, new hAP ac^2
sjafka
Thu May 31, 2018 11:12 am
Thank you guys, for your answer, ill check later out, my college has an ac2, ill try out, but on a RB2011UiAS i get somewhat about 500kbit/sec, is it normal(so i should just check out other HW), or should i check things out in my config (if yes, what would u check out?) Thank you in advance!
normis
Re: L2TP IPSec speed  [SOLVED]
Thu May 31, 2018 11:18 am
IPsec is very CPU intensive. You need either a powerful machine, or IPsec acceleration chip. RB2011 is an older device, it may not be as powerful for IPsec at higher speed.
sjafka
Thu May 31, 2018 11:57 am
Thank you for answering, i know this is other topic but i'll ask: i choosed IPsec because i read that this should be one the best (and under best i mean secure). Is there any other vpn type i could use with this machine, to achieve a better performance and security? Thank you in advance
normis
Thu May 31, 2018 12:00 pm
IPsec is the best and most secure. I also recommend using this VPN type.
PPTP is no longer considered secure.
sjafka
Thu May 31, 2018 12:15 pm
Thank you!
sjafka
Thu Jun 07, 2018 12:58 pm
Hi Normis,
i tried the same with a hap ac2 and the result is the same if not a little bit slower. I get ~500kb/s with this router too. Could you please help me out?
nichky
Long time Member
Long time Member
Thu Jun 07, 2018 1:28 pm
export your conf
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
!) Safe Mode is your friend;
sindy
Thu Jun 07, 2018 3:58 pm
Hi Normis,
Hardware encryption only works for particular encryption algorithms, so maybe your proposal is too wide and some algorithm which does not have hardware encryption support is negotiated.
But as @nichky said, publish the output of
/ip ipsec export hide-sensitive
/interface l2tp-server export hide-sensitive
/ip ipsec peer print
(don't forget to remove secret=xxxx from the output of the last command).
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
daggerCVN
Sun Oct 14, 2018 5:49 pm
All - using this existing thread as I'm having the same issue: I have a L2TP IPSEC VPN setup on my hEX r3 router and am only getting about 65Mbps throughput (its connected to a 500M fiber circuit). Here are the ipsec config outputs:
[admin@MikroTik Lab] > /ip ipsec export hide-sensitive
# oct/14/2018 10:36:13 by RouterOS 6.40.9
# software id = TYIJ-MRTU
# model = RouterBOARD 750G r3
# serial number = 6F3906415ED1
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
/ip ipsec peer
add address=0.0.0.0/0 dh-group=modp1024 generate-policy=port-override passive=\
yes
[admin@MikroTik Lab] > /interface l2tp-server export hide-sensitive
# oct/14/2018 10:43:38 by RouterOS 6.40.9
/interface l2tp-server server
set default-profile=profile-vpn enabled=yes use-ipsec=yes
[admin@MikroTik Lab] > /ip ipsec peer print
Flags: X - disabled, D - dynamic, R - responder
0 R address=0.0.0.0/0 passive=yes auth-method=pre-shared-key
secret="xxxx" generate-policy=port-override
policy-template-group=default exchange-mode=main
send-initial-contact=yes nat-traversal=yes proposal-check=obey
hash-algorithm=sha1 enc-algorithm=aes-128,3des dh-group=modp1024
lifetime=1d dpd-interval=2m dpd-maximum-failures=5
1 DR address=::/0 passive=yes auth-method=pre-shared-key secret="xxxx"
generate-policy=port-strict policy-template-group=default
exchange-mode=main-l2tp send-initial-contact=yes nat-traversal=yes
proposal-check=obey hash-algorithm=sha1
enc-algorithm=aes-256,aes-192,aes-128,3des dh-group=modp2048,modp1024
sindy
Sun Oct 14, 2018 6:06 pm
Does /ip ipsec installed-sa print show the H attribute in the leftmost-but-one column at both peers? If not, there is no support for Hardware acceleration for the negotiated combination of auth-algorithms and enc-algorithms on the peer which misses the H. Check this table, including all the *, **, and ***, to see for what combinations of algorithms the hardware acceleration is available.
If one of the devices is not a Mikrotik one, and you have hardware acceleration at Mikrotik side, the bottleneck is the other device.
One other point is that many small packets give worse throughput than fewer larger packets. So you'll always get better off with file transfers over TCP than with e.g. voice traffic which uses ~250 byte UDP packets.
Triple figthfulness (which is what děs means in Czech) is definitely not a secure choice these days.
daggerCVN
Sun Oct 14, 2018 6:41 pm
Thanks sindy. The installed-sa check shows all connections as HE I did note the 3des encryption and I just followed one of the guides to setup the vpn, so I just changed it to only use aes encryption and retested/reconnected and now the installed-sa shows aes. No change in speed, so may be device (laptop) limitation??
sindy
Sun Oct 14, 2018 7:32 pm
The test results page of hEX S says that for 512-byte packets, the IPsec throughput is around 170 Mbit/s. The L2TP overhead takes quite a lot off the packets, so for an 8 Mbit/s stream tunnelled via L2TP via IPsec, the transport stream has some 11 Mbit/s. It still doesn't explain your 65 Mbit/s, but I have no idea what else on Mikrotik side might be the bottleneck. If the MTU at the client is not proportionally reduced, you may have each packet fragmented to one long and one short one, which makes me think about the 521-byte frames rather than 1500 byte ones.
So if you can, try with several clients at a time. If the summary throughput is higher, it is likely a client-side limitation; if it is still your 65 Mbit/s, it is likely a Mikrotik side limitation. Of course I assume that when you measure from a laptop connected directly to Mikrotik's LAN interface with no L2TP/IPsec, the throughput is much higher.
I would test it myself but I lack the 500 Mbit/s uplink here :-)
daggerCVN
Mon Oct 15, 2018 1:08 am
I tried another client device and it got 135Mbps. these are default windows machines with default MTU settings. That said, it looks like it's client related, thank you again for your inputs and guidance.
Cheers - dagger
daggerCVN
Mon Oct 15, 2018 4:43 pm
Ran thru a different device at a different location. Got as high as 145Mbps. I watched the CPU load on the four vCores, and cpu0 was hitting 95% - 100% during the speed tests, so this looks like device dependent and router model cpu load levels. Thanks again.
ahtoh
Mon Oct 07, 2019 4:14 am
I set up my wAP ac to use as L2TP/IPSec client and it reaches 100% cpu load when I run speed test.
The maximum throughput speed I get is about 26-27 Mbps
Are these numbers OK or I should look into optimizing some settings?
ahtoh
Wed Oct 09, 2019 6:21 pm
Switched to ipesc/ikev2 and get slightly better speed around 34 mbps with aes-128-cbc.
Looks like this router does not support ipsec encryption acceleration
Users browsing this forum: No registered users and 97 guests
