Sob
Re: New IP cloud is coming.
Sun Jul 08, 2018 6:35 pm
This was discussed in 6.43rc thread, but here is better place for it.
IMHO the cloud DDNS needs user-configurable option what protocol to use (IPv4 only, IPv6 only, both). Ideally with "both" as default, because if I have dualstack and IPv4 fails (perhaps by user mistake, which is more likely than real outage), IPv6 is very nice backup option (for some purposes at least).
Based on current description, only A record gets added for dualstack, and if IPv4 fails, user will sit and try hard to remember what the last IPv6 address was? It doesn't sound very good.
Ultimate solution would be support for multiple subdomains (for multi-WAN purposes) with suggested option available for each item. That way there could be A-only subdomain for e.g. OpenVPN server (to not slow down client trying AAAA; alternatively, you could add IPv6 support to OpenVPN, I wouldn't object) and another A/AAAA for administration. Well, it might get a little too complex, but it would be nice.
Another possibility, to keep it simple, automatic A-only and AAAA-only subdomains could be added by server (xxx.sn.mynetname.net with A/AAAA, ip4.xxx.sn.mynetname.net with A only, ip6.xxx.sn.mynetname.net with AAAA only) and user could use the right one for each intended purpose.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
janisk
Tue Jul 10, 2018 9:57 am
There are some not so clear scenarios. However, in your secnario if your IPv4 fails and router still has connectivity via IPv6 - in about 60 seconds router will register IPv6 address as cloud address and $host command will suddenly return IPv6 AAAA entry.
edit: I have some more scenarios in my head when I want this to work but it will not in the current state. We are working hard to resolve those.
Steveocee
Tue Jul 10, 2018 10:29 am
It's nice to see a great feature being refined that bit more. I have noticed recently the "old" cloud is quite slow to respond so maybe this is the reason why?
I'd be lost without IP>Cloud for hairpin NAT scenarios on dynamic WAN IP's.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
Resnais
Fri Jul 27, 2018 10:16 am
It looks like the old[stable] cloud implementation does not work for me anymore. (using v6.42.6 on routers)
After pressing force update in ip cloud settings (ddns enabled) it says request timed out.
Also "nslookup serialnr.sn.mynetname.net ns1.kissthenet.net" still shows the old address.
Your experiences?
netflow
Fri Jul 27, 2018 9:51 pm
I am amazed by the amount of responses and effort from MT team for a set of 2 features that can easily be replaced by ntp and duckdns, both being better alternatives.
freemannnn
Long time Member
Long time Member
Sat Jul 28, 2018 12:08 am
I dont care for the alternatives. I am HAPPY with ip-cloud. working from the start 100% for me.
Free dyndns per device. What more can u ask
mkx
Sat Jul 28, 2018 2:16 pm
Indeed.
Even time precission is enough for coarse log analysis (did it happen this morning or a fortnight ago?). Anybody requiring "better" services are more than welcome to use alternatives.
BR,
Metod
netflow
Sat Jul 28, 2018 2:24 pm
Well some sort of control and completely brand agnostic solution... Not to say there are hundreds of more important features requests than IP Cloud or Kids Control viewtopic.php?f=1&t=45934 to tackle first and clearly most of them cannot be replaced by a less than 10 lines script or by an existing component supporting an established standard !
carl0s
Sat Jul 28, 2018 2:28 pm
Actually this would put the mikrotik in the middleman role. It has to be considered as unsafe. I understand that some people do not care about it, but I rather build my own management network instead of rely on services that I cannot control and that can do whatever I do not know what above what they promote.
While you find some feature not so useful to yourself and relentlessly bash them - consider that there are other features made by RouterOS developer team that you are using. This one particular - IP-Cloud - is touted by you as very unsafe and understandably so - MikroTik hasn't disclosed information - but from time to time your posts look like just bashing.
Ona brighter note - there are new features in testing, new features in the development and one feature that just came out of testing and is included in new RC - IPv6 support.
this is what "IPv6 support" entails -
*) DNS requests via IPV6
*) IP-Cloud services (DDNS update, timezone) via IPv6
*) AAAA support for *.ns.mynetname.net domains
For now - there is only AAAA OR A entry support. Due to nature of RouterOS - if you have a dual-stack router and want the IP-Cloud address to be IPv6 you have to force it via /ip dns static entry - add cloud2.mikrotik.com with these IPv6 addresses 20a2:610:7501:4000::251 and 2a02:610:7501:1000::201
While you're doing this DNS stuff, is there any chance that conditional-forwarders might be added into the RouterOS DNS resolver? i.e. relay any requests for company.local to 192.168.1.1, for a branch office scenario?
Sob
Sat Jul 28, 2018 6:20 pm
@carl0s: It's not really related to this, but yes, it would be nice. Every other DNS resolver supports it, and no, keeping another machine around only because of such simple feature is not good solution.
janisk
Wed Aug 08, 2018 12:33 pm
coming to the router near you soon:
$ host <serial>.sn.mynetname.net
<serial>.sn.mynetname.net has address 192.168.88.1
<serial>.sn.mynetname.net has IPv6 address 2001:db8:1337:beef::ada
amokkatmt
Wed Aug 08, 2018 3:53 pm
Any plans to add wildcard hostnames support? I mean "firsthost.123456.sn.mynetname.net" . If not - why?
janisk
Fri Aug 10, 2018 11:53 am
Please explain what that would solve? If you have several routers - they all are eligible for the IP Cloud address.
edit: If you have a company and want all routers under same "umbrella", then you can create CNAME entries in your local DNS server for your domain.
ivanfm
Fri Aug 10, 2018 5:25 pm
Suggestion : add an option in cloud service to add an extra personal prefix.
like "xyz" when user define personal prefix the name will became
xyz.<serial>.sn.mynetname.net
this make difficult for brute force detect all mikrotiks in the world and make difficult in case of new vulnerability to attack all .
Currently is easy to make a brute force search for mikrotik devices using the cloud service as the names follow an simple pattern and is just an DNS query.
ckleea
Wed Aug 15, 2018 1:16 am
Will it be available for x86 router soon?
I am also looking forward to have support in x86
Steveocee
Wed Aug 15, 2018 10:49 am
I hear mumbles of CHR being available from 6.43 so there could quite possibly be x86 implementation.
janisk
Wed Aug 15, 2018 11:22 am
Currently, there are no plans to bring it to the x86 platform.
Cha0s
Forum Veteran
Forum Veteran
Wed Aug 15, 2018 3:55 pm
The serial number consists of 12 hexadecimal characters.
I wouldn't call making 184884258895036416 (12^16) dns lookups 'easy'.
It's easier to just use masscan and scan the whole IPv4 address space for open port 8291.
Splash
Fri Sep 14, 2018 3:39 pm
You think there is any chance in the future to support multi-wan setups? One option is to prepend or append the interface number to the dyndns hostname?
pppoe-out1 = xxxxx-1.sn.mynetname.net
pppoe-out2 = xxxxx-2.sn.mynetname.net
MTCNA, MTCRE, MTCINE, MTCTCE, MTCIPv6E, MTCUME
janisk
Tue Sep 18, 2018 10:40 am
Finally a change worth talking about
6.44beta9:
!) cloud - added command "/system backup cloud" for backup storing on cloud (CLI only);
Some details:
*) Only aes-sha265 encrypted files are accepted.
*) If you save the secret-download-key, one will be able to download the backup file from another router.
*) one command to make, encrypt and upload
*) one command to download and apply
*) communication with IP Cloud servers is fully encrypted (so your encrypted file is transferred over an encrypted channel)
*) one backup file per router
*) free
of course, if you just download the file, then it has to be applied via /system backup load
edit: specified encryption method used for backup file that is accepted, file slot count = 1 per router. free
pe1chl
Tue Sep 18, 2018 10:55 am
Ah finally some new functionality :D
Are you considering implementing a management VPN function?
freemannnn
Long time Member
Long time Member
Tue Sep 18, 2018 11:19 am
is this for backup configuration to cloud? free?
if yes VERY NICE MIKROTIK.
janisk
Tue Sep 18, 2018 11:22 am
yes, 1 file slot per router and it is free for all the platforms that can use IP Cloud
freemannnn
Long time Member
Long time Member
Tue Sep 18, 2018 11:44 am
free cloud backup. very nice really nice.
one tip, there is option to schedule to backup every xx days to cloud automatically. (of course you can do it with scheduler, but i am just saying)
doneware
Trainer
Trainer
Tue Sep 18, 2018 5:53 pm
will there maybe an API we could use to interact with the backup file?
my aim is to have a "remote controlled" set of CPEs... i make changes to the "cloud-twin" and it is (pulled) "replicated" to the physical one.
maybe in a way that it could import the file w/o hurting device specific things, like MAC addresses.
#TR0359
janisk
Tue Oct 02, 2018 1:34 pm
not really, as restoring backup file will replace MAC addresses and EVERYTHING else. After that you can reset mac addresses of the interfaces on the router. But that is it.
sup5
Tue Oct 02, 2018 2:38 pm
It would be nice to have the option NOT to restore or backup MAC-addresses on HW-interfaces (Ethernet and Wireless).
Restoring MAC-addresses of logical interfaces like bridges, EoIP, VPLS and the like is useful though.
janisk
Fri Oct 05, 2018 2:19 pm
This actually is not related to the IP Cloud functionality anymore. For the IP Cloud Backup feature, it was important to be able to effortlessly upload the backup file and retrieve it afterwards. There is other stuff coming related to IP Cloud Backup in the future (regarding ease of access) however that is in no way related to the basic functionality of the backup system itself.
So the points are:
1) easily create backup and upload
2) retrieve and/or apply
3) in case of the router damage make the backup file available from the other device
florid
Fri Oct 19, 2018 7:39 am
Would be great if the IP cloud can expand the feature to whole configuration, something like Cloud Winbox.
User can login the cloud portal to modify and customize the configuration, when the router box connects to Internet, automatically grab updated cloud configuration and deploy it.
Two beauties:
1. reduce the risk of exposing winbox to Internet
2. easy bulk deployment
jarda
Fri Oct 19, 2018 4:36 pm
Really? Everyone wants to have a supersecured router and you would give all your login details to a cloud?
pe1chl
Fri Oct 19, 2018 6:27 pm
It certainly has some applications. I have been suggesting a management VPN to be part of IP cloud as well.
People have trouble arranging secure management of their routers that are on dynamic addresses, behind CGNAT, or otherwise inconvenient to access, and it could be nice to register them in a cloud system so you can manage routers that are not connectable from outside.
Of course the access to that cloud system should be done in a secure way. But remember, when some fault is found there it can be resolved by updates.
2nd factor authentication can be used. This is all much better than having 200.000 vulnerable routers in the field without a way to get them updated.
janisk
Mon Oct 29, 2018 12:15 pm
ManagementVPN as such is not planned for now. The main reason is the security implications.
thobias
Thu Nov 08, 2018 5:39 pm
This! We need to be able to monitor backup connections that have dynamic IP.
faraujo88
Sun Aug 04, 2019 5:47 am
Its a "free" service. I think that is usefull as it works actually. And U can manipulate from which link ddns works on it.
Enviado de meu MI 9 usando o Tapatalk
Users browsing this forum: No registered users and 5 guests
