riyadislam
DHCP server problem
Thu May 31, 2018 9:05 pm
firstly let me explain my network diagram.
There is a mikrotik router in which port 2 is connected to a d link manageable switch. users are connected from that switch via dummy switch. Recently users are not getting their ip through dhcp.
dhcp server has been configured properly on the router. users were getting ip through dhcp. but now without any changing in the configuration of mikrotik router, users aren't getting ip.
again if a tplink router is connected to the d link switch, users are getting ip through dhcp.
Help me to troubleshoot the problem
Van9018
Long time Member
Long time Member
Re: DHCP server problem
Tue Jun 05, 2018 10:15 am
I would start with Tools > Packet sniffer. Set it to save to a file and only capture UDP packets. Click Apply, then Start and renew the IP on a client. Wait 10 seconds and stop the packet capture. Copy the file to your computer and open it with Wireshark. In the list of packets, you should see a Discovery, Offer, Request, Ack. Do you see all 4?
The Discovery is your client looking for DHCP Servers on the network. There should only be 1.
The Offer is your mikrotik offering an IP.
The client will then deny or request the IP. If denying, maybe the client detects an IP conflict however RouterOS detects conflicts too and skips bad IPs.
The Mikrotik will then acknowledge that the client accepted the IP.
Also double check the basics:
- IP > Pool, check the "Used IPs". You out of IPs?
- IP > DHCP Server, is the entry red which denotes a misconfig?
DHCP is on the correct interface?
- Enable log topic DHCP and renew a client, anything interesting in the log?
Finally if still no success, set a static IP and ping the Mikrotik. If you can't ping or do an ARP lookup to find the router, then possibly a physical connection issue or your smart switch is blocking the MAC of the mikrotik.
mbarchiesi
Wed Oct 31, 2018 4:06 am
All Mikrotik products that i have presents these issue... All starts working great but after a while, DHCP Server stop working. Since 6.3X I have this problem and I don't found any solution, just unplug and plug power cable... A simple tplink router does not have these problems and even a 16-core CCR does. Is incredible. A year waiting for solutions.
Mikrotik products have serious problems with DHCP: FIX THEM!
vecernik87
Forum Veteran
Forum Veteran
Wed Oct 31, 2018 4:19 am
does really dhcp stop working? Unless you have data from packet sniffer and log, you cant prove that it is mikrotik's fault and such blind blaming is ridiculous - I had never such issue on any of my routers. My ISP has CCRs and also don't have this problem. I am sure that there many other customers who never saw your issue. The issue must be related to your environment/setting.
If you got problem, you cant just say "mikrotik must fix it". You need to point out where exactly is the problem with logs and packet captures.
Van9018 gave you excellent guide so you can debug it and write good bug report. With good bug report, developers will understand where is issue and they can fix it. Without proper bug report, they cant fix it because they dont know where the issue is.
tnlnet
Thu Nov 01, 2018 11:43 am
I have lots of Mikrotik Routers on my network and that of my clients running DHCP server. I have not come across this issue for once. I think the issue must have to do with the specific network. Just like Van said, take more steps to troubleshoot and I'm sure you would see the problem somewhere.
ICT & Telecom solutions - https://tnlnetworks.com
FErArg
Thu Dec 27, 2018 5:18 pm
We manage 6 mikrotik routers, different models and different RouterOS version, all version up 6.X, and with all of them got problem with DHCP, specially with leased IP address
-=< FErArg >=-
Buelo
Mon Jan 06, 2020 9:10 am
same here, we have DHCP Problems!
I set up a Kids Control, that based on IP Adresses. But some times the wrong System get the wrong ip.
Happened on Fire TV Sticks (Cable not Wlan) and iMac!
Regards
borislav
Sat Jan 16, 2021 9:47 pm
Same problem here.
I have two separate clients, both with RB1100AhX4 router and CRS354-48P-4S+2Q+RM switch, connected to ether2 of the router. All client devices use the router dhcp server, but through the switch.
In the beginning everything was working, but two weeks later problems started. In both routers log files I saw many dhcp deassign and reassign but thought it was because of the lease time.
Today, at 5 in the morning, according to the logs, one of the routers suddenly deassigned all dhcp clients and nothing could make them get again IP address.
The switch is divided in two bridges - one is used for the LAN, where it lost the dhcp, and the last 8 ports are in bridge and used for IPTV - they are working perfectly.
I would be grateful for any ideas!
erlinden
Forum Veteran
Forum Veteran
Sat Jan 16, 2021 10:54 pm
@Buelo, Kid Control is MAC Address based. You might run into problems because a lot of devices are using random MAC addresses for privacy purposes.
@borislav, can you share your config (/export hide-sensitive file=anythingyoulike)? Only situation where I ran into DHCP problems, it was because of misconfiguration.
First the problem, then the solution
borislav
Mon Jan 18, 2021 12:29 pm
below is the router config.
The switch config was blank, now I have configured it as a second router, because there must be some internet.
So, switch settings were without dhcp client and server, IP pool and firewall masquerade rule.
# jan/18/2021 12:21:09 by RouterOS 6.48
# software id = LDD6-9T84
# model = RB1100Dx4
# serial number = D0BF0B953F24
add name=bridge
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
set 12 default-vlan-id=0
set 13 default-vlan-id=0
set 14 default-vlan-id=0
set 15 default-vlan-id=0
add name=dhcp_pool1 ranges=192.168.1.11-192.168.1.254
add address-pool=dhcp_pool1 disabled=no interface=bridge name=dhcp1
/system logging action
set 1 disk-file-count=5 disk-file-name=logg disk-lines-per-file=10000 \
    disk-stop-on-full=yes
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=ether6
add bridge=bridge interface=ether7
add bridge=bridge interface=ether8
add bridge=bridge interface=ether9
add bridge=bridge interface=ether10
add bridge=bridge interface=ether11
add bridge=bridge interface=ether12
add bridge=bridge interface=ether13
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
    192.168.1.0
/ip dhcp-client
add !dhcp-options disabled=no interface=ether1
/ip dhcp-server config
set store-leases-disk=12h
add address=192.168.1.0/24 gateway=192.168.1.1 netmask=24
set servers=192.168.1.1
/ip firewall address-list
add address=192.168.1.2-192.168.1.254 list=allowed_to_router
add address=78.83.52.228 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment=" 6to4  relay  Anycast  [RFC  3068]" list=\
    not_in_internet
add action=accept chain=input comment="default  configuration" \
add action=accept chain=input src-address-list=allowed_to_router
add action=drop chain=input disabled=yes
add action=fasttrack-connection chain=forward comment=FastTrack \
add action=accept chain=forward comment=" Established,  related" \
add action=drop chain=forward comment=" Drop  Invalid" connection-state=\
    invalid disabled=yes log=yes log-prefix=invalid
    " Drop  tries  to  reach  not  public  addresses  from  LAN" disabled=yes \
    dst-address-list=not_in_internet in-interface=bridge log=yes log-prefix=\
    !public_from_LAN out-interface=!bridge
    " Drop  incoming  packets  that  are  not  NATted" connection-nat-state=\
    !dstnat connection-state=new disabled=yes in-interface=ether1 log=yes \
    log-prefix=!NAT
    " Drop  incoming  from  internet  which  is  not  public  IP" disabled=\
    yes in-interface=ether1 log=yes log-prefix=!public src-address-list=\
    not_in_internet
    " Drop  packets  from  LAN  that  do  not  have  LAN  IP" disabled=yes \
    in-interface=bridge log=yes log-prefix=LAN_!LAN src-address=\
    !192.168.1.0/24
add action=dst-nat chain=dstnat disabled=yes dst-port=xxx protocol=tcp \
    to-addresses=xxx to-ports=xxx
add action=dst-nat chain=dstnat dst-port=xxx protocol=udp to-addresses=\
    xxx to-ports=xxx
add action=dst-nat chain=dstnat dst-port=xxx protocol=tcp to-addresses=\
    xxx to-ports=xxx
    xxx to-ports=xxx
    xxx to-ports=xxx
    xxx to-ports=xxx
    xxx to-ports=xxx
    xxx to-ports=xxx
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.1.0/24,xxxxxx
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Sofia
/system logging
add action=disk topics=info
add action=disk topics=warning
add action=disk topics=firewall
add action=disk topics=pptp
borislav
Mon Jan 18, 2021 12:30 pm
Switch config:
# jan/18/2021 12:26:32 by RouterOS 6.46.1
# software id = 0LAN-B0MR
# model = CRS354-48P-4S+2Q+
# serial number = B8440B40A8FE
add admin-mac=C4:AD:34:BD:0E:FD auto-mac=no name=a1tv
add admin-mac=C4:AD:34:BD:0E:FD auto-mac=no comment=defconf name=bridge
set [ find default-name=qsfpplus1-1 ] disabled=yes
set [ find default-name=qsfpplus1-2 ] disabled=yes
set [ find default-name=qsfpplus1-3 ] disabled=yes
set [ find default-name=qsfpplus1-4 ] disabled=yes
set [ find default-name=qsfpplus2-1 ] disabled=yes
set [ find default-name=qsfpplus2-2 ] disabled=yes
set [ find default-name=qsfpplus2-3 ] disabled=yes
set [ find default-name=qsfpplus2-4 ] disabled=yes
set [ find default-name=sfp-sfpplus1 ] disabled=yes
set [ find default-name=sfp-sfpplus2 ] disabled=yes
set [ find default-name=sfp-sfpplus3 ] disabled=yes
set [ find default-name=sfp-sfpplus4 ] disabled=yes
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.88.11-192.168.88.254
add address-pool=dhcp_pool0 disabled=no interface=bridge lease-time=12h name=\
    dhcp1
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=ether11
add bridge=bridge comment=defconf interface=ether12
add bridge=bridge comment=defconf interface=ether13
add bridge=bridge comment=defconf interface=ether14
add bridge=bridge comment=defconf interface=ether15
add bridge=bridge comment=defconf interface=ether16
add bridge=bridge comment=defconf interface=ether17
add bridge=bridge comment=defconf interface=ether18
add bridge=bridge comment=defconf interface=ether19
add bridge=bridge comment=defconf interface=ether20
add bridge=bridge comment=defconf interface=ether21
add bridge=bridge comment=defconf interface=ether22
add bridge=bridge comment=defconf interface=ether23
add bridge=bridge comment=defconf interface=ether24
add bridge=bridge comment=defconf interface=ether25
add bridge=bridge comment=defconf interface=ether26
add bridge=bridge comment=defconf interface=ether27
add bridge=bridge comment=defconf interface=ether28
add bridge=bridge comment=defconf interface=ether29
add bridge=bridge comment=defconf interface=ether30
add bridge=bridge comment=defconf interface=ether31
add bridge=bridge comment=defconf interface=ether32
add bridge=bridge comment=defconf interface=ether33
add bridge=bridge comment=defconf interface=ether34
add bridge=bridge comment=defconf interface=ether35
add bridge=bridge comment=defconf interface=ether36
add bridge=bridge comment=defconf interface=ether37
add bridge=a1tv comment=defconf interface=ether38
add bridge=a1tv comment=defconf interface=ether39
add bridge=a1tv comment=defconf interface=ether40
add bridge=a1tv comment=defconf interface=ether41
add bridge=a1tv comment=defconf interface=ether42
add bridge=a1tv comment=defconf interface=ether43
add bridge=a1tv comment=defconf interface=ether44
add bridge=a1tv comment=defconf interface=ether45
add bridge=a1tv comment=defconf interface=ether46
add bridge=a1tv comment=defconf interface=ether47
add bridge=a1tv comment=defconf interface=ether48
add bridge=bridge comment=defconf interface=ether49
add bridge=bridge comment=defconf interface=qsfpplus1-1
add bridge=bridge comment=defconf interface=qsfpplus1-2
add bridge=bridge comment=defconf interface=qsfpplus1-3
add bridge=bridge comment=defconf interface=qsfpplus1-4
add bridge=bridge comment=defconf interface=qsfpplus2-1
add bridge=bridge comment=defconf interface=qsfpplus2-2
add bridge=bridge comment=defconf interface=qsfpplus2-3
add bridge=bridge comment=defconf interface=qsfpplus2-4
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=sfp-sfpplus2
add bridge=bridge comment=defconf interface=sfp-sfpplus3
add bridge=bridge comment=defconf interface=sfp-sfpplus4
    192.168.88.0
/ip dhcp-client
add disabled=no interface=ether1
/ip dhcp-relay
add dhcp-server=192.168.1.1 disabled=no interface=ether1 name=relay1
add address=192.168.88.0/24 gateway=192.168.88.1
/system clock
/system routerboard settings
set boot-os=router-os
#error exporting /system swos
borislav
Wed Feb 17, 2021 9:35 am
any suggestions for my problem? I will be grateful for any hints
cdiedrich
Forum Veteran
Forum Veteran
Tue Feb 23, 2021 6:24 pm
Didn't see anything that would point to a dhcp server problem. I guess you know your firewall is pretty wide open, don't you?
Just out of curiosity: do your udp dst-nat rules include port 67 and/or 68?
What's the actual mac address of your 1100's bridge? I see a duplicated mac address in your switch config, just curious if there might be some fragments from earlier config attempts around.
A good idea would be hooking up problematic devices to the router directly and see if the problem persists.
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
borislav
Sat Mar 20, 2021 10:41 am
-Chris
No, I do not udp dst-nat port 67 and 68
Actual mac address of the 1100's bridge is as the mac address of the first port in the bridge.
I fixed the duplicating mac addresses in the switch, but the same problem occurs.
[admin@MikroTik] > /export
# mar/20/2021 10:38:29 by RouterOS 6.46.1
add admin-mac=C4:AD:34:BD:0F:23 auto-mac=no name=a1tv
add admin-mac=C4:AD:34:BD:0E:FE auto-mac=no comment=defconf name=bridge
add name=domofon
/ip hotspot profile
add name=domofon ranges=10.0.0.1-10.0.0.15
add address-pool=dhcp_pool0 disabled=no interface=bridge name=dhcp1
add address-pool=domofon interface=domofon name=domofon
set 1 disk-file-count=10 disk-lines-per-file=5000
add bridge=domofon comment=defconf interface=ether31
add bridge=domofon comment=defconf interface=ether32
add bridge=domofon comment=defconf interface=ether33
add bridge=domofon comment=defconf interface=ether34
add bridge=domofon comment=defconf interface=ether35
add bridge=domofon comment=defconf interface=ether36
add bridge=domofon comment=defconf interface=ether37
add bridge=domofon comment=defconf interface=ether38
    192.168.88.0
add address=10.0.0.1/24 interface=domofon network=10.0.0.0
/ip dhcp-client
add address=10.0.0.0/24 gateway=10.0.0.1 netmask=24
/system clock
/system logging
add action=disk topics=dhcp
Users browsing this forum: No registered users and 9 guests
