sonyhavana
Connecting QRT5 ac and LGH5 on a 16Km link? Is it possible?
Sun Jun 10, 2018 7:37 pm
Hi guys. I have a QRT5 AC and I´m l will like to stablish a point to point link. I´m thinking on using a sxt HG5, but the antenna is adviced to have 24 degree beamwith so it not very directional. Do yo guys think is it better(and cheaper) to use a LGH 5 to achieve this? I can´t afford another QRT5ac right now, that´s why I need a cheaper solution. And also, is QRT compatible with all other mikrotik wireless devices? Thanks!
mistry7
Re: Connecting QRT5 ac and LGH5 on a 16Km link? Is it possible?
Sun Jun 10, 2018 11:08 pm
How much Power EIRP is allowed to you?
samsung172
Mon Jun 11, 2018 12:08 am
sonyhavana
Fri Jun 15, 2018 3:33 am
Hello and thanks for the reply. I can use max power in both devices. And by the way.. is it possible to force the QRT to use 31dbm power all the time?
samsung172
Sun Jun 17, 2018 10:04 pm
ITs possible to force a device to specific power level. But remember - in noisy environment - You will also amplify the noice.
InoX
Sun Jun 17, 2018 11:45 pm
Distance: 16.0 Km (9.94 miles)
Free Space Path Loss: 131.223 dB
Theoretical signal level at TX: -67
Theoretical signal level at RX: -59
Link status: Unreliable
Use LHG5 XL.
sonyhavana
Mon Jun 18, 2018 7:01 am
Thank you so much for your time. I will keep in mind your advice and try to use this equiment in a closer link, about 9Km, so it should be fine with this distance without forcing the maximum power. Thanks guys!
docmarius
Mon Jun 18, 2018 9:37 pm
Now this needs a little explanation since it makes no sense. IMHO the noise gets amplified on supplemental Rx amplification, not on Tx, where only the S/N ratio gets boosted.
Unless you mean the spectral purity of the signal, which is something entirely different and is possible to be degraded by increased Tx power. But for devices with the proper FCC and CEPT certifications, this should not be a major issue.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
samsung172
Tue Jun 19, 2018 10:42 pm
Well - in real life - this is some of the main issue related to poor speed on a link. Its always better to amp by using a antenna instead of using power on the card. Search in mum videos - its explaned a lot of times here. eg https://mum.mikrotik.com//presentations/ZA13/savage.pdf You can also read about this eg google Millimeter Wave Technology in Wireless PAN, LAN, and MAN. This is not a mikrotik spesific thing, but how signal goes trough air (and in that case also coax/fiber/ethernet at low level ) Also read https://en.wikipedia.org/wiki/Noise_(electronics)
Btw . Your equipment will always make its own noise. There is no such as a perfect signal and a device generating no noise at all. So both TX and RX are efected by increasing powerlevel. more db put - is amplified nosie out, and its bad for your other side of the link.
Users browsing this forum: MSN [Bot] and 19 guests
