MUM Europe 2020
mkorban
Transparent proxy
Thu Jan 25, 2007 12:36 pm
Hi all, i have a strong problem:
Mikrotik RouterBoard with RouterOS v3.0beta5.
[admin@Office.GW] /ip proxy> export
# jan/25/2007 14:22:16 by RouterOS 3.0beta5
# software id = UK5C-3TT
/ip proxy
set cache-administrator="webmaster" cache-drive=CompactFlash \
    cache-hit-tos=0x10 cache-on-disk=yes enabled=yes max-cache-size=111000KiB \
    max-fresh-time=3d maximal-client-connections=1000 \
    maximal-server-connections=1000 parent-proxy=0.0.0.0:0 port=3128 \
    serialize-connections=no src-address=0.0.0.0
/ip proxy access
add action=allow comment="" disabled=no dst-address=!10.0.4.0/24 \
    src-address=10.0.4.0/24
/ip proxy cache
add action=masquerade chain=srcnat comment="Full Direct Access" disabled=no \
    dst-address-list=!LAN src-address-list=LAN
add action=redirect chain=dstnat comment="IP-Proxy" disabled=no \
    dst-address-list=!LAN dst-port=80 in-interface=LAN-eth4 \
    protocol=tcp src-address-list=LAN to-ports=3128
Problem : web-traffic to *:80 not redirected to proxy.
Please help my for setup transparent proxy
janisk
Thu Jan 25, 2007 12:39 pm
maybe this -> dst-address-list=!LAN
has something to do with that?
mkorban
Thu Jan 25, 2007 12:45 pm
add address=10.0.4.0/24 comment="" disabled=no list=LAN
add address=10.0.5.0/24 comment="" disabled=no list=LAN
add address=10.0.1.0/24 comment="" disabled=no list=LAN
add address=10.0.3.0/24 comment="" disabled=no list=LAN
add address=192.168.0.0/24 comment="" disabled=no list=LAN
add address=192.168.1.0/24 comment="" disabled=no list=LAN
This is segments of our local area network.
dsn-nat rules without *-address-list - no effect :-(
janisk
Thu Jan 25, 2007 1:00 pm
from this try to remove in-interface
might help :roll:
at least i hope so
EDIT:
this should be close to true :)
http://www.mikrotik.com/testdocs/ros/2.9/ip/proxy.php
mkorban
Thu Jan 25, 2007 1:40 pm
Yes, It worked...
But not good.
Situation 1: Client open https://issa.samara.mts.ru (Browser setting does not have a proxy, used transparent). Site not opened!
Situation 2: Client open https://issa.samara.mts.ru (Browser proxy setting is 10.0.4.254:3128 (MT) - Site opened normaly.
add action=dst-nat chain=dstnat comment="Torrent MKORBAN" disabled=no \
    dst-address=81.22.60.43 dst-port=63812 protocol=tcp \
    to-addresses=10.0.4.211 to-ports=63812
    dst-address=!10.0.4.0/24 dst-port=80,443,8080,8443 protocol=tcp \
    src-address=10.0.4.0/24 to-ports=3128
Solusan
Tue Jan 30, 2007 12:55 pm
Talking abut this topic i have a question:
I have this configuration in mi Mikrotik system.
Add one rule to chain=forward,
'ip firewall filter add action=jump jump-target=hotspot chain=forward',
set for 'guest' user profile,
'ip hotspot user profile set profile_name incoming-filter=1 outgoing-filter=1', that will redirect current profile traffic to chain=1.
Add rule to chain 1 to drop traffic with specific dst-address,
'ip firewall filter add chain=1 dst-address=172.0.0.0/8 action=drop'.
And I applied this rule at the user 'guest'
I did that for locking to the user 'guest' couldn't acceed to 172.0.0.0/8 but as you can see I obtain a drop
But now I would need that the user could redirect to the hotspot home page or to nay error page where the user can be alerted that can not be acceed to the rank
How could I do it?
I feel that it's dst-nat of table NAT which can solve this.
I have tried it without success.
Many thanks for your help and understanding.
Users browsing this forum: akops, daveavagnina, Google [Bot], jindranix, llag and 47 guests
