MUM Europe 2020
p3rad0x
Long time Member
Long time Member
Best way to Monitor PPPoE servers
Fri Jun 01, 2018 10:59 am
Good day,
I'm in the process of setting up pppoe for authentication.
There will be one or two pppoe servers on each tower site.
What is the best way to monitor all of these and make sure the servers is up and running?
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
omega-00
Re: Best way to Monitor PPPoE servers
Mon Jun 04, 2018 6:06 am
When you say servers do you mean your device is accepting multiple customer connection requests?
If so I would simply recommend you install a spare device also at the tower (something like a mAP/mAP lite) that should always have a test PPPoE connection established.
If you used the mAP you could connect both ports and have it do one that is site local (using a static user/pass stored on the MikroTik acting as a PPPoE server) and one that is an account stored on whatever system you are using to manage your customers, so you can see if the PPPoE server is down or if your RADIUS server is the problem.
You would then put a script on this mAP to have it cycle the connections every 5 minutes.
On the PPPoE Server MikroTik you could look for these connections via SNMP (interfaces) or write another script to check if they are available. If one or more is offline then raise an alert by sending an email / sms or posting to Telegram / Slack etc - all of this can be done with a script.
brightwifi.com | mikrotik-routeros.com | MTCNA,MTCWE.MTCTCE | Give karma where due
Users browsing this forum: No registered users and 190 guests
