Chiverel
Incorrect Upnp entries when using VLANs in a bridge. What's missing?
Mon Jun 11, 2018 2:50 pm
I face a problem with dynamic Upnp rules created by my RB2011 running Ros6.42.3. Setup is following:
  • Upnp is on
  • eth2 is a wan port; it is the only external inteface in upnp settings
  • there is a bridge, containing VLAN and a number of ports. Setup is working properly (lan, internet access etc), 192.168.10.1 is set as IP on vlan. VLAN is an internal interface in upnp settings according to a wiki note.
Print
ip upnp interfaces print
Flags: X - disabled, D - dynamic
 #   INTERFACE        TYPE     FORCED-IP
 0   eth2-isp        external
 6   vid222-guest        internal
 7   vid10-home-wireless        internal
 8   vid10-home-wired        internal
ip firewall nat print
 2  D ;;; upnp 192.168.10.aaa: Transmission/2.92 at 192.168.10.aaa:BBBB
      chain=dstnat action=dst-nat to-addresses=192.168.10.aaa to-ports=BBBB protocol=tcp dst-address=192.168.10.1
      in-interface=vid10-home-wired dst-port=CCCC
 3    ;;; static
      chain=dstnat action=dst-nat to-addresses=192.168.10.aaa to-ports=BBBB protocol=tcp dst-port=CCCC log=no log-prefix=""
The rule #2 is dynamic, then it is copied into rule #3 with removing VLAN ip as "dst-address" and vlan itself as "in-interface". Traffic is counting on #3 only which is expected with such settings.
Upnp worked properly when I had just bridges without any vlans. How to make MT creating proper dynamic entries now? Thanks.
2frogs
Long time Member
Long time Member
Re: Incorrect Upnp entries when using VLANs in a bridge. What's missing?
Mon Jun 11, 2018 3:29 pm
What happens when you add the Bridge to the upnp interface also?
Chiverel
Mon Jun 11, 2018 4:02 pm
Thanks for a quick reply.
Rules are created exactly the same way. Using vlan IP and in-interface. Basically I was going the opposite way: I had both bridge and vlan in the Upnp -> internal interfaces; then disabled bridge there and that didn't improve the situation.
2frogs
Long time Member
Long time Member
Mon Jun 11, 2018 4:22 pm
I am guessing leaving just the Bridge doesn’t work either.
If not email support and include a supout. It looks to be treating the vlan as an external interface instead of internal...
Chiverel
Mon Jun 11, 2018 4:51 pm
Ok, thanks for the hint. I'll try to reproduce the case on another device and provide supout from that box. I'm a bit unsure to send such data from my main router.
Chiverel
Fri Jun 15, 2018 1:48 pm
There was some glitch with that RB. I've checked upnp replies from router even when disabled external interface or upnp completely. Reply contained information about 2 WANConnectionDevices. One of those had that vlan address as an external IP. It seems like some process got stuck and haven't received configuration updates. Not sure why, but some apps used one or another WANConnectionDevice entry and thus several NAT rules were created properly even with a glitch.
The only thing that helped me was a router reboot. UPNP configuration was sent out properly afterwards and new NAT rules appeared correctly.
Users browsing this forum: No registered users and 47 guests
